FNQ-R-1-1/4
FNQ-R-1-1/4
    EATON(伊顿)
    5AG,10.00 x 38.10mm
    FUSE CARTRIDGE 1.25A 600VAC 5AG
FNQ-R-1-1/4 数据手册
Bussmann® CC-TRON® FNQ-R Time-Delay Fuses ⁄‹Ω£™∑ ≈ 1⁄Ω™∑, 600 Volt, ⁄Ω¢ to 30 Amps Dimensional Data General Information: • The Bussmann CC-TRON® (FNQ-R) was designed to meet the needs of control circuit transformer protection. • Current-limitation protects down stream components against damaging thermal and magnetic effects of shortcircuit currents. • High inrush time-delay. Control circuit transformers can experience inrush currents up to 85 times their full-load current rating. FNQ-R fuses can be sized according to NEC and UL requirements and still allow the high inrush currents, with significantly more time-delay than the UL minimum value of 12 seconds at 200% for Class CC fuses. • Melamine tube. Nickel-plated brass endcaps. 1.5" (50.031) (38.1mm) .41" (50.005) (10.3mm) Catalog Symbol: FNQ-R Time-Delay Application: Circuit Transformer Protection Ampere Rating: ⁄Ω¢ to 30A Voltage Rating: 600Vac (or less)† Interrupting Rating: 200,000A RMS Sym. (UL) Agency Information: UL Listed, Std. 248-4, Class CC, Guide JDDZ, File E4273 CSA Certified, Class CC CSA, Class 1422-01, File 53787–HRC-MISC †12-30A is 300Vdc and 10k AIR. Maximum Acceptable Rating of Overcurrent Device* Rated Primary Current (Amperes) Maximum Rating of Overcurrent Protective Device Expressed As A Percent of Transformer Primary Current Rating Less than 2A 500** 2A to less than 9A 167 9A or more 125 *UL 508A Table 42.1. **300% for other than motor control applications. CE logo denotes compliance with European Union Low Voltage Directive (50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. Electrical Ratings (Catalog Symbol and Amperes) FNQ-R-⁄Ω¢ FNQ-R-1‹Ω¡º FNQ-R-3¤Ω¡º FNQ-R-8 FNQ-R-‹Ω¡º FNQ-R-1›Ω¡º FNQ-R-3⁄Ω™ FNQ-R-9 FNQ-R-›Ω¡º FNQ-R-1⁄Ω™ FNQ-R-4 FNQ-R-10 FNQ-R-⁄Ω™ FNQ-R-1flΩ¡º FNQ-R-4⁄Ω™ FNQ-R-12 FNQ-R-flΩ¡º FNQ-R-1°Ω¡º FNQ-R-5 FNQ-R-15 FNQ-R-‹Ω¢ FNQ-R-2 FNQ-R-5flΩ¡º FNQ-R-17⁄Ω™ FNQ-R-°Ω¡º FNQ-R-2⁄Ω¢ FNQ-R-6 FNQ-R-20 FNQ-R-1 FNQ-R-2⁄Ω™ FNQ-R-6⁄Ω¢ FNQ-R-25 FNQ-R-1⁄Ω• FNQ-R-2°Ω¡º FNQ-R-7 FNQ-R-30 FNQ-R-1⁄Ω¢ FNQ-R-3 FNQ-R-7⁄Ω™ — Carton Quantity and Weight Ampere Ratings ⁄Ω¢-30 Weight* Carton Qty. Lbs. Kg. 10 .200 .091 *Weight per carton 11-20-02 SB02450 Form No. FNQ-R Page 1 of 2 Data Sheet: 1014 Bussmann® CC-TRON® FNQ-R Time-Delay Fuses ⁄‹Ω£™∑ ≈ 1⁄Ω™∑, 600 Volt, ⁄Ω¢ to 30 Amps 1/2 6/10 3/4 8/10 1 1-1/8 1-1/4 1-1/2 1-8/10 2 2-1/2 3 3-2/10 3-1/2 4 5 5-6/10 6 6-1/4 7 7-1/2 Time-Current Characteristics–Average Melt Time-Current Characteristics–Average Melt AMPERE RATING 200 15A 20A 100 30A 1000 100 TIME IN SECONDS TIME IN SECONDS 10 1 10 1 .1 10000 10 100 CURRENT IN AMPERES 1000 CURRENT IN AMPERES .01 1 300 400 500 200 100 1 .5 .01 10 .1 Recommended fuseblocks/fuseholders for Class CC 600V fuses See Data Sheets listed below • Open fuseblocks - 1105 • Finger-safe fuseholders - 1109, 1102, 1103, 1151 • Panel-mount fuseholders - 2114, 2113 • In-line fuseholders - 2126 The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 11-20-02 SB02450 Form No. FNQ-R Page 2 of 2 Data Sheet: 1014
FNQ-R-1-1/4 价格&库存
很抱歉,暂时无法提供与“FNQ-R-1-1/4”相匹配的价格&库存,您可以联系我们找货
