CB61F12A-TR1
CB61F12A-TR1
    EATON(伊顿)
    SMD,6.1x2.57mm
    一次性保险丝(熔断) 12A 125V
CB61F12A-TR1 数据手册
Effective May 2017 Supersedes January 2012 Technical Data 4377 CB61F Fast-acting surface mount Brick™ fuses HALOGEN Pb HF FREE Applications Primary circuit protection: Surface Mount Device • • • • • • • Product features • • • • • • • • High Interrupting Ratings: 50A @ 125Vac / 300A @ 125Vdc Wide Selection: ratings from 2 to 15 amps providing a range of solutions for applications requiring fast-acting performance CQC Approved: Meets the growing market demand. cULus Certified and PSE Level 1 Certified Excellent Environmental Integrity: lead-free, halogen free and RoHS compliant, and present no disposal issues at end of life. Solder immersion compatible Wire-in-Air design Agency information • • • • Environmental data • • • cULus: Standard UL 248-14, Guide JDYX, File E 19180 and Guide JDYX7, File E19180 PSE: JET 1641-31007-1003 (2A-5A),JET 1641-31007-1004 (6.3A-10A), JET 1641-31007-1005 (12-15A) CQC: CQC09012040316 (2A-6.3A & 8A-10A) • • Ordering • • LCD/PDP TVs Notebooks Telecom/PoE Industrial applications LCD Monitors Servers Medical equipment LCD backlight inverters Power supplies White goods Mechanical Shock: MIL-STD-202G, Method 213B, Test Condition C (100 G’s peak for 6 milliseconds; half-sine waveform) Mechanical Vibration: MIL-STD-202G, Method 201,Test Condition A (10-55Hz, 0.06 inch, total excursion) Insulation Resistance: MIL-STD-202, Method 302, Test Condition A (after opening) 10,000 ohms minimum Resistance to Solder Heat: MIL-STD-202G, Method 210F, Test Condition D (10 sec, at 260°C); Test Condition A (350°C, 5s) for hand solder Thermal Shock: MIL-STD-202, Method 107G, Test Condition B (-65°C to +125°C) Specify product and packaging code Catalog Number CB61F2A CB61F3A CB61F4A CB61F5A CB61F6.3A CB61F7A CB61F8A CB61F10A CB61F12A CB61F15A Current Ratings (amps) 2 3 4 5 6.3 7 8 10 12 15 Voltage Ratings Vac Vdc 125 125 125 125 125 125 125 125 125 125 125 125 125 125 125 125 125 125 125 125 Interrupting Ratings (amps)* 125Vac 125Vdc 100 100 100 100 100 100 100 100 50 50 300 300 300 300 300 300 300 300 300 300 Specifications Typical Cold Resistance (Ω)** 0.039 0.025 0.017 0.013 0.010 0.009 0.008 0.006 0.005 0.004 Typical Melting I2t (A2s)*** Typical Voltage Drop (mV)‡ 0.85 2.08 4.4 7.7 13.7 15.6 19.5 36 40 56 100 100 93 90 90 85 90 90 90 85 Agency Approvals cULus PSE CQC X X X X X X X X X X X X X X X X X X X X * AC Interrupting Rating (measured at designated voltage, 100% power factor); DC Interrupting Rating (measured at designated voltage, time constant of less than 50 microseconds, battery source) ** Typical Cold Resistance (measured at 10% of rated current) *** Typical Melting I2t (measured with a battery bank at rated DC voltage, 10x-rated current, time constant of calibrated circuit less than 50 microseconds) ‡ Typical Voltage Drop (measured at rated current after temperature stabilizes) X X X X X X X  Technical Data 4377 Effective May 2017  Dimensions - mm Recommended Pad Layout Drawing Not to Scale Time-Current Curves 2A 3A 4A 6 .3 A 7 A 8 A 1 0 A 1 2 A 1 5 A 1000 100 Time (s) 10 1 0 .1 0 .0 1 1 10 Current (A) 2 www.eaton.com/electronics 100  Technical Data 4377 Effective May 2017  Soldering Characteristics Wave Immersion • Reservoir Temperature: 260° C • Time in Reservoir : 10 Seconds Maximum Infrared Reflow • Temperature: 260° C • Time: 30 Seconds Maximum Hand Soldering • Maximum tip temperature: 350°C • Maximum soldering time: 5 seconds max Recommend Reflow Profile Packaging Code Packaging Code Suffix -TR1 -TR2 Description 1000 Fuses in Tape and Reel on 7 inch (178mm) diameter reel 5000 Fuses in Tape and Reel on 13 inch (330mm) diameter reel Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 4377 BU-SB111447 May 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
CB61F12A-TR1 价格&库存
很抱歉,暂时无法提供与“CB61F12A-TR1”相匹配的价格&库存,您可以联系我们找货
CB61F12A-TR1
    • 1+1.84659
    • 200+0.71464
    • 500+0.68948
    • 1000+0.67706
    CB61F12A-TR1
