FNA-1/2
FNA-1/2
    EATON(伊顿)
    Cylindrical,Alarm Indicating,5AG,10x38.1mm
    FUSE CARTRIDGE 500MA 250VAC CYL
FNA-1/2 数据手册
Bussmann® Pin Indicating Type FNA Dual-Element, Time-Delay 1/10–30 Amps Dimensional Data Time-Current Characteristic Curves–Average Melt 0.406" (blown) AMPERE RATING 15 20 100 0.343" (blown) 0.343" 1 (50.004) 0.063" 1.5" (50.031) (not blown) 1.5" 10 .406" .406" .817" TIME IN SECONDS 0.063" 1 12-30A Dual Tube Construction CATALOG SYMBOL: FNA (5AG) ⁄Ω¡º-10A DUAL-ELEMENT, TIME-DELAY 1/10 TO 30 AMPERES U.L. LISTED: ⁄Ω¡º-°Ω¡ºA, IR 35A@ 250V IR 10kA@ 125V 1-15A, IR 10kA@ 125V (GUIDE # JDYX, FILE # E19180) CSA CERTIFIED 0-10/125V A (CLASS 1422-01, FILE # 53787) 125 Volts AC FNA-1 FNA-3 FNA-9 FNA-1/8 FNA-1-1/8 FNA-3-2/10 FNA-10 FNA-15/100 FNA-1-1/4 FNA-3-1/2 CURRENT IN AMPERES IR FNA-12 10,000A FNA-2/10 FNA-1-4/10 FNA-4 FNA-15 FNA-1/4 FNA-1-1/2 FNA-4-1/2 32 Volts AC† FNA-3/10 FNA-4/10 IR IR IR FNA-20 35A FNA-1-6/10 10,000A FNA-5 10,000A FNA-1-8/10 FNA-5-6/10 FNA-25 FNA-1/2 FNA-2 FNA-6 FNA-6/10 FNA-2-1/4 FNA-6-1/4 FNA-30 — FNA-3/4 FNA-2-1/2 FNA-7 — FNA-8/10 FNA-2-8/10 FNA-8 — *Interrupting rating of 10,000A at 125V AC. †Interrupting rating of 1,000A at 32V. 1,000 125 Volts AC IR FNA-1/10 100 250 Volts AC IR* 125 Volts AC IR 10 .01 Electrical Ratings (Catalog Symbol and Amperes) 1 .1 IR 1kA • Use in power electronic circuits in which there are high inrush currents and fuse openings must be quickly apparent. • Has silver-plated pin for positive, electrical signal activation. • FNAs larger than 10 amperes have dual-tube construction. • Mount in Buss fuseblock 3839 for signal indication. • Mount in HPF-C panel-mounted fuseholder or BM series fuseblocks for visual indication. CE logo denotes compliance with European Union Low Voltage Directive (50-1000V AC, 75-1500V DC). Refer to BIF document #8002 or contact Bussmann Application Engineering at 314-527-1270 for more information. Carton Quantity and Weight Ampere Ratings Carton Qty Weight Lbs. Kg. 0–10 100 1.5 0.650 12–30 100 3.0 1.36 The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 11-7-01 SB98107 Form No. FNA Page 1 of 1 BIF Doc #2029
FNA-1/2 价格&库存
很抱歉,暂时无法提供与“FNA-1/2”相匹配的价格&库存,您可以联系我们找货
