CB11220807
CB11220807
    EATON(伊顿)
    CONN TERM BLK PC BARR 8POLE
CB11220807 数据手册
Single Row Terminal Blocks CB11 Dimensions Inches (Millimeters) Specifications CB11 Rating: 15 A, 300 V Center Spacing: 0.325” (8.25 mm) Wire Range: #14-22 AWG Screw Size: M3.0, nickel-plated steel CB11720407 Torque Rating: 12 lb-in. Recommended PCB Hole Diameter: 1.6 mm - 1.8 mm Operating Temperature: -40 °C to +120 °C Body Material: Polyamide 66, UL94 V-0, Black Terminal Material: Brass, tin plated Breakdown Voltage: 2000 V Agency Information: UL file E62622 0.325 (8.25) 0.15 (3.8) Ø MOUNTING ENDS 0.610 (15.5) A Mount End Barrier End 0.49 (12.5) 0.236 (6.0) Mount End B Barrier End BARRIER ENDS Poles A Length B Mount Centers A Length B End Pole Centers 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 1.35 1.67 2.00 2.32 2.65 2.97 3.30 3.62 3.94 4.27 4.59 4.92 5.24 5.57 5.89 6.22 6.54 6.87 7.19 7.52 7.84 8.17 8.49 8.82 9.14 9.47 9.79 10.12 10.44 0.65 0.97 1.30 1.62 1.95 2.27 2.60 2.92 3.25 3.57 3.90 4.22 4.55 4.87 5.20 5.52 5.85 6.17 6.50 6.82 7.15 7.47 7.80 8.12 8.44 8.77 9.09 9.42 9.74 0.70 1.02 1.35 1.67 2.00 2.32 2.65 2.97 3.30 3.62 3.94 4.27 4.59 4.92 5.24 5.57 5.89 6.22 6.54 6.87 7.19 7.52 7.84 8.17 8.49 8.82 9.14 9.47 9.79 0.32 0.65 0.97 1.30 1.62 1.95 2.27 2.60 2.92 3.25 3.57 3.90 4.22 4.55 4.87 5.20 5.52 5.85 6.17 6.50 6.82 7.15 7.47 7.80 8.12 8.44 8.77 9.09 9.42 Dimensions in inches. To convert to millimeters, multiply by 25.4. CB11   Single Row Terminal Blocks  Part Numbering System Family Terminal Style Base/End Poles Screw Options Options 12 - printed circuit 1 - mount end 02 to 30 03 - stainless steel 17 - extended pin 2 - barrier end B1 to B9 - 0.187˝ QC L1 to L6 - marking options (pg 25) LT1 to LT6 - marking options (pg 25) C B 1 CB1 - closed back 07 - steel SEMS Terminal Styles- Inches(Millimeters) 0.492 (12.5) 0.236 (6.0) 0.047 (1.2) 0.325 (8.25) 0.197 (5.0) 0.236 (6.0) 0.047 (1.2) 0.031 (0.8) 0.492 (12.5) 0.512 (13.0) 0.173 (4.4) 0.047 (1.2) 0.325 (8.25) 12 17 Printed Circuit Extended Pin 0.031 (0.8) 0.173 (4.4) Screw Options (Bulk ordering part numbers are in parentheses) 03 07 Stainless steel (CB1-SSSC) Steel SEMS Nickel-plated (CB1-STSC) Hardware Options (Bulk ordering part numbers are in parentheses) Jumpers (JA1-xx-J) (JB1-xx-J) (JC1-xx-J) EATON www.eaton.com 7 Effective November 2019 Supersedes December 2017 Single Row Terminal Blocks Tools & resources • • • • Webpage Terminal block selector tool Terminal block cross reference Conatct us Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2019 Eaton All Rights Reserved Printed in USA Publication No. 10682 — BU-MC19146 November 2019 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
CB11220807 价格&库存
很抱歉,暂时无法提供与“CB11220807”相匹配的价格&库存,您可以联系我们找货
CB11220807
    • 1+93.57120
    • 200+37.33560
    • 500+36.09360
    • 1000+35.47800
    CB11220807
      • 25+35.89819
      • 50+33.22608
      库存:1200
