AGX-6
AGX-6
    EATON(伊顿)
    D6.35xL25.4mm
    一次性保险丝(熔断) 6A 250V
AGX-6 数据手册
/4" x 1" Fast-Acting, Glass Tube Fuses 1 AGX Series Agency Information • cULus: AGX 0-10A (Guide JDYX, File E 19180 and Guide JDYX7, File E19180) • UL Recognized Card: AGX 15-30A (Guide JDYX2, File E19180) • CSA Component Acceptance Card : AGX 15-30A (Class No. 1422-01, File 53787) Ordering Description • Insert packaging code prefix before part number, e.g., BK/AGX-1 • • • • • Dimensions - mm (in) Fast-acting glass tube fuse 1 /4" x 1" (6.3 x 25.4mm) physical size Glass tube, nickel-plated brass endcap construction For instruments, electronic and small appliance circuits UL Listed product meets standard 248-14 Electrical Characteristics Rated Current % of Amp Rating Opening Time 110% 4 hours. min. 1 /10 - 30A 135% 60 minutes max. 1 200% 5 seconds max. /10 - 2A 2.5 - 30A 200% 2 minutes max. 25.4±0.8 1.000±0.31 6.35±0.1 0.250±0.004 Specifications Part Number (Amps) AGX-1/10 AGX-1/8 AGX-3/16 AGX-2/10 AGX-1/4 AGX-3/10 AGX-3/8 AGX-4/10 AGX-1/2 AGX-3/4 AGX-1 AGX-1-1/4 AGX-1-1/2 AGX-2 AGX-2-1/2 AGX-3 AGX-4 AGX-5 AGX-6 AGX-7 AGX-8 AGX-10 AGX-15** AGX-20** AGX-25*** AGX-30*** Voltage Rating Vac 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 125 125 Interrupting Rating (amps) 250Vac 125Vac 32Vac 35 35 35 35 35 35 35 35 35 35 35 100 100 100 100 100 200 200 200 200 200 200 200 200 - 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 200 200 100 100 1000 1000 1000 1000 1000 1000 Typical DC Cold Resistance (Ω)* Lower Upper N/A 7.610 3.086 2.918 1.010 0.789 0.547 0.514 0.318 0.158 0.111 0.080 0.064 0.041 0.031 0.027 0.021 0.014 0.011 0.009 0.008 0.006 0.004 0.003 0.002 0.002 N/A 10.293 4.176 3.948 1.366 1.067 0.740 0.568 0.431 0.215 0.150 0.109 0.086 0.055 0.043 0.036 0.028 0.019 0.015 0.015 0.011 0.008 0.005 0.003 0.003 0.002 * Typical DC Cold Resistance (Measured at
AGX-6 价格&库存
很抱歉,暂时无法提供与“AGX-6”相匹配的价格&库存,您可以联系我们找货
