BK/ABC-4-R
BK/ABC-4-R
    EATON(伊顿)
    3AB,3AG,1/4" x 1-1/4"
    FUSE CERM 4A 250VAC 125VDC 3AB
BK/ABC-4-R 数据手册
⁄4” x 1 1⁄4” Glass Tube Fuses 1 ABC Series, Fast-Acting, Ceramic Tube Description • Fast-acting, ceramic tube • Optional axial leads available • 1⁄4” x 1 1⁄4” (6.4 x 31.7mm) physical size • Ceramic tube, nickel-plated brass endcap construction • UL Listed product meets standard 248-14 ELECTRICAL CHARACTERISTICS % of Amp Rating Opening Time 100% 4 Hours Minimum 135% 60 Minutes maximum 200% 120 Seconds Maximum Agency Information • UL Listed Guide JDYX & File E19180 • UL Recognition Guide JDYX2 & File E19180 • CSA Certification: Class No: 1422-01 & 1422-30, File 53787 Environmental Data • Shock: 1⁄4A - 30A – MIL-STD-202, Method 213, Test Condition J • Vibration: 1⁄4A - 30A – MIL-STD-202, Method 204, Test Condition C (Except 5g, 500Hz) Ordering • Specify packaging, product and option code Part Number ABC-1⁄4-R ABC-1⁄2-R ABC-3⁄4-R ABC-1-R ABC-1-1⁄2-R ABC-2-R ABC-2-1⁄2-R ABC-3-R ABC-4-R ABC-5-R ABC-6-R ABC-7-R ABC-8-R ABC-10-R ABC-12-R ABC-15-R ABC-18-R ABC-20-R ABC-25-R ABC-30-R Voltage Ratings Vac 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 Vdc 125 125 125 125 125 125 125 125 125 125 125 125 125 125 125 125 – 125 125 125 Vac Interrupting Ratings* (amps) 250 125 35 10,000 35 10,000 35 10,000 35 10,000 100 10,000 100 10,000 100 10,000 100 10,000 200 10,000 200 10,000 200 10,000 200 10,000 200 10,000 200 10,000 750 10,000 750 10,000 400 1000 400 1000 200 1000 200 1000 Dimensions - mm Drawing Not to Scale Specifications Vdc Interrupting Ratings (amps) 125 75 10,000 – 10,000 – 10,000 – 10,000 – 10,000 – 10,000 – 10,000 – 10,000 – 10,000 – 10,000 – 10,000 – 10,000 – 10,000 – 10,000 – 10,000 – 10,000 – – – 10,000 – 400 1000 400 1000 Typical DC Cold Resistance (Ω)** 2.950 0.587 0.300 0.1950 0.131 0.0890 0.061 0.047 0.031 0.026 0.021 0.016 0.014 0.011 0.0068 0.00553 0.00465 0.00366 0.0028 0.002225 Typical Pre-Arc I2t AC† 0.0020 0.0390 0.1450 0.4310 1.1630 2.1670 4.4670 6.55 22.28 32.83 58 109.33 116.5 208.8 133.3 200.2 400 550.8 839.3 1429 Typical Voltage Drop (V)‡ 0.35 0.41 0.32 0.3 0.28 0.31 0.23 0.14 0.17 0.22 0.19 0.17 0.19 0.15 0.1 0.1 0.1 0.1 0.09 0.09 Agency Approvals UL UR CSA X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X‡‡ X X‡‡ * Interrupting ratings measured at 70% - 80% power factor on AC. The interrupting ratings for 18A and 20A were measured at 85% - 95% power factor on AC. The interrupting ratings for 25A and 30A were measured at 89% power factor on AC. ** Typical DC cold resistance measured at
BK/ABC-4-R 价格&库存
很抱歉,暂时无法提供与“BK/ABC-4-R”相匹配的价格&库存,您可以联系我们找货
BK/ABC-4-R
  • 25+22.68272
  • 100+17.14505
  • 1000+5.45305
  • 5000+5.27168
  • 10000+5.17495
库存:100
