9575H3A000
9575H3A000
    EATON(伊顿)
    EATON CUTLER HAMMER - 9575H3A000 - RELAY, DPDT, 300VAC, 28VDC, 40A, PANEL
9575H3A000 数据手册
40.5 40 Control Relays and Timers General Purpose Relays—Type AA Contents 9575H Series 3000 Relay Description 40 9575H Series 3000—Type AA, AC and DC Product Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Accessories. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications . . . . . . . . . . . . . . . . . . Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40 40 40 40 40 40 40 40 40 9575H Series 3000—Type AA, AC and DC 40 Product Description Application Description Standards and Certifications Type AA panel-mounted relays are rated (each pole) 40A up to 300 Vac, 50/60 Hz; 5A at 480/600 Vac, 50/60 Hz and 40A at 28 Vdc. 9575H Series 3000 relays are ideal for applications when controlling smaller loads, such as single-phase motors. ● 40 40 ● ● UL listed, E1491 CSA 41729 CE: EN60947-4-1, EN60947-5-1 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 516 Volume 7—Motor Controls, Logic and Connectivity CA08100008E—December 2010 www.eaton.com Page 517 517 518 519 40.5 Control Relays and Timers General Purpose Relays—Type AA Product Selection 40 When Ordering, Specify Catalog number and magnet coil code letter. Example: for DPDT relay with auxiliary switch and a 120V 50/60 Hz coil, order Catalog Number 9575H3A010. 40 Coil Voltage Selection Coil Voltage Hz Suffix Code 40 120 50/60 A 40 240 50/60 B 480/440 60/50 C 600/550 60/50 D 208 50/60 E 277 50/60 H 6 50/60 J 12 50/60 K 24 50/60 L 48 50/60 M 40 — P 40 220 — Q 6 — R 12 — S 24 — T 48 — W Volts AC 9575H Series 3000 Relay Type AA Relays Relay Style Catalog Number Relay (DPDT) 9575H3_000 Relay with auxiliary switch 9575H3_010 Relay with blowout magnets 9575H3_100 Relay with auxiliary switch and blowout magnets 9575H3_110 40 40 40 40 Volts DC 110 40 40 40 40 40 Accessories 40 Enclosure Description Catalog Number 40 NEMA 1 Enclosure 9575H2449 40 Notes There are no “repair parts” available for these relays. Underscore indicates missing code suffix for magnet coil—see Selection table above. Only 9575H3 relays without an auxiliary switch should be mounted in the 9575H2449 enclosure. 40 40 40 40 40 40 40 40 40 40 40 40 Volume 7—Motor Controls, Logic and Connectivity CA08100008E—December 2010 www.eaton.com 517 40.5 40 40 40 40 40 40 40 40 Control Relays and Timers General Purpose Relays—Type AA Technical Data and Specifications Relay Specifications Coil ● Pull-in voltage: 80% DC coils, 85% AC coils of nominal voltage or less at 25ºC ● Dropout voltage: 10% of nominal voltage or more at 25ºC ● Coil resistance: ±10% measured at 25ºC ● Max. DC coil dissipation capability: 4 watts DC continuous at 25ºC 40 40 40 40 40 40 40 40 40 Contacts ● Contact combination: DPDT ● Contact rating each pole (main contacts): Each pole rated 40 amps up to 300 Vac, 50/60 Hz, 5 amps at 480/600 Vac 50/60 Hz, 0.75 PF load. 1-1/2 hp motor load (each pole) at 120–600 Vac, 50/60 Hz. 2 hp motor load at 200–600 Vac, 50/60 Hz only when using both poles to switch both sides of load, 40 amps at 28 Vdc resistive load each pole. NEMA A 600 pilot duty 50/60 Hz ● Additional contact ratings for relays with blowout magnets: 10A at 110 Vdc resistive, 4A at 225 Vdc resistive, 2A at 325 Vdc resistive. For inductive loads, contacts must be derated accordingly. ● Contact material: Silver cadmium oxide, gold flashed. 5/16 in (7.9 mm) diameter standard Dielectric Withstanding Voltage ● Between open contacts: 1500 Vrms ● All other mutually insulated conductive elements: 2200 Vrms Miscellaneous ● Coil terminals: 6–32 screws ● Contact terminals: 8-–32 screws ● Main base material: Molded phenolic, UL recognized (QMFZ2) ● Weight (DPDT Relay): 11 oz (311 grams) approximately ● Weight (DPDT Relay with auxiliary switch) 14.5 oz (411 grams) approximately Auxiliary Switch Specifications ● Contact combination: SPDT ● Contact rating: Auxiliary switch rated 10 amps at 125 or 250 Vac, resistive load; 1/4 hp at 125 or 250 Vac, motor load; 0.4 amps at 125 Vdc or 0.20 amps at 250 Vdc, resistive load; 3 amps at 125 Vac lamp load. All AC ratings are 50/60 Hz ● Dielectric withstanding voltage: 500 Vac rms between open contacts, 1500 Vac rms between all other mutually insulated conductive elements ● Terminals: 4–40 round head screws for auxiliary contacts standard Average Operating Times (Milliseconds) 40 Operation DPDT Relay DPDT Relay with Auxiliary Switch Pickup 40 50 40 Dropout 35 35 40 Temperature Ranges 40 40 Temperature AC DC Operating range –30º to 55ºC –30º to 55ºC Non-operating range –30º to 100ºC –30º to 100˚C 40 40 40 40 40 40 40 40 518 Volume 7—Motor Controls, Logic and Connectivity CA08100008E—December 2010 www.eaton.com Control Relays and Timers General Purpose Plug-In Relays—Type AA 40.5 Dimensions 40 Approximate Dimensions in Inches (mm) 9575H3 DPDT Relay 40 9575H2449 3.31" (84.2) Mounting Holes 0.187 (4.75) Dia. (2 Places) 40 1.88" (47.6) 8-32 Machine Screw on Contact Terminals (6 Places) 0.218" (5.5) Dia. 0.56" (4.3) 40 0.230" (5.8) Square Hole 40 2.25 (58.7) Max. 40 3.55" (90.1) 1.87 (47.5) 0.38 (9.5) 2.50 (63.5) 1.62 (41.1) 40 0.159" (4) Dia. 10-32 Tap Typ. 4 Places 40 4.50" (114.3) 3.12 (79.2) Max. 6-32 Machine Screw on Coil Terminals (2 Places) 40 5.63" (142.9) 0.136" (3.4) Dia. 8-32 Tap Typ. 2 Places 0.50" (2.7) 40 40 9575H3 DPDT Relay with Auxiliary SPDT Switch Mounting Holes 0.187 (4.75) Dia. (2 Places) 2.00" (50.8) 0.218" (5.5) Dia. Typ. 2 Places 3.00" (76.2) 40 0.36" (9.1) Typ. 2 Places 40 40 8-32 Machine Screw on Contact Terminals (6 Places) 40 2.25 (58.7) Max. 40 0.20" (5.1) 40 1.87 (47.5) 2.50 (63.5) 0.38 (9.5) 40 1.62 (41.1) 3.12 (79.2) Max. 40 6-32 Machine Screw on Coil Terminals (2 Places) 40 40 NC 10A 1/4 hp 125 OR 250 Vac 0.4A at 125 Vdc, 0.2A at 250 Vdc 3A 125 Vac “LAMP” 278 VA 125/250 Vac P.D. NO COM 40 40 Mounting Holes (2) AUX. SWITCH MARKING SURFACE 40 Insulators (2 Sides) 40 40 4.44 (112.7) Max. Screw Terminals (4-40) RHMS with External Tooth Lockwashers (3 Places) 40 40 RELAY TOP VIEW 40 40 Volume 7—Motor Controls, Logic and Connectivity CA08100008E—December 2010 www.eaton.com 519
9575H3A000 价格&库存
很抱歉,暂时无法提供与“9575H3A000”相匹配的价格&库存,您可以联系我们找货
