Technical Data ELX1189
Effective June 2022
ECSTA1V0504
Automotive grade SMT current sense transformer
Applications
Product features
AEC-Q200 qualified
EE4.4 SMT package
(4.8 mm x 3.65 mm x 3.55 mm)
Very low DC resistance
Wide selection of turns ratios
Sensed current – primary rated for 7 A
Frequency range: 50 kHz to 1 MHz
Moisture sensitivity level (MSL): 1
Motor drive
On-board chargers
DC/DC converters
Wireless chargers
Battery management systems (BMS)
EV charging
Feedback control
Overload sensing
Environmental compliance and general
specifications
Storage temperature (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb
ECSTA1V0504
Effective June 2022
Product specifications
Turns ratio
sec :pri
Secondary
inductance (µH)
@ 100 kHz 0.1 V
minimum
DCR sec (Ω)
maximum
DCR pri (mΩ)
reference
Hi-pot pri to sec
@ 2 mA 3 seconds
50 Hz
Sensed
current1 (A)
maximum
ECSTA1V0504-1020-R
20:1
33
0.35
3
500 Vac
7
ECSTA1V0504-1030-R
30:1
74
0.8
3
500 Vac
7
ECSTA1V0504-1040-R
40:1
132
1.6
3
500 Vac
7
ECSTA1V0504-1050-R
50:1
205
2.5
3
500 Vac
7
ECSTA1V0504-1060-R
60:1
295
3.6
3
500 Vac
7
ECSTA1V0504-1070-R
70:1
400
4.6
3
500 Vac
7
ECSTA1V0504-1100-R
100:1
820
9.5
3
500 Vac
7
ECSTA1V0504-1125-R
125:1
1280
13
3
500 Vac
7
ECSTA1V0504-1150-R
150:1
1800
21
3
500 Vac
7
Part number
3
1. Primary current of 7 A causes less than 40°C temperature rise @ +2 5°C ambient. Higher current causes a greater
temperature rise
2. Electrical specifications at +25 °C
3. Part Number Definition: ECSTA1V0504-1xxx-R
ECSTA1V0504 = Product code and size
1xxx= Turns ratio sec:pri 1=pri, xxx=sec; 1020= 20:1
-R suffix = RoHS compliant
Mechanical parameters, schematic, pad layout (mm)
Recommended PCB Layout
Schematic
Dimension
Value
A
4.80 maximum
B
3.65 maximum
C
3.55 maximum
E
0.4
F
0.85
G
2.10
J
2.50
Part marking: White dot, Pin 1 indicator
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Traces or vias underneath the inductor is not recommended
2
www.eaton.com/electronics
ECSTA1V0504
Effective June 2022
Temperature rise vs current
3
Effective June 2022
ECSTA1V0504
Packaging information (mm)
Supplied in tape and reel packaging, 13” diameter reel (EIA-481 compliant)
2000 parts per reel
4
Dimension
Value
W
12.0 ±0.3
P1
8.0 ±0.1
E1
1.75 ±0.1
F
5.50 ±0.05
P2
2.0 ±0.05
D0
1.5 +0.1/-0
D1
1.5 +0.1/-0
B0
4.4 ±0.1
A0
4.8 ±0.1
K0
3.5 ±0.1
P0
4.0 ±0.1
T
0.35 ±0.05
Dimension
Value
A
330 ±3.0
B
2.6 ±0.3
N
100 ±1.0
C
13+0.5/-0.2
D
21.5 ±0.5
W1
12.4+2.0/-0.0
W2
18.4 max
W3
na
ECSTA1V0504
Effective June 2022
Solder reflow profile
Table 1 - Standard SnPb solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“ECSTA1V0504-1040-R”相匹配的价格&库存,您可以联系我们找货
