BBS-10
BBS-10
    EATON(伊顿)
    Cartridge,Non-Standard
    FUSE CARTRIDGE 10A 250VAC
BBS-10 数据手册
Effective December 2015 Supersedes April 2014 Technical Data 2010 BUSSMANN SERIES BBS 13⁄32˝ x 1-3/8˝ 600Vac fast-acting supplemental fuses Catalog symbol / color code: • Carton quantity BBS •   Black (600Vac max, 1/10 to 6A) •   Green (250Vac max, 7 to 10A) •   Purple (48Vac max, 12 to 30A) Amps 1/10 to 30 Qty. 10 Dimensions - in: Description: Fast-acting supplemental fuse. For superior protection, Eaton recommends upgrading to Bussmann series Low-Peak™ Class CC fuses. See data sheet No.1023. 600Vac 1/10 to 6A Features: Ratings • Color coded for 600Vac (black) 250Vac (green) and 48Vac (purple) for maximum voltage ratings • Fiber tube construction • Nickel-plated endcaps. Fuse amp range 600 Vac 1/10 to 6 10kA 7 to 10 – 12 to 30* – Agency information 250 Vac 48 Vac UL® CSA® – 10kA – – – – X X – X X - Typical applications • Control circuits • Gaseous vapor fixtures * For interrupting rating, contact factory. • HID ballasts Agency information • Electronic circuits Hand-held meters • CE • • UL Listed, Std. 248-14 (1/10-6A@600Vac, 7-10A@250Vac), Guide JDYX, File E19180 • CSA Certified, C22.2 No. 248.14 (1/10-6A@600Vac, 7-10A@250Vac), Class 1422-01, File 53787 Recommended fuse blocks/fuse holders: Catalog numbers (amps) 48Vac 12 to 30A 1.38" (±0.031) Specifications: Interrupting rating at system voltage 250Vac 7 to 10A 0.41" (±0.004) BBS-1/10 BBS-2/10 BBS-1/4 BBS-4/10 BBS-1/2 BBS-6/10 BBS-3/4 BBS-8/10 BBS-1 BBS-1-1/2 BBS-1-6/10 BBS-1-8/10 BBS-2 BBS-3 BBS-4 BBS-5 BBS-6 BBS-7 BBS-8 BBS-10 BBS-12 BBS-15 BBS-20 BBS-25 BBS-30 Catalog Description symbol Blocks BMM 1-, 2- and 3-pole modular blocks with optional covers Data sheet No. 10235 DIN-Rail holders / switches CHM 1-, 2- and 3-pole 3185 Optima NG 3-pole protection module 1109 Optima 3-pole holder 1102 Optima 3-pole holder + switch 1103 Panel mount holders HPF-L 1-pole holder 2114 HPS-L 1-pole holder 2113 1-pole holder 2124 PCB fuseclips 2132 In-line HEH Fuseclips 1A3400, 5956 and 5960 Fuse covers CVR(I)-CCM(-QC) Finger-safe fuse cover 10235 BBS 600Vac fast-acting supplemental fuses Technical Data 2010 Effective December 2015 3 5 6 7 2 3/4 1 100 4/10 Time-current characteristic curves – average melt: Amp rating Amp Rating Time in Seconds Time in seconds 10 1 200 Current CurrentininAmps amps 100 10 0.4 0.01 1 0.1 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2015 Eaton All Rights Reserved Printed in USA Publication No. 2010 – BU-SB14287 December 2015 Eaton, Bussmann and Low-Peak are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Follow us on social media to get the latest product and support information.
BBS-10 价格&库存
很抱歉,暂时无法提供与“BBS-10”相匹配的价格&库存,您可以联系我们找货
