DILAC-31(110V50HZ,120V60HZ)
    EATON(伊顿)
    EATON MOELLER - DILAC-31(110V50HZ,120V60HZ) - Relay Contactor, DILAC Series, DPST-NO, DPST-NC, 4P, 4...
DILAC-31(110V50HZ,120V60HZ) 数据手册
DATASHEET - DILAC-31(110V50HZ,120V60HZ) Contactor relay, 110 V 50 Hz, 120 V 60 Hz, N/O = Normally open: 3 N/O, N/C = Normally closed: 1 NC, Spring-loaded terminals, AC operation Similar to illustration Part no.  Catalog No.  Alternate Catalog No.  EL-Nummer (Norway)  Delivery program DILAC-31(110V50HZ,120V60HZ) 276470 XTREC10B31A 4110164 Product range     DILA relays Application     Contactor relays Description     Basic devices with positive operation contacts Connection technique     Spring-loaded terminals Rated operational current       AC-15       220 V 230 V 240 V Ie A 4 380 V 400 V 415 V Ie A 4       N/O = Normally open     3 N/O N/C = Normally closed 1 NC Contacts     Contact sequence     Code number and version of combination           31E Can be combined with auxiliary contact module     DILA-XHIC(V)… Actuating voltage     110 V 50 Hz, 120 V 60 Hz Voltage AC/DC     AC operation Connection to SmartWire-DT     no Instructions     Contact numbers to EN 50011 Coil terminal markings to EN 50005 Standards     IEC/EN 60947, EN 60947-5-1, VDE 0660, UL, CSA Lifespan, mechanical       Operations x 10 Distinctive number Technical data General AC operated 6 20 Maximum operating frequency Operations/h   9000 Climatic proofing     Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60068-2-30 Ambient temperature       Open   °C -25 - +60 Enclosed   °C - 25 - 40 Ambient temperature, storage   °C - 40 - 80           Mechanical shock resistance (IEC/EN 60068-2-27)     07/12/2020 Eaton 276470 ED2020 V70.0 EN Mounting position Mounting position   1/8 Half-sinusoidal shock, 10 ms Basic unit with auxiliary contact module         g   N/O contact   g 7 N/C contact   g 5 Degree of Protection     IP20 Protection against direct contact when actuated from front (EN 50274)     Finger and back-of-hand proof Altitude   m Max. 2000 Weight       AC operated   kg Terminal capacities   mm         Spring-loaded terminals 0.24 2 Solid   2 mm 1 x (0.75 - 2.5) 2 x (0.75 - 2.5) Flexible with or without ferrule DIN 46228   mm 2 1 x (0,75 - 1.5) 2 x (0,75 - 1.5) Solid or stranded Stripping length   AWG 18 - 14   mm 10 Standard screwdriver   mm 0.6 x 3.5 Positive operating contacts to ZH 1/457, including auxiliary contact module     Yes Rated impulse withstand voltage Uimp V AC 6000 Overvoltage category/pollution degree     III/3 Rated insulation voltage Ui V AC 690 Rated operational voltage Ue V AC 690 Safe isolation to EN 61140       between coil and auxiliary contacts   V AC 400 between the auxiliary contacts   V AC 400   A               Ith =Ie A 16       220 V 230 V 240 V Ie A 4 380 V 400 V 415 V Ie A 4 500 V Ie A 1.5 Contacts Rated operational current Conventional free air thermal current, 1 pole Open at 60 °C AC-15 DC current       Notes     Switch-on and switch-off conditions based on DC-13, time constant as specified. DC L/R ≦ 15 ms         A   1 24 V A 10 1 60 V A 6 2 60 V A 10 1 110 V A 3 3 110 V A 6 1 220 V A 1 3 220 V A 5       Contacts in series: DC L/R ≦ 50 ms Contacts in series:   A   3 24 V A 4 3 60 V A 4 3 110 V A 2 3 220 V A 1 Failure rate λ
DILAC-31(110V50HZ,120V60HZ) 价格&库存
很抱歉,暂时无法提供与“DILAC-31(110V50HZ,120V60HZ)”相匹配的价格&库存,您可以联系我们找货
