Technical Data 10390
Effective September 2017
Supersedes April 2015
FPV1006
High current power inductors
Applications
Compatible with Picor® Cool-Power®
ZVS Buck and Buck-Boost regulator families
Environmental Data
Product features
Magnetically shielded
Inductance range 85 nH to 150 nH
Current range from 25 A to 81 A
10.3 mm x 8.7 mm footprint surface mount
package in 6.4 mm height
Ferrite core material
Storage temperature range (component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
Picor® and Cool-Power® are trademarks of Vicor Corporation.
FPV1006
Product Specifications
Part Number4
OCL1
(nH) ±10%
Irms2
(A)
Isat3
(A)
DCR (mΩ)
@ +20 °C
maximum
FPV1006-85-R
85
25
81
0.41
FPV1006-125-R
125
25
57
0.41
FPV1006-150-R
150
25
45
0.41
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C
2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating
conditions verified in the end application.
3. Isat : Peak current for approximately 5% rolloff @ +25 °C
4. Part Number Definition: FPV1006-xxx-R
FPV1006 = Product code and size
xxx=Inductance value in nH,
-R suffix = RoHS compliant
Note: Hipot: 250 Vdc minimum for 2 seconds, conductor to core
Dimensions (mm)
Recommended Pad Layout
Part marking: FPV1006–xxx, xxx=inductance value in nH,
wwllyy= date code, R=revision level
Tolerances are ±0.25 unless stated otherwise
Soldering surfaces to be coplanar within 0.102 millimeters
DCR measured from point “a” to point “b”
Do not route traces or vias underneath the inductor.
Packaging information (mm)
Supplied in tape and reel packaging, 620 parts per 13” diameter reel
Direction of feed
2
www.eaton.com/electronics
Schematic
FPV1006
Inductance characteristics
FPV1006-85-R
FPV1006-125-R
110%
110%
100%
100%
-40°C
90%
+25°C
% of OCL
% of OCL
80%
70%
60%
50%
70%
60%
+25°C
+125°C
40%
30%
20%
80%
50%
+125°C
40%
-40°C
90%
30%
60
80
100
120
140
20%
40
50
60
70
80
90
100
Idc (A)
Idc (A)
FPV1006-150-R
110%
100%
% of OCL
90%
-40°C
80%
70%
+25°C
60%
50%
+125°C
40%
30%
20%
40
50
60
70
80
Idc (A)
3
FPV1006
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FPV1006-85-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 620+13.57155620+1.75670
- 1240+12.799591240+1.65678
- 1860+12.369031860+1.60105
- 3100+11.847823100+1.53358
- 4340+11.596414340+1.50104
- 国内价格 香港价格
- 1+15.812261+2.04674
- 10+13.0055810+1.68344
- 100+10.69432100+1.38427
