EM220504
EM220504
    EATON(伊顿)
    插件,P=5mm
    接线端子 1x4P 5mm 插件 排数:单排 每排Pin数:4
EM220504 数据手册
Cage & Screw EM2205 Series EuroMag Terminal Blocks 45° Angle, 5.00 Centers, Modular SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #12-24 AWG Housing Material: Grey Polyamide Type 6/6, 94V0 Contact Material: Brass Tin-Plated Cage Material: Brass, Tin-Plated Screw Size: M2.6 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -33°C (-27°F) min. Torque Rating: 3.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Poles L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 Compliance References Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Terminal Blocks To convert to inches, divide by 25.4 EM220505 Dimensions - mm (in) PCB Hole Layout Part Numbering System En Mn 2n 2n 0n 5 nn n Series # of Poles 02 to 24 For additional product information, visit www.eaton.com/connectors 42
EM220504 价格&库存
很抱歉,暂时无法提供与“EM220504”相匹配的价格&库存,您可以联系我们找货
