BK/GBB-9-R
BK/GBB-9-R
    EATON(伊顿)
    3AB,3AG,1/4" x 1-1/4"
    FUSE CERM 9A 250VAC/125VDC 3AB
BK/GBB-9-R 数据手册
Effective May 2017 Supersedes July 2009 Technical Data 2013 GBB 1⁄4" x 1 1⁄4" Very-fast acting ceramic tube fuses Agency information • UL Recognized Card: 1-30A (JFHR2, E56412) • CSA Component Accepted Card: 1-30A (Class 1422-30 File 53787) Ordering • Specify packaging, product, and option code Product features Very fast-acting Optional axial leads available 1⁄4" x 1 1⁄4" (6.3 x 32mm) physical size Ceramic tube, nickel-plated brass endcap construction • 100pc-carton quantity weighs 1.0 lb (0.45 kg) • UL Recognized product meets standard 248-14 • • • • Part Number GBB-1-R GBB-1-1/4-R GBB-2-R GBB-3-R GBB-4-R GBB-5-R GBB-6-R GBB-7-R GBB-8-R GBB-9-R GBB-10-R GBB-12-R GBB-15-R GBB-20-R GBB-25-R GBB-30-R Voltage Rating Vac Vdc 250 125 250 125 250 125 250 125 250 125 250 125 250 125 250 125 250 125 250 125 250 125 250 125 250 125 250 125 250 125 250 125 Rated Current 1 - 20A 25, 30A Specifications AC Interrupting Rating (amps)* 250Vac 125Vac 200 10,000 200 10,000 200 10,000 200 10,000 200 10,000 200 10,000 200 10,000 200 10,000 200 10,000 200 10,000 200 10,000 200 10,000 200 10,000 200 200 200 200 200 200 DC Interrupting Rating (amps)* 125Vdc 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 200 200 200 Electrical Characteristics % of Amp Rating Opening Time 100% None 150% 2 minutes maximum 250% 1 seconds maximum 400% 100% None 150% 2 minutes maximum 250% 6 seconds maximum 400% - Typical DC Cold Resistance (Ω)** 0.17750 0.17900 0.06620 0.04475 0.03175 0.02125 0.01800 0.01550 0.01360 0.01070 0.00934 0.00620 0.00472 0.00330 0.00252 0.00206 Typical Voltage Drop (V)‡ 0.2096 0.2497 0.1687 0.1816 0.1778 0.1217 0.1324 0.1355 0.1144 0.1218 0.0877 0.0806 0.0735 0.0728 0.0610 0.0657 * Interrupting ratings: Interrupting ratings for 1-15A at 125Vdc was measured at 10,000A, 3.5 ms maximum, with time constant. Ratings 20-30A at 125Vdc were measured at 200A, 0.5 ms maximum, with time constant. Ratings 1-15A at 125Vac were measured at 10,000A, and 70% - 80% power factor. The interrupting ratings for 1-30A at 250Vac were measured at 90% - 100% power factor. ** DC Cold Resistance (Measured at
BK/GBB-9-R 价格&库存
很抱歉,暂时无法提供与“BK/GBB-9-R”相匹配的价格&库存,您可以联系我们找货
BK/GBB-9-R
