ECX09C1AAA-R63/BL30
ECX09C1AAA-R63/BL30
    EATON(伊顿)
    EATON CUTLER HAMMER - ECX09C1AAA-R63/BL30 - MOTOR STARTER, 1-PH, 9A, 115VAC
ECX09C1AAA-R63/BL30 数据手册
3.1 3 IEC Contactors and Starters XT IEC Power Control Contents IEC Metallic Enclosure—Contactors and Starters Description 3 Page Non-Metallic Enclosure—Contactors and Starters . . Metallic Enclosure—Contactors and Starters Catalog Number Selection . . . . . . . . . . . . . . . . Product Selection Non-Combination Starters . . . . . . . . . . . . . Combination Starters . . . . . . . . . . . . . . . . . Wiring Diagrams . . . . . . . . . . . . . . . . . . . . . . . Combination Motor Controllers . . . . . . . . . . . . . . . 3 3 3 3 V10-T3-2 V10-T3-9 V10-T3-14 V10-T3-23 V10-T3-35 V10-T3-43 3 3 3 3 3 Metallic Enclosure—Contactors and Starters 3 Product Description 3 3 3 3 Eaton’s XT line includes IEC contactors, starters and combination motor controllers (CMCs). Designed to meet international standards, the enclosed control XT line (ECX), carries UL and cUL certifications. ● ● ● ● ● 3 3 ● 3 ● 3 ● 3 ● 3 3 3 3 3 ● Features and Benefits AC control from 12 V to 600 V 50/60 Hz DC control from 24 V to 220 V Available with screw or spring cage terminals Reversing or non-reversing contactors and starters AC-3 contactor ratings to 1000 A and AC-1 contactor ratings to 2000 A Non-reversing starters to 650 A Panel or DIN rail mounting to 65 A IP20 finger and back-ofhand proof Large ambient temperature range, –25 °C to +50 °C [–13 °F to +122 °F] ● ● ● ● ● ● AC and DC controlled contactors in the same compact frame Low power consumption DC coils Built-in NO or NC auxiliary contacts to 32 A Plug-in accessories for reduced installation time Types 1 (IP23), 4 (IP66), 4X (IP66), 12 (IP65) and 3R (IP32) Circuit breakers, fused, non-fused and noncombination designs available Opaque (standard) or clear covers available on nonmetallic Halyester enclosure option Additional Reference Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Accessories and Modifications . . . . . . . . . . . . . . . Renewal Parts . . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications . . . . . . . . . . . . . Tab 14 Tab 15 Tab 16 Tab 17 3 3 3 3 V10-T3-8 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com Standards and Certifications Note: See Tab 17 for additional information on standards and certifications that apply to all enclosed control products. ● Fusible—with Class J fuses ● UL Listed ● cUL Listed 1 ● Circuit Breaker HMCP/E ● UL Listed ● cUL Listed 1 Short-Circuit Ratings ● Fused, non-fused ● 10K AIC at 600 V ● HMCP ● 0–10 hp 15K AIC at 600 V ● 15–125 hp 25K AIC at 600 V ● Non-combination ● 0–1 hp 1K AIC at 600 V ● 1.5–50 hp 5K AIC at 600 V ● 50–200 hp 10K AIC at 600 V Note 1 cUL Listing indicates appropriate CSA standard investigation. 3.1 IEC Contactors and Starters XT IEC Power Control Catalog Number Selection 3 XT IEC Line Metallic Enclosed Control 3 EC X 25 E 5 A A A - 00 00 3 Design X = XT IEC Class 09 = Non-combination non-reversing starter 10 = Non-combination reversing starter 11 = Non-combination non-reversing starter with CPT 19 = Combination non-reversing starter— fusible/non-fusible disconnect 20 = Combination reversing starter— fusible/non-fusible disconnect 25 = Combination non-reversing starter— circuit breaker 26 = Combination reversing starter— circuit breaker Combination (Class 16–74) IEC Size B–Q 3 Modification Codes See Tab 15 3 3 Overload Range See table below Page V10-T3-14 V10-T3-17 V10-T3-20 3 Disconnect Fuse Clip Ratings A = None C = 30 A J E = 60 A J G = 100 A J Circuit Breaker Ratings A = None F = 50 A B= 3A W = 70 A C= 7A G = 100 A D = 15 A H = 150 A E = 30 A J = 250 A V10-T3-23 V10-T3-26 V10-T3-29 V10-T3-32 Size Non-Combination (Class 09–11) Ampere Rating (UL 600 V) B= 7A J = 40 A C= 9A K = 50 A D = 12 A L = 65 A E = 15 A M = 80 A F = 18 A N = 95 A G = 25 A P = 115 A H = 32 A Q = 150 A 1 3 4 5 8 = = = = = 3 3 3 3 Cover Control Type 1 non-comb. (NEW BOX 1 only) starters see Page V10-T3-11 Type 1 non-comb. starters see Page V10-T3-12 All other starters see Page V10-T3-14 Enclosure Type/IP Ratings 1 Type 1—General purpose/IP23 Type 4—Painted steel/IP66 Type 4X—Watertight (304-Grade stainless steel)/IP66 Type 4X—Watertight (non-metallic)/IP66 Type 12—Dust-tight/IP65 A= B= C= D= E= 3 3 3 3 Coil Voltage 120 V H = 277 V 240 V L = 380 V / 50 Hz 480 V Q = 24 Vdc 600 V T = 24 Vac 208 V 3 3 XTOB Overload Relays for Enclosed XT FLA Ratings Size B–E 7–15 A Size F–H 18–32 A Size J–L 40–65 A Size M–N 80–95 A Size P–Q 115–150 A FLA Ratings Size B–E 7–15 A Size F–H 18–32 A Size J–L 40–65 A Size M–N 80–95 A Size P–Q 115–150 A 0.1–0.16 A A — — — 16–24 — M M — — 0.16–0.24 B B — — — 24–32 — N — — — 0.24–0.4 C C — — — 24–40 — — P — — 0.4–0.6 D D — — — 25–35 — — — S S 0.6–1 E E — — — 35–50 — — — T T 1–1.6 F F — — — 40–57 — — Q — — 1.6–2.4 G G — — — 50–65 — — R — — 2.4–4 H H — — — 50–70 — — — U U 4–6 I I — — — 70–100 — — — V V 6–10 J J J — — 95–125 — — — — W 9–12 K — — — — 120–150 — — — — X 12–16 L2 L L — — 3 3 3 3 3 3 3 3 3 Notes 1 See Tab 1 for enclosure type/IP rating cross-reference. 2 Size B–E is 10–16 A. 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-9 3.1 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 IEC Contactors and Starters XT IEC Power Control C440 Solid-State Overload Modifications Reliability and Improved Uptime ● C440 provides the users with peace of mind knowing that their assets are protected with the highest level of motor protection and communication capability in its class ● Extends the life of plant assets with selectable motor protection features such as trip class, phase unbalance and ground fault ● Protects against unnecessary downtime by discovering changes in your system (line/load) with remote monitoring capabilities ● Status LED provides added assurance that valuable assets are protected by indicating the overload operational status Flexibility Improves return on investment by reducing inventory carrying costs with wide FLA adjustment (5:1) and selectable trip class ● Design incorporates built-in ground fault protection thus eliminating the need for separate CTs and modules ● Flexible communication with optional I/O enables easy integration into plant management systems for remote monitoring and control Three-Phase with Ground Fault Auto/Manual Reset Overload NEMA Size Full Load Current Adjustment Range (A) Selectable Class 10/20/30 Selectable Class 10/20/30 Solid-state electronic overload relay 1 B and C 00 0.33–1.65 2 R63/A R64/A 1–5 R63/B R64/B 4–20 R63/C R64/C C and D 3 3 3 3 Three-Phase without Ground Fault Auto/Manual Reset Overload IEC Size 0 and 1 3 3 Safety IP20 rated terminal blocks ● Available in Eaton’s industry leading FlashGard MCCs ● Tested to the highest industry standards such as UL, CSA, CE and IEC ● RoHS compliant ● Modification 3 3 ● For solid-state overload enclosed control, add R63 or R64 modification code after the base Catalog Number. (Example, ECX09G1AAA-R63/B). 3 3 Monitoring Capabilities Individual phase currents RMS ● Average three-phase current RMS ● Thermal memory ● Fault indication (overload, phase loss, phase unbalance, ground fault) ● 2 R63/A R64/A 1–5 R63/B R64/B 4–20 R63/C R64/C 0.33–1.65 9–45 R63/D R64/D D 2 9–45 R63/D R64/D D, F and G 3 20–100 R63/E R64/E G 4 28–140 R63/F R64/F N/A 5 60–300 R63/G R64/G N/A 6 120–600 R63/H R64/H Notes 1 Features: • Self-powered • Phase loss protection • Current adjustment knob • ±1% repeat accuracy • 1NO and 1NC isolated contacts 2 Not UL Listed. 3 3 3 3 V10-T3-10 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com IEC Contactors and Starters XT IEC Power Control 3.1 Cover Control 3 Product Selection 3 Type 1 Non-Combination Cover Control (Box 1 Only) ● Cover control for noncombination starters uses M22 style devices as standard ● ● Pushbuttons are momentary type Field convertible selector switches from momentary to maintained operation and vice versa ● Cover control kits include hardware, M22 pushbuttons, bracket and pre-wired wire harnesses ● See Volume 7, Tab 1, for more details on M22 pushbuttons 3 3 Factory Installed Flange Control Field Installation Kits Position 9 Cover Control Code Catalog Number 3 Non-Reversing 3 No cover mounted pilot devices A STOP/START oval pushbuttons B C600M1 C C600M101_ 1 1 With red RUN pilot light With red RUN/green OFF lights — D C600M102_ OFF/ON oval pushbuttons E C600M2 With red RUN pilot light F C600M201_ 1 With red RUN/green OFF lights G C600M202_ 1 STOP/START selector switch S C600M13 With red RUN pilot light T C600M131_ 1 With red RUN/green OFF lights U C600M132_ 1 OFF/ON selector switch V C600M14 W C600M141_ 1 With red RUN/green OFF lights X C600M142_ 1 HAND/OFF/AUTO selector switch H C600M12 With red RUN pilot light J C600M121_ 1 With red RUN/green OFF lights K C600M122_ 1 With red RUN pilot light Green START pushbutton L C600M3 Red STOP pushbutton Y C600M7 1 Green ON pushbutton M C600M4 Red OFF pushbutton N C600M5 Red RUN pilot light P C600M9_ 1 Green OFF pilot light Q C600M10_ 1 Red RUN/green OFF lights R C600M11_ 1 TEST/OFF/AUTO selector switch — C600M8 E C600M27 F C600M271_ H C600M15 3 3 3 3 3 3 3 3 3 3 3 3 3 Reversing UP/STOP/DOWN selector switch With 2 red pilot lights REV/STOP/FWD selector switch With 2 red pilot lights J C600M151_ Two red pilot lights (labeled FWD, REV) P C600M28_ Green OFF pilot light Q C600M10_ 3 3 3 3 3 Note 1 Add code letter from the table below to catalog number for voltage. Example: C600M101A. Rating Code Letter 85–264 Vac A 480 Vac C 12–30 Vac/Vdc T 3 3 Type 1 Non-Combination Cover Control (Box 1 Only) Box 1 offering includes metallic enclosures with starters up to 32 A. Description 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-11 3.1 3 3 3 XT IEC Power Control Type 1 Non-Combination Cover Control (Box 2 and Larger Enclosures Only) ● Cover control for combination starters uses 10250T style devices as standard 3 3 IEC Contactors and Starters Type 1 Cover Control 3 3 ● ● Selector switches are maintained with lever operators Pushbuttons are momentary type with extended pushbutton ● The kit includes hardware and connecting wires (where possible) Type 1 Non-Combination Cover Control (Box 2 and Larger Enclosures Only) Box 2 and Larger Enclosure offering includes metallic enclosures with starters larger than 32 A. Description Factory Installed Flange Control 1 Position 9 Cover Control Code Field Installation Kits Catalog Number 3 Non-Reversing 3 No cover mounted pilot devices A C400GK0 STOP/START pushbuttons B C400GK1 With red RUN pilot light C C400GK12 2 With red RUN/green OFF lights D C400GK16 2 HAND/OFF/AUTO selector switch H C400GK3 With red RUN pilot light J C400GK32 2 With red RUN/green OFF lights K C400GK36 2 Red RUN pilot light P C400GK42 2 Green OFF pilot light Q C400GK41 2 3 Red RUN/green OFF pilot lights R C400GK46 2 3 No cover mounted pilot devices A C400GK0 FOR/REV/STOP pushbuttons B C400GR1 With two red pilot lights C C400GR14 2 E C400GR2 F C400GR24 2 3 3 3 3 Reversing 3 3 UP/STOP/DOWN pushbuttons 3 Two red pilot lights P C400GK44 2 One green pilot light Q C400GK41 2 With two red pilot lights 3 Notes 1 For more available factory installed flange control, see Page V10-T3-11. 2 Add code letter from the table below to catalog number for voltage—kits only. Example: C400GK0B. 3 3 Rating Code Letter Rating Code Letter Rating Code Letter 3 120 V 60 Hz A 277 V 60 Hz H 480 V 60 Hz C 208 V 60 Hz E 380 V 50 Hz L 600 V 60 Hz D 240 V 60 Hz B 3 3 3 3 3 3 3 3 V10-T3-12 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com ● For factory installed control devices other than shown below, refer to modification codes, Tab 15 IEC Contactors and Starters XT IEC Power Control 3.1 Type 1 Non-Combination Empty Enclosure (Box 1 Only) 3 There is a universal empty enclosure for the non-metallic Type 1 Non-Combination Box 1 regardless of the starter or the contactor needed. The only difference is the length of the easily interchangeable reset rod. The reset rod kit provides everything needed to install the correct reset rod, including all the reset rod lengths, a protective shroud, a paddle and a reset button with nut. 3 3 3 Box 1 offering includes metallic enclosures with starters up to 32 A. Empty Enclosure Stocking Needs Catalog Number Empty enclosure C899001 Reset rod kit RESET001 3 3 The table below shows which reset rod is used with each starter or contactor. Starter or Contactor Reset Rod Length IEC Frame Size B and C, SSOL 0.74-inch reset IEC Frame Size B, Bi-Metallic Overload 1.74-inch reset IEC Frame Size C, Bi-Metallic Overload 1.30-inch reset 3 3 3 3 3 3 3 3 3 3 IEC Frame Size B and C, SSOL— 0.74-inch reset IEC Frame Size C, Bi-Metallic Overload— 1.30-inch reset 3 IEC Frame Size B, Bi-Metallic Overload — 1.74-inch reset 3 3 3 3 3 3 3 3 3 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-13 3.1 IEC Contactors and Starters XT IEC Power Control 3 Product Selection 3 Non-Combination Starters 3 3 3 Class ECX09—Non-Combination Non-Reversing Starter Maximum hp 1 Amps Motor Voltage 2 Single-Phase Three-Phase Type 4X/IP66 5 Type 1/IP23 Coil Voltage at 60 Hz 3 Catalog Number 4 Catalog Number Type 12/IP65 4 Catalog Number Component 4 Catalog Number 4 Size B 115 1/4 — 120 ECX09B1AAA-_ ECX09B4AAA-_ ECX09B8AAA-_ XTAE007B10A_ 3 208 3/4 1-1/2 208 ECX09B1EAA-_ ECX09B4EAA-_ ECX09B8EAA-_ XTAE007B10E_ 230 1 2 240 ECX09B1BAA-_ ECX09B4BAA-_ ECX09B8BAA-_ XTAE007B10B_ 3 380 — 3 380/50 Hz ECX09B1LAA-_ ECX09B4LAA-_ ECX09B8LAA-_ XTAE007B10L_ 460 — 3 480 ECX09B1CAA-_ ECX09B4CAA-_ ECX09B8CAA-_ XTAE007B10C_ 575 — 5 600 ECX09B1DAA-_ ECX09B4DAA-_ ECX09B8DAA-_ XTAE007B10D_ XTAE009B10A_ 3 3 7 Size C 115 1/2 — 120 ECX09C1AAA-_ ECX09C4AAA-_ ECX09C8AAA-_ 3 208 1 2 208 ECX09C1EAA-_ ECX09C4EAA-_ ECX09C8EAA-_ XTAE009B10E_ 230 1-1/2 3 240 ECX09C1BAA-_ ECX09C4BAA-_ ECX09C8BAA-_ XTAE009B10B_ 3 380 — 5 380/50 Hz ECX09C1LAA-_ ECX09C4LAA-_ ECX09C8LAA-_ XTAE009B10L_ 460 — 5 480 ECX09C1CAA-_ ECX09C4CAA-_ ECX09C8CAA-_ XTAE009B10C_ 575 — 7-1/2 600 ECX09C1DAA-_ ECX09C4DAA-_ ECX09C8DAA-_ XTAE009B10D_ 115 1/2 — 120 ECX09D1AAA-_ ECX09D4AAA-_ ECX09D8AAA-_ XTAE012B10A_ 3 208 1-1/2 3 208 ECX09D1EAA-_ ECX09D4EAA-_ ECX09D8EAA-_ XTAE012B10E_ 230 2 3 240 ECX09D1BAA-_ ECX09D4BAA-_ ECX09D8BAA-_ XTAE012B10B_ 3 380 — 5 380/50 Hz ECX09D1LAA-_ ECX09D4LAA-_ ECX09D8LAA-_ XTAE012B10L_ 460 — 7-1/2 480 ECX09D1CAA-_ ECX09D4CAA-_ ECX09D8CAA-_ XTAE012B10C_ 575 — 10 600 ECX09D1DAA-_ ECX09D4DAA-_ ECX09D8DAA-_ XTAE012B10D_ 3 3 9 Size D 12 3 3 Size E 15 115 3/4 — 120 ECX09E1AAA-_ ECX09E4AAA-_ ECX09E8AAA-_ XTAE015B10A_ 208 2 3 208 ECX09E1EAA-_ ECX09E4EAA-_ ECX09E8EAA-_ XTAE015B10E_ 230 2 3 240 ECX09E1BAA-_ ECX09E4BAA-_ ECX09E8BAA-_ XTAE015B10B_ 3 380 — 5 380/50 Hz ECX09E1LAA-_ ECX09E4LAA-_ ECX09E8LAA-_ XTAE015B10L_ 3 460 — 7-1/2 480 ECX09E1CAA-_ ECX09E4CAA-_ ECX09E8CAA-_ XTAE015B10C_ 575 — 10 600 ECX09E1DAA-_ ECX09E4DAA-_ ECX09E8DAA-_ XTAE015B10D_ 115 2 — 120 ECX09F1AAA-_ ECX09F4AAA-_ ECX09F8AAA-_ XTAE018C10A_ 208 2 5 208 ECX09F1EAA-_ ECX09F4EAA-_ ECX09F8EAA-_ XTAE018C10E_ 230 3 5 240 ECX09F1BAA-_ ECX09F4BAA-_ ECX09F8BAA-_ XTAE018C10B_ 3 380 — 7-1/2 380/50 Hz ECX09F1LAA-_ ECX09F4LAA-_ ECX09F8LAA-_ XTAE018C10L_ 3 460 — 10 480 ECX09F1CAA-_ ECX09F4CAA-_ ECX09F8CAA-_ XTAE018C10C_ 575 — 15 600 ECX09F1DAA-_ ECX09F4DAA-_ ECX09F8DAA-_ XTAE018C10D_ 3 3 Size F 18 3 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX09B4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 V10-T3-14 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com IEC Contactors and Starters XT IEC Power Control 3.1 Class ECX09—Non-Combination Non-Reversing Starter, continued Maximum hp 1 Amps 3 Type 1/IP23 Type 4X/IP66 5 Type 12/IP65 Component Catalog Number 4 Catalog Number 4 Catalog Number 4 Catalog Number 4 3 3 Motor Voltage 2 Single-Phase Three-Phase Coil Voltage at 60 Hz 3 115 2 — 120 ECX09G1AAA-_ ECX09G4AAA-_ ECX09G8AAA-_ XTAE025C10A_ 208 3 7-1/2 208 ECX09G1EAA-_ ECX09G4EAA-_ ECX09G8EAA-_ XTAE025C10E_ 230 5 7-1/2 240 ECX09G1BAA-_ ECX09G4BAA-_ ECX09G8BAA-_ XTAE025C10B_ 380 — 10 380/50 Hz ECX09G1LAA-_ ECX09G4LAA-_ ECX09G8LAA-_ XTAE025C10L_ 460 — 15 480 ECX09G1CAA-_ ECX09G4CAA-_ ECX09G8CAA-_ XTAE025C10C_ 575 — 20 600 ECX09G1DAA-_ ECX09G4DAA-_ ECX09G8DAA-_ XTAE025C10D_ 115 3 — 120 ECX09H1AAA-_ ECX09H4AAA-_ ECX09H8AAA-_ XTAE032C10A_ 208 5 10 208 ECX09H1EAA-_ ECX09H4EAA-_ ECX09H8EAA-_ XTAE032C10E_ 230 5 10 240 ECX09H1BAA-_ ECX09H4BAA-_ ECX09H8BAA-_ XTAE032C10B_ 380 — 15 380/50 Hz ECX09H1LAA-_ ECX09H4LAA-_ ECX09H8LAA-_ XTAE032C10L_ 460 — 20 480 ECX09H1CAA-_ ECX09H4CAA-_ ECX09H8CAA-_ XTAE032C10C_ 575 — 25 600 ECX09H1DAA-_ ECX09H4DAA-_ ECX09H8DAA-_ XTAE032C10D_ 115 3 — 120 ECX09J1AAA-_ ECX09J4AAA-_ ECX09J8AAA-_ XTAE040D00A_ 208 5 10 208 ECX09J1EAA-_ ECX09J4EAA-_ ECX09J8EAA-_ XTAE040D00E_ 230 7-1/2 15 240 ECX09J1BAA-_ ECX09J4BAA-_ ECX09J8BAA-_ XTAE040D00D_ 380 — 15 380/50 Hz ECX09J1LAA-_ ECX09J4LAA-_ ECX09J8LAA-_ XTAE040D00L_ 460 — 30 480 ECX09J1CAA-_ ECX09J4CAA-_ ECX09J8CAA-_ XTAE040D00C_ 575 — 40 600 ECX09J1DAA-_ ECX09J4DAA-_ ECX09J8DAA-_ XTAE040D00D_ 3 115 3 — 120 ECX09K1AAA-_ ECX09K4AAA-_ ECX09K8AAA-_ XTAE050D00A_ 3 Size G 25 Size H 32 Size J 40 Size K 50 3 3 3 3 3 3 3 3 3 3 208 7-1/2 15 208 ECX09K1EAA-_ ECX09K4EAA-_ ECX09K8EAA-_ XTAE050D00E_ 230 10 20 240 ECX09K1BAA-_ ECX09K4BAA-_ ECX09K8BAA-_ XTAE050D00B_ 380 — 20 380/50 Hz ECX09K1LAA-_ ECX09K4LAA-_ ECX09K8LAA-_ XTAE050D00L_ 460 — 40 480 ECX09K1CAA-_ ECX09K4CAA-_ ECX09K8CAA-_ XTAE050D00C_ 575 — 50 600 ECX09K1DAA-_ ECX09K4DAA-_ ECX09K8DAA-_ XTAE050D00D_ 3 115 5 — 120 ECX09L1AAA-_ ECX09L4AAA-_ ECX09L8AAA-_ XTAE065D00A_ 3 208 10 20 208 ECX09L1EAA-_ ECX09L4EAA-_ ECX09L8EAA-_ XTAE065D00E_ 230 15 25 240 ECX09L1BAA-_ ECX09L4BAA-_ ECX09L8BAA-_ XTAE065D00B_ 380 — 30 380/50 Hz ECX09L1LAA-_ ECX09L4LAA-_ ECX09L8LAA-_ XTAE065D00L_ 460 — 50 480 ECX09L1CAA-_ ECX09L4CAA-_ ECX09L8CAA-_ XTAE065D00C_ 575 — 60 600 ECX09L1DAA-_ ECX09L4DAA-_ ECX09L8DAA-_ XTAE065D00D_ Size L 65 3 3 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX09G4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-15 3.1 3 3 IEC Contactors and Starters XT IEC Power Control Class ECX09—Non-Combination Non-Reversing Starter, continued Maximum hp 1 Amps 2 Type 4X/IP66 5 Type 1/IP23 Coil Voltage at 60 Hz 3 Catalog Number 4 Catalog Number 4 Three-Phase 115 7-1/2 — 120 ECX09M1AAA-_ ECX09M4AAA-_ ECX09M8AAA-_ 3 208 15 25 208 ECX09M1EAA-_ ECX09M4EAA-_ ECX09M8EAA-_ XTAE080F00E_ 230 15 30 240 ECX09M1BAA-_ ECX09M4BAA-_ ECX09M8BAA-_ XTAE080F00B_ 3 380 — 50 380/50 Hz ECX09M1LAA-_ ECX09M4LAA-_ ECX09M8LAA-_ XTAE080F00L_ 3 460 — 60 480 ECX09M1CAA-_ ECX09M4CAA-_ ECX09M8CAA-_ XTAE080F00C_ 575 — 75 600 ECX09M1DAA-_ ECX09M4DAA-_ ECX09M8DAA-_ XTAE080F00D_ 115 7-1/2 — 120 ECX09N1AAA-_ ECX09N4AAA-_ ECX09N8AAA-_ XTAE095F00A_ 208 15 25 208 ECX09N1EAA-_ ECX09N4EAA-_ ECX09N8EAA-_ XTAE095F00E_ 230 15 40 240 ECX09N1BAA-_ ECX09N4BAA-_ ECX09N8BAA-_ XTAE095F00B_ 380 — 60 380/50 Hz ECX09N1LAA-_ ECX09N4LAA-_ ECX09N8LAA-_ XTAE095F00L_ 460 — 75 480 ECX09N1CAA-_ ECX09N4CAA-_ ECX09N8CAA-_ XTAE095F00C_ 575 — 100 600 ECX09N1DAA-_ ECX09N4DAA-_ ECX09N8DAA-_ XTAE095F00D_ XTAE115G00A_ 3 3 Size M 80 XTAE080F00A_ Size N 95 3 3 3 3 Catalog Number Component 4 Single-Phase Motor Voltage Catalog Number Type 12/IP65 4 Size P 115 115 10 — 120 ECX09P1AAA-_ ECX09P4AAA-_ ECX09P8AAA-_ 208 25 40 208 ECX09P1EAA-_ ECX09P4EAA-_ ECX09P8EAA-_ XTAE115G00E_ 230 25 50 240 ECX09P1BAA-_ ECX09P4BAA-_ ECX09P8BAA-_ XTAE115G00B_ 3 380 — 60 380/50 Hz ECX09P1LAA-_ ECX09P4LAA-_ ECX09P8LAA-_ XTAE115G00L_ 3 460 — 100 480 ECX09P1CAA-_ ECX09P4CAA-_ ECX09P8CAA-_ XTAE115G00C_ 575 — 125 600 ECX09P1DAA-_ ECX09P4DAA-_ ECX09P8DAA-_ XTAE115G00D_ 3 3 Size Q 150 115 15 — 120 ECX09Q1AAA-_ ECX09Q4AAA-_ ECX09Q8AAA-_ XTAE150G00A_ 3 208 25 40 208 ECX09Q1EAA-_ ECX09Q4EAA-_ ECX09Q8EAA-_ XTAE150G00E_ 3 230 30 60 240 ECX09Q1BAA-_ ECX09Q4BAA-_ ECX09Q8BAA-_ XTAE150G00B_ 380 — 60 380/50 Hz ECX09Q1LAA-_ ECX09Q4LAA-_ ECX09Q8LAA-_ XTAE150G00L_ 460 — 125 480 ECX09Q1CAA-_ ECX09Q4CAA-_ ECX09Q8CAA-_ XTAE150G00C_ 575 — 150 600 ECX09Q1DAA-_ ECX09Q4DAA-_ ECX09Q8DAA-_ XTAE150G00D_ 3 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX09M4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 3 3 3 3 V10-T3-16 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com IEC Contactors and Starters XT IEC Power Control 3.1 Class ECX10—Non-Combination Reversing Starter Maximum hp 1 Amps Motor Voltage 2 Single-Phase Three-Phase 3 Coil Voltage at 60 Hz 3 Type 1/IP23 Type 4X/IP66 5 Type 12/IP65 Component Catalog Number 4 Catalog Number 4 Catalog Number 4 Catalog Number 4 3 3 Size B 7 115 1/4 — 120 ECX10B1AAA-_ ECX10B4AAA-_ ECX10B8AAA-_ XTAR007B10A_ 208 3/4 1-1/2 208 ECX10B1EAA-_ ECX10B4EAA-_ ECX10B8EAA-_ XTAR007B10E_ 230 1 2 240 ECX10B1BAA-_ ECX10B4BAA-_ ECX10B8BAA-_ XTAR007B10B_ 380 — 3 380/50 Hz ECX10B1LAA-_ ECX10B4LAA-_ ECX10B8LAA-_ XTAR007B10L_ 460 — 3 480 ECX10B1CAA-_ ECX10B4CAA-_ ECX10B8CAA-_ XTAR007B10C_ 575 — 5 600 ECX10B1DAA-_ ECX10B4DAA-_ ECX10B8DAA-_ XTAR007B10D_ 115 1/2 — 120 ECX10C1AAA-_ ECX10C4AAA-_ ECX10C8AAA-_ XTAR009B10A_ Size C 9 208 1 2 208 ECX10C1EAA-_ ECX10C4EAA-_ ECX10C8EAA-_ XTAR009B10E_ 230 1-1/2 3 240 ECX10C1BAA-_ ECX10C4BAA-_ ECX10C8BAA-_ XTAR009B10B_ 380 — 5 380/50 Hz ECX10C1LAA-_ ECX10C4LAA-_ ECX10C8LAA-_ XTAR009B10L_ 460 — 5 480 ECX10C1CAA-_ ECX10C4CAA-_ ECX10C8CAA-_ XTAR009B10C_ 575 — 7-1/2 600 ECX10C1DAA-_ ECX10C4DAA-_ ECX10C8DAA-_ XTAR009B10D_ 115 1/2 — 120 ECX10D1AAA-_ ECX10D4AAA-_ ECX10D8AAA-_ XTAR012B10A_ 208 1-1/2 3 208 ECX10D1EAA-_ ECX10D4EAA-_ ECX10D8EAA-_ XTAR012B10E_ 230 2 3 240 ECX10D1BAA-_ ECX10D4BAA-_ ECX10D8BAA-_ XTAR012B10B_ Size D 12 3 3 3 3 3 3 3 3 — 5 380/50 Hz ECX10D1LAA-_ ECX10D4LAA-_ ECX10D8LAA-_ XTAR012B10L_ 460 — 7-1/2 480 ECX10D1CAA-_ ECX10D4CAA-_ ECX10D8CAA-_ XTAR012B10C_ 575 — 10 600 ECX10D1DAA-_ ECX10D4DAA-_ ECX10D8DAA-_ XTAR012B10D_ 3 115 3/4 — 120 ECX10E1AAA-_ ECX10E4AAA-_ ECX10E8AAA-_ XTAR015B10A_ 3 208 2 3 208 ECX10E1EAA-_ ECX10E4EAA-_ ECX10E8EAA-_ XTAR015B10E_ 230 2 3 240 ECX10E1BAA-_ ECX10E4BAA-_ ECX10E8BAA-_ XTAR015B10B_ 3 3 380 — 5 380/50 Hz ECX10E1LAA-_ ECX10E4LAA-_ ECX10E8LAA-_ XTAR015B10L_ 460 — 7-1/2 480 ECX10E1CAA-_ ECX10E4CAA-_ ECX10E8CAA-_ XTAR015B10C_ 575 — 10 600 ECX10E1DAA-_ ECX10E4DAA-_ ECX10E8DAA-_ XTAR015B10D_ 3 115 2 — 120 ECX10F1AAA-_ ECX10F4AAA-_ ECX10F8AAA-_ XTAR018C10A_ 3 208 2 5 208 ECX10F1EAA-_ ECX10F4EAA-_ ECX10F8EAA-_ XTAR018C10E_ 230 3 5 240 ECX10F1BAA-_ ECX10F4BAA-_ ECX10F8BAA-_ XTAR018C10B_ 380 — 7-1/2 380/50 Hz ECX10F1LAA-_ ECX10F4LAA-_ ECX10F8LAA-_ XTAR018C10L_ 460 — 10 480 ECX10F1CAA-_ ECX10F4CAA-_ ECX10F8CAA-_ XTAR018C10C_ 575 — 15 600 ECX10F1DAA-_ ECX10F4DAA-_ ECX10F8DAA-_ XTAR018C10D_ Size F 18 3 380 Size E 15 3 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX10B4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-17 3.1 3 IEC Contactors and Starters XT IEC Power Control Class ECX10—Non-Combination Reversing Starter, continued Maximum hp 1 3 Amps 3 25 2 Type 4X/IP66 5 Type 1/IP23 Coil Voltage at 60 Hz 3 Catalog Number 4 Catalog Number 4 Three-Phase 115 2 — 120 ECX10G1AAA-_ ECX10G4AAA-_ ECX10G8AAA-_ 3 208 3 7-1/2 208 ECX10G1EAA-_ ECX10G4EAA-_ ECX10G8EAA-_ XTAR025C10E_ 230 5 7-1/2 240 ECX10G1BAA-_ ECX10G4BAA-_ ECX10G8BAA-_ XTAR025C10B_ 3 380 — 10 380/50 Hz ECX10G1LAA-_ ECX10G4LAA-_ ECX10G8LAA-_ XTAR025C10L_ 3 460 — 15 480 ECX10G1CAA-_ ECX10G4CAA-_ ECX10G8CAA-_ XTAR025C10C_ 575 — 20 600 ECX10G1DAA-_ ECX10G4DAA-_ ECX10G8DAA-_ XTAR025C10D_ 115 3 — 120 ECX10H1AAA-_ ECX10H4AAA-_ ECX10H8AAA-_ XTAR032C10A_ 208 5 10 208 ECX10H1EAA-_ ECX10H4EAA-_ ECX10H8EAA-_ XTAR032C10E_ 230 5 10 240 ECX10H1BAA-_ ECX10H4BAA-_ ECX10H8BAA-_ XTAR032C10B_ 380 — 15 380/50 Hz ECX10H1LAA-_ ECX10H4LAA-_ ECX10H8LAA-_ XTAR032C10L_ 460 — 20 480 ECX10H1CAA-_ ECX10H4CAA-_ ECX10H8CAA-_ XTAR032C10C_ 575 — 25 600 ECX10H1DAA-_ ECX10H4DAA-_ ECX10H8DAA-_ XTAR032C10D_ 115 3 — 120 ECX10J1AAA-_ ECX10J4AAA-_ ECX10J8AAA-_ XTAR040D00A_ 208 5 10 208 ECX10J1EAA-_ ECX10J4EAA-_ ECX10J8EAA-_ XTAR040D00E_ 3 Size G XTAR025C10A_ Size H 32 3 3 3 3 Catalog Number Component 4 Single-Phase Motor Voltage Catalog Number Type 12/IP65 4 Size J 40 3 230 7-1/2 15 240 ECX10J1BAA-_ ECX10J4BAA-_ ECX10J8BAA-_ XTAR040D00B_ 3 380 — 15 380/50 Hz ECX10J1LAA-_ ECX10J4LAA-_ ECX10J8LAA-_ XTAR040D00L_ 3 460 — 30 480 ECX10J1CAA-_ ECX10J4CAA-_ ECX10J8CAA-_ XTAR040D00C_ 575 — 40 600 ECX10J1DAA-_ ECX10J4DAA-_ ECX10J8DAA-_ XTAR040D00D_ 115 3 — 120 ECX10K1AAA-_ ECX10K4AAA-_ ECX10K8AAA-_ XTAR050D00A_ 3 208 7-1/2 15 208 ECX10K1EAA-_ ECX10K4EAA-_ ECX10K8EAA-_ XTAR050D00E_ 3 230 10 20 240 ECX10K1BAA-_ ECX10K4BAA-_ ECX10K8BAA-_ XTAR050D00B_ 380 — 20 380/50 Hz ECX10K1LAA-_ ECX10K4LAA-_ ECX10K8LAA-_ XTAR050D00L_ 460 — 40 480 ECX10K1CAA-_ ECX10K4CAA-_ ECX10K8CAA-_ XTAR050D00C_ 575 — 50 600 ECX10K1DAA-_ ECX10K4DAA-_ ECX10K8DAA-_ XTAR050D00D_ 3 Size K 50 3 3 Size L 65 115 5 — 120 ECX10L1AAA-_ ECX10L4AAA-_ ECX10L8AAA-_ XTAR065D00A_ 3 208 10 20 208 ECX10L1EAA-_ ECX10L4EAA-_ ECX10L8EAA-_ XTAR065D00E_ 3 230 15 25 240 ECX10L1BAA-_ ECX10L4BAA-_ ECX10L8BAA-_ XTAR065D00B_ 380 — 30 380/50 Hz ECX10L1LAA-_ ECX10L4LAA-_ ECX10L8LAA-_ XTAR065D00L_ 460 — 50 480 ECX10L1CAA-_ ECX10L4CAA-_ ECX10L8CAA-_ XTAR065D00C_ 575 — 60 600 ECX10L1DAA-_ ECX10L4DAA-_ ECX10L8DAA-_ XTAR065D00D_ 3 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX10G4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 V10-T3-18 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com IEC Contactors and Starters XT IEC Power Control 3.1 Class ECX10—Non-Combination Reversing Starter, continued Maximum hp 1 Amps Motor Voltage 2 Single-Phase 3 Type 1/IP23 Type 4X/IP66 5 Type 12/IP65 Component Three-Phase Coil Voltage at 60 Hz 3 Catalog Number 4 Catalog Number 4 Catalog Number 4 Catalog Number 4 3 3 Size M 80 115 7-1/2 — 120 ECX10M1AAA-_ ECX10M4AAA-_ ECX10M8AAA-_ XTAR080F00A_ 208 15 25 208 ECX10M1EAA-_ ECX10M4EAA-_ ECX10M8EAA-_ XTAR080F00E_ 230 15 30 240 ECX10M1BAA-_ ECX10M4BAA-_ ECX10M8BAA-_ XTAR080F00B_ 380 — 50 380/50 Hz ECX10M1LAA-_ ECX10M4LAA-_ ECX10M8LAA-_ XTAR080F00L_ 460 — 60 480 ECX10M1CAA-_ ECX10M4CAA-_ ECX10M8CAA-_ XTAR080F00C_ 575 — 75 600 ECX10M1DAA-_ ECX10M4DAA-_ ECX10M8DAA-_ XTAR080F00D_ 115 7-1/2 — 120 ECX10N1AAA-_ ECX10N4AAA-_ ECX10N8AAA-_ XTAR095F00A_ 208 15 25 208 ECX10N1EAA-_ ECX10N4EAA-_ ECX10N8EAA-_ XTAR095F00E_ 230 15 40 240 ECX10N1BAA-_ ECX10N4BAA-_ ECX10N8BAA-_ XTAR095F00B_ 380 — 60 380/50 Hz ECX10N1LAA-_ ECX10N4LAA-_ ECX10N8LAA-_ XTAR095F00L_ 460 — 75 480 ECX10N1CAA-_ ECX10N4CAA-_ ECX10N8CAA-_ XTAR095F00C_ 575 — 100 600 ECX10N1DAA-_ ECX10N4DAA-_ ECX10N8DAA-_ XTAR095F00D_ 115 10 — 120 ECX10P1AAA-_ ECX10P4AAA-_ ECX10P8AAA-_ XTAR115G00A_ 208 25 40 208 ECX10P1EAA-_ ECX10P4EAA-_ ECX10P8EAA-_ XTAR115G00E_ 230 25 50 240 ECX10P1BAA-_ ECX10P4BAA-_ ECX10P8BAA-_ XTAR115G00B_ 380 — 60 380/50 Hz ECX10P1LAA-_ ECX10P4LAA-_ ECX10P8LAA-_ XTAR115G00L_ 460 — 100 480 ECX10P1CAA-_ ECX10P4CAA-_ ECX10P8CAA-_ XTAR115G00C_ 575 — 125 600 ECX10P1DAA-_ ECX10P4DAA-_ ECX10P8DAA-_ XTAR115G00D_ 3 115 15 — 120 ECX10Q1AAA-_ ECX10Q4AAA-_ ECX10Q8AAA-_ XTAR150G00A_ 3 208 25 40 208 ECX10Q1EAA-_ ECX10Q4EAA-_ ECX10Q8EAA-_ XTAR150G00E_ 230 30 60 240 ECX10Q1BAA-_ ECX10Q4BAA-_ ECX10Q8BAA-_ XTAR150G00B_ 380 — 60 380/50 Hz ECX10Q1LAA-_ ECX10Q4LAA-_ ECX10Q8LAA-_ XTAR150G00L_ 460 — 125 480 ECX10Q1CAA-_ ECX10Q4CAA-_ ECX10Q8CAA-_ XTAR150G00C_ 575 — 150 600 ECX10Q1DAA-_ ECX10Q4DAA-_ ECX10Q8DAA-_ XTAR150G00D_ Size N 95 Size P 115 Size Q 150 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX10M4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 3 3 3 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-19 3.1 3 IEC Contactors and Starters XT IEC Power Control Class ECX11—Non-Combination Non-Reversing Starter with CPT Maximum hp 1 3 Amps 3 7 Motor Voltage 2 Single-Phase Three-Phase Type 4X/IP66 5 Type 1/IP23 Coil Voltage at 60 Hz 3 Catalog Number 4 Catalog Number Type 12/IP65 4 Catalog Number Component 4 Catalog Number 4 Size B 115 1/4 — 120 ECX11B1AAA-_ ECX11B4AAA-_ ECX11B8AAA-_ XTAE007B10A_ 3 208 3/4 1-1/2 120 ECX11B1AAA-_ ECX11B4AAA-_ ECX11B8AAA-_ XTAE007B10A_ 230 1 2 120 ECX11B1AAA-_ ECX11B4AAA-_ ECX11B8AAA-_ XTAE007B10A_ 3 380 — 3 110 ECX11B1AAA-_ ECX11B4AAA-_ ECX11B8AAA-_ XTAE007B10A_ 3 460 — 3 120 ECX11B1AAA-_ ECX11B4AAA-_ ECX11B8AAA-_ XTAE007B10A_ 575 — 5 120 ECX11B1AAA-_ ECX11B4AAA-_ ECX11B8AAA-_ XTAE007B10A_ 3 Size C 9 115 1/2 — 120 ECX11C1AAA-_ ECX11C4AAA-_ ECX11C8AAA-_ XTAE009B10A_ 208 1 2 120 ECX11C1AAA-_ ECX11C4AAA-_ ECX11C8AAA-_ XTAE009B10A_ 230 1-1/2 3 120 ECX11C1AAA-_ ECX11C4AAA-_ ECX11C8AAA-_ XTAE009B10A_ 380 — 5 110 ECX11C1AAA-_ ECX11C4AAA-_ ECX11C8AAA-_ XTAE009B10A_ 460 — 5 120 ECX11C1AAA-_ ECX11C4AAA-_ ECX11C8AAA-_ XTAE009B10A_ 575 — 7-1/2 120 ECX11C1AAA-_ ECX11C4AAA-_ ECX11C8AAA-_ XTAE009B10A_ 115 1/2 — 120 ECX11D1AAA-_ ECX11D4AAA-_ ECX11D8AAA-_ XTAE012B10A_ 208 1-1/2 3 120 ECX11D1AAA-_ ECX11D4AAA-_ ECX11D8AAA-_ XTAE012B10A_ 230 2 3 120 ECX11D1AAA-_ ECX11D4AAA-_ ECX11D8AAA-_ XTAE012B10A_ 3 380 — 5 110 ECX11D1AAA-_ ECX11D4AAA-_ ECX11D8AAA-_ XTAE012B10A_ 3 460 — 7-1/2 120 ECX11D1AAA-_ ECX11D4AAA-_ ECX11D8AAA-_ XTAE012B10A_ 575 — 10 120 ECX11D1AAA-_ ECX11D4AAA-_ ECX11D8AAA-_ XTAE012B10A_ 115 3/4 — 120 ECX11E1AAA-_ ECX11E4AAA-_ ECX11E8AAA-_ XTAE015B10A_ 3 208 2 3 120 ECX11E1AAA-_ ECX11E4AAA-_ ECX11E8AAA-_ XTAE015B10A_ 3 230 2 3 120 ECX11E1AAA-_ ECX11E4AAA-_ ECX11E8AAA-_ XTAE015B10A_ 380 — 5 110 ECX11E1AAA-_ ECX11E4AAA-_ ECX11E8AAA-_ XTAE015B10A_ 460 — 7-1/2 120 ECX11E1AAA-_ ECX11E4AAA-_ ECX11E8AAA-_ XTAE015B10A_ 575 — 10 120 ECX11E1AAA-_ ECX11E4AAA-_ ECX11E8AAA-_ XTAE015B10A_ 115 2 — 120 ECX11F1AAA-_ ECX11F4AAA-_ ECX11F8AAA-_ XTAE018C10A_ 3 208 2 5 120 ECX11F1AAA-_ ECX11F4AAA-_ ECX11F8AAA-_ XTAE018C10A_ 3 230 3 5 120 ECX11F1AAA-_ ECX11F4AAA-_ ECX11F8AAA-_ XTAE018C10A_ 380 — 7-1/2 110 ECX11F1AAA-_ ECX11F4AAA-_ ECX11F8AAA-_ XTAE018C10A_ 460 — 10 120 ECX11F1AAA-_ ECX11F4AAA-_ ECX11F8AAA-_ XTAE018C10A_ 575 — 15 120 ECX11F1AAA-_ ECX11F4AAA-_ ECX11F8AAA-_ XTAE018C10A_ 3 3 3 3 Size D 12 3 3 Size E 15 3 3 Size F 18 3 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX11B4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 V10-T3-20 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com IEC Contactors and Starters XT IEC Power Control 3.1 Class ECX11—Non-Combination Non-Reversing Starter with CPT, continued Maximum hp 1 Amps 3 Type 1/IP23 Type 4X/IP66 5 Type 12/IP65 Component Catalog Number 4 Catalog Number 4 Catalog Number 4 Catalog Number 4 3 3 Motor Voltage 2 Single-Phase Three-Phase Coil Voltage at 60 Hz 3 115 2 — 120 ECX11G1AAA-_ ECX11G4AAA-_ ECX11G8AAA-_ XTAE025C10A_ 208 3 7-1/2 120 ECX11G1AAA-_ ECX11G4AAA-_ ECX11G8AAA-_ XTAE025C10A_ 230 5 7-1/2 120 ECX11G1AAA-_ ECX11G4AAA-_ ECX11G8AAA-_ XTAE025C10A_ 380 — 10 110 ECX11G1AAA-_ ECX11G4AAA-_ ECX11G8AAA-_ XTAE025C10A_ 460 — 15 120 ECX11G1AAA-_ ECX11G4AAA-_ ECX11G8AAA-_ XTAE025C10A_ 575 — 20 120 ECX11G1AAA-_ ECX11G4AAA-_ ECX11G8AAA-_ XTAE025C10A_ 115 3 — 120 ECX11H1AAA-_ ECX11H4AAA-_ ECX11H8AAA-_ XTAE032C10A_ 208 5 10 120 ECX11H1AAA-_ ECX11H4AAA-_ ECX11H8AAA-_ XTAE032C10A_ 230 5 10 120 ECX11H1AAA-_ ECX11H4AAA-_ ECX11H8AAA-_ XTAE032C10A_ 380 — 15 110 ECX11H1AAA-_ ECX11H4AAA-_ ECX11H8AAA-_ XTAE032C10A_ 460 — 20 120 ECX11H1AAA-_ ECX11H4AAA-_ ECX11H8AAA-_ XTAE032C10A_ 575 — 25 120 ECX11H1AAA-_ ECX11H4AAA-_ ECX11H8AAA-_ XTAE032C10A_ 115 3 — 120 ECX11J1AAA-_ ECX11J4AAA-_ ECX11J8AAA-_ XTAE040D00A_ 208 5 10 120 ECX11J1AAA-_ ECX11J4AAA-_ ECX11J8AAA-_ XTAE040D00A_ 230 7-1/2 15 120 ECX11J1AAA-_ ECX11J4AAA-_ ECX11J8AAA-_ XTAE040D00A_ 380 — 15 110 ECX11J1AAA-_ ECX11J4AAA-_ ECX11J8AAA-_ XTAE040D00A_ 460 — 30 120 ECX11J1AAA-_ ECX11J4AAA-_ ECX11J8AAA-_ XTAE040D00A_ 575 — 40 120 ECX11J1AAA-_ ECX11J4AAA-_ ECX11J8AAA-_ XTAE040D00A_ 3 115 3 — 120 ECX11K1AAA-_ ECX11K4AAA-_ ECX11K8AAA-_ XTAE050D00A_ 3 Size G 25 Size H 32 Size J 40 Size K 50 3 3 3 3 3 3 3 3 3 3 208 7-1/2 15 120 ECX11K1AAA-_ ECX11K4AAA-_ ECX11K8AAA-_ XTAE050D00A_ 230 10 20 120 ECX11K1AAA-_ ECX11K4AAA-_ ECX11K8AAA-_ XTAE050D00A_ 380 — 20 110 ECX11K1AAA-_ ECX11K4AAA-_ ECX11K8AAA-_ XTAE050D00A_ 460 — 40 120 ECX11K1AAA-_ ECX11K4AAA-_ ECX11K8AAA-_ XTAE050D00A_ 575 — 50 120 ECX11K1AAA-_ ECX11K4AAA-_ ECX11K8AAA-_ XTAE050D00A_ 3 115 5 — 120 ECX11L1AAA-_ ECX11L4AAA-_ ECX11L8AAA-_ XTAE065D00A_ 3 208 10 20 120 ECX11L1AAA-_ ECX11L4AAA-_ ECX11L8AAA-_ XTAE065D00A_ 230 15 25 120 ECX11L1AAA-_ ECX11L4AAA-_ ECX11L8AAA-_ XTAE065D00A_ 380 — 30 110 ECX11L1AAA-_ ECX11L4AAA-_ ECX11L8AAA-_ XTAE065D00A_ 460 — 50 120 ECX11L1AAA-_ ECX11L4AAA-_ ECX11L8AAA-_ XTAE065D00A_ 575 — 60 120 ECX11L1AAA-_ ECX11L4AAA-_ ECX11L8AAA-_ XTAE065D00A_ Size L 65 3 3 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX11G4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-21 3.1 3 3 IEC Contactors and Starters XT IEC Power Control Class ECX11—Non-Combination Non-Reversing Starter with CPT, continued Maximum hp 1 Amps 2 Type 4X/IP66 5 Type 1/IP23 Coil Voltage at 60 Hz 3 Catalog Number 4 Catalog Number 4 Three-Phase 115 7-1/2 — 120 ECX11M1AAA-_ ECX11M4AAA-_ ECX11M8AAA-_ XTAE080F00A_ 3 208 15 25 120 ECX11M1AAA-_ ECX11M4AAA-_ ECX11M8AAA-_ XTAE080F00A_ 230 15 30 120 ECX11M1AAA-_ ECX11M4AAA-_ ECX11M8AAA-_ XTAE080F00A_ 3 380 — 50 110 ECX11M1AAA-_ ECX11M4AAA-_ ECX11M8AAA-_ XTAE080F00A_ 3 460 — 60 120 ECX11M1AAA-_ ECX11M4AAA-_ ECX11M8AAA-_ XTAE080F00A_ 575 — 75 120 ECX11M1AAA-_ ECX11M4AAA-_ ECX11M8AAA-_ XTAE080F00A_ 115 7-1/2 — 120 ECX11N1AAA-_ ECX11N4AAA-_ ECX11N8AAA-_ XTAE095F00A_ 208 15 25 120 ECX11N1AAA-_ ECX11N4AAA-_ ECX11N8AAA-_ XTAE095F00A_ 230 15 40 120 ECX11N1AAA-_ ECX11N4AAA-_ ECX11N8AAA-_ XTAE095F00A_ 380 — 60 110 ECX11N1AAA-_ ECX11N4AAA-_ ECX11N8AAA-_ XTAE095F00A_ 460 — 75 120 ECX11N1AAA-_ ECX11N4AAA-_ ECX11N8AAA-_ XTAE095F00A_ 575 — 100 120 ECX11N1AAA-_ ECX11N4AAA-_ ECX11N8AAA-_ XTAE095F00A_ 3 3 Size M 80 Size N 95 3 3 3 3 Catalog Number Component 4 Single-Phase Motor Voltage Catalog Number Type 12/IP65 4 Size P 115 115 10 — 120 ECX11P1AAA-_ ECX11P4AAA-_ ECX11P8AAA-_ XTAE115G00A_ 208 25 40 120 ECX11P1AAA-_ ECX11P4AAA-_ ECX11P8AAA-_ XTAE115G00A_ 230 25 50 120 ECX11P1AAA-_ ECX11P4AAA-_ ECX11P8AAA-_ XTAE115G00A_ 3 380 — 60 110 ECX11P1AAA-_ ECX11P4AAA-_ ECX11P8AAA-_ XTAE115G00A_ 3 460 — 100 120 ECX11P1AAA-_ ECX11P4AAA-_ ECX11P8AAA-_ XTAE115G00A_ 575 — 125 120 ECX11P1AAA-_ ECX11P4AAA-_ ECX11P8AAA-_ XTAE115G00A_ 3 3 Size Q 150 115 15 — 120 ECX11Q1AAA-_ ECX11Q4AAA-_ ECX11Q8AAA-_ XTAE150G00A_ 3 208 25 40 120 ECX11Q1AAA-_ ECX11Q4AAA-_ ECX11Q8AAA-_ XTAE150G00A_ 3 230 30 60 120 ECX11Q1AAA-_ ECX11Q4AAA-_ ECX11Q8AAA-_ XTAE150G00A_ 380 — 60 110 ECX11Q1AAA-_ ECX11Q4AAA-_ ECX11Q8AAA-_ XTAE150G00A_ 460 — 125 120 ECX11Q1AAA-_ ECX11Q4AAA-_ ECX11Q8AAA-_ XTAE150G00A_ 575 — 150 120 ECX11Q1AAA-_ ECX11Q4AAA-_ ECX11Q8AAA-_ XTAE150G00A_ 3 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX11M4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 3 3 3 3 V10-T3-22 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com IEC Contactors and Starters XT IEC Power Control 3.1 Combination Starters 3 Class ECX19—Combination Non-Reversing Starter—Fusible/Non-Fusible Disconnect Maximum hp 1 Amps Type 4X/IP66 5 Type 12/IP65 Component Catalog Number 4 Catalog Number 4 Catalog Number 4 Catalog Number 4 3 3 Motor Voltage 2 Single-Phase Three-Phase — — — — ECX19B1AAA-_ ECX19B4AAA-_ ECX19B8AAA-_ XTAE007B10A_ 115 1/4 — 120 ECX19B1AAC-_ ECX19B4AAC-_ ECX19B8AAC-_ XTAE007B10A_ Size B 7 30 A 3/4 1-1/2 208 ECX19B1EAC-_ ECX19B4EAC-_ ECX19B8EAC-_ XTAE007B10E_ 230 1 2 240 ECX19B1BAC-_ ECX19B4BAC-_ ECX19B8BAC-_ XTAE007B10B_ 380 — 3 380/50 Hz ECX19B1LAC-_ ECX19B4LAC-_ ECX19B8LAC-_ XTAE007B10L_ 460 — 3 480 ECX19B1CAC-_ ECX19B4CAC-_ ECX19B8CAC-_ XTAE007B10C_ 575 — 5 600 ECX19B1DAC-_ ECX19B4DAC-_ ECX19B8DAC-_ XTAE007B10D_ — — — — ECX19C1AAA-_ ECX19C4AAA-_ ECX19C8AAA-_ XTAE009B10A_ 115 1/2 — 120 ECX19C1AAC-_ ECX19C4AAC-_ ECX19C8AAC-_ XTAE009B10A_ 208 1 2 208 ECX19C1EAC-_ ECX19C4EAC-_ ECX19C8EAC-_ XTAE009B10E_ 230 1-1/2 3 240 ECX19C1BAC-_ ECX19C4BAC-_ ECX19C8BAC-_ XTAE009B10B_ 380 — 5 380/50 Hz ECX19C1LAC-_ ECX19C4LAC-_ ECX19C8LAC-_ XTAE009B10L_ 460 — 5 480 ECX19C1CAC-_ ECX19C4CAC-_ ECX19C8CAC-_ XTAE009B10C_ 575 — 7-1/2 600 ECX19C1DAC-_ ECX19C4DAC-_ ECX19C8DAC-_ XTAE009B10D_ 3 — — — — ECX19D1AAA-_ ECX19D4AAA-_ ECX19D8AAA-_ XTAE012B10A_ 3 115 1/2 — 120 ECX19D1AAC-_ ECX19D4AAC-_ ECX19D8AAC-_ XTAE012B10A_ 208 1-1/2 3 208 ECX19D1EAC-_ ECX19D4EAC-_ ECX19D8EAC-_ XTAE012B10E_ 230 2 3 240 ECX19D1BAC-_ ECX19D4BAC-_ ECX19D8BAC-_ XTAE012B10B_ 380 — 5 380/50 Hz ECX19D1LAC-_ ECX19D4LAC-_ ECX19D8LAC-_ XTAE012B10L_ 460 — 7-1/2 480 ECX19D1CAC-_ ECX19D4CAC-_ ECX19D8CAC-_ XTAE012B10C_ 575 — 10 600 ECX19D1DAC-_ ECX19D4DAC-_ ECX19D8DAC-_ XTAE012B10D_ — — — — ECX19E1AAA-_ ECX19E4AAA-_ ECX19E8AAA-_ XTAE015B10A_ 115 3/4 — 120 ECX19E1AAC-_ ECX19E4AAC-_ ECX19E8AAC-_ XTAE015B10A_ 208 2 3 208 ECX19E1EAC-_ ECX19E4EAC-_ ECX19E8EAC-_ XTAE015B10E_ 230 2 3 240 ECX19E1BAC-_ ECX19E4BAC-_ ECX19E8BAC-_ XTAE015B10B_ 380 — 5 380/50 Hz ECX19E1LAC-_ ECX19E4LAC-_ ECX19E8LAC-_ XTAE015B10L_ 460 — 7-1/2 480 ECX19E1CAC-_ ECX19E4CAC-_ ECX19E8CAC-_ XTAE015B10C_ 575 — 10 600 ECX19E1DAC-_ ECX19E4DAC-_ ECX19E8DAC-_ XTAE015B10D_ 30 A Size D 12 30 A Size E 15 3 208 Size C 9 3 Type 1/IP23 Coil Voltage Fuse at 60 Hz 3 Clips 30 A Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX19B4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-23 3.1 3 IEC Contactors and Starters XT IEC Power Control Class ECX19—Combination Non-Reversing Starter—Fusible/Non-Fusible Disconnect, continued Maximum hp 1 3 Amps 3 18 Motor Voltage 2 Single-Phase Three-Phase Type 4X/IP66 5 Type 1/IP23 Coil Voltage Fuse at 60 Hz 3 Clips Catalog Number 4 Catalog Number Type 12/IP65 4 Catalog Number Component 4 Catalog Number 4 Size F — — — — ECX19F1AAA-_ ECX19F4AAA-_ ECX19F8AAA-_ XTAE018C10A_ 3 115 2 — 120 ECX19F1AAC-_ ECX19F4AAC-_ ECX19F8AAC-_ XTAE018C10A_ 208 2 5 208 ECX19F1EAC-_ ECX19F4EAC-_ ECX19F8EAC-_ XTAE018C10E_ 3 230 3 5 240 ECX19F1BAC-_ ECX19F4BAC-_ ECX19F8BAC-_ XTAE018C10B_ 3 380 — 7-1/2 380/50 Hz ECX19F1LAC-_ ECX19F4LAC-_ ECX19F8LAC-_ XTAE018C10L_ 460 — 10 480 ECX19F1CAC-_ ECX19F4CAC-_ ECX19F8CAC-_ XTAE018C10C_ 575 — 15 600 ECX19F1DAC-_ ECX19F4DAC-_ ECX19F8DAC-_ XTAE018C10D_ 3 3 30 A Size G 25 — — — — ECX19G1AAA-_ ECX19G4AAA-_ ECX19G8AAA-_ XTAE025C10A_ 115 2 — 120 ECX19G1AAC-_ ECX19G4AAC-_ ECX19G8AAC-_ XTAE025C10A_ 3 208 3 7-1/2 208 ECX19G1EAC-_ ECX19G4EAC-_ ECX19G8EAC-_ XTAE025C10E_ 3 230 5 7-1/2 240 ECX19G1BAC-_ ECX19G4BAC-_ ECX19G8BAC-_ XTAE025C10B_ 380 — 10 380/50 Hz ECX19G1LAC-_ ECX19G4LAC-_ ECX19G8LAC-_ XTAE025C10L_ 460 — 15 480 ECX19G1CAC-_ ECX19G4CAC-_ ECX19G8CAC-_ XTAE025C10C_ 575 — 20 600 ECX19G1DAC-_ ECX19G4DAC-_ ECX19G8DAC-_ XTAE025C10D_ 3 3 30 A Size H — — — — ECX19H1AAA-_ ECX19H4AAA-_ ECX19H8AAA-_ XTAE032C10A_ 3 115 3 — 120 ECX19H1AAE-_ ECX19H4AAE-_ ECX19H8AAE-_ XTAE032C10A_ 3 208 5 10 208 ECX19H1EAE-_ ECX19H4EAE-_ ECX19H8EAE-_ XTAE032C10E_ 230 5 10 240 ECX19H1BAE-_ ECX19H4BAE-_ ECX19H8BAE-_ XTAE032C10B_ 3 380 — 15 380/50 Hz ECX19H1LAE-_ ECX19H4LAE-_ ECX19H8LAE-_ XTAE032C10L_ 460 — 20 480 ECX19H1CAE-_ ECX19H4CAE-_ ECX19H8CAE-_ XTAE032C10C_ 3 575 — 25 600 ECX19H1DAE-_ ECX19H4DAE-_ ECX19H8DAE-_ XTAE032C10D_ 3 32 60 A Size J 40 — — — — ECX19J1AAA-_ ECX19J4AAA-_ ECX19J8AAA-_ XTAE040D00A_ 3 115 3 — 120 ECX19J1AAE-_ ECX19J4AAE-_ ECX19J8AAE-_ XTAE040D00A_ 208 5 10 208 ECX19J1EAE-_ ECX19J4EAE-_ ECX19J8EAE-_ XTAE040D00E_ 3 230 7-1/2 15 240 ECX19J1BAE-_ ECX19J4BAE-_ ECX19J8BAE-_ XTAE040D00B_ 380 — 15 380/50 Hz ECX19J1LAE-_ ECX19J4LAE-_ ECX19J8LAE-_ XTAE040D00L_ 460 — 30 480 ECX19J1CAE-_ ECX19J4CAE-_ ECX19J8CAE-_ XTAE040D00C_ 575 — 40 600 ECX19J1DAE-_ ECX19J4DAE-_ ECX19J8DAE-_ XTAE040D00D_ — — — — ECX19K1AAA-_ ECX19K4AAA-_ ECX19K8AAA-_ XTAE050D00A_ 115 3 — 120 ECX19K1AAE-_ ECX19K4AAG-_ ECX19K8AAG-_ XTAE050D00A_ 208 7-1/2 15 208 ECX19K1EAE-_ ECX19K4EAG-_ ECX19K8EAG-_ XTAE050D00E_ 230 10 20 240 ECX19K1BAE-_ ECX19K4BAG-_ ECX19K8BAG-_ XTAE050D00B_ 3 380 — 20 380/50 Hz ECX19K1LAE-_ ECX19K4LAG-_ ECX19K8LAG-_ XTAE050D00L_ 3 460 — 40 480 ECX19K1CAE-_ ECX19K4CAG-_ ECX19K8CAG-_ XTAE050D00C_ 575 — 50 600 ECX19K1DAE-_ ECX19K4DAG-_ ECX19K8DAG-_ XTAE050D00D_ 3 3 3 3 3 3 3 3 60 A Size K 50 100 A Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX19F4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 V10-T3-24 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com IEC Contactors and Starters XT IEC Power Control 3.1 Class ECX19—Combination Non-Reversing Starter—Fusible/Non-Fusible Disconnect, continued Maximum hp 1 Motor Voltage 2 Amps Single-Phase Three-Phase Type 1/IP23 Type 4X/IP66 5 Type 12/IP65 Component Catalog Number 4 Catalog Number 4 Catalog Number 4 Catalog Number 4 3 3 Size L 65 — — — — ECX19L1AAA-_ ECX19L4AAA-_ ECX19L8AAA-_ XTAE065D00A_ 115 5 — 120 100 A ECX19L1AAG-_ ECX19L4AAG-_ ECX19L8AAG-_ XTAE065D00A_ 208 10 20 208 ECX19L1EAG-_ ECX19L4EAG-_ ECX19L8EAG-_ XTAE065D00E_ Size N 25 240 ECX19L1BAG-_ ECX19L4BAG-_ ECX19L8BAG-_ XTAE065D00B_ — 30 380/50 Hz ECX19L1LAG-_ ECX19L4LAG-_ ECX19L8LAG-_ XTAE065D00L_ 460 — 50 480 ECX19L1CAG-_ ECX19L4CAG-_ ECX19L8CAG-_ XTAE065D00C_ 575 — 60 600 ECX19L1DAG-_ ECX19L4DAG-_ ECX19L8DAG-_ XTAE065D00D_ 3 3 100 A 3 — — — — ECX19M1AAA-_ ECX19M4AAA-_ ECX19M8AAA-_ XTAE080F00A_ 115 7-1/2 — 120 ECX19M1AAG-_ ECX19M4AAG-_ ECX19M8AAG-_ XTAE080F00A_ 208 15 25 208 ECX19M1EAG-_ ECX19M4EAG-_ ECX19M8EAG-_ XTAE080F00E_ 230 15 30 240 ECX19M1BAG-_ ECX19M4BAG-_ ECX19M8BAG-_ XTAE080F00B_ 380 — 50 380/50 Hz ECX19M1LAG-_ ECX19M4LAG-_ ECX19M8LAG-_ XTAE080F00L_ 460 — 60 480 ECX19M1CAG-_ ECX19M4CAG-_ ECX19M8CAG-_ XTAE080F00C_ 575 — 75 600 ECX19M1DAG-_ ECX19M4DAG-_ ECX19M8DAG-_ XTAE080F00D_ 3 — — — — ECX19N1AAA-_ ECX19N4AAA-_ ECX19N8AAA-_ XTAE095F00A_ 3 115 7-1/2 — 120 ECX19N1AAA-_ ECX19N4AAA-_ ECX19N8AAA-_ XTAE095F00A_ 208 15 25 208 ECX19N1EAA-_ ECX19N4EAA-_ ECX19N8EAA-_ XTAE095F00E_ 230 15 40 240 ECX19N1BAA-_ ECX19N4BAA-_ ECX19N8BAA-_ XTAE095F00B_ 380 — 60 380/50 Hz ECX19N1LAA-_ ECX19N4LAA-_ ECX19N8LAA-_ XTAE095F00L_ 460 — 75 480 ECX19N1CAA-_ ECX19N4CAA-_ ECX19N8CAA-_ XTAE095F00C_ 575 — 100 600 ECX19N1DAA-_ ECX19N4DAA-_ ECX19N8DAA-_ XTAE095F00D_ 3 — — — — ECX19P1AAA-_ ECX19P4AAA-_ ECX19P8AAA-_ XTAE115G00A_ 3 115 10 — 120 ECX19P1AAA-_ ECX19P4AAA-_ ECX19P8AAA-_ XTAE115G00A_ 208 25 30 208 ECX19P1EAA-_ ECX19P4EAA-_ ECX19P8EAA-_ XTAE115G00E_ 230 25 40 240 ECX19P1BAA-_ ECX19P4BAA-_ ECX19P8BAA-_ XTAE115G00B_ 380 — 60 380/50 Hz ECX19P1LAA-_ ECX19P4LAA-_ ECX19P8LAA-_ XTAE115G00L_ 460 — 75 480 ECX19P1CAA-_ ECX19P4CAA-_ ECX19P8CAA-_ XTAE115G00C_ 575 — 100 600 ECX19P1DAA-_ ECX19P4DAA-_ ECX19P8DAA-_ XTAE115G00D_ 6 Size P 6 105 3 15 380 6 95 3 230 Size M 80 3 Coil Voltage Fuse at 60 Hz 2 Clips 6 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX19L4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 6 Non-fused disconnect only. 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-25 3.1 3 IEC Contactors and Starters XT IEC Power Control Class ECX20—Combination Reversing Starter—Fusible/Non-Fusible Disconnect Maximum hp 1 Type 4X/IP66 5 Type 1/IP23 Type 12/IP65 Component Single-Phase Three-Phase Coil Voltage Fuse at 60 Hz 3 Clips — — — — ECX20B1AAA-_ ECX20B4AAA-_ ECX20B8AAA-_ 3 115 1/4 — 120 ECX20B1AAC-_ ECX20B4AAC-_ ECX20B8AAC-_ XTAR007B10A_ 208 3/4 1-1/2 208 ECX20B1EAC-_ ECX20B4EAC-_ ECX20B8EAC-_ XTAR007B10E_ 3 230 1 2 240 ECX20B1BAC-_ ECX20B4BAC-_ ECX20B8BAC-_ XTAR007B10B_ 3 380 — 3 380/50 Hz ECX20B1LAC-_ ECX20B4LAC-_ ECX20B8LAC-_ XTAR007B10L_ 460 — 3 480 ECX20B1CAC-_ ECX20B4CAC-_ ECX20B8CAC-_ XTAR007B10C_ 575 — 5 600 ECX20B1DAC-_ ECX20B4DAC-_ ECX20B8DAC-_ XTAR007B10D_ — — — — ECX20C1AAA-_ ECX20C4AAA-_ ECX20C8AAA-_ XTAR009B10A_ 115 1/2 — 120 ECX20C1AAC-_ ECX20C4AAC-_ ECX20C8AAC-_ XTAR009B10A_ 3 Amps 3 7 3 3 Motor Voltage 2 Catalog Number 4 Catalog Number 4 Catalog Number 4 Catalog Number 4 Size B 30 A XTAR007B10A_ Size C 9 30 A 3 208 1 2 208 ECX20C1EAC-_ ECX20C4EAC-_ ECX20C8EAC-_ XTAR009B10E_ 3 230 1-1/2 3 240 ECX20C1BAC-_ ECX20C4BAC-_ ECX20C8BAC-_ XTAR009B10B_ 380 — 5 380/50 Hz ECX20C1LAC-_ ECX20C4LAC-_ ECX20C8LAC-_ XTAR009B10L_ 460 — 5 480 ECX20C1CAC-_ ECX20C4CAC-_ ECX20C8CAC-_ XTAR009B10C_ 575 — 7-1/2 600 ECX20C1DAC-_ ECX20C4DAC-_ ECX20C8DAC-_ XTAR009B10D_ XTAR012B10A_ 3 3 Size D 12 — — — — ECX20D1AAA-_ ECX20D4AAA-_ ECX20D8AAA-_ 3 115 1/2 — 120 30 A ECX20D1AAC-_ ECX20D4AAC-_ ECX20D8AAC-_ XTAR012B10A_ 3 208 1-1/2 3 208 ECX20D1EAC-_ ECX20D4EAC-_ ECX20D8EAC-_ XTAR012B10E_ 230 2 3 240 ECX20D1BAC-_ ECX20D4BAC-_ ECX20D8BAC-_ XTAR012B10B_ 3 380 — 5 380/50 Hz ECX20D1LAC-_ ECX20D4LAC-_ ECX20D8LAC-_ XTAR012B10L_ 460 — 7-1/2 480 ECX20D1CAC-_ ECX20D4CAC-_ ECX20D8CAC-_ XTAR012B10C_ 3 575 — 10 600 ECX20D1DAC-_ ECX20D4DAC-_ ECX20D8DAC-_ XTAR012B10D_ XTAR015B10A_ 3 Size E — — — — ECX20E1AAA-_ ECX20E4AAA-_ ECX20E8AAA-_ 3 115 3/4 — 120 ECX20E1AAC-_ ECX20E4AAC-_ ECX20E8AAC-_ XTAR015B10A_ 208 2 3 208 ECX20E1EAC-_ ECX20E4EAC-_ ECX20E8EAC-_ XTAR015B10E_ 3 230 2 3 240 ECX20E1BAC-_ ECX20E4BAC-_ ECX20E8BAC-_ XTAR015B10B_ 3 3 3 3 3 15 30 A 380 — 5 380/50 Hz ECX20E1LAC-_ ECX20E4LAC-_ ECX20E8LAC-_ XTAR015B10L_ 460 — 7-1/2 480 ECX20E1CAC-_ ECX20E4CAC-_ ECX20E8CAC-_ XTAR015B10C_ 575 — 10 600 ECX20E1DAC-_ ECX20E4DAC-_ ECX20E8DAC-_ XTAR015B10D_ Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX20B4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 3 3 V10-T3-26 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com IEC Contactors and Starters XT IEC Power Control 3.1 Class ECX20—Combination Reversing Starter—Fusible/Non-Fusible Disconnect, continued Maximum hp 1 Amps Motor Voltage 2 Single-Phase Three-Phase Type 1/IP23 Type 4X/IP66 5 Type 12/IP65 Component Catalog Number 4 Catalog Number 4 Catalog Number 4 Catalog Number 4 3 3 Size F 18 — — — — ECX20F1AAA-_ ECX20F4AAA-_ ECX20F8AAA-_ XTAR018C10A_ 115 2 — 120 30 A ECX20F1AAC-_ ECX20F4AAC-_ ECX20F8AAC-_ XTAR018C10A_ 208 2 5 208 ECX20F1EAC-_ ECX20F4EAC-_ ECX20F8EAC-_ XTAR018C10E_ 5 240 ECX20F1BAC-_ ECX20F4BAC-_ ECX20F8BAC-_ XTAR018C10B_ — 7-1/2 380/50 Hz ECX20F1LAC-_ ECX20F4LAC-_ ECX20F8LAC-_ XTAR018C10L_ 460 — 10 480 ECX20F1CAC-_ ECX20F4CAC-_ ECX20F8CAC-_ XTAR018C10C_ 575 — 15 600 ECX20F1DAC-_ ECX20F4DAC-_ ECX20F8DAC-_ XTAR018C10D_ 3 3 30 A — — — — ECX20G1AAA-_ ECX20G4AAA-_ ECX20G8AAA-_ XTAR025C10A_ 2 — 120 ECX20G1AAC-_ ECX20G4AAC-_ ECX20G8AAC-_ XTAR025C10A_ 208 3 7-1/2 208 ECX20G1EAC-_ ECX20G4EAC-_ ECX20G8EAC-_ XTAR025C10E_ 230 5 7-1/2 240 ECX20G1BAC-_ ECX20G4BAC-_ ECX20G8BAC-_ XTAR025C10B_ 380 — 10 380/50 Hz ECX20G1LAC-_ ECX20G4LAC-_ ECX20G8LAC-_ XTAR025C10L_ 460 — 15 480 ECX20G1CAC-_ ECX20G4CAC-_ ECX20G8CAC-_ XTAR025C10C_ 575 — 20 600 ECX20G1DAC-_ ECX20G4DAC-_ ECX20G8DAC-_ XTAR025C10D_ 3 — — — — ECX20H1AAA-_ ECX20H4AAA-_ ECX20H8AAA-_ XTAR032C10A_ 3 115 3 — 120 ECX20H1AAE-_ ECX20H4AAE-_ ECX20H8AAE-_ XTAR032C10A_ 208 5 10 208 ECX20H1EAE-_ ECX20H4EAE-_ ECX20H8EAE-_ XTAR032C10E_ 60 A 3 3 3 3 230 5 10 240 ECX20H1BAE-_ ECX20H4BAE-_ ECX20H8BAE-_ XTAR032C10B_ 380 — 15 380/50 Hz ECX20H1LAE-_ ECX20H4LAE-_ ECX20H8LAE-_ XTAR032C10L_ 460 — 20 480 ECX20H1CAE-_ ECX20H4CAE-_ ECX20H8CAE-_ XTAR032C10C_ 575 — 25 600 ECX20H1DAE-_ ECX20H4DAE-_ ECX20H8DAE-_ XTAR032C10D_ 3 3 — — — — ECX20J1AAA-_ ECX20J4AAA-_ ECX20J8AAA-_ XTAR040D00A_ 115 3 — 120 60 A ECX20J1AAE-_ ECX20J4AAE-_ ECX20J8AAE-_ XTAR040D00A_ 208 5 10 208 ECX20J1EAE-_ ECX20J4EAE-_ ECX20J8EAE-_ XTAR040D00E_ 230 7-1/2 15 240 ECX20J1BAE-_ ECX20J4BAE-_ ECX20J8BAE-_ XTAR040D00B_ 380 — 15 380/50 Hz ECX20J1LAE-_ ECX20J4LAE-_ ECX20J8LAE-_ XTAR040D00L_ 460 — 30 480 ECX20J1CAE-_ ECX20J4CAE-_ ECX20J8CAE-_ XTAR040D00C_ 575 — 40 600 ECX20J1DAE-_ ECX20J4DAE-_ ECX20J8DAE-_ XTAR040D00D_ — — — — ECX20K1AAA-_ ECX20K4AAA-_ ECX20K8AAA-_ XTAR050D00A_ 115 3 — 120 ECX20K1AAG-_ ECX20K4AAG-_ ECX20K8AAG-_ XTAR050D00A_ 208 7-1/2 15 208 ECX20K1EAG-_ ECX20K4EAG-_ ECX20K8EAG-_ XTAR050D00E_ 230 10 20 240 ECX20K1BAG-_ ECX20K4BAG-_ ECX20K8BAG-_ XTAR050D00B_ 380 — 20 380/50 Hz ECX20K1LAG-_ ECX20K4LAG-_ ECX20K8LAG-_ XTAR050D00L_ 460 — 40 480 ECX20K1CAG-_ ECX20K4CAG-_ ECX20K8CAG-_ XTAR050D00C_ 575 — 50 600 ECX20K1DAG-_ ECX20K4DAG-_ ECX20K8DAG-_ XTAR050D00D_ Size K 50 3 115 Size J 40 3 3 380 Size H 32 3 230 Size G 25 3 Coil Voltage Fuse at 60 Hz 3 Clips 100 A 3 3 3 3 3 3 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX20F4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-27 3.1 3 IEC Contactors and Starters XT IEC Power Control Class ECX20—Combination Reversing Starter—Fusible/Non-Fusible Disconnect, continued Maximum hp 1 Type 4X/IP66 5 Type 1/IP23 Type 12/IP65 Component Single-Phase Three-Phase Coil Voltage Fuse at 60 Hz 3 Clips — — — — ECX20L1AAA-_ ECX20L4AAA-_ ECX20L8AAA-_ 3 115 5 — 120 ECX20L1AAG-_ ECX20L4AAG-_ ECX20L8AAG-_ XTAR065D00A_ 208 10 20 208 ECX20L1EAG-_ ECX20L4EAG-_ ECX20L8EAG-_ XTAR065D00E_ 3 230 15 25 240 ECX20L1BAG-_ ECX20L4BAG-_ ECX20L8BAG-_ XTAR065D00B_ 3 380 — 30 380/50 Hz ECX20L1LAG-_ ECX20L4LAG-_ ECX20L8LAG-_ XTAR065D00L_ 460 — 50 480 ECX20L1CAG-_ ECX20L4CAG-_ ECX20L8CAG-_ XTAR065D00C_ 575 — 60 600 ECX20L1DAG-_ ECX20L4DAG-_ ECX20L8DAG-_ XTAR065D00D_ — — — — ECX20M1AAA-_ ECX20M4AAA-_ ECX20M8AAA-_ XTAR080F00A_ 115 7-1/2 — 120 ECX20M1AAG-_ ECX20M4AAG-_ ECX20M8AAG-_ XTAR080F00A_ 3 208 15 25 208 ECX20M1EAG-_ ECX20M4EAG-_ ECX20M8EAG-_ XTAR080F00E_ 3 230 15 30 240 ECX20M1BAG-_ ECX20M4BAG-_ ECX20M8BAG-_ XTAR080F00B_ 380 — 50 380/50 Hz ECX20M1LAG-_ ECX20M4LAG-_ ECX20M8LAG-_ XTAR080F00L_ 460 — 60 480 ECX20M1CAG-_ ECX20M4CAG-_ ECX20M8CAG-_ XTAR080F00C_ 575 — 75 600 ECX20M1DAG-_ ECX20M4DAG-_ ECX20M8DAG-_ XTAR080F00D_ 3 3 3 3 Amps Catalog Number 4 Catalog Number 4 Catalog Number 4 Catalog Number 4 Size L 65 100 A XTAR065D00A_ Size M 80 3 3 Motor Voltage 2 100 A Size N 6 6 — — — — ECX20N1AAA-_ ECX20N4AAA-_ ECX20N8AAA-_ XTAR095F00A_ 3 115 7-1/2 — 120 ECX20N1AAA-_ ECX20N4AAA-_ ECX20N8AAA-_ XTAR095F00A_ 3 208 15 25 208 ECX20N1EAA-_ ECX20N4EAA-_ ECX20N8EAA-_ XTAR095F00E_ 230 15 40 240 ECX20N1BAA-_ ECX20N4BAA-_ ECX20N8BAA-_ XTAR095F00B_ 3 380 — 60 380/50 Hz ECX20N1LAA-_ ECX20N4LAA-_ ECX20N8LAA-_ XTAR095F00L_ 460 — 75 480 ECX20N1CAA-_ ECX20N4CAA-_ ECX20N8CAA-_ XTAR095F00C_ 3 575 — 100 600 ECX20N1DAA-_ ECX20N4DAA-_ ECX20N8DAA-_ XTAR095F00D_ — — — — ECX20P1AAA-_ ECX20P4AAA-_ ECX20P8AAA-_ XTAR115G00A_ 3 115 10 — 120 ECX20P1AAA-_ ECX20P4AAA-_ ECX20P8AAA-_ XTAR115G00A_ 208 25 30 208 ECX20P1EAA-_ ECX20P4EAA-_ ECX20P8EAA-_ XTAR115G00E_ 3 230 25 40 240 ECX20P1BAA-_ ECX20P4BAA-_ ECX20P8BAA-_ XTAR115G00B_ 380 — 60 380/50 Hz ECX20P1LAA-_ ECX20P4LAA-_ ECX20P8LAA-_ XTAR115G00L_ 460 — 75 480 ECX20P1CAA-_ ECX20P4CAA-_ ECX20P8CAA-_ XTAR115G00C_ 575 — 100 600 ECX20P1DAA-_ ECX20P4DAA- ECX20P8DAA-_ XTAR115G00D_ 3 3 3 3 3 3 3 95 Size P 6 105 6 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX20L4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 6 Non-fused disconnect only. 3 3 3 3 3 V10-T3-28 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com IEC Contactors and Starters XT IEC Power Control 3.1 Class ECX25—Combination Non-Reversing Starter—Circuit Breaker Maximum hp 1 Amps Motor Voltage 2 Single-Phase Three-Phase Type 4X/IP66 5 Type 12/IP65 Component Catalog Number 4 Catalog Number 4 Catalog Number 4 3 3 Size B 7 115 1/4 — 120 ECX25B1AAC-_ ECX25B4AAC-_ ECX25B8AAC-_ XTAE007B10A_ 208 3/4 1-1/2 208 7A ECX25B1EAC-_ ECX25B4EAC-_ ECX25B8EAC-_ XTAE007B10E_ 230 1 2 240 ECX25B1BAC-_ ECX25B4BAC-_ ECX25B8BAC-_ XTAE007B10B_ 380 — 3 380/50 Hz ECX25B1LAC-_ ECX25B4LAC-_ ECX25B8LAC-_ XTAE007B10L_ 460 — 3 480 ECX25B1CAC-_ ECX25B4CAC-_ ECX25B8CAC-_ XTAE007B10C_ 575 — 5 600 ECX25B1DAC-_ ECX25B4DAC-_ ECX25B8DAC-_ XTAE007B10D_ 115 1/2 — 120 ECX25C1AAD-_ ECX25C4AAD-_ ECX25C8AAD-_ XTAE009B10A_ Size C 9 15 A 208 1 2 208 ECX25C1EAD-_ ECX25C4EAD-_ ECX25C8EAD-_ XTAE009B10E_ 230 1-1/2 3 240 ECX25C1BAD-_ ECX25C4BAD-_ ECX25C8BAD-_ XTAE009B10B_ 380 — 5 380/50 Hz ECX25C1LAD-_ ECX25C4LAD-_ ECX25C8LAD-_ XTAE009B10L_ 460 — 5 480 ECX25C1CAD-_ ECX25C4CAD-_ ECX25C8CAD-_ XTAE009B10C_ 575 — 7-1/2 600 ECX25C1DAD-_ ECX25C4DAD-_ ECX25C8DAD-_ XTAE009B10D_ 115 1/2 — 120 ECX25D1AAD-_ ECX25D4AAD-_ ECX25D8AAD-_ XTAE012B10A_ 208 1-1/2 3 208 ECX25D1EAD-_ ECX25D4EAD-_ ECX25D8EAD-_ XTAE012B10E_ 230 2 3 240 ECX25D1BAD-_ ECX25D4BAD-_ ECX25D8BAD-_ XTAE012B10B_ Size D 12 15 A 3 3 3 3 3 3 3 3 3 — 5 380/50 Hz ECX25D1LAD-_ ECX25D4LAD-_ ECX25D8LAD-_ XTAE012B10L_ 460 — 7-1/2 480 ECX25D1CAD-_ ECX25D4CAD-_ ECX25D8CAD-_ XTAE012B10C_ 575 — 10 600 ECX25D1DAD-_ ECX25D4DAD-_ ECX25D8DAD-_ XTAE012B10D_ 3 115 3/4 — 120 ECX25E1AAE-_ ECX25E4AAE-_ ECX25E8AAE-_ XTAE015B10A_ 3 208 2 3 208 ECX25E1EAE-_ ECX25E4EAE-_ ECX25E8EAE-_ XTAE015B10E_ 230 2 3 240 ECX25E1BAE-_ ECX25E4BAE-_ ECX25E8BAE-_ XTAE015B10B_ 30 A 3 3 380 — 5 380/50 Hz ECX25E1LAE-_ ECX25E4LAE-_ ECX25E8LAE-_ XTAE015B10L_ 460 — 7-1/2 480 ECX25E1CAE-_ ECX25E4CAE-_ ECX25E8CAE-_ XTAE015B10C_ 575 — 10 600 ECX25E1DAE-_ ECX25E4DAE-_ ECX25E8DAE-_ XTAE015B10D_ 3 115 2 — 120 ECX25F1AAE-_ ECX25F4AAE-_ ECX25F8AAE-_ XTAE018C10A_ 3 208 2 5 208 ECX25F1EAE-_ ECX25F4EAE-_ ECX25F8EAE-_ XTAE018C10E_ 230 3 5 240 ECX25F1BAE-_ ECX25F4BAE-_ ECX25F8BAE-_ XTAE018C10B_ 380 — 7-1/2 380/50 Hz ECX25F1LAE-_ ECX25F4LAE-_ ECX25F8LAE-_ XTAE018C10L_ 460 — 10 480 ECX25F1CAE-_ ECX25F4CAE-_ ECX25F8CAE-_ XTAE018C10C_ 575 — 15 600 ECX25F1DAE-_ ECX25F4DAE-_ ECX25F8DAE-_ XTAE018C10D_ Size F 18 3 380 Size E 15 3 Type 1/IP23 Coil Voltage Circuit at 60 Hz 3 Breaker Catalog Number 4 30 A 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX25B4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-29 3.1 3 IEC Contactors and Starters XT IEC Power Control Class ECX25—Combination Non-Reversing Starter—Circuit Breaker, continued Maximum hp 1 3 Amps 3 25 Motor Voltage 2 Single-Phase Three-Phase Type 1/IP23 Coil Voltage Circuit 3 at 60 Hz Breaker Catalog Number 4 Type 4X/IP66 5 Catalog Number Type 12/IP65 4 Catalog Number Component 4 Catalog Number 4 Size G 115 2 — 120 ECX25G1AAF-_ ECX25G4AAF-_ ECX25G8AAF-_ XTAE025C10A_ 3 208 3 7-1/2 208 ECX25G1EAF-_ ECX25G4EAF-_ ECX25G8EAF-_ XTAE025C10E_ 230 5 7-1/2 240 ECX25G1BAF-_ ECX25G4BAF-_ ECX25G8BAF-_ XTAE025C10B_ 3 380 — 10 380/50 Hz ECX25G1LAF-_ ECX25G4LAF-_ ECX25G8LAF-_ XTAE025C10L_ 3 460 — 15 480 ECX25G1CAF-_ ECX25G4CAF-_ ECX25G8CAF-_ XTAE025C10C_ 575 — 20 600 ECX25G1DAF-_ ECX25G4DAF-_ ECX25G8DAF-_ XTAE025C10D_ 115 3 — 120 ECX25H1AAF-_ ECX25H4AAF-_ ECX25H8AAF-_ XTAE032C10A_ 208 5 10 208 ECX25H1EAF-_ ECX25H4EAF-_ ECX25H8EAF-_ XTAE032C10E_ 3 Size H 32 3 3 3 3 50 A 50 A 230 5 10 240 ECX25H1BAF-_ ECX25H4BAF-_ ECX25H8BAF-_ XTAE032C10B_ 380 — 15 380/50 Hz ECX25H1LAF-_ ECX25H4LAF-_ ECX25H8LAF-_ XTAE032C10L_ 460 — 20 480 ECX25H1CAF-_ ECX25H4CAF-_ ECX25H8CAF-_ XTAE032C10C_ 575 — 25 600 ECX25H1DAF-_ ECX25H4DAF-_ ECX25H8DAF-_ XTAE032C10D_ 115 3 — 120 ECX25J1AAF-_ ECX25J4AAF-_ ECX25J8AAF-_ XTAE040D00A_ 208 5 10 208 ECX25J1EAF-_ ECX25J4EAF-_ ECX25J8EAF-_ XTAE040D00E_ Size J 40 3 50 A 230 7-1/2 15 240 ECX25J1BAF-_ ECX25J4BAF-_ ECX25J8BAF-_ XTAE040D00B_ 3 380 — 15 380/50 Hz ECX25J1LAF-_ ECX25J4LAF-_ ECX25J8LAF-_ XTAE040D00L_ 3 460 — 30 480 ECX25J1CAF-_ ECX25J4CAF-_ ECX25J8CAF-_ XTAE040D00C_ 575 — 40 600 ECX25J1DAF-_ ECX25J4DAF-_ ECX25J8DAF-_ XTAE040D00D_ 115 3 — 120 ECX25K1AAW-_ ECX25K4AAW-_ ECX25K8AAW-_ XTAE050D00A_ 3 208 7-1/2 15 208 ECX25K1EAW-_ ECX25K4EAW-_ ECX25K8EAW-_ XTAE050D00E_ 3 230 10 20 240 ECX25K1BAW-_ ECX25K4BAW-_ ECX25K8BAW-_ XTAE050D00B_ 380 — 20 380/50 Hz ECX25K1LAW-_ ECX25K4LAW-_ ECX25K8LAW-_ XTAE050D00L_ 460 — 40 480 ECX25K1CAW-_ ECX25K4CAW-_ ECX25K8CAW-_ XTAE050D00C_ 575 — 50 600 ECX25K1DAW-_ ECX25K4DAW-_ ECX25K8DAW-_ XTAE050D00D_ 115 5 — 120 ECX25L1AAW-_ ECX25L4AAW-_ ECX25L8AAW-_ XTAE065D00A_ 3 208 10 20 208 ECX25L1EAW-_ ECX25L4EAW-_ ECX25L8EAW-_ XTAE065D00E_ 3 230 15 25 240 ECX25L1BAW-_ ECX25L4BAW-_ ECX25L8BAW-_ XTAE065D00B_ 380 — 30 380/50 Hz ECX25L1LAW-_ ECX25L4LAW-_ ECX25L8LAW-_ XTAE065D00L_ 460 — 50 480 ECX25L1CAW-_ ECX25L4CAW-_ ECX25L8CAW-_ XTAE065D00C_ 575 — 60 600 ECX25L1DAW-_ ECX25L4DAW-_ ECX25L8DAW-_ XTAE065D00D_ 3 Size K 50 3 3 3 3 3 3 3 70 A Size L 65 70 A Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX25G4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 V10-T3-30 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com IEC Contactors and Starters XT IEC Power Control 3.1 Class ECX25—Combination Non-Reversing Starter—Circuit Breaker, continued Maximum hp 1 Amps Motor Voltage 2 Single-Phase Three-Phase Type 4X/IP66 5 Type 12/IP65 Component Catalog Number 4 Catalog Number 4 Catalog Number 4 3 3 Size M 80 115 7-1/2 — 120 ECX25M1AAG-_ ECX25M4AAG-_ ECX25M8AAG-_ XTAE080F00A_ 208 15 25 208 100 A ECX25M1EAG-_ ECX25M4EAG-_ ECX25M8EAG-_ XTAE080F00E_ 230 15 30 240 ECX25M1BAG-_ ECX25M4BAG-_ ECX25M8BAG-_ XTAE080F00B_ 380 — 50 380/50 Hz ECX25M1LAG-_ ECX25M4LAG-_ ECX25M8LAG-_ XTAE080F00L_ 460 — 60 480 ECX25M1CAG-_ ECX25M4CAG-_ ECX25M8CAG-_ XTAE080F00C_ 575 — 75 600 ECX25M1DAG-_ ECX25M4DAG-_ ECX25M8DAG-_ XTAE080F00D_ 115 7-1/2 — 120 ECX25N1AAG-_ ECX25N4AAG-_ ECX25N8AAG-_ XTAE095F00A_ 208 15 25 208 ECX25N1EAG-_ ECX25N4EAG-_ ECX25N8EAG-_ XTAE095F00E_ 230 15 40 240 ECX25N1BAG-_ ECX25N4BAG-_ ECX25N8BAG-_ XTAE095F00B_ 380 — 60 380/50 Hz ECX25N1LAG-_ ECX25N4LAG-_ ECX25N8LAG-_ XTAE095F00L_ 460 — 75 480 ECX25N1CAG-_ ECX25N4CAG-_ ECX25N8CAG-_ XTAE095F00C_ 575 — 100 600 ECX25N1DAG-_ ECX25N4DAG-_ ECX25N8DAG-_ XTAE095F00D_ 115 10 — 120 ECX25P1AAH-_ ECX25P4AAH-_ ECX25P8AAH-_ XTAE115G00A_ 208 25 40 208 ECX25P1EAH-_ ECX25P4EAH-_ ECX25P8EAH-_ XTAE115G00E_ 230 25 50 240 ECX25P1BAH-_ ECX25P4BAH-_ ECX25P8BAH-_ XTAE115G00B_ 380 — 60 380/50 Hz ECX25P1LAH-_ ECX25P4LAH-_ ECX25P8LAH-_ XTAE115G00L_ 460 — 100 480 ECX25P1CAH-_ ECX25P4CAH-_ ECX25P8CAH-_ XTAE115G00C_ 575 — 125 600 ECX25P1DAH-_ ECX25P4DAH-_ ECX25P8DAH-_ XTAE115G00D_ 3 115 15 — 120 ECX25Q1AAH-_ ECX25Q4AAH-_ ECX25Q8AAH-_ XTAE150G00A_ 3 208 25 40 208 ECX25Q1EAH-_ ECX25Q4EAH-_ ECX25Q8EAH-_ XTAE150G00E_ 230 25 50 240 ECX25Q1BAH-_ ECX25Q4BAH-_ ECX25Q8BAH-_ XTAE150G00B_ 380 — 75 380/50 Hz ECX25Q1LAH-_ ECX25Q4LAH-_ ECX25Q8LAH-_ XTAE150G00L_ 460 — 100 480 ECX25Q1CAH-_ ECX25Q4CAH-_ ECX25Q8CAH-_ XTAE150G00C_ 575 — 125 600 ECX25Q1DAH-_ ECX25Q4DAH-_ ECX25Q8DAH-_ XTAE150G00D_ Size N 95 100 A Size P 115 150 A Size Q 125 3 Type 1/IP23 Coil Voltage Circuit at 60 Hz 3 Breaker Catalog Number 4 150 A 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX25M4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 3 3 3 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-31 3.1 3 IEC Contactors and Starters XT IEC Power Control Class ECX26—Combination Reversing Starter—Circuit Breaker Maximum hp 1 3 Amps 3 7 Motor Voltage 2 Single-Phase Three-Phase Type 1/IP23 Coil Voltage Circuit 3 at 60 Hz Breaker Catalog Number 4 Type 4X/IP66 5 Catalog Number Type 12/IP65 4 Catalog Number Component 4 Catalog Number 4 Size B 115 1/4 — 120 ECX26B1AAC-_ ECX26B4AAC-_ ECX26B8AAC-_ XTAR007B10A_ 3 208 3/4 1-1/2 208 ECX26B1EAC-_ ECX26B4EAC-_ ECX26B8EAC-_ XTAR007B10E_ 230 1 2 240 ECX26B1BAC-_ ECX26B4BAC-_ ECX26B8BAC-_ XTAR007B10B_ 3 380 — 3 380/50 Hz ECX26B1LAC-_ ECX26B4LAC-_ ECX26B8LAC-_ XTAR007B10L_ 3 460 — 3 480 ECX26B1CAC-_ ECX26B4CAC-_ ECX26B8CAC-_ XTAR007B10C_ 575 — 5 600 ECX26B1DAC-_ ECX26B4DAC-_ ECX26B8DAC-_ XTAR007B10D_ 3 7A Size C 9 115 1/2 — 120 ECX26C1AAD-_ ECX26C4AAD-_ ECX26C8AAD-_ XTAR009B10A_ 208 1 2 208 ECX26C1EAD-_ ECX26C4EAD-_ ECX26C8EAD-_ XTAR009B10E_ 230 1-1/2 3 240 ECX26C1BAD-_ ECX26C4BAD-_ ECX26C8BAD-_ XTAR009B10B_ 380 — 5 380/50 Hz ECX26C1LAD-_ ECX26C4LAD-_ ECX26C8LAD-_ XTAR009B10L_ 460 — 5 480 ECX26C1CAD-_ ECX26C4CAD-_ ECX26C8CAD-_ XTAR009B10C_ 575 — 7-1/2 600 ECX26C1DAD-_ ECX26C4DAD-_ ECX26C8DAD-_ XTAR009B10D_ 115 1/2 — 120 ECX26D1AAD-_ ECX26D4AAD-_ ECX26D8AAD-_ XTAR012B10A_ 208 1-1/2 3 208 ECX26D1EAD-_ ECX26D4EAD-_ ECX26D8EAD-_ XTAR012B10E_ 230 2 3 240 ECX26D1BAD-_ ECX26D4BAD-_ ECX26D8BAD-_ XTAR012B10B_ 3 380 — 5 380/50 Hz ECX26D1LAD-_ ECX26D4LAD-_ ECX26D8LAD-_ XTAR012B10L_ 3 460 — 7-1/2 480 ECX26D1CAD-_ ECX26D4CAD-_ ECX26D8CAD-_ XTAR012B10C_ 575 — 10 600 ECX26D1DAD-_ ECX26D4DAD-_ ECX26D8DAD-_ XTAR012B10D_ 115 3/4 — 120 ECX26E1AAE-_ ECX26E4AAE-_ ECX26E8AAE-_ XTAR015B10A_ 3 208 2 3 208 ECX26E1EAE-_ ECX26E4EAE-_ ECX26E8EAE-_ XTAR015B10E_ 3 230 2 3 240 ECX26E1BAE-_ ECX26E4BAE-_ ECX26E8BAE-_ XTAR015B10B_ 380 — 5 380/50 Hz ECX26E1LAE-_ ECX26E4LAE-_ ECX26E8LAE-_ XTAR015B10L_ 460 — 7-1/2 480 ECX26E1CAE-_ ECX26E4CAE-_ ECX26E8CAE-_ XTAR015B10C_ 575 — 10 600 ECX26E1DAE-_ ECX26E4DAE-_ ECX26E8DAE-_ XTAR015B10D_ 115 2 — 120 ECX26F1AAE-_ ECX26F4AAE-_ ECX26F8AAE-_ XTAR018C10A_ 3 208 2 5 208 ECX26F1EAE-_ ECX26F4EAE-_ ECX26F8EAE-_ XTAR018C10E_ 3 230 3 5 240 ECX26F1BAE-_ ECX26F4BAE-_ ECX26F8BAE-_ XTAR018C10B_ 380 — 7-1/2 380/50 Hz ECX26F1LAE-_ ECX26F4LAE-_ ECX26F8LAE-_ XTAR018C10L_ 460 — 10 480 ECX26F1CAE-_ ECX26F4CAE-_ ECX26F8CAE-_ XTAR018C10C_ 575 — 15 600 ECX26F1DAE-_ ECX26F4DAE-_ ECX26F8DAE-_ XTAR018C10D_ 3 3 3 3 Size D 12 3 3 3 3 3 3 3 15 A Size E 15 3 3 15 A 30 A Size F 18 30 A Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX26B4AAA-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 V10-T3-32 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com IEC Contactors and Starters XT IEC Power Control 3.1 Class ECX26—Combination Reversing Starter—Circuit Breaker, continued Maximum hp 1 Amps Motor Voltage 2 Single-Phase Three-Phase Type 4X/IP66 5 Type 12/IP65 Component Catalog Number 4 Catalog Number 4 Catalog Number 4 3 3 Size G 25 115 2 — 120 ECX26G1AAF-_ ECX26G4AAF-_ ECX26G8AAF-_ XTAR025C10A_ 208 3 7-1/2 208 50 A ECX26G1EAF-_ ECX26G4EAF-_ ECX26G8EAF-_ XTAR025C10E_ 230 5 7-1/2 240 ECX26G1BAF-_ ECX26G4BAF-_ ECX26G8BAF-_ XTAR025C10B_ 380 — 10 380/50 Hz ECX26G1LAF-_ ECX26G4LAF-_ ECX26G8LAF-_ XTAR025C10L_ 460 — 15 480 ECX26G1CAF-_ ECX26G4CAF-_ ECX26G8CAF-_ XTAR025C10C_ 575 — 20 600 ECX26G1DAF-_ ECX26G4DAF-_ ECX26G8DAF-_ XTAR025C10D_ 115 3 — 120 ECX26H1AAF-_ ECX26H4AAF-_ ECX26H8AAF-_ XTAR032C10A_ 208 5 10 208 ECX26H1EAF-_ ECX26H4EAF-_ ECX26H8EAF-_ XTAR032C10E_ 230 5 10 240 ECX26H1BAF-_ ECX26H4BAF-_ ECX26H8BAF-_ XTAR032C10B_ 380 — 15 380/50 Hz ECX26H1LAF-_ ECX26H4LAF-_ ECX26H8LAF-_ XTAR032C10L_ 460 — 20 480 ECX26H1CAF-_ ECX26H4CAF-_ ECX26H8CAF-_ XTAR032C10C_ 575 — 25 600 ECX26H1DAF-_ ECX26H4DAF-_ ECX26H8DAF-_ XTAR032C10D_ 115 3 — 120 ECX26J1AAF-_ ECX26J4AAF-_ ECX26J8AAF-_ XTAR040D00A_ 208 5 10 208 ECX26J1EAF-_ ECX26J4EAF-_ ECX26J8EAF-_ XTAR040D00E_ 230 7-1/2 15 240 ECX26J1BAF-_ ECX26J4BAF-_ ECX26J8BAF-_ XTAR040D00B_ 380 — 15 380/50 Hz ECX26J1LAF-_ ECX26J4LAF-_ ECX26J8LAF-_ XTAR040D00L_ 460 — 30 480 ECX26J1CAF-_ ECX26J4CAF-_ ECX26J8CAF-_ XTAR040D00C_ 575 — 40 600 ECX26J1DAF-_ ECX26J4DAF-_ ECX26J8DAF-_ XTAR040D00D_ 3 115 3 — 120 ECX26K1AAW-_ ECX26K4AAW-_ ECX26K8AAW-_ XTAR050D00A_ 3 208 7-1/2 15 208 ECX26K1EAW-_ ECX26K4EAW-_ ECX26K8EAW-_ XTAR050D00E_ 230 10 20 240 ECX26K1BAW-_ ECX26K4BAW-_ ECX26K8BAW-_ XTAR050D00B_ 380 — 20 380/50 Hz ECX26K1LAW-_ ECX26K4LAW-_ ECX26K8LAW-_ XTAR050D00L_ 460 — 40 480 ECX26K1CAW-_ ECX26K4CAW-_ ECX26K8CAW-_ XTAR050D00C_ 575 — 50 600 ECX26K1DAW-_ ECX26K4DAW-_ ECX26K8DAW-_ XTAR050D00D_ 3 115 5 — 120 ECX26L1AAW-_ ECX26L4AAW-_ ECX26L8AAW-_ XTAR065D00A_ 3 208 10 20 208 ECX26L1EAW-_ ECX26L4EAW-_ ECX26L8EAW-_ XTAR065D00E_ 230 15 25 240 ECX26L1BAW-_ ECX26L4BAW-_ ECX26L8BAW-_ XTAR065D00B_ 380 — 30 380/50 Hz ECX26L1LAW-_ ECX26L4LAW-_ ECX26L8LAW-_ XTAR065D00L_ 460 — 50 480 ECX26L1CAW-_ ECX26L4CAW-_ ECX26L8CAW-_ XTAR065D00C_ 575 — 60 600 ECX26L1DAW-_ ECX26L4DAW-_ ECX26L8DAW-_ XTAR065D00D_ Size H 32 50 A Size J 40 50 A Size K 50 70 A Size L 65 3 Type 1/IP23 Coil Voltage Circuit at 60 Hz 3 Breaker Catalog Number 4 100 A 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX26G4AAF-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-33 3.1 3 IEC Contactors and Starters XT IEC Power Control Class ECX26—Combination Reversing Starter—Circuit Breaker, continued Maximum hp 1 Type 4X/IP66 5 Single-Phase Three-Phase Type 1/IP23 Coil Voltage Circuit 3 at 60 Hz Breaker Catalog Number 4 115 7-1/2 — 120 ECX26M1AAG-_ ECX26M4AAG-_ ECX26M8AAG-_ 3 208 15 25 208 ECX26M1EAG-_ ECX26M4EAG-_ ECX26M8EAG-_ XTAR080F00E_ 230 15 30 240 ECX26M1BAG-_ ECX26M4BAG-_ ECX26M8BAG-_ XTAR080F00B_ 3 380 — 50 380/50 Hz ECX26M1LAG-_ ECX26M4LAG-_ ECX26M8LAG-_ XTAR080F00L_ 3 460 — 60 480 ECX26M1CAG-_ ECX26M4CAG-_ ECX26M8CAG-_ XTAR080F00C_ 575 — 75 600 ECX26M1DAG-_ ECX26M4DAG-_ ECX26M8DAG-_ XTAR080F00D_ 115 7-1/2 — 120 ECX26N1AAG-_ ECX26N4AAG-_ ECX26N8AAG-_ XTAR095F00A_ 208 15 25 208 ECX26N1EAG-_ ECX26N4EAG-_ ECX26N8EAG-_ XTAR095F00E_ 230 15 40 240 ECX26N1BAG-_ ECX26N4BAG-_ ECX26N8BAG-_ XTAR095F00B_ 380 — 60 380/50 Hz ECX26N1LAG-_ ECX26N4LAG-_ ECX26N8LAG-_ XTAR095F00L_ 460 — 75 480 ECX26N1CAG-_ ECX26N4CAG-_ ECX26N8CAG-_ XTAR095F00C_ 575 — 100 600 ECX26N1DAG-_ ECX26N4DAG-_ ECX26N8DAG-_ XTAR095F00D_ 3 3 3 Amps 80 Catalog Number Component 4 Catalog Number 4 100 A XTAR080F00A_ Size N 95 3 3 3 Catalog Number Type 12/IP65 4 Size M 3 3 Motor Voltage 2 100 A Size P 115 115 10 — 120 ECX26P1AAH-_ ECX26P4AAH-_ ECX26P8AAH-_ XTAR115G00A_ 208 25 40 208 150 A ECX26P1EAH-_ ECX26P4EAH-_ ECX26P8EAH-_ XTAR115G00E_ 230 25 50 240 ECX26P1BAH-_ ECX26P4BAH-_ ECX26P8BAH-_ XTAR115G00B_ 3 380 — 60 380/50 Hz ECX26P1LAH-_ ECX26P4LAH-_ ECX26P8LAH-_ XTAR115G00L_ 3 460 — 100 480 ECX26P1CAH-_ ECX26P4CAH-_ ECX26P8CAH-_ XTAR115G00C_ 575 — 125 600 ECX26P1DAH-_ ECX26P4DAH-_ ECX26P8DAH-_ XTAR115G00D_ 3 3 3 3 Notes 1 1 hp = 0.746 kW. 2 Contact factory for other voltage options. 3 Voltage is listed at 60 Hz unless otherwise noted. Other voltages available upon request. 4 Select proper “XTOB” overload amperage range as per motor FLA, see Page V10-T3-9. 5 The catalog numbers listed in the Type 4X column are for Type 4X 304-Grade stainless steel, as indicated by the seventh digit. Example: ECX26M4AAG-_. To order Type 4X 316-Grade stainless steel, change that digit to 9. To order Type 4 painted steel, change that digit to 3. To order non-metallic, change that digit to 5. For details on these alternate enclosures, see Tab 13. 3 3 3 3 3 3 3 3 3 3 3 3 V10-T3-34 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com 3.1 IEC Contactors and Starters XT IEC Power Control Wiring Diagrams 3 Typical Wiring Diagram Hand M 01 L1 02 L2 03 L3 3 With Three-Position Selector Switch FVNR with Pushbutton Control OL T1 OFF 2/3 1 T2 A1 M M 3 A2 3 3/4 3 Motor Auto T3 Remote Auto Contact Motor Run 3 3 Control Power Transformer Option Stop Start A1 1 M 2/3 61 M 3/4 A2 95 M OL M 96 Motor Stopped 62/7 97 OL 01 L1 02 L2 03 L3 3 OL 3 3 Overload Tripped 3 98 3 96 1 3 3 Reversing Combination Starter Wiring 3 R 3 3 Three-Position Switch F 01 L1 02 L2 OL T1 Fwd 3 3 3 T2 L3 03 1 Motor OFF T3 3 5 3 Rev 96 OL 95 3 Fwd 3 Two- and Three-Position Switch For Stop 1 Rev FLS 3 2 R A1 F A2 Fwd Hand 6 3 1B F (If used) 1 OFF 1B RLS 5 4 R F A1 7 R 5 Rev A2 3 3 3 3 Auto Remote 3 Rev 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-35 3.1 3 3 IEC Contactors and Starters XT IEC Power Control Non-Combination Starters (Non-Reversing) Remote Pilot Devices Two-Wire Control 3 3/14 1 3 Not for Use with Auto Reset OL Relays 3 Three-Wire Control Start 3 Stop 3 3 3 3 3 3 Connections for Non-Reversing Starter 3/14 2/13 1 When More than One Pushbutton Station is Used, Omit Connector “A” and Connect per Sketch Below Start Start 3/14 Stop Stop 2/13 1 “A” Three-Phase Motor 3 3 Single-Phase Motor 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 V10-T3-36 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com 3.1 IEC Contactors and Starters XT IEC Power Control Non-Combination Starters (Reversing) SPDT Switch For 3 Connections for Reversing Starter Remote Control Stations 1 5 3 Contactors “F” and “R” are Mechanically Interlocked 3 Lines L1 L2 L3 Hold Down Pushbutton For 3 Rev 1 3 Reversing Starter Elementary Diagram F 3 R 5 Rev OL F T2 T3 R Pushbutton OL F For 3 AC Motor 3 R 3 2 4 Rev 3 T1 OL 3 “C” Stop 5 1 Stop For. Rev. 2 F 1 53 R 3 62 54 4 R 53 5 62 3 OL 95 61 F Pushbutton with FOR and REV Buttons Electrically Interlocked A1 F A2 96 3 A1 R A2 3 61 54 3 For 3 2 3 Rev 3 4 5 Stop 1 3 Three-Phase Motor 3 C400T Control Options 3 Local Control Options (If used) Full Voltage Non-Reversing Starters Figure A Yellow 2/13 Black 3/14 START/STOP Pushbuttons Start 3 4 Stop Red 1 Figure B 1 Figure D Two-Positon Selector Switch Yellow Hand Black Red 2 1 3 2 4 Auto Figure G 3 Overload Tripped 3 Black/White X1 3 X2 3 Black/White 3 Red 1 START/STOP Selector Switch 98 1 3 97 3 Red 4 Figure C 2 Three-Position Selector Switch 4 4 Red 3 96 Reset 95 1 Yellow To Coil Hand Remote Switch Black To Coil 3 Auto 3 OL Black 3 1 Start Figure E Pilot Light (Motor RUN) Connect to Coil Terminals “A1” and “A2” Black/White X1 X2 Black/White 3 Wire “C” 3 3 Figure F Pilot Light (Motor STOP) Connect to NC Interlock Black/White X1 Connect to OL X2 Terminal No. 96 Black/White 3 3 3 1 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-37 3.1 IEC Contactors and Starters XT IEC Power Control 3 Non-Reversing Cover Control 3 Type 1 C600M Control Options (To be used with Box 1 Only) Connections for Non-Reversing Starter Schematic Symbol Legend 3 Normally Open Auxiliary 3 Normally Closed Auxiliary Normally Open Momentary PB 3 Normally Closed Momentary PB 3 Contactor Coil 3 Red Pilot Light 3 Green Pilot Light 3 Normally Closed Overload Auxiliary Normally Open Overload Auxiliary 3 M22-XLED230-T: Used to lower voltage for pilot lights. 3 Two-position selector switch (STOP/START, OFF/ON) 3 3 Three-position selector switch (HOA) 3 Signifies Location of Side and Top Adder Auxiliary Referenced on Diagram Under Auxiliary Symbol 3 3 3 1/L1 OR SEPARATE CONTROL 3 STOP/START OR OFF/ON OVAL. OPTIONS SHOWN: RUN LIGHT AND OFF LIGHT 3 3/L2 OR SEPARATE CONTROL DASHED COMPONENTS ARE OPTIONAL USE AS REQUIRED FOR SELECTED COVER CONTROL OPTIONS RED RED REFERENCE NOTES BELOW FOR CONTROL POWER WIRING OPTIONS 3 STOP/OFF RED NC1 NC2 3 3 BLK M 2/13 R1 RED 4 T1 53 3 3 3 T1 62 A2 RED (BLU/WHT IF DC) 95 RUN 1 2 RED 1 2 RED R X1 X2 OFF BLK/WHT 1 2 RED 1 2 RED G X1 X2 54 1 OPTION FOR RUN LIGHT (RED TYPICAL) 2 REQUIRED FOR 480V OPTION 3 OPTION FOR OFF LIGHT (GREEN TYPICAL) (INCLUDES 1NO-1NC AUX) 4 1NO-1NC TOP ADDER AUX INCLUDED FOR COIL VOLTAGES 120V AND LESS FOR SEPARATE CONTROL. FOR HIGHER COIL VOLTAGES, 1/L1 IS CONNECTED TO PILOT DEVICE TERMINAL FOR COMMON CONTROL 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com OL 96 BLK/RED 3 3 V10-T3-38 M OL 97 2 M 3 1 3/14 M 61 3 A1 BLK/RED YEL 3 RED (BLU IF DC) START/ON NO4 NO3 BLK/WHT 98 IEC Contactors and Starters XT IEC Power Control 3.1 Type 1 C600M Control Options (To be used with Box 1 Only) 3 STOP/START OR OFF/ON 2-POSTION SELECTOR SWITCH OPTIONS SHOWN: RUN LIGHT, AND OFF LIGHT 1/L1 OR SEPARATE CONTROL 3 3/L2 OR SEPARATE CONTROL DASHED COMPONENTS ARE OPTIONAL USE AS REQUIRED FOR SELECTED COVER CONTROL OPTIONS RED 3 RED 3 REFERENCE NOTES BELOW FOR CONTROL POWER WIRING OPTIONS STOP/OFF 3/14 R1 RED 4 1 BLK/RED T1 62 T1 A2 RED (BLU/WHT IF DC) 95 OL 3 96 3 RUN 1 2 RED 1 2 RED R X1 X2 OL 97 3 98 2 3 BLK/WHT 3 3 M 53 M OFF BLK/WHT 1 2 RED 1 2 RED G X1 X2 M 61 A1 BLK/RED BLK M 2/13 RED (BLU IF DC) START/ON OX NO3 NO4 3 54 3 1 OPTION FOR RUN LIGHT (RED TYPICAL) 2 REQUIRED FOR 480V OPTION 3 OPTION FOR OFF LIGHT (GREEN TYPICAL) (INCLUDES 1NO-1NC AUX) 3 4 1NO-1NC TOP ADDER AUX INCLUDED FOR COIL VOLTAGES 120V AND LESS FOR SEPARATE CONTROL. FOR HIGHER COIL VOLTAGES, 1/L1 IS CONNECTED TO PILOT DEVICE TERMINAL FOR COMMON CONTROL 3 3 3 HAND/OFF/AUTO OR TEST/OFF/AUTO 3-POSTION SELECTOR SWITCH OPTIONS SHOWN: RUN LIGHT, AND OFF LIGHT 1/L1 OR SEPARATE CONTROL 3 3/L2 OR SEPARATE CONTROL DASHED COMPONENTS ARE OPTIONAL USE AS REQUIRED FOR SELECTED COVER CONTROL OPTIONS 3 REFERENCE NOTES BELOW FOR CONTROL POWER WIRING OPTIONS HAND/TEST 0 AUTO XOO NO4 NO3 YEL A1 A2 RED (BLU/WHT IF DC) 3 95 OL 3 96 RED (BLU/WHT IF DC) REMOTE SWITCH 1 M 2/13 NO4 M R1 3/14 RUN 1 2 RED 1 2 RED R X1 X2 3 OL 97 98 3 BLK/RED 3 2 OOX NO3 RED M 61 4 T1 62 T1 3 BLK/WHT 3 3 M 53 OFF BLK/WHT 1 2 RED 1 2 RED G X1 X2 3 54 3 1 OPTION FOR RUN LIGHT (RED TYPICAL) 2 REQUIRED FOR 480V OPTION 3 OPTION FOR OFF LIGHT (GREEN TYPICAL) (INCLUDES 1NO-1NC AUX) 3 4 1NO-1NC TOP ADDER AUX INCLUDED FOR COIL VOLTAGES 120V AND LESS FOR SEPARATE CONTROL. FOR HIGHER COIL VOLTAGES, 1/L1 IS CONNECTED TO PILOT DEVICE TERMINAL FOR COMMON CONTROL 3 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-39 3.1 3 3 IEC Contactors and Starters XT IEC Power Control Type 1 C600M Control Options (To be used with Box 1 Only) START/ON OR STOP/OFF PUSHBUTTON OPTIONS SHOWN: RUN LIGHT, AND OFF LIGHT 1/L1 OR SEPARATE CONTROL 3/L2 OR SEPARATE CONTROL DASHED COMPONENTS ARE OPTIONAL USE AS REQUIRED FOR SELECTED COVER CONTROL OPTIONS RED 3 RED REFERENCE NOTES BELOW FOR CONTROL POWER WIRING OPTIONS 3 NC2 3 NC1 R1 RED 3 5 T1 3 T1 M A2 RED (BLU/WHT IF DC) 95 OL 96 BLK/RED RUN 1 2 RED 1 2 RED R X1 X2 OL 97 98 2 62 OFF BLK/WHT 1 2 RED 1 2 RED G X1 X2 BLK/WHT 3 M 53 1 3/14 M 61 A1 BLK/RED BLK M 2/13 3 RED (BLU IF DC) STOP/OFF 4 54 3 3 4 3 YEL 3 3 3 START/ON NO4 NO3 BLK M 2/13 R1 3/14 WIRING FOR START/ON ONLY 3 3 1 OPTION FOR RUN LIGHT (RED TYPICAL) 2 REQUIRED FOR 480V OPTION 3 OPTION FOR OFF LIGHT (GREEN TYPICAL) (INCLUDES 1NO-1NC AUX) 4 OPTION FOR START/ON OR STOP/OFF PB 5 1NO-1NC TOP ADDER AUX INCLUDED FOR COIL VOLTAGES 120V AND LESS FOR SEPARATE CONTROL. FOR HIGHER COIL VOLTAGES, 1/L1 IS CONNECTED TO PILOT DEVICE TERMINAL FOR COMMON CONTROL 3 3 3 3 3 3 3 3 3 3 3 3 3 3 V10-T3-40 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com 3.1 IEC Contactors and Starters XT IEC Power Control Reversing Cover Control 3 Type 1 C600M Control Options (To be used with Box 1 Only) 3 Schematic Symbol Legend Normally Open Auxiliary 3 Normally Closed Auxiliary 3 Normally Open Momentary PB 3 Normally Closed Momentary PB Contactor Coil 3 Red Pilot Light 3 Green Pilot Light 3 3 Normally Closed Overload Auxiliary Normally Open Overload Auxiliary 3 M22-XLED230-T: Used to lower voltage for pilot lights. 3 Two-position selector switch (STOP/START, OFF/ON) 3 3 Three-position selector switch (HOA) 3 Signifies Location of Side and Top Adder Auxiliary Referenced on Diagram Under Auxiliary Symbol 3 3 3 REV/OFF/FWD OR DWN/OFF/UP 3-POSITION SELECTOR SWITCH OPTIONS SHOWN: REV/DWN LIGHT AND FWD/UP LIGHT 1/L1 OR SEPARATE CONTROL RED 3/L2 OR SEPARATE CONTROL RED DASHED COMPONENTS ARE OPTIONAL USE AS REQUIRED FOR SELECTED COVER CONTROL OPTIONS NO4 0 BLK FWD/UP OOX NO3 RED F 2/13/53 L1 3/14/54 R 6/22/62 R1 _/21/61 RED (BLU IF DC) 1 2 RED 1 2 R BLU XOO NO3 4/13/53 R1 RED 5/14/54 F 63 T1 RED (BLU IF DC) F 7/22/62 L1 63 T2 64 53 T1 53 T2 1 2 RED 1 2 2 R 54 R 3 BLK/RED X2 OL 97 3 98 RED (BLU IF DC) 3 A2 BLK/RED 3 F 1 FWD/UP R A1 3 RED (BLU IF DC) OL 95 96 X1 BLK/RED 3 REV/DWN X1 3 3 2 _/21/61 R 64 A2 BLK/RED RED NO4 F A1 RED REV/DWN RED Connections for Reversing Starter R X2 3 1 3 54 3 SEPARATE CONTROL WIRES REFERENCE NOTES BELOW FOR CONTROL POWER WIRING OPTIONS 1 OPTION FOR RUN LIGHT (RED TYPICAL) 2 REQUIRED FOR 480V OPTION 3 3 TWO 2NO TOP ADDER AUX INCLUDED FOR ALL COIL VOLTAGES. WHEN COIL VOLTAGES 120V AND LESS, CONTROL WIRING ROUTED TO NO. 63 TERMINAL FOR SEPARATE CONTROL. 3 3 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com V10-T3-41 3.1 IEC Contactors and Starters XT IEC Power Control 3 Type 1 C600M Control Options (To be used with Box 1 Only) 3 1/L1 OR SEPARATE CONTROL REV/FWD OR DWN/UP CUSTOMER CONTROL OPTIONS SHOWN: REV/DWN LIGHT AND FWD/UP LIGHT, OFF LIGHT DASHED COMPONENTS ARE OPTIONAL USE AS REQUIRED FOR SELECTED COVER CONTROL OPTIONS RED 3 RED F 2/13/53 3/14/54 L1 RED 3 RED (BLU IF DC) R 6/22/62 R1 _/21/61 2 3 RED R 4/13/53 5/14/54 R1 F 7/22/62 L1 BLK/RED 3 2 3 3 RED F 61 3 3 T1 61 64 63 T2 F 63 3 T1 BLK/WHT R 62 1 R A1 62 OL 95 FWD/UP 1 2 RED 1 2 RED R A1 A2 RED (BLU IF DC) _/21/61 RED RED (BLU/WHT IF DC) A2 BLK/RED CUSTOMER CONTROL CIRCUIT 3 F A1 3/L2 OR SEPARATE CONTROL 96 BLK/RED OL 97 98 RED (BLU IF DC) A2 BLK/RED REV/DWN 1 2 RED 1 2 RED R A1 A2 OFF 1 2 RED 1 2 RED G X1 X2 1 BLK/WHT R T2 64 4 F 53 3 T1 R 54 53 T2 54 NOT INCLUDED FOR SEPARATE CONTROL COIL VOLTAGES 120V AND LESS 3 3 3 1 OPTION FOR RUN LIGHT (RED TYPICAL) 2 REQUIRED FOR 480V OPTION 3 OPTION FOR OFF LIGHT (GREEN TYPICAL) (INCLUDES 1NO-1NC AUX IN PLACE OF 2NO AUX IN POSITION T1) 4 TWO 2NO TOP ADDER AUX INCLUDED FOR ALL COIL VOLTAGES EXCEPT WHEN OPTION FOR OFF LIGHT IS USED AND ONE 2NO TOP ADDER AUX IS SWAPPED OUT FOR ONE 1NO-1NC. 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 V10-T3-42 Volume 10—Enclosed Control CA08100012E—June 2015 www.eaton.com
ECX09C1AAA-R63/BL30 价格&库存
很抱歉,暂时无法提供与“ECX09C1AAA-R63/BL30”相匹配的价格&库存,您可以联系我们找货
