14002-5
14002-5
    EATON(伊顿)
14002-5 数据手册
Power Distribution & Terminal Blocks Power Terminal Blocks: Barrier & Dead Front Series 14002 Specifications Description: Barrier terminal block. Poles: 2- to 6-poles. Wire Range: 2 – 14 AWG Cu/8 AWG Al. Ratings: Volts: — 600Vac/dc Amps: — 115A SCCR:— 10kA per UL 508A table SB4.1 Agency Information: CE, Guide XCFR2, UL E62622; CSA LR15364. Torque Ratings*: 2-3, 50 lb-in; 4-6, 45 lb-in; 8, 40 lb-in; 10-14, 35 lb-in. *Consult factory for torque ratings for CP and Q options. Marking: Marking strip optional, consult factory. Options For Load Side Connector CP: Sems pressure plate, rated 60A, 600V Q: Quick-Connect, rated 50A, 600V To order options, enter letter code in front of Catalog Number: i.e., CP14002-2. Catalog Numbers Poles 2 3 4 Catalog Numbers 14002-5 14002-6 Poles 5 6 Power Distribution & Terminal Blocks Catalog Numbers 14002-2 14002-3 14002-4 Series 14004 Specifications Description: Dead front terminal block. Poles: 2 to 12 poles. Wire Range: 4 – 14 AWG Cu/8 AWG Al. Ratings: Volts: — 600Vac/dc Amps: — 90A SCCR:— 10kA per UL 508A table SB4.1 Agency Information: CE, Guide XCFR2, UL E62622; CSA LR15364. Marking: Marking strip optional, consult factory. Catalog Numbers Catalog Numbers 14004-2 14004-3 14004-4 14004-5 14004-6 14004-7 Poles 2 3 4 5 6 7 Catalog Numbers 14004-8 14004-9 14004-10 14004-11 14004-12 Poles 8 9 10 11 12 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 301
14002-5 价格&库存
很抱歉,暂时无法提供与“14002-5”相匹配的价格&库存,您可以联系我们找货
