BK/C518-5-R
BK/C518-5-R
    EATON(伊顿)
    插件,D5.5xL15.2mm
    一次性保险丝(熔断) 5A 250V
BK/C518-5-R 数据手册
Effective May 2017 Supersedes September 2009 Technical Data 2026 C518 5 mm x 15 mm Fast-acting glass tube fuses Agency information • UL Recognition Card: Guide JDYX2, File E19180 • CSA Certification Card: Class 1422-01, File 53787 Ordering • Specify product code: Insert packaging code prefix before part number. E.g. BK (or TR2)/C518-2-R • Specify option code, if desired: For insulation sleeve, insert “S” after part series. E.g. BK/C518S-2-R • With TR2 packaging code, lead wire length is 20.3mm Product features Rated Current Axial-leaded fast-acting 5 x 15mm physical size Nickel-plated brass endcap construction Optional insulation sleeve is flexible flouropolymer (UL Flammability rating VW-1). • UL Listed product meets standard UL 248-14 • • • • Part Number C518-100-R C518-125-R C518-250-R C518-375-R C518-500-R C518-750-R C518-1.5-R C518-2-R C518-2.5-R C518-3-R C518-3.5-R C518-4-R C518-5-R Voltage Rating Vac 250 250 250 250 250 250 250 250 250 250 250 250 250 2Electrical seconds Characteristics max. 100mA-5A Specifications Interrupting Rating at Rated Voltage (amps) 250Vac 125Vac 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 100 10,000 100 10,000 100 10,000 100 10,000 100 10,000 200 10,000 200 10,000 Typical DC Cold Resistance* (Ω) 22.30 15.20 5.66 2.53 1.66 0.91 0.900 0.064 0.046 0.038 0.032 0.022 0.018 * DC Cold Resistance (Measured at
BK/C518-5-R 价格&库存
很抱歉,暂时无法提供与“BK/C518-5-R”相匹配的价格&库存,您可以联系我们找货
