Technical Data 4132
Effective April 2016
Supersedes March 2007
DR1030
Shielded power inductors
Applications
LED/LCD backlighting
High definition televisions (HDTV)
Server and desktop power supplies
Portable electronics
Notebook and laptop regulators
Graphics cards and battery powered systems
Point-of-load (POL) modules
Printers and peripherals
Environmental Data
Description
Shielded drum core
Inductance range from 1.1 μH to 155 μH
Current range from 0.68 A to 9.5 A
10.5 mm x 10.3 mm footprint surface mount
package in a 3.0 mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
Storage temperature range (Component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
HALOGEN
Pb HF
FREE
DR1030
Technical Data 4132
Product Specifications
OCL1
(μH) ±30%
Irms2
(A)
Isat3
(A)
DCR (mΩ)
typical
@ 20°C
DCR (mΩ)
maximum
@ 20°C
K-factor4
DR1030-1R1-R
1.1
7.0
9.5
6.5
7.9
22
DR1030-1R8-R
1.9
5.9
7.4
9.1
11.0
17
DR1030-2R8-R
2.8
5.1
6.08
12.1
14.5
14
DR1030-3R9-R
4.0
4.3
5.1
16.4
20.0
12
DR1030-5R2-R
5.2
3.7
4.75
22.9
27.5
10
DR1030-6R8-R
6.8
3.5
3.9
24.9
30.0
9
DR1030-8R2-R
8.4
3.3
3.54
28.4
34.1
8
DR1030-100-R
10.4
2.8
3.18
40.2
48.0
7
DR1030-150-R
14.8
2.3
2.66
57.3
68.8
6
DR1030-220-R
22.8
1.8
2.19
95.5
115
5
DR1030-330-R
32.4
1.6
1.81
114
136
4
DR1030-470-R
47.9
1.3
1.52
167
200
3.4
DR1030-680-R
67
1.1
1.24
253
304
2.9
DR1030-820-R
82
1.0
1.14
332
382
2.6
DR1030-101-R
100
0.86
1.05
375
450
2.4
DR1030-121-R
119
0.80
0.95
523
602
1.9
DR1030-151-R
155
0.68
0.86
590
700
1.4
Part Number
5
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C
2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed 125 °C under worst case operating
conditions verified in the end application.
3. Isat: Peak current for approximately 35% rolloff @ +25 °C
4. K-factor: K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (mT), K:
(K-factor from table), L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps)..
5. Part Number Definition: DR1030-xxx-R
DR1030 = Product code and size
-xxx= inductance value in μH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
Dimensions (mm)
Part marking: inductance value in uH. R = decimal point. If no R is present then last character equals number of zeroes.
wwlly = date code, R = revision level
Do not route traces or vias underneath the inductor
2
www.eaton.com/elx
DR1030
Technical Data 4132
Packaging information (mm)
Supplied in tape and reel packaging , 1000 parts per 13” diameter reel
Temperature rise vs. total loss
160
140
Temperature Rise (°C)
120
100
80
60
40
0.20
0.40
0.60
0.80
1.00
1.20
Total Loss (W)
www.eaton.com/elx
3
DR1030
Technical Data 4132
Core loss vs. Bp-p
N+]
0+]
N+]
N+]
N+]
Core Loss (W)
Bp-p (mT)
Inductance characteristics
% of OCL vs. % of Isat
120%
100%
% of OCL
80%
60%
-40 °C
+25 °C
+85 °C
40%
20%
0%
0%
20%
40%
60%
% of Isat
4
www.eaton.com/elx
80%
100%
120%
DR1030
Technical Data 4132
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“DR1030-1R1-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.613511+0.85974
- 10+5.4422810+0.70748
- 100+4.47489100+0.58173
- 国内价格
- 1000+7.85916
- 15000+5.90041
- 国内价格 香港价格
- 1000+3.920521000+0.50966
- 2000+3.697002000+0.48060
- 3000+3.572353000+0.46440
- 5000+3.421395000+0.44477
- 7000+3.325567000+0.43232
- 10000+3.2269910000+0.41950
