D38999/24FJ46SN-LC
D38999/24FJ46SN-LC
    EATON(伊顿)
    SOURIAU-SUNBANK / EATON - D38999/24FJ46SN-LC - Circular Connector, MIL-DTL-38999 Series III, Jam Nut...
D38999/24FJ46SN-LC 数据手册
8D SERIES Standard Aerospace & Military Connectors MIL-DTL-38999 Series III / EN3645 8D Series Presentation Since the early 80’s, SOURIAU is a major supplier of 38999 Series III, the screw-coupled version of MIL-C-38999. Present on the main international programs, SOURIAU has developed a range of products that meet the performance required in extreme environments. This product family is in accordance with MIL-DTL-38999 Series III, EN3645, CECC (standard for bronze shell), and also meets many customers’ standards (Rolls Royce, ABS, BACC, ...) This evolution of MIL-C-38999 allows: • A high contact density up to 128 contacts #22D • A quick screw coupling with self locking mechanism • High resistance to harsh environments (vibration, 200°C) Always at the cutting edge of innovation, SOURIAU’s teams have continuously improved this range of connectors: • Composite version in the 90’s (Its choice is recommended wherever weight is critical) • Titanium version for weight saving and very high and mechanical resistance • Today SOURIAU remains innovative with cadmium free and RoHS solutions. In 2009 SOURIAU was the first to be QPL qualified for Zinc Nickel plating. Contents Overview Typical applications .......................................... Features & Benefits .......................................... Product overview .............................................. A universal product platform ............................ Technical characteristics ................................... Contact layouts ................................................ Common Section 6 7 8 10 11 13 Standard Series Aluminum Series .............................................. Composite Series ............................................. Stainless steel Series ........................................ Titanium Series ................................................. Bronze Series .................................................... 22 35 41 47 52 Contacts ........................................................... Dummy contacts / Filler plugs ......................... Wiring instruction ............................................. Tooling ............................................................. Accessories ...................................................... Orientations ..................................................... Panel cut-out .................................................... Coordinates ..................................................... 64 70 71 72 74 75 75 76 Derived Series ..................... 85 Range Extension ..................... 145 3 8D SERIES © 2016 SOURIAU - SOURIAU is a registratred trademark 8D Series Overview Typical applications ................................................................................................ 6 Features & Benefits ................................................................................................ 7 Product overview - A superior concept .................................................................. 8 Product overview - A performing MIL standard connector design ......................... 10 A universal product platform .................................................................................. 10 Technical characteristics .......................................................................................... 11 Contact layouts ....................................................................................................... 13 Contact layouts (matrix) .......................................................................................... 18 © Aleksey Stemmer / Fotolia Civil Aeronautics Ground Military Marine - Offshore 6 © Metlion / Fotolia © JPS / Fotolia Military Aeronautics Industrial - Railway Courtesy of Esterline Communication Systems © Npologuy / Fotolia © Dell / Fotolia 8D Series | Overview Typical applications Defense 8D Series | Overview Features & Benefits MIL-DTL-38999 Qualified QPL 54 qualified layouts. Qualified protective caps. High reliability ROBUST Temperature up to 200°C. High vibration withstanding (44g). 500 mating/unmating cycles. High end materials LIGHT WEIGHT Aluminum (D38999 & EN3645 qualified). Composite (D38999, EN3645 & BACC qualified). Titanium version. Versatility LARGE OFFER RoHS platings, high density layouts, ... Contacts: signal, high speed (optical, quadrax), high power, ... Specific shells: double flange, clinch nuts, integrated backshell, ... Class K FIRE SEAL Stainless steel (D38999, EN3645 & BACC qualified). Hermetic version. 7 8D Series | Overview A superior concept 5 Materials & Platings Aluminum Black zinc nickel RoHS, Nickel RoHS, Green zinc cobalt, Olive drab cadmium Versatile & Robust Metallic clips retention Unique technology, High performance contact retention, High temperature and high vibrations withstanding 8 offer Versatility PC Tail contacts with or without shoulder, Crimp contacts, Solder cup contacts, Wire wrap contacts Adaptability Common cavity for all #8 contacts Stainless Steel Passivated RoHS, Nickel RoHS Bronze Without plating Contact High density #26 contact layouts Composite Nickel RoHS, Olive drab cadmium, Without plating Titanium Nickel RoHS, Without plating Full Accessories Full backshells offer, Protective caps, Tooling High sealing IP67, Each contact cavity is individually sealed Multi-contact technology Signal transmission, High power up to 850A, High speed data transmission: . Quadrax . Coax . Twinax . Triax (= concentric twinax) . ELIO® fiber optic . Expanded beam 8D Series | Overview Derived Series Various possibilities of range extension and shell variant from Standard Series. The only limit is your imagination: Consult us ! HIGH SPEED SOLUTIONS Twinax and Quadrax contacts see page 86 BMA coaxial contacts see page 92 ELIO® fiber optic contacts see page 96 POWER SOLUTIONS Power contacts see page 106 High power contacts see page 111 COMPACT SOLUTIONS High density see page 116 SMART DESIGN SOLUTIONS High vibration: 8DV Series see page 122 Clinch nuts or helicoils see page 126 ELIOBEAM fiber optic contacts see page 102 Plug with integrated backshell see page 118 PC TAIL CONTACTS SOLUTIONS Double flange receptacle see page 129 REINFORCED SEALING PC tail contact without shoulder see page 132 INTERCONNECT SOLUTIONS SUNBANK provides a large variety of interconnect solutions to vector and secure the cable routing. Consult us for more information. Resin sealed connector see page 134 Glass sealed connector see page 137 Backshells Flexible conduits Protective caps Accessories 9 8D Series | Overview A performing MIL standard connector design Quick coupling 11/4 turn to mate Fully Scoop proof Self locking Visual mating Mechanism patented by SOURIAU. Connector will never unscrew even under high vibration (44 g) Red band visible = not correctly mated shielded No risk of damaging contacts during the coupling operation Shell to shell bottoming = perfect shield continuity 360° shielding 360° teeth for optimum shield continuity with accessories Red band hidden = correctly mated EMI Ring A universal product platform 38999 Series I 38999 Series II MIL-DTL-38999 MIL-DTL-38999 8LT Series 8T Series . High density MIL-spec circular . Scoop proof . Bayonet coupling . Mounting: screws or jam nut . Shell: Aluminum alloy . Plating: Cadmium or nickel . QPL approved . Numerous layouts 10 . Short version of 38999 Series I . High density MIL-spec circular . Bayonet coupling . Mounting: screws or jam nut . Shell: Aluminum alloy . Plating: Cadmium, nickel or hard anodized . QPL approved VG96912 & JN1003 8ST Series . High density . Lightweight version of Series I . Scoop proof, bayonet coupling . Mounting: screws or jam nut . Shell: Aluminum alloy . Plating: Cadmium or nickel . VG 96912 German specification . JN 1003 Typhoon specification 8D Series | Overview Description • High contact density layouts available • Screw coupling, Shell size from 9 to 25 • Contact protection: 100% Scoop proof • Protected by cadmium, nickel, green zinc cobalt or black zinc nickel plating • RFI - EMI shielding and shell to shell continuity • Accessories (protective caps, backshells, etc… ) • Hermetic versions • High power up to 850A • Optical layouts • 230V layouts available (ABS22-19, ABS22-20, ABS22-21 & ABS22-22 qualified) • Standards: . MIL-DTL-38999 Series III . EN3645 . BACC63CT/CU; BACC63DB/DC Technical features Mechanical • Shell: Aluminum, composite, stainless steel, bronze • Shell plating: . Aluminum shell: Cadmium olive drab (W) Nickel (F) Black zinc nickel (Z) Green zinc cobalt (ZC) . Composite shell: Cadmium olive drab (J) Nickel (M) Without plating (X) . Stainless steel shell: Passivated (K) Nickel (S) . Titanium shell: Without plating (TT) Nickel (TF) . Bronze shell: Without plating • Insulator: Thermoplastic • Grommet and interfacial seal: Silicone elastomer • Contacts: Copper alloy Weight comparison • Contacts plating: Gold over nickel plated Example for a plug shell size 15 • Endurance: . 500 mating cycles all materials . 1500 mating cycles for composite connectors with specifics contacts Materials Weight Stainless steel 58.80 g 42% lighter • Shock: 300 g, 3 ms according EN2591-D2 method A • Vibration: . Sinus: . 10 à 2000 Hz, 3x12 hrs (60 g, 140 - 2000 Hz) with T° cycling . Random: . 50 to 2000 Hz, 2x8 Hrs (1 g2/ Hz, 100 - 2000 Hz) at T° max. . 25 to 2000 Hz, 2x8 Hrs (5 g2/ Hz, 100 - 300 Hz) at ambiant T° Test with accessories in acc with EN2591-D3 Titanium 33.90 g 40% lighter Aluminum 20.35 g 30% lighter Composite 14.30 g • Contact retention: Contacts size 26 22 20 16 12 Min force in N 30 44 67 111 111 111 200 8 4 11 8D Series | Overview Electrical • Test voltage rating (Vrms) Service R M N I II sea level 400 1 300 1 000 1 800 2 300 at 21000 m N/A 800 600 1 000 1 000 • Contact resistance Contacts size 26 22 20 16 12 8 4 Resistance mΩ 16 14.6 7.3 3.8 3.5 3 2 • Insulation resistance: ≥ 5 000 MΩ (under 500 Vdc) • Shielding: . Aluminum shell: F: 65 db at 10 GHz Z, F & W: 85 db at 1 GHz Z & W: 50 db at 10 GHz ZC: Consult us . Composite shell: J & M: 85 db at 1 GHz . Stainless steel shell: K: 45 db at 10 GHz S: 65 db at 10 GHz . Titanium shell: TT: 45 db at 10 GHz TF: 65 db at 10 GHz . Bronze shell: 85 db at 10 GHz Environmental • Contact rating: Contacts size 26 22 20 16 12 10 8 Rating (A) 3 12 4 5 7.5 13 23 33 45 80 • Shell continuity . Aluminum shell: Cadmium olive drab (W): 2.5 mΩ Nickel (F): 1 mΩ Black zinc nickel (Z): 2.5 mΩ Green zinc cobalt (ZC): 2.5 mΩ . Composite shell: Cadmium olive drab (J): 3 mΩ Nickel (M): 3 mΩ . Stainless steel shell: Passivated (K): 10 mΩ Nickel (S): 1 mΩ . Titanium shell: Without plating (TT): 10 mΩ Nickel (TF): 1 mΩ . Bronze shell: Without plating: 5 mΩ • Salt spray: . Aluminum shell: W: 500 Hrs F: 48 Hrs Z: 500 Hrs ZC: 250 Hrs . Composite shell: J: 2000 Hrs M: 2000 Hrs Without plating (X): 2000 Hrs . Stainless steel shell: K: 500 Hrs S: 500 Hrs . Titanium shell: TT: 500 Hrs TF: 48 Hrs . Bronze shell: Without plating: 500 Hrs • Temperature range: . Aluminum shell: W: -65°C +175°C F: -65°C +200°C Z: -65°C +200°C ZC: -65°C +175°C . Composite shell: J: -65°C +175°C M: -65°C +200°C Without plating (X): -65°C +175°C . Stainless steel shell: K: -65°C +200°C S: -65°C +200°C . Titanium shell: TT: -65°C +200°C TF: -65°C +200°C . Bronze shell: Without plating: -65°C +175°C • Sealing: Mated connectors meet altitude immersion requirements of MIL-DTL-38999. Resistance to fluids • According to MIL-DTL-38999 standard . Gasoline: JP5 (OTAN F44) . Mineral hydraulic fluid: MIL-H-5606 (OTAN H515) . Synthetic hydraulic fluid: Skydrol 500 B4 • LD4 (SAE AS 1241) . Mineral lubricating: MIL-L-7870A (OTAN 0142) . Synthetic lubricating: MIL-L-23699 (OTAN 0156), MIL-L-7808 . Cleaning fluid: MIL-C-87936 diluted . De-icing fluid: MIL-A-8243 . Extinguishing fluid: Bromochloromethane . Cooling fluid: Coolanol 8D Series | Overview Contact layouts P Power or High Power Contact sizes Q Quadrax or Twinax #26 #22D C Concentric Twinax (=Triax) or Coax #20 #16 #12 #10 #8 Triax (=Concentric Twinax) or Coax - consult us HD High Density H Hermetic version developed #4 Power Fiber optic ELIO® or Expanded beam Fiber optic ELIO® or Expanded beam #8 Quadrax or Twinax #8 Power F High Power 09 / A 01 05* 12 35 98 1 Optical position 1#8 Quadrax 12#26 Service R 6#22D Service M 3#20 Service I F Q HD H H * 09-05 layout: - Grounded version only (spec. 620) - Plug with female contact & receptacle with male contact only 11 / B 01 01 02 02 04 05 12 22 1#12 Service II 1#8 Coax Service I 2#16 Service I 2 Optical positions 4#20 Service I 5#20 Service I 1#12 Service II 4#22D Service M all Series excepted JVS only for JVS 26 35 80 26#26 Service R 13#22D Service M HD H only for JVS F C 80 81 98 99 1#8 Triax Service I 1#8 Power 1#8 Quadrax 6#20 Service I 7#20 Service I C P Q H Spec 251 As stated in MIL-DTL-38999 standard, insert arrangements uding multi-axial contacts (coax, twinax, quadrax, ...) should not be used in firewall aplications. 13 8D Series | Overview Contact layouts P Power or High Power Q Quadrax or Twinax C Concentric Twinax (=Triax) or Coax HD High Density H Hermetic version developed F Fiber optic ELIO® or Expanded beam 13 / C 03 04 04 08 26 35 43 98 3#16 Service I 4#16 Service I 4 Optical positions 8#20 Service I 2#12, 6#22D Service M 22#22D Service M 43#26 Service R 10#20 Service I H F H H HD H 05 06 15 18 19 35 97 5#16 Service II 6 Optical positions 1#16, 14#20 Service I 18#20 Service I 19#20 Service I 37#22D Service M 4#16, 8#20 Service I H H H H 15 / D F 17 / E 02 02 06 08 20 22 38#22D 1#8 Triax Service M 38#22D 1#8 Power 6#12 Service I 8#16 Service II 4#12 16#22D Service M C P H H 35 75 75 80 55#22D Service M 2#8 Triax Service M 2#8 Power H C P Spec 251 Spec 251 22 26 2#12 2#8 Triax Service M 2#12 2#8 Power 26#20 Service I C P H 81 82 99 2#12 2#8 Quadrax 38#22D 1#8 Quadrax 2#8 Quadrax 2#16, 21#20 Service I Q Q Q Spec 251 As stated in MIL-DTL-38999 standard, insert arrangements uding multi-axial contacts (coax, twinax, quadrax, ...) should not be used in firewall aplications. 14 8D Series | Overview Contact layouts P Power or High Power Q Quadrax or Twinax C Concentric Twinax (=Triax) or Coax HD High Density H Hermetic version developed F Fiber optic ELIO® or Expanded beam 19 / F 08 11 18 8 Optical positions 11#16 Service II F 18 28 14#22D 4#8 Triax Service M 14#22D 4#8 Power 26#20 2#16 Service I C P Spec 251 32 35 84 H1 32#20 Service I 66#22D Service M 14#22D 4#8 Quadrax 1#00 High power H Q P 11 12 16 20 11#12 Service I 12 Optical positions 16#16 Service II 21 / G F 20 35 39 41 18#20 2#8 Triax Service M 18#20 2#8 Power 79#22D Service M 2#16 37#20 Service I 41#20 Service I C P Spec 251 42 48 59 72 75 2#4 Power Service I 4#8 Power Service I 55#22D 4#12 Service M 6#16 2#4 Power Service I P P H P H 75 77 4#8 Triax Service M 4#8 Power 17#22D 2#8 Triax Service M C P C Spec 251 → See next page for more size 21/G layouts As stated in MIL-DTL-38999 standard, insert arrangements uding multi-axial contacts (coax, twinax, quadrax, ...) should not be used in firewall aplications. 15 8D Series | Overview Contact layouts P Power or High Power Q Quadrax or Twinax C Concentric Twinax (=Triax) or Coax HD High Density H Hermetic version developed 21 / G 77 78 80 84 17#22D 2#8 Power 17#22D 2#8 Quadrax 18#20 2#8 Quadrax 4#8 Quadrax P Q Q Q 06 21 32 35 6#8 Triax Service M 6#8 Power Service M 21#16 Service II 32#20 Service I 100#22D Service M C P 53 54 55 86 H1 53#20 Service I 4#12, 9#16 40#22D Service M 55#20 Service I 6#8 Quadrax 1#000 High power H Q P Spec 251 23 / H 06 H Spec 251 As stated in MIL-DTL-38999 standard, insert arrangements uding multi-axial contacts (coax, twinax, quadrax, ...) should not be used in firewall aplications. 16 F Fiber optic ELIO® or Expanded beam 8D Series | Overview Contact layouts P Power or High Power Q Quadrax or Twinax C Concentric Twinax (=Triax) or Coax HD High Density H Hermetic version developed F Fiber optic ELIO® or Expanded beam 25 / J 04 07 07 08 48#20 8#16 Service I 97#22D 2#8 Triax Service M 97#22D 2#8 Power H C 19 20* 19#12 Service I H 41 08 11 17 8#8 Triax Service M 8#8 Power 2#20 9#10 Service N 36#22D 6#8 Triax 36#22D 6#8 Power P C P C P 20* 24 24 29 35 37 10#20, 13#16 4#12 Coax 3#8 Triax Service N 10#20 13#16, 4#12 3#8 Power 12#16 12#12 Service I 24 Optical positions 29#16 Service I 128#22D Service M 37#16 Service II C P 41 43 46 61 80 61#20 Service I 10#20 13#16 4#12 Coax 3#8 Quadrax Spec 251 Spec 251 Spec 251 Spec 251 17 Spec 251 F 44 46 4#16 4#4 Power Service I 40#20, 4#16 2#8 Coax Service I 40#20, 4#16 2#8 Power Service I P C P Spec 251 H 22#22D, 3#20 11#16, 2#12 3#8 Triax Service M 22#22D, 3#20 11#16, 2#12 3#8 Power 23#20 20#16 Service I C P 81 82 86 87 88 90 H1 22#22D 3#20, 11#16 2#12 3#8 Quadrax 97#22D 2#8 Quadrax 40#20 4#16 2#8 Quadrax 36#22D 6#8 Quadrax 8#8 Quadrax 40#20, 4#16 2#8 Triax Service I 1#0000 High power Q Q Q Q Q C P Q As stated in MIL-DTL-38999 standard, insert arrangements uding multi-axial contacts (coax, twinax, quadrax, ...) should not be used in firewall aplications. 17 8D Series | Overview Contact layouts (matrix) Shell size 09 / A Layout MIL-DTL-38999 (QPL) JVS-CECC 8D Aluminum, Bronze Hermetics EN3645 Titanium Stainless steel connector & Composite 13 / C 15 / D 17 / E 19 / F OK Number of contacts 09-01 OK OK OK 1 09-05 (1) OK OK OK 1 09-12 OK 09-35 Q OK Q OK Q Q 6 09-98 Q OK Q OK Q Q 3 11-01 OK OK 11-01 OK OK OK 11-02 Q OK Q 12 #26 #22D #20 #16 11-02 OK OK OK Q OK OK 11-05 Q OK Q #10 #8 Q 6 3 1 1 Coax Q 2 Q 4 4 5 5 Q 1 OK OK 4 2 2 Optic. 1 11-22 OK 11-26 OK 11-35 Q OK Q 11-80 OK OK OK 1 1 Twx 11-80 sp.251 OK OK OK 1 1 Pow 11-81 OK OK OK 11-98 Q OK Q 11-99 Q OK Q 13-03 OK OK OK 26 13-04 Q OK Q 13-04 OK OK OK 13-08 Q OK Q OK Q Q 4 26 13 13 1 OK Q Q Q Q 1 Qdx 6 6 7 7 3 OK Q Q 4 4 4 OK Q Q 8 Q 4 Optic. 8 13-26 OK OK Q 8 6 13-35 Q OK Q OK Q Q 22 22 13-43 OK 13-98 Q OK Q OK Q Q 10 15-05 Q OK Q Q Q 5 15-06 OK OK OK 15-15 Q OK Q 15-18 Q OK Q 15-19 Q OK Q 15-35 Q OK 15-97 Q 17-02 Q 17-02 sp.251 43 2 43 10 5 6 6 Optic Q Q 15 14 OK Q Q 18 18 OK Q Q 19 Q OK Q Q 37 OK Q OK Q Q 12 OK OK Q Q 39 38 1 Twx OK OK OK 39 38 1 Pow 1 19 37 8 4 17-06 Q OK Q OK Q Q 6 17-08 Q OK Q OK Q Q 8 17-20 OK OK OK 20 17-22 OK OK OK 4 2 2 Twx 17-22 sp.251 OK OK OK 4 2 2 Pow 17-26 Q OK Q OK Q Q 26 17-35 Q OK Q OK Q Q 55 6 8 16 4 26 55 17-75 OK OK OK 2 2 Twx 17-75 sp.251 OK OK OK 2 2 Pow 17-80 OK OK OK 4 17-81 OK OK OK 39 17-82 OK OK OK 17-99 Q OK Q 19-08 OK OK OK 19-11 Q OK Q 19-18 Q OK OK 19-18 sp.251 OK OK OK 19-28 Q OK Q 19-32 Q OK Q 19-35 Q OK Q 19-84 OK OK OK 19-H1 OK Q 2 Q Q 23 Q Q 11 Q 18 2 38 SOURIAU’s layout & Layout according to corresponding norm Grounded insert only - Please consult us #8 Pow: Power; Qdx: Quadrax; Twx: Concentric Twinax 2 Qdx 1 Qdx 2 Qdx 21 2 8 OK 8 Optic. 11 14 4 Twx Q 28 26 Q Q 32 32 Q Q 66 66 18 14 2 1 SOURIAU’s layout (1) Fiber optic or High power 12 2 Q #4 1 Optic. 1 OK Q As stated in MIL-DTL-38999 standard, insert arrangements uding multi-axial contacts (coax, twinax, quadrax, ...) should not be used in firewall aplications. 18 #12 1 Qdx 1 11-04 11-12 11 / B BACC63 CT/CU DB/DC 4 Qdx 1 #00 8D Series | Overview Contact layouts (matrix) Shell size 21 / G 23 / H 25 / J OK Layout MIL-DTL-38999 (QPL) JVS-CECC 8D Aluminum, Bronze Hermetics EN3645 Titanium Stainless steel connector & Composite 21-11 Q OK Q 21-12 OK OK OK Q 21-16 Q OK Q BACC63 CT/CU DB/DC Number of contacts Q 11 #26 #22D #20 #16 #12 #10 #8 Q 12 Optic 16 16 21-20 OK OK OK 20 18 2 Twx 21-20 sp.251 OK OK OK 20 18 2 Pow 21-35 Q OK Q Q Q 79 21-39 Q OK Q Q Q 39 37 21-41 Q OK Q Q Q 41 41 21-42 OK OK OK 21-48 OK OK Q 21-59 OK OK OK 59 21-72 OK OK OK 8 21-75 Q OK OK 21-75 sp.251 OK OK OK 21-77 OK OK 21-77 sp.251 OK OK 21-78 OK OK 21-80 OK OK OK 21-84 OK OK OK 23-06 OK OK OK 6 6 Twx 23-06 sp.251 OK OK OK 6 6 Pow 23-21 Q OK Q 23-32 Q OK OK OK OK Q OK Q 23-54 OK OK OK 23-55 Q OK Q OK OK 23-86 OK OK 25-04 Q 2 Pow Q 4 Pow 55 4 6 2 Pow 4 4 Twx 4 4 Pow 19 17 2 Twx 19 17 2 Pow 19 17 20 Q Q Q 23-H1 Q Q Q 2 4 OK 23-35 79 2 OK Q OK 4 Qdx 21 Q Q 100 Q 53 Q 21 32 100 53 53 Q 2 Qdx 4 Q Q 2 Qdx 18 32 OK 40 55 9 4 55 6 6 Qdx 1 OK OK 25-07 Q OK OK 25-07 sp.251 OK OK OK OK 1 #000 Q Q 56 Q Q 99 97 2 Twx 99 97 2 Pow 48 8 25-08 Q OK Q (2) 25-08 sp.251 OK OK OK 25-11 Q OK OK 25-17 OK OK OK 42 36 6 Twx 25-17 sp.251 OK OK OK 42 36 6 Pow 25-19 Q OK Q 25-20 Q OK OK 25-20 sp.251 OK OK 25-24 Q OK Q 25-24 OK OK OK 25-29 Q OK Q Q Q 29 25-35 Q OK Q Q Q 128 25-37 Q OK OK Q Q 37 25-41 OK OK OK 41 22 3 11 2 3 Twx 25-41 sp.251 OK OK OK 41 22 3 11 2 3 Pow 25-43 Q OK Q 23 20 25-44 OK OK OK 25-46 Q OK OK 25-46 sp.251 OK OK OK 25-61 Q OK Q 25-80 OK OK OK 30 25-81 OK OK OK 41 22 25-82 OK OK OK 99 97 25-86 OK OK OK 46 25-87 OK OK OK 42 25-88 OK OK OK 8 25-90 Q OK OK 46 25-H1 OK Q Q OK (3) Q Q 8 8 Twx 8 8 Pow 11 2 9 Q Q 19 Q (4) Q (5) 30 10 13 4 (6) 3 Twx 30 10 3 4 3 Pow 12 12 OK Q Q 19 24 24 Q Q 24 Optic. 29 128 37 43 8 Q Q Q Q Fiber optic or High power 11 12 Q 23-53 #4 4 4 Pow 46 40 4 2 Coax 46 40 4 2 Pow 61 61 10 13 4 3 Qdx 3 11 2 3 Qdx 40 4 2 Qdx 36 2 Qdx 6 Qdx 8 Qdx 40 4 2 Twx 1 1 #0000 SOURIAU’s layout (3) For classes F, W, S, K only (6) 4 #12 coax (2+2) Q SOURIAU’s layout & Layout according to corresponding norm (4) For classes F, W, K only #8 Pow: Power; Qdx: Quadrax; Twx: Concentric Twinax (2) For CECC, layout 25-08 only delivered without contact (5) Qualified BACC63DB/DC only As stated in MIL-DTL-38999 standard, insert arrangements uding multi-axial contacts (coax, twinax, quadrax, ...) should not be used in firewall aplications. 19 8D SERIES © 2016 SOURIAU - SOURIAU is a registratred trademark 8D Series Standard Series Aluminum Series: Part numbers ..................................................................................................... Dimensions ........................................................................................................ Connectors weight ............................................................................................. Backshells .......................................................................................................... Metallic caps ...................................................................................................... 22 24 27 28 34 Composite Series: Part numbers ..................................................................................................... Dimensions ........................................................................................................ Connectors weight ............................................................................................. Backshells .......................................................................................................... 35 37 39 40 Stainless Steel Series: Part numbers ..................................................................................................... Dimensions ........................................................................................................ Connectors weight ............................................................................................. 41 43 46 Titanium Series: Part numbers ..................................................................................................... Dimensions ........................................................................................................ Connectors weight ............................................................................................. 47 48 51 Bronze Series: Part numbers ..................................................................................................... Dimensions ........................................................................................................ Connectors weight ............................................................................................. Backshells .......................................................................................................... Metallic caps ...................................................................................................... 52 53 56 57 61 8D Series | D38999 Aluminum Series Connector part numbers Basic Series 8D 0 - 11 W 35 P Shell style: 0: Square flange receptacle 1: In line receptacle 7: Jam nut receptacle 5: Plug with RFI shielding Also available: . Square flange receptacle with clinch nuts or helicoils (see page 126) . Jam nut receptacle with double flange (see page 129) Type: - : Connectors with standard crimp contacts. L: Receptacle with long PC tail (male and female size #22D, #20). C: Receptacle with short PC tail (male and female #22D, #20, #16, #12). S: Receptacle with specific PC tail (male et female #22D) W: Receptacle with male contacts #22D for wire wrap (3 wraps) T: Receptacle with male contacts #20 for wire wrap (2 wraps) P: Receptacle with solder cup contacts - please consult us . see page 134 for Reinforced sealing Series with solder cup contacts . see page 68 for solder cup contacts information Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Plating: W: Olive drab cadmium F: Nickel ZC: Green zinc cobalt Z: Black zinc nickel Contact layout: See pages 13 to 19 Contact type: P: Pin A: Connector supplied less pin contact or with specific contacts (connector marking: A + orientation) S: Socket B: Connector supplied less socket contact or with specific contacts (connector marking: B + orientation) Orientation: N, A, B, C, D, E (see page 75) Specification: 046: Tinned straight PC tail 251: Connector provided with power contacts (layouts with contact #8) 022: Fuel tank Special custom: None: Standard plastic cap M: Antistatic plastic cap L: For P or S contact type only, connectors delivered without contacts, connectors marking P or S plus orientation Note: PC tail contacts without shoulder also available. Please see page 132. 22 N L 8D Series | D38999 Aluminum Series MIL-DTL-38999 part numbers Basic Series D38999/ 20 W B 35 P N L Shell style: 20: Square flange receptacle 24: Jam nut receptacle 26: Plug with RFI shielding. Plating: Z: Black zinc nickel W: Olive drab cadmium F: Nickel Shell size: A, B, C, D, E, F, G, H, J Contact layout: See page 18 for layout according to MIL-DTL-38999 Contact type: P: Pin A: Connector supplied less pin contact or with specific contacts (connector marking: A + orientation) S: Socket B: Connector supplied less socket contact or with specific contacts (connector marking: B + orientation) Orientation: N, A, B, C, D, E (see page 75) L: For P or S contact type only, connector delevired without contacts, connector marking P or S (without L) Note: To place an order of MIL connectors delivered without MIL removable crimp contacts and keep P or S plus orientation marking, it must be specify clearly on the order (by adding a suffix L at the end of the P/N or specified in comment). Delivered with MIL contacts mandatory. As stated in MIL-DTL-38999 standard, insert arrangements uding multi-axial contacts (coax, twinax, quadrax, ...) should not be used in firewall aplications. EN3645 part numbers Basic Series EN3645 W 6 G N 35 B N Plating: W: Olive drab cadmium F: Nickel Shell style: 0: Square flange receptacle 6: Plug 7: Jam nut receptacle Shell size: 09=A, 11=B, 13=C, 15=D, 17=E, 19=F, 21=G, 23=H, 25=J Grounding: N: Standard insert not grounded Contact layout: See page 18 for layout according to EN3645 Contact type: A: Connector supplied less pin contact B: Connector supplied less socket contact F: Socket M: Pin Orientation: N, A, B, C, D, E (see page 75) 23 8D Series | D38999 Aluminum Series Dimensions Plug type 5 Receptacle type 1 ØB 31.45 Maxi ØA A Thread Thread Shell size Thread ØB Max Shell size Thread ØA 09 (A) M12 x 1-6g 21.80 09 (A) M12 x 1-6g 15.90 11 (B) M15 x 1-6g 25.00 11 (B) M15 x 1-6g 19.00 13 (C) M18 x 1-6g 29.40 13 (C) M18 x 1-6g 22.25 15 (D) M22 x 1-6g 32.50 15 (D) M22 x 1-6g 25.45 17 (E) A Max M25 x 1-6g 35.70 17 (E) M25 x 1-6g 30.20 19 (F) M28 x 1-6g 38.50 19 (F) M28 x 1-6g 31.75 21 (G) M31 x 1-6g 41.70 21 (G) M31 x 1-6g 34.95 23 (H) M34 x 1-6g 44.90 23 (H) M34 x 1-6g 38.10 25 (J) M37 x 1-6g 48.00 25 (J) M37 x 1-6g 41.30 31.00 Receptacle type 7 B A C D Ø G 22.6 Max Shell size A±0.15 09 (A) 11 (B) B Max C Max F±0.4 ØG Max 23 27 30.5 26 31.8 35.2 D Thread E Max 16.53 M12 x 1-6g 19.07 M15 x 1-6g 13 (C) 23.82 M18 x 1-6g 31 34.9 38.4 15 (D) 26.97 M22 x 1-6g 34 38.1 41.6 17 (E) 30.15 M25 x 1-6g 37 41.3 44.8 19 (F) 33.32 M28 x 1-6g 41 46 49.5 21 (G) 36.50 M31 x 1-6g 46 49.2 52.7 9.9 3.2 23 (H) 39.67 M34 x 1-6g 47 52.4 55.9 25 (J) 42.85 M37 x 1-6g 51.23 55.6 59 Recommended coupling torque on panel for jam nut receptacle (type 7) E F Note: All dimensions are in millimeters (mm) 24 Shell 09 (A) 11 (B) 13 (C) 15 (D) 17 (E) 19 (F) 21 (G) 23 (H) 25 (J) Coupling torque (±0.5 N.m) 4 5 7 8 9 10 12 13 14 8D Series | D38999 Aluminum Series Dimensions Receptacle type 0 A Shell size A Max B Max C Max E F G B 09 (A) H D J E±0.3 F G M12 x 1-6g 23.8 18.26 15.09 11 (B) M15 x 1-6g 26.2 20.62 18.26 13 (C) M18 x 1-6g 28.6 23.01 20.62 20.9 15 (D) C D Thread 10.72 2.5 M22 x 1-6g 31 24.61 23.01 17 (E) M25 x 1-6g 33.3 26.97 24.61 19 (F) M28 x 1-6g 36.5 29.36 26.97 21 (G) M31 x 1-6g 39.7 31.75 29.36 M34 x 1-6g 42.9 34.93 31.75 M37 x 1-6g 46 38.1 34.93 23 (H) 20.07 11.54 3.2 25 (J) H±0.2 J±0.2 5.49 4.93 3.25 4.45 4.93 3.91 6.15 Mated connectors Type 0 with plug Type 7 with plug C A B Shell size A Max B Max C Max D Max 09 to 11 37.00 52.30 38.30 53.60 13 to 19 37.00 52.30 38.50 53.80 21 to 25 36.00 51.30 38.50 53.80 D Dummy receptacle Shell size Part number A Max B Max C±0.30 A B C Coupling seal C F G E D D E F±0.20 G±0.20 09 8D0-09 • UR 20.90 2.50 23.80 18.26 15.09 4.49 3.25 11 8D0-11 • UR 20.90 2.50 26.20 20.62 18.26 4.93 3.25 13 8D0-13 • UR 20.90 2.50 28.60 23.01 20.62 4.93 3.25 15 8D0-15 • UR 20.90 2.50 31.00 24.61 23.01 4.93 3.25 17 8D0-17 • UR 20.90 2.50 33.30 26.97 24.61 4.93 3.25 19 8D0-19 • UR 20.90 2.50 36.50 26.97 24.61 4.93 3.25 21 8D0-21 • UR 20.10 3.20 39.70 31.75 29.36 4.93 3.25 23 8D0-23 • UR 20.10 3.20 42.90 34.93 31.75 6.15 3.91 25 8D0-25 • UR 20.10 3.20 46.00 38.10 34.93 6.15 3.91 • : " G" for Olive green cadmium; "F" for Nickel. Note: All dimensions are in millimeters (mm) 25 8D Series | D38999 Aluminum Series PC tail contacts lengths ØA #20 #16 #12 #22D L1 #20 #16 #12 #22D L2 #20 #16 #12 #22D L3 #20 #16 #12 M&F M&F M&F M&F M&F M M F F M M F F M M F F M M F F M M F F M&F M&F M&F M&F M&F M&F M M F F M M F F M M F F M M F F M M F F Max Max Max Max Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Max Max Max Max Max Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Note: All dimensions are in millimeters (mm) 26 PC tail type L&C S C C C L&C L&C L&C L&C S S S S C C C C C C C C C C C C L C S C C C L&C L&C L&C L&C S S S S C C C C C C C C C C C C Shell size 09 (A) 11 (B) 13 (C) 15 C) 17 (E) 19 (F) 21 (G) 23 (H) M: Male contact F: Female contact 0.70 0.50 0.70 1.15 1.65 10.52 11.46 10.19 11.46 10.19 11.46 10.69 11.63 10.36 11.63 10.69 11.63 10.69 11.63 10.69 11.63 10.63 11.56 10.63 11.56 L: Long PC tail C: Short PC tail S: Specific PC tail 10.34 11.28 10.01 11.28 10.01 11.28 10.51 11.45 10.18 11.45 10.51 11.45 10.51 11.45 10.51 11.45 10.45 11.38 10.45 11.38 Receptacle type 7 L1 L2 Receptacle type 0 L3 L2 8.50 4.00 5.10 5.10 5.10 5.10 9.48 10.58 9.15 10.58 9.65 10.75 9.15 10.75 9.65 10.75 9.65 10.75 9.64 10.75 9.64 10.75 10.25 11.21 10.25 11.21 25 (J) ØA #22D Contact type ØA Contact size 9.59 10.69 9.26 10.69 9.76 10.86 9.26 10.86 9.76 10.86 9.76 10.86 9.75 10.86 9.75 10.86 9.95 10.91 9.95 10.91 8D Series | D38999 Aluminum Series Connectors weight - in gram (±15%) With contacts Shell size & Layout 09 11 13 15 17 19 21 23 25 35 98 01 02 04 05 22 35 80 98 99 04 08 26 35 98 05 15 18 19 35 97 02 06 08 26 35 75 99 11 32 35 11 16 35 39 41 48 75 21 35 53 55 07 11 19 24 29 35 37 44 43 46 61 08 20 04 Plug (type 5) Without contacts Receptacle (type 0) Receptacle (type 7) Plug (type 5) Receptacle (type 0) Receptacle (type 7) Male Female Male Female Male Female Male Female Male Female Male Female 11.47 11.47 14.98 14.61 14.80 14.83 14.47 14.73 18.30 14.70 14.87 21.04 21.42 21.79 21.22 21.08 26.04 26.84 27.05 26.58 26.68 26.51 32.96 29.90 28.89 29.47 29.71 35.31 29.52 37.77 36.98 37.29 45.51 42.61 42.89 44.27 42.81 49.59 54.48 50.49 48.85 48.91 49.66 61.89 54.48 59.76 59.26 57.58 55.37 57.57 52.80 57.62 59.92 54.67 81.00 66.02 58.42 13.05 12.77 17.92 17.15 17.86 18.04 16.89 18.20 21.90 17.46 18.09 24.82 26.60 27.44 26.99 25.70 31.38 34.00 35.93 34.31 35.92 33.56 46.30 39.50 37.62 40.26 43.26 46.60 40.08 51.36 50.38 53.74 65.35 57.89 63.55 64.60 60.18 49.93 71.38 73.74 75.00 71.10 72.73 90.70 71.38 91.77 90.62 86.55 88.20 89.86 67.61 88.30 83.76 81.42 112.83 96.24 88.27 9.15 9.15 12.01 11.64 11.83 11.86 11.50 11.76 15.30 11.73 11.90 15.71 16.09 16.46 15.89 15.75 19.54 20.34 20.55 20.08 20.18 20.01 31.26 28.21 27.20 27.78 28.02 33.62 27.83 31.07 30.28 30.59 39.31 36.41 36.69 38.07 36.61 43.39 48.28 44.19 42.55 42.61 43.36 55.73 48.28 53.60 53.10 51.42 49.21 51.41 46.53 51.46 53.76 48.51 74.84 59.86 52.26 10.73 10.45 14.95 14.18 14.89 15.07 13.92 15.30 18.90 14.49 15.12 19.29 21.27 22.11 21.46 20.37 24.88 27.22 29.43 27.81 29.42 27.06 44.60 37.81 35.93 38.57 41.57 44.91 38.39 44.66 43.68 47.04 59.05 51.69 57.25 58.40 64.36 63.62 65.18 67.44 68.70 64.80 66.43 85.10 79.90 85.61 84.46 80.39 82.04 59.36 65.39 82.14 77.60 75.26 106.67 90.08 82.11 13.91 13.91 18.17 17.80 17.99 19.48 17.66 17.68 21.50 17.89 18.06 24.14 24.52 24.89 24.32 24.18 29.62 30.42 30.63 30.16 30.26 30.09 42.06 39.00 37.99 38.57 38.81 44.41 38.62 44.62 43.83 44.14 53.19 50.29 50.57 51.95 50.49 55.27 62.16 59.23 57.59 57.65 58.40 71.15 62.16 69.02 68.52 66.84 64.63 66.83 62.05 66.88 69.18 63.93 90.26 75.28 67.68 15.49 15.21 21.11 20.34 21.05 21.23 20.08 21.39 28.39 20.65 21.28 27.92 29.70 30.54 30.09 28.80 34.96 37.58 39.51 37.89 39.50 37.14 55.40 48.60 46.72 49.36 52.36 55.70 49.18 58.21 57.23 44.09 73.03 65.57 71.23 72.28 67.86 57.61 79.06 82.48 83.74 79.84 81.47 99.10 79.06 101.03 99.88 95.81 97.46 90.06 83.39 97.56 93.02 90.68 122.09 105.50 97.53 11.05 11.05 14.32 13.99 14.24 14.13 14.19 13.82 13.80 13.86 13.89 19.80 20.30 20.05 19.68 19.68 24.49 24.57 24.53 23.92 24.09 24.15 25.80 25.94 26.41 25.83 25.86 26.31 25.96 34.36 32.50 32.67 38.25 37.65 37.36 38.47 37.07 36.48 36.48 43.98 41.85 41.49 41.96 46.41 36.48 47.22 47.62 48.59 46.41 46.10 44.40 48.20 45.28 46.13 45.00 44.45 49.22 11.55 11.57 16.32 15.59 16.26 16.04 15.89 14.95 14.90 15.06 15.29 21.70 23.40 22.74 21.49 21.70 27.48 27.62 28.73 26.71 26.67 27.24 29.80 29.90 31.38 29.86 29.51 32.60 30.12 42.78 37.58 37.24 47.75 45.41 43.80 48.24 43.78 43.38 43.38 57.36 50.00 49.90 50.73 56.20 43.38 61.37 62.06 63.93 56.20 61.00 59.22 63.50 55.44 57.02 56.83 54.70 62.83 8.73 8.73 11.35 11.02 11.27 11.16 11.22 10.85 10.80 10.89 10.92 14.47 14.97 14.72 14.35 14.35 17.99 18.07 18.03 17.42 17.59 17.65 24.10 24.25 24.72 24.14 24.17 24.62 24.27 27.66 25.80 25.97 32.05 31.45 31.16 32.27 30.87 30.28 30.28 37.68 35.55 35.19 35.66 40.25 42.94 41.06 41.46 42.43 40.25 39.94 38.14 42.04 39.12 39.97 38.84 38.29 43.06 9.23 9.25 13.35 12.62 13.29 13.07 12.92 12.05 11.90 12.09 12.32 16.17 18.07 17.41 15.96 16.37 20.98 20.84 22.23 20.21 20.17 20.74 28.10 28.21 29.69 28.17 27.82 30.91 28.43 46.43 41.23 40.89 41.45 49.59 37.50 52.42 47.96 36.70 37.18 62.20 54.84 54.74 55.57 61.26 56.60 66.43 67.12 68.99 61.26 60.50 57.00 68.56 60.50 62.08 61.69 59.76 67.89 13.49 13.49 17.51 17.18 17.43 17.32 17.38 17.01 17.00 17.05 17.08 22.90 23.40 23.15 22.78 22.78 28.07 28.15 28.11 27.50 27.67 27.73 34.90 35.04 35.51 34.93 34.96 35.41 35.06 30.86 29.00 29.17 35.55 34.95 34.66 35.77 34.37 44.16 44.16 41.58 39.45 39.09 39.56 44.45 58.36 45.26 45.66 46.63 44.45 55.36 53.66 46.24 43.32 44.17 43.04 42.49 47.26 13.99 14.01 19.51 18.78 19.45 19.23 19.08 18.14 18.10 18.25 18.48 24.80 26.50 25.84 24.59 24.80 31.06 31.20 32.31 30.29 30.25 30.82 38.90 39.00 40.48 38.96 38.61 41.70 39.22 49.63 44.43 44.09 55.43 53.09 51.48 55.92 51.46 51.06 51.06 66.10 58.74 58.64 59.47 65.46 71.36 70.63 71.32 73.19 65.46 61.20 75.00 72.76 64.70 66.28 66.09 63.96 72.09 27 8D Series | D38999 Aluminum Series SOURIAU aluminum backshells Ordering information Basic Series 8D AB 05 A 17 W Accessories type Type: 01: Backnut 04: Crimp ring 02: Cable clamp 05: Band lock 03: Shrink boot Angle: A: Straight B: 90° (Type 02 only) Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Finish: Z: Black zinc nickel W: Olive green cadmium F: Nickel A: Black anodized Self locking option: None S: Self locking (available for Types 01 & 02 - mandatory for Type 05) Cable entry (Type 05 only): 02, 03 (03 mandatory for shell size 09 & 11) Drain hole option: None D: Drain hole (Type 03 only) Dimensions Aluminum backshell Type 01 - Backnut 9.65 Max (Self locking type) ØA Thread ØB 6.35 Max (Non self locking type) Shell size ØA Min ØB Max 09 6.7 17.9 11 9.95 20.9 13 12.85 24.3 15 17.0 27.9 17 19.25 31.3 19 21.7 35.3 21 24.7 38.1 23 27.8 41.5 25 32.0 44.5 Thread: See page 30 for information. Note: All dimensions are in millimeters (mm) 28 S 02 - 8D Series | D38999 Aluminum Series SOURIAU aluminum backshells Aluminum backshell Type 02 - Cable clamp A Angle - straight B Angle - 90° F C Thread C ØB ØA Thread ØB D ØA E ØA Shell size Min Max 09 2.49 11 13 ØB Max C Max D Max E Max F Max 5.94 17.9 21.5 23.1 29.5 20 3.89 5.94 20.9 21.5 23.1 29.5 21.5 4.83 8.33 24.3 24.5 25.6 31.5 23.5 15 6.60 11.61 27.9 27.5 26.9 35.8 25.5 17 7.19 15.6 31.3 31.5 29.4 40.1 27.5 19 8.26 16.1 35.3 35.5 35.8 40.6 30.5 21 8.71 17.73 38.1 37 38.3 42.7 31.5 23 9.68 20.9 41.5 40.5 42.1 46.2 34.5 25 10.62 21.67 44.5 45 44.7 49 36.5 Thread: See page 30 for information. Aluminum backshell Type 03 - Shrink boot Shell size ØC ØA Thread ØB 18 Max ØA Min ØB Max C Max 09 6.7 19.0 11.3 11 9.95 21.5 14.9 13 12.85 25.3 17.8 15 16.05 29.1 21.27 17 19.2 31.7 24.3 19 21.5 35.5 26.4 21 24.7 39.3 30.8 23 27.8 41.8 34.1 25 31 46.9 36.6 Thread: See page 30 for information. Note: All dimensions are in millimeters (mm) 29 8D Series | D38999 Aluminum Series SOURIAU aluminum backshells Aluminum backshell Type 04 - Crimp ring Shell size ØA Thread ØB 22 Max ØA Min ØB Max 09 6 17.9 11 8.2 20.9 13 10.5 24.3 15 13.6 27.9 17 16.9 31.3 19 20 34.3 21 23.2 38.1 23 26.1 41.5 25 28.1 44.4 Thread: See below for information. Aluminum backshell Type 05 - Band lock Shell size 34 Max ØA Thread ØB 09 ØA Max - Entry size 02 03 - 6.6 17.9 11 - 8 24.9 13 8 11.2 29.3 15 11.2 14.4 32.4 17 12.8 16 35.6 19 16 19.1 38.4 21 16 20.7 41.6 23 17.6 23.9 44.8 25 19.1 25.5 47.9 Thread: See below for information. Recommended installation torque Shell Size Installation Torque (Inch-Pounds) 09, 11, 13, 15, 17 & 19 40 21, 23 & 25 80 Note: Torque values are based on 80% of the coupling thread strength specified in SAE-AS85049 standard. Note: All dimensions are in millimeters (mm) 30 ØB Max Thread information Shell size UNEF Thread 09 M12x1.0-6H-0.10R 11 M15x1.0-6H-0.10R 13 M18x1.0-6H-0.10R 15 M22x1.0-6H-0.10R 17 M25x1.0-6H-0.10R 19 M28x1.0-6H-0.10R 21 M31x1.0-6H-0.10R 23 M34x1.0-6H-0.10R 25 M37x1.0-6H-0.10R 8D Series | D38999 Aluminum Series M85049 aluminum backshells Backshells - Cable clamp Straight cable clamp (Type 38) 90° cable clamp (Type 39) F C E D ØB ØB A A D Shell size 09 11 13 15 17 19 21 23 25 A Min 2.50 3.90 4.80 6.60 7.20 8.30 8.70 9.70 10.60 Max 5.90 5.90 8.30 11.60 15.60 16.10 17.70 20.90 21.70 ØB Max C Max D Max E F 21.80 25.00 29.40 32.50 35.70 38.50 41.70 44.90 48.00 23.10 23.10 25.70 26.90 29.50 35.80 38.40 42.20 44.70 21.60 22.90 27.90 29.20 33.00 38.10 40.60 43.20 45.70 25.40 27.90 27.90 31.80 33.00 34.30 40.60 44.50 47.00 25.70 25.70 30.70 32.00 35.80 38.40 42.20 44.70 48.50 Basic Series M85049 38 - 11 W Backshell type: 38: Straight cable clamp 39: 90° cable clamp Nut type: - : Without self-locking S: With self-locking Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Plating: Type 38 & 39: A: Black anodized (500 hours salt spray) W: Olive drab cadmium over nickel (500 hours salt spray) Type 38S & 39S: W: Olive drab cadmium over nickel (500 hours salt spray) N: Nickel (48 hours salt spray) Note: All dimensions are in millimeters (mm) 31 8D Series | D38999 Aluminum Series M85049 aluminum backshells Backshells for heat shrink boots Backshell for heat shrink boots (Type 69) Straight backshell for EMI/RFI heat shrink boots (Type 88) ØA Max ØB Max ØC Max Shell size ØA Max 09 11 13 15 17 19 21 23 25 19.10 21.60 25.40 29.20 31.80 35.60 39.40 41.90 47.00 6.35 9.50 12.70 15.90 19.00 20.60 23.80 27.00 30.20 13.55 15.40 19.70 21.30 24.50 26.50 30.90 34.40 36.65 09 11 13 15 17 19 21 23 25 21.79 24.99 29.39 32.49 35.71 38.51 41.71 44.91 47.98 Basic Series Backshell type: 69: Backshell for heat shrink boots 88: Straight backshell for EMI/RFI heat shrink boots Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Plating: Type 69: A: Black anodised (500 hours salt spray) Type 88: W: Olive drab cadmium N: Nickel Option (Type 69 only): Empty: Without drain hole D: With drain hole Entry size (Type 88 only): 02: See table above 03: See table above Note: All dimensions are in millimeters (mm) 32 ØB ØA ØC ØB ØA Shell size ØB±0.10 Entry size 02 03 6.35 7.92 7.92 11.13 11.13 14.27 12.70 15.88 15.88 19.05 15.88 20.62 17.47 23.83 19.05 25.40 M85049 69 ØC 40.65 Max 19.60 Max ØC 02 11.61 14.81 16.38 19.56 19.56 21.06 22.73 11 03 10.03 11.61 14.81 17.96 19.56 22.73 24.30 27.51 29.08 A D 8D Series | D38999 Aluminum Series M85049 aluminum backshells Backshell for screen termination and cable clamp Backshell for screen termination and cable clamp (Type 19) 33.3 Max Shell size A Max B Max Clamp indicator base on shell size D B ØC A C Clamp size indicator Min Max D 09 19.10 01 - 02 01 1.60 3.20 20.30 11 21.60 01 - 02 - 03 02 3.20 6.35 25.40 02 - 03 - 04 03 6.35 9.50 27.90 02 - 03 - 04 - 05 04 7.90 12.70 30.50 05 11.10 15.90 31.80 06 14.30 19.00 35.60 07 17.45 22.20 38.10 13 25.40 15 27.90 17 31.80 02 - 03 - 04 - 05 - 06 19 35.60 03 - 04 - 05 - 06 - 07 21 38.10 03 - 04 - 05 - 06 - 07 - 08 08 20.60 24.40 41.90 23 41.90 03 - 04 - 05 - 06 - 07 - 08 09 23.80 28.60 44.50 25 44.50 04 - 05 - 06 - 07 - 08 - 10 10 27.00 31.75 48.30 38.10 Basic Series M85049 19 11 W 03 Shell style: 19: Backshell for screen termination and cable clamp Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Plating: W: Olive drab cadmium N: Nickel Clamp size indicator: See tables above 8599-9344 8599-9345 8599-9346 4.0 (REF.) 362.1 ±1.5 6.1 (REF.) Hand banding tool Tail length indicator mark 0.5 (REF.) Pre-coiled stainless steel standard band 1.9 (REF.) Part number Flat stainless steel standard band 8.9 (REF.) Band-it Note: All dimensions are in millimeters (mm) 33 8D Series | D38999 Aluminum Series Aluminum caps SOURIAU part number Basic Series 8D AC MIL-DTL-38999 part number 5 R 09 W Basic Series AC: Aluminum caps D38999 / 32 W 09 Caps style 32: Plug caps 33: Receptacle caps Caps style: 5: Plug caps 0: Receptacle caps Finish W: Olive drab cadmium F: Nickel Z: Black zinc nickel Accessories N: With stainless steel rope and ring R: With stainless steel rope and eyelet Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Accessories N: With stainless steel rope and ring R: With stainless steel rope and eyelet Finish W: Olive drab cadmium F: Nickel Z: Black zinc nickel A: Black anodized Dimensions Aluminum caps with stainless steel rope 20 Max. For receptacle 25 Max. For plug Thread stub ACME 2A modified 60° Thread stub ACME 2B modified 60° ØA Max. ØB Max. 130±4 with eyelet 130±4 ØC +0.2 -0 with ring Note: All dimensions are in millimeters (mm) 34 ØC for plug ØC for receptacle Size ØA ØB 09 22.6 22.8 15 18.4 0.6250-0.1P-0.3L-TS 11 25.8 26.5 18.4 23.2 0.7500-0.1P-0.3L-TS 13 30 30 23.2 26.5 0.8750-0.1P-0.3L-TS 15 33 31.8 23.2 30.3 1.0000-0.1P-0.3L-TS 17 36.5 36.8 26.5 32.6 1.1875-0.1P-0.3L-TS 19 39.2 38.8 30.3 36.5 1.2500-0.1P-0.3L-TS 21 42.5 41.8 32.6 39.3 1.3750-0.1P-0.3L-TS 23 45.8 44.8 36.5 42.9 1.5000-0.1P-0.3L-TS 25 48.9 48.8 39.3 45 1.6250-0.1P-0.3L-TS Ø4.3±0.05 Thread R 8D Series | D38999 Composite Series Connector part numbers Basic Series 8D 0 - 11 J 35 P N L Shell style: 0: Square flange receptacle 5: Plug with RFI shielding Type: - : Connectors with standard crimp contacts. L: Receptacle with long PC tail (male and female size #22D, #20). C: Receptacle with short PC tail (male and female #22D, #20, #16, #12). S: Receptacle with specific PC tail (male et female #22D) W: Receptacle with male contacts #22D for wire wrap (3 wraps) T: Receptacle with male contacts #20 for wire wrap (2 wraps) P: Receptacle with solder cup contacts - see page 69, please consult us Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Plating: J: Olive drab cadmium M: Nickel X: Without plating Contact layout: See pages 13 to 19 Contact type: P: Pin (500 mating/unmating) H: Pin (1500 mating/unmating) A: Connector supplied less pin contact or with specific contacts (connector marking: A + orientation) S: Socket (500 mating/unmating) J: Socket (1500 mating/unmating) B: Connector supplied less socket contact or with specific contacts (connector marking: B + orientation) Orientation: N, A, B, C, D, E, T, V (see page 75) Specification: 046: Tinned straight PC tail 251: Connector provided with power contacts (layouts with contact #8) 022: Fuel tank 600: 230V qualified connector (T or V orientation mandatory - Consult us for available layouts) Special custom: None: Standard plastic cap M: Antistatic plastic cap L: For P or S contact type only, connectors delivered without contacts, connectors marking P or S plus orientation. Note: PC tail contacts without shoulder also available. Please see page 132. BACC part numbers Basic Series: BACC63CT: 8D5*M (composite plug) BACC63CU: 8D0*M (composite square flange receptacle) BACC63CT 13 - 98 P N H Shell size: 09=A, 11=B, 13=C, 15=D, 17=E, 19=F, 21=G, 23=H, 25=J Plating & grounding: - : Nickel plated, ungrounded G: Nickel plated, grounded D: Cadmium plated, ungrounded C: Cadmium plated, grounded Contact layout: See page 18 for layout according to BACC Contact type: P: Pin S: Socket Orientation: N, A, B, C, D, E (see page 75) Specification: None: With contacts H: Without contact & without filler plug 35 8D Series | D38999 Composite Series MIL-DTL-38999 part numbers Basic Series D38999/ 20 M B 35 P N L Shell style: 20: Square flange receptacle 26: Plug with RFI shielding. Plating: J: Olive drab cadmium M: Nickel Shell size: 09=A, 11=B, 13=C, 15=D, 17=E, 19=F, 21=G, 23=H, 25=J Contact layout: See page 18 for layout according to MIL-DTL-38999 Contact type: P: Pin (500 mating/unmating) H: Pin (1500 mating/unmating) A: Connector supplied less pin contact or with specific contacts (connector marking: A + orientation) S: Socket (500 mating/unmating) J: Socket (1500 mating/unmating) B: Connector supplied less socket contact or with specific contacts (connector marking: B + orientation) Orientation: N, A, B, C, D, E (see page 75) L: For P or S contact type only, connector delevired without contacts, connector marking P or S (without L) Note: To place an order of MIL connectors delivered without MIL removable crimp contacts and keep P or S plus orientation marking, it must be specify clearly on the order (by adding a suffix L at the end of the P/N or specified in comment). Delivered with MIL contacts mandatory. As stated in MIL-DTL-38999 standard, insert arrangements uding multi-axial contacts (coax, twinax, quadrax, ...) should not be used in firewall aplications. EN3645 part numbers Basic Series Plating: J: Olive drab cadmium M: Nickel Shell style: 0: Square flange receptacle 6: Plug Shell size: 09=A, 11=B, 13=C, 15=D, 17=E, 19=F, 21=G, 23=H, 25=J Grounding: N: Standard insert not grounded Contact layout: See page 18 for layout according to EN3645 Contact type: A: Connector supplied less pin contact B: Connector supplied less socket contact F: Socket M: Pin Orientation: N, A, B, C, D, E (see page 75) 36 EN3645 J 6 G N 35 B N 8D Series | D38999 Composite Series Dimensions Receptacle type 0 A B Shell size A Max B Max C Max 09 (A) D 11 (B) C 13 (C) E F G 15 (D) 19.65 11.96 3.65 17 (E) E±0.3 F G M12 x 1-6g 23.8 18.26 15.09 M15 x 1-6g 26.2 20.62 18.26 M18 x 1-6g 28.6 23.01 20.62 M22 x 1-6g 31 24.61 23.01 M25 x 1-6g 33.3 26.97 24.61 19 (F) 3.7 M28 x 1-6g 36.5 29.36 26.97 21 (G) 4.35 M31 x 1-6g 39.7 31.75 29.36 M34 x 1-6g 42.9 34.93 31.75 M37 x 1-6g 46 38.1 34.93 23 (H) H D Thread 18.85 25 (J) 12.76 4.4 H±0.2 J±0.2 5.49 4.93 3.25 4.39 4.93 3.91 6.15 J Plug type 5 A Mated connectors ØB Type 0 with plug A B Thread Shell size Thread ØB Max Shell size 09 (A) A Max M12 x 1-6g 21.80 09 (A) 11 (B) M15 x 1-6g 25.00 11 (B) 13 (C) M18 x 1-6g 29.40 13 (C) 15 (D) M22 x 1-6g 32.50 15 (D) M25 x 1-6g 35.70 17 (E) 17 (E) 31.00 19 (F) M28 x 1-6g 38.50 19 (F) 21 (G) M31 x 1-6g 41.70 21 (G) 23 (H) M34 x 1-6g 44.90 23 (H) 25 (J) M37 x 1-6g 48.00 25 (J) A Max B Max 37.00 52.30 36.00 51.30 Note: All dimensions are in millimeters (mm) 37 8D Series | D38999 Composite Series PC tail contacts lengths #22D ØA #20 #16 #12 #22D L1 #20 #16 #12 #22D L2 #20 #16 #12 Contact type M&F M&F M&F M&F M&F M&F M&F M&F M&F M&F M&F M M F F M M F F M M F F M M F F M M F F Max Max Max Max Max Max Max Max Max Max Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Note: All dimensions are in millimeters (mm) 38 PC tail type L&C S C C C L C S C C C L&C L&C L&C L&C S S S S C C C C C C C C C C C C Shell size 09 (A) 11 (B) 13 (C) 15 C) 17 (E) 19 (F) 21 (G) 23 (H) M: Male contact F: Female contact 0.70 0.50 0.70 1.15 1.65 8.50 4.00 5.10 5.10 5.10 5.10 9.48 10.38 9.15 10.38 9.65 10.55 9.32 10.55 9.65 10.55 9.65 10.55 9.65 10.55 9.65 10.55 9.66 10.53 9.66 10.53 25 (J) L: Long PC tail C: Short PC tail S: Specific PC tail Receptacle type 0 L2 L1 9.59 10.48 9.26 10.48 9.76 10.65 9.42 10.65 9.76 10.65 9.76 10.65 9.76 10.65 9.76 10.65 9.76 10.63 9.76 10.63 ØA Contact size 8D Series | D38999 Composite Series Connectors weight - in gram (±15%) Shell size & Layout 09 11 13 15 17 19 21 23 25 35 98 01 02 04 05 22 35 80 98 99 04 08 26 35 98 05 15 18 19 35 97 02 06 08 26 35 75 99 11 32 35 11 16 35 39 41 48 75 21 35 53 55 07 11 19 24 29 35 37 44 43 46 61 08 20 04 With contacts Plug (type 5) Without contacts Receptacle (type 0) Plug (type 5) Receptacle (type 0) Male Female Male Female Male Female Male Female 8.5 8.5 12.8 11.5 12.6 12.6 11.4 12.5 15.2 12.5 11.8 17.2 17.6 17.9 17.4 17.2 21.4 22.2 22.4 22.0 22.0 21.8 26.5 25.9 24.9 25.5 25.7 31.3 25.5 32.1 31.3 31.6 38.0 35.1 35.4 36.8 35.3 42.4 47.3 43.1 41.4 41.5 42.2 53.6 59.1 51.7 51.2 49.5 47.3 49.3 69.6 49.6 51.9 46.6 72.9 57.9 50.4 10.1 9.8 15.7 14.1 15.7 15.8 13.8 16.0 18.6 15.3 15.0 20.9 22.8 23.6 23.1 21.8 26.7 29.3 31.3 29.6 31.3 28.9 38.8 35.5 33.6 36.3 39.3 42.6 36.1 45.7 44.7 48.1 57.9 50.4 56.1 57.1 52.7 62.4 64.2 66.3 67.5 63.6 65.3 90.05 81.6 83.7 82.5 78.5 80.1 80.4 93.7 80.2 75.7 73.4 104.8 88.2 80.2 7.8 7.8 10.4 09.3 10.2 10.2 9.1 10.1 13.4 10.1 9.6 13.7 14.1 14.4 13.8 13.7 16.6 17.4 17.6 17.1 17.2 17.1 25.2 23.2 22.2 22.8 23.0 28.6 22.8 26.1 25.3 25.6 32.8 29.9 30.1 31.5 30.1 37.7 42.6 38.0 36.3 36.4 42.2 49.0 54.5 46.6 46.1 44.4 42.2 45.5 65.0 44.4 46.7 41.5 67.8 52.8 45.3 9.4 9.1 13.3 11.8 13.3 13.4 11.6 13.61 10.4 12.9 12.8 17.44 19.2 20.1 19.61 18.3 21.9 24.51 26.5 24.8 26.5 24.1 37.6 32.8 30.1 33.6 36.6 39.9 33.4 39.7 38.7 42.0 52.62 45.2 50.82 51.9 47.5 57.19 59.50 61.2 62.5 58.6 60.2 84.8 72.79 78.6 77.4 73.4 75.0 76.2 94.6 75.1 70.1 68.2 99.6 83.0 75.0 8.1 8.1 12.1 10.9 12.0 11.9 11.1 11.6 10.7 11.7 10.8 15.6 16.5 16.2 15.8 15.8 19.8 19.9 19.9 19.2 19.4 19.4 19.3 21.9 22.4 21.8 21.9 22.3 22.0 28.7 26.8 27.1 30.8 30.2 29.9 31.0 29.6 29.3 29.3 36.5 34.4 34.1 34.5 37.8 40.8 39.2 39.6 40.5 38.4 37.8 36.1 40.1 37.2 38.1 36.9 36.4 41.2 8.6 8.6 14.1 12.5 14.1 13.8 12.8 12.8 11.6 12.8 12.2 17.9 19.6 18.9 17.6 17.9 22.8 23.0 24.0 22.0 22.0 22.6 22.3 25.9 27.4 25.9 25.5 28.6 26.1 37.1 31.9 31.6 40.3 37.9 36.3 40.8 36.3 36.2 36.2 49.9 42.5 42.4 43.3 51.8 53.8 53.3 54.0 55.9 48.1 51.5 45.8 55.4 47.4 48.9 48.8 46.6 54.8 7.4 7.4 9.7 8.7 9.7 9.5 8.8 9.2 8.9 9.3 8.6 12.4 12.9 12.7 12.3 12.3 15.0 15.1 15.0 14.5 14.6 14.7 18.1 19.2 19.7 19.2 19.2 19.6 19.3 22.7 20.8 21.0 25.5 24.9 24.6 25.7 24.3 24.6 24.6 31.5 29.3 29.0 29.4 33.2 36.2 34.0 34.4 35.4 33.2 34.0 31.5 35.0 32.1 32.9 31.8 31.3 36.1 7.9 7.9 11.7 10.3 11.7 11.5 10.6 10.36 9.4 10.5 10.0 14.32 16.1 15.4 14.11 14.3 18.0 18.13 19.2 17.2 17.2 17.8 21.1 23.2 24.7 23.1 22.8 25.9 23.4 31.1 25.9 25.6 35.02 32.7 31.07 35.5 31.0 30.27 31.5 44.8 37.5 37.4 38.2 46.6 49.49 48.2 48.9 50.7 43.0 47.3 46.7 50.3 42.2 43.8 43.6 41.5 49.6 39 8D Series | D38999 Composite Series M85049 composite backshells Dimensions & Ordering Straight backshell for EMI/RFI heat shrink boots (Type 88) Straight cable clamp (Type 91) 90° cable clamp (Type 92) F G D ØA H ØE ØA ØB ØC ØA 40.65 Max ØE ØB±0.10 Entry size ØA Max 09 21.80 11 25.00 N/A 7.92 N/A 11.61 26.00 6.70 24.30 23.80 27.95 13 29.40 7.92 11.13 11.61 14.81 30.50 8.75 27.95 26.20 30.00 15 32.50 11.13 14.27 14.81 17.96 33.00 11.70 27.95 28.60 33.00 17 35.70 12.70 15.88 16.38 19.56 36.10 13.85 31.25 33.30 35.05 19 38.50 15.88 19.05 19.56 22.73 38.60 15.60 35.80 34.95 36.85 21 41.70 15.88 20.62 19.56 24.30 41.65 17.75 38.35 38.10 39.15 23 44.90 17.47 23.83 21.06 27.51 45.00 19.80 42.15 41.30 41.15 25 48.00 19.05 25.40 22.73 29.08 48.00 21.60 44.70 44.45 42.95 02 03 02 03 N/A 6.35 N/A 10.03 Basic Series Backshell type: 88: Straight backshell for EMI/RFI heat shrink boots 91: Straight cable clamp 92: 90° cable clamp Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Plating: J: Olive drab cadmium over electroless nickel M: Electroless nickel T: Without plating (Type 91 & 92 only) Entry size (Type 88 only): 02: See table above 03: See table above Note: All dimensions are in millimeters (mm) 40 ØC Entry size Shell size D Max E Max F Max G H 24.90 5.55 21.25 22.20 26.95 M85049 91 11 M 8D Series | D38999 Stainless Steel Series Connector part numbers Basic Series 8D 0 - 11 K 35 P N - 98 L Shell style: 0: Square flange receptacle 7: Jam nut receptacle 5: Plug with RFI shielding Type: - : Connectors with standard crimp contacts L: Receptacle with long PC tail (male and female size #22D, #20) C: Receptacle with short PC tail (male and female #22D, #20, #16, #12) S: Receptacle with specific PC tail (male et female #22D) W: Receptacle with male contacts #22D for wire wrap (3 wraps) T: Receptacle with male contacts #20 for wire wrap (2 wraps) P: Receptacle with solder cup contacts - see page 68, please consult us Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Plating: K: Passivated S: Nickel Contact layout: See pages 13 to 19 Contact type: P: Pin A: Connector supplied less pin contact or with specific contacts (connector marking: A + orientation) S: Socket B: Connector supplied less socket contact or with specific contacts (connector marking: B + orientation) Orientation: N, A, B, C, D, E, T, V (see page 75) Specification: 046: Tinned straight PC tail 251: Connector provided with power contacts (layouts with contact #8) 022: Fuel tank 600: 230V qualified connector (T or V orientation mandatory - Consult us for available layouts) Special custom: None: Standard plastic cap M: Antistatic plastic cap L: For P or S contact type only, connectors delivered without contacts, connectors marking P or S plus orientation. Note: PC tail contacts without shoulder also available. Please see page 132. 8DV plug with reinforced locking available. Please see page 122. BACC part numbers Basic Series: BACC63DB: 8D5*K (stainless steel plug) BACC63DC: 8D0*K (stainless steel square flange receptacle) BACC63DB 13 P N H Shell size: 09=A, 11=B, 13=C, 15=D, 17=E, 19=F, 21=G, 23=H, 25=J - : Separator (mandatory) Contact layout: See page 18 for layout according to BACC Contact type: P: Pin S: Socket Orientation: N, A, B, C, D, E (see page 75) Specification: None: With contacts H: Without contact & without filler plug 41 8D Series | D38999 Stainless Steel Series MIL-DTL-38999 part numbers Basic Series D38999/ 20 K B 35 P N L Shell style: 20: Square flange receptacle 24: Jam nut receptacle 26: Plug with RFI shielding Plating: K: Passivated S: Nickel Shell size: 09=A, 11=B, 13=C, 15=D, 17=E, 19=F, 21=G, 23=H, 25=J Contact layout: See page 18 for layout according to MIL-DTL-38999 Contact type: P: Pin A: Connector supplied less pin contact or with specific contacts (connector marking: A + orientation) S: Socket B: Connector supplied less socket contact or with specific contacts (connector marking: B + orientation) Orientation: N, A, B, C, D, E (see page 75) L: For P or S contact type only, connector delivered without contacts, connector marking P or S (without L) Note: To place an order of MIL connectors delivered without MIL removable crimp contacts and keep P or S plus orientation marking, it must be specify clearly on the order (by adding a suffix L at the end of the P/N or specified in comment). Delivered with MIL contacts mandatory. As stated in MIL-DTL-38999, class K connectors with #8 cavities may not meet the firewall requirement. EN3645 part numbers Basic Series Plating: K: Stainless steel passivated Shell style: 0: Square flange receptacle 6: Plug 7: Jam nut receptacle Shell size: 09=A, 11=B, 13=C, 15=D, 17=E, 19=F, 21=G, 23=H, 25=J Grounding: N: Standard insert not grounded Contact layout: See page 18 for layout according to EN3645 Contact type: A: Connector supplied less pin contact B: Connector supplied less socket contact F: Socket M: Pin Orientation: N, A, B, C, D, E (see page 75) 42 EN3645 K 6 G N 35 B N 8D Series | D38999 Stainless Steel Series Dimensions Receptacle type 0 (8D) or type 20 (D38999) A B D Thread E±0.3 F G 09 (A) M12 x 1-6g 23.8 18.26 15.09 11 (B) M15 x 1-6g 26.2 20.62 18.26 13 (C) M18 x 1-6g 28.6 23.01 20.62 15 (D) M22 x 1-6g 31 24.61 23.01 17 (E) M25 x 1-6g 33.3 26.97 24.61 19 (F) M28 x 1-6g 36.5 29.36 26.97 21 (G) M31 x 1-6g 39.7 31.75 29.36 M34 x 1-6g 42.9 34.93 31.75 M37 x 1-6g 46 38.1 34.93 Shell size D C A Max B Max C Max H±0.2 J±0.2 5.49 4.93 20.2 E F G H 23 (H) 11.4 19.8 2.5 11.8 3.2 3.25 4.93 3.91 25 (J) 4.4 6.15 J Receptacle type 7 (8D) or type 24 (D38999) C A B D Ø G 22.6 Max Shell size A±0.15 D Thread E Max F±0.4 ØG Max 09 (A) 16.53 M12 x 1-6g 23 27 30.5 11 (B) 19.07 M15 x 1-6g 26 31.8 35.2 13 (C) 23.82 M18 x 1-6g 31 34.9 38.4 15 (D) 26.97 M22 x 1-6g 34 38.1 41.6 17 (E) 30.15 M25 x 1-6g 37 41.3 44.8 19 (F) 33.32 M28 x 1-6g 41 46 49.5 21 (G) 36.50 M31 x 1-6g 46 49.2 52.7 23 (H) 39.67 M34 x 1-6g 47 52.4 55.9 25 (J) 42.85 M37 x 1-6g 51.23 55.6 59 B Max 9.9 C Max 3.2 Recommended coupling torque on panel for jam nut receptacle (type 7) E F Shell 09 (A) 11 (B) 13 (C) 15 (D) 17 (E) 19 (F) 21 (G) 23 (H) 25 (J) Coupling torque (±0.5 N.m) 4 5 7 8 9 10 12 13 14 Note: All dimensions are in millimeters (mm) 43 8D Series | D38999 Stainless Steel Series Dimensions Plug type 5 (8D) or type 26 (D38999) 8D type 5 & D38999 type 26 A Shell size ØB A Max Thread ØB Max 09 (A) M12 x 1-6g 21.80 11 (B) M15 x 1-6g 25.00 13 (C) M18 x 1-6g 29.40 15 (D) M22 x 1-6g 32.50 M25 x 1-6g 35.70 17 (E) Thread 31.00 19 (F) M28 x 1-6g 38.50 21 (G) M31 x 1-6g 41.70 23 (H) M34 x 1-6g 44.90 25 (J) M37 x 1-6g 48.00 8DV plug with reinforced locking available. Please see page 122. Mated connectors dimensions Type 0 with plug Type 7 with plug C A Shell size A Max B Max 09 (A) 11 (B) 13 (C) 15 (D) 37.00 C Max D Max 38.30 53.60 38.50 53.80 52.30 17 (E) 19 (F) 21 (G) B D 23 (H) 25 (J) Note: All dimensions are in millimeters (mm) 44 36.00 51.30 8D Series | D38999 Stainless Steel Series PC tail contacts lengths ØA #20 #16 #12 #22D L1 #20 #16 #12 #22D L2 #20 #16 #12 #22D L3 #20 #16 #12 M&F M&F M&F M&F M&F M M F F M M F F M M F F M M F F M M F F M&F M&F M&F M&F M&F M&F M M F F M M F F M M F F M M F F M M F F Max Max Max Max Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Max Max Max Max Max Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max PC tail type L&C S C C C L&C L&C L&C L&C S S S S C C C C C C C C C C C C L C S C C C L&C L&C L&C L&C S S S S C C C C C C C C C C C C Shell size 09 (A) 11 (B) 13 (C) 15 C) 17 (E) 19 (F) 21 (G) 23 (H) M: Male contact F: Female contact 0.70 0.50 0.70 1.15 1.65 10.52 11.46 10.19 11.46 10.19 11.46 10.69 11.63 10.36 11.63 10.69 11.63 10.69 11.63 10.69 11.63 10.63 11.56 10.63 11.56 25 (J) L: Long PC tail C: Short PC tail S: Specific PC tail 10.34 11.28 10.01 11.28 10.01 11.28 10.51 11.45 10.18 11.45 10.51 11.45 10.51 11.45 10.51 11.45 10.45 11.38 10.45 11.38 Receptacle type 7 L1 L2 ØA #22D Contact type Receptacle type 0 L3 L2 ØA Contact size 8.50 4.00 5.10 5.10 5.10 5.10 9.48 10.58 9.15 10.58 9.65 10.75 9.15 10.75 9.65 10.75 9.65 10.75 9.64 10.75 9.64 10.75 10.25 11.21 10.25 11.21 9.59 10.69 9.26 10.69 9.76 10.86 9.26 10.86 9.76 10.86 9.76 10.86 9.75 10.86 9.75 10.86 9.95 10.91 9.95 10.91 Note: All dimensions are in millimeters (mm) 45 8D Series | D38999 Stainless Steel Series Connectors weight - in gram (±15%) Shell size & Layout 09 11 13 15 17 19 21 23 25 46 35 98 01 02 04 05 22 35 80 98 99 04 08 26 35 98 05 15 18 19 35 97 02 06 08 26 35 75 99 11 32 35 11 16 35 39 41 48 75 21 35 53 55 07 11 19 24 29 35 37 44 43 46 61 08 20 04 With contacts Plug 8D (type 5) Plug 8DV (type 5) Recep. (type 0) Male Female Male Female Male Female 30.63 32.21 32.53 34.11 23.93 25.51 30.63 31.93 32.53 33.83 23.93 25.23 38.13 41.07 41.53 44.47 29.53 32.47 37.76 40.30 41.16 43.70 39.36 30.12 37.95 41.01 41.35 44.41 29.35 32.41 37.98 41.19 41.38 44.59 29.38 32.59 37.48 39.54 40.88 42.94 28.90 30.86 37.88 41.35 41.28 44.75 29.28 32.75 38.12 44.84 41.52 48.24 29.73 36.26 37.85 40.61 41.25 44.01 29.25 32.01 38.02 41.24 41.42 44.64 29.44 32.66 53.34 57.12 56.64 60.42 37.94 41.72 53.72 58.90 57.02 62.20 38.32 43.50 54.09 59.74 57.39 63.04 38.69 44.34 53.52 59.29 56.82 62.59 38.12 43.89 53.38 58.00 56.68 61.30 37.98 42.60 64.49 69.83 68.49 73.83 45.69 51.03 65.29 72.45 69.29 76.45 46.49 53.65 65.50 74.38 69.50 78.38 46.70 55.58 65.03 72.76 69.03 76.76 46.23 53.96 65.13 74.37 69.13 78.37 46.33 55.57 64.96 72.01 68.96 76.01 46.16 53.21 77.80 92.64 82.70 97.54 72.89 87.73 69.07 78.67 73.97 83.57 64.17 73.77 68.06 76.79 72.96 81.69 63.16 71.89 68.64 79.43 73.54 84.33 63.74 74.53 68.88 82.43 73.78 87.33 63.98 77.53 74.48 85.77 79.38 90.67 69.58 80.87 68.69 79.25 73.59 84.15 63.79 74.35 87.04 100.63 87.99 101.58 67.69 81.28 86.25 99.65 87.20 100.60 66.90 80.30 86.56 103.01 87.51 103.96 67.21 83.66 99.71 119.55 101.71 121.55 81.81 101.65 96.81 112.09 98.81 114.09 78.91 94.19 97.09 117.75 99.09 119.75 79.19 99.85 98.47 118.80 100.47 120.8 80.57 100.90 97.01 114.38 99.01 116.38 79.11 126.48 103.84 123.82 105.84 125.82 85.93 105.91 108.72 125.62 110.72 127.62 90.81 107.71 108.81 132.06 118.01 141.26 90.61 113.86 107.17 133.32 116.37 142.52 88.97 115.12 107.23 129.42 116.43 138.62 89.03 111.22 107.98 131.05 117.18 140.25 89.78 112.85 133.3 157.7 141.50 165.90 115.50 172.25 132.31 152.31 140.51 160.51 114.51 134.51 122.14 154.15 130.34 162.35 104.34 136.35 121.64 153.00 129.84 161.20 103.84 135.20 119.96 148.93 128.16 157.13 102.16 131.13 117.75 150.58 125.95 158.78 99.95 132.78 119.98 148.26 128.18 156.46 102.18 162.67 140.35 164.98 148.55 173.18 122.55 179.58 120.00 150.68 128.20 158.88 102.20 132.88 122.30 146.14 130.50 154.34 104.50 128.34 117.05 143.80 125.25 152.00 99.25 126.00 143.38 175.21 151.58 183.41 125.58 157.41 128.40 158.62 136.60 166.82 110.60 140.82 120.80 150.65 129.00 158.85 103.00 132.85 Without contacts Recep. (type 7) Plug 8D (type 5) Plug 8DV (type 5) Recep. (type 0) Male Female Male Female Male Female Male Female 33.93 35.51 30.21 30.71 32.11 32.61 23.51 24.01 33.93 35.23 30.21 30.73 32.11 32.63 23.51 24.03 42.43 45.37 37.47 39.47 40.87 42.87 28.87 30.87 46.98 49.52 37.14 38.74 40.54 42.14 28.56 30.16 42.25 45.31 37.39 39.41 40.79 42.81 28.79 30.81 42.04 45.49 37.28 39.19 40.68 42.59 28.68 30.59 46.70 48.76 37.34 39.04 40.74 42.44 28.76 30.36 41.94 45.65 36.97 38.10 40.37 41.50 28.37 29.50 47.78 54.06 34.86 37.84 38.26 41.24 26.45 29.26 42.15 44.91 37.01 38.21 40.41 41.61 28.41 29.61 47.24 50.46 37.04 38.44 40.44 41.84 28.46 29.86 56.24 60.02 52.10 54.00 55.40 57.30 36.70 38.60 56.62 61.80 52.60 55.70 55.90 59.00 37.20 40.30 56.99 62.64 52.35 55.04 55.65 58.34 36.95 39.64 56.42 62.19 51.98 53.79 55.28 57.09 36.58 38.39 56.28 60.90 51.98 54.00 55.28 57.30 36.58 38.60 67.59 72.93 62.94 65.93 66.94 69.93 44.14 47.13 68.39 75.55 63.02 66.07 67.02 70.07 44.22 47.27 68.60 77.48 62.98 67.18 66.98 71.18 44.18 48.38 68.13 75.86 62.37 65.16 66.37 69.16 43.57 46.36 68.23 77.47 62.54 65.12 66.54 69.12 43.74 46.32 68.06 75.11 62.60 65.69 66.60 69.69 43.80 46.89 104.09 118.95 74.53 86.09 79.43 90.99 69.62 81.18 87.27 96.87 65.11 69.07 70.01 73.97 60.21 64.17 86.26 94.99 65.58 70.55 70.48 75.45 60.68 65.65 86.84 97.63 65.00 69.03 69.90 73.93 60.10 64.13 87.08 100.63 65.03 68.68 69.93 73.58 60.13 63.78 92.68 103.97 65.48 71.77 70.38 76.67 60.58 66.87 86.89 97.45 65.13 69.29 70.03 74.19 60.23 64.39 97.59 111.18 83.63 92.05 84.58 93.00 64.28 73.45 96.80 110.20 81.77 86.85 82.72 87.80 62.42 67.50 97.11 113.56 81.94 86.51 82.89 87.46 62.59 67.16 111.81 131.65 92.45 101.95 94.45 103.95 74.55 84.05 108.91 124.19 91.85 99.61 93.85 101.61 73.95 81.71 109.19 129.85 91.56 98.00 93.56 100.00 73.66 80.10 110.57 130.90 92.67 102.44 94.67 104.44 74.77 84.54 109.11 126.48 91.27 97.98 93.27 99.98 73.37 80.08 126.02 146.02 90.72 97.62 92.72 99.62 72.81 79.71 130.92 147.82 90.72 97.62 92.72 99.62 72.81 79.71 122.81 146.06 102.30 115.68 111.5 124.88 84.10 97.48 121.17 147.32 100.17 108.32 109.37 117.52 81.97 90.12 121.23 143.42 99.81 108.22 109.01 117.42 81.61 90.02 121.98 145.05 100.28 109.05 109.48 118.25 82.08 90.85 160.06 172.25 108.51 119.45 116.71 127.65 90.71 101.65 159.71 179.07 111.51 124.51 119.71 132.71 93.71 106.71 136.74 168.75 109.60 123.75 117.80 131.95 91.80 105.95 136.24 167.60 110.00 124.44 118.20 132.64 92.20 106.64 134.56 163.53 110.97 126.31 119.17 134.51 93.17 108.51 132.35 165.18 108.79 118.58 116.99 126.78 90.99 100.78 146.74 162.67 108.51 119.40 116.71 127.60 90.71 101.60 167.11 179.71 106.81 117.08 115.01 125.28 89.01 99.28 134.60 165.28 110.58 125.88 118.78 134.08 92.78 108.08 136.90 160.74 107.66 117.82 115.86 126.02 89.86 100.02 131.65 158.40 108.51 119.40 116.71 127.60 90.71 101.60 157.98 189.81 107.38 119.21 115.58 127.41 89.58 101.41 143.00 173.22 106.83 117.08 115.03 125.28 89.03 99.28 135.40 165.25 111.60 125.21 119.80 133.41 93.80 107.41 Recep. (type 7) Male Female 33.51 34.01 33.51 34.03 41.77 43.77 46.36 47.96 41.69 43.71 41.58 43.49 46.56 48.26 41.27 42.40 44.51 47.06 41.31 42.51 46.26 47.66 55.00 56.90 55.50 58.60 55.25 57.94 54.88 56.69 54.88 56.90 66.04 69.03 66.12 69.17 66.08 70.28 65.47 68.26 65.64 68.22 65.70 68.79 100.82 112.38 83.31 87.27 83.78 88.75 83.20 87.23 83.23 86.88 83.68 89.97 83.33 87.49 94.18 103.35 92.32 97.40 92.49 97.06 104.55 114.05 103.95 111.71 103.66 110.10 104.77 114.54 103.37 80.08 112.92 119.82 112.92 119.82 116.30 129.68 114.17 122.32 113.81 122.22 114.28 123.05 135.27 101.65 138.91 151.27 124.20 138.35 124.60 139.04 125.57 140.91 123.39 133.18 135.27 101.60 133.57 99.41 125.18 140.48 122.26 132.42 123.11 155.51 121.98 133.81 121.43 131.68 126.20 139.81 8D Series | Titanium Series Connector part numbers Basic Series 8D 0 - 11 TT 35 P N L Shell style: 0: Square flange receptacle 7: Jam nut receptacle 5: Plug with RFI shielding Type: - : Connectors with standard crimp contacts L: Receptacle with long PC tail (male and female size #22D, #20) C: Receptacle with short PC tail (male and female #22D, #20, #16, #12) S: Receptacle with specific PC tail (male et female #22D) W: Receptacle with male contacts #22D for wire wrap (3 wraps) T: Receptacle with male contacts #20 for wire wrap (2 wraps) P: Receptacle with solder cup contacts - see page 68, please consult us Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Plating: TT: Without plating TF: Nickel Contact layout: See pages 13 to 19 Contact type: P: Pin A: Connector supplied less pin contact or with specific contacts (connector marking: A + orientation) S: Socket B: Connector supplied less socket contact or with specific contacts (connector marking: B + orientation) Orientation: N, A, B, C, D, E (see page 75) Specification: 046: Tinned straight PC tail 251: Connector provided with power contacts (layouts with contact #8) 022: Fuel tank Special custom None: Standard plastic cap M: Antistatic plastic cap L: For P or S contact type only, connectors delivered without contacts, connectors marking P or S plus orientation Note: PC tail contacts without shoulder also available. Please see page 132. 47 8D Series | Titanium Series Dimensions Receptacle type 0 A B D Thread E±0.3 F G 09 (A) M12 x 1-6g 23.8 18.26 15.09 11 (B) M15 x 1-6g 26.2 20.62 18.26 13 (C) M18 x 1-6g 28.6 23.01 20.62 15 (D) M22 x 1-6g 31 24.61 23.01 17 (E) M25 x 1-6g 33.3 26.97 24.61 19 (F) M28 x 1-6g 36.5 29.36 26.97 M31 x 1-6g 39.7 31.75 29.36 M34 x 1-6g 42.9 34.93 31.75 M37 x 1-6g 46 38.1 34.93 Shell size D C A Max B Max C Max H±0.2 J±0.2 5.49 4.93 20.2 E F G 11.4 21 (G) H 2.5 11.8 23 (H) 19.8 3.2 3.25 4.93 11.4 3.91 25 (J) 4.4 6.15 J Receptacle type 7 C A B D Ø G 22.6 Max Shell size A±0.15 D Thread E Max F±0.4 ØG Max 09 (A) 16.53 M12 x 1-6g 23 27 30.5 11 (B) 19.07 M15 x 1-6g 26 31.8 35.2 13 (C) 23.82 M18 x 1-6g 31 34.9 38.4 15 (D) 26.97 M22 x 1-6g 34 38.1 41.6 17 (E) 30.15 M25 x 1-6g 37 41.3 44.8 19 (F) 33.32 M28 x 1-6g 41 46 49.5 21 (G) 36.50 M31 x 1-6g 46 49.2 52.7 23 (H) 39.67 M34 x 1-6g 47 52.4 55.9 25 (J) 42.85 M37 x 1-6g 51.23 55.6 59 B Max 9.9 C Max 3.2 Recommended coupling torque on panel for jam nut receptacle (type 7) E F Note: All dimensions are in millimeters (mm) 48 Shell 09 (A) 11 (B) 13 (C) 15 (D) 17 (E) 19 (F) 21 (G) 23 (H) 25 (J) Coupling torque (±0.5 N.m) 4 5 7 8 9 10 12 13 14 8D Series | Titanium Series Dimensions Plug type 5 Shell size A ØB A Max Thread ØB Max 09 (A) M12 x 1-6g 21.80 11 (B) M15 x 1-6g 25.00 13 (C) M18 x 1-6g 29.40 M22 x 1-6g 32.50 M25 x 1-6g 35.70 15 (D) 17 (E) Thread 31.00 19 (F) M28 x 1-6g 38.50 21 (G) M31 x 1-6g 41.70 23 (H) M34 x 1-6g 44.90 25 (J) M37 x 1-6g 48.00 Mated connectors dimensions Type 0 with plug Type 7 with plug C A Shell size A Max B Max 09 (A) 11 (B) 13 (C) 15 (D) 37.00 C Max D Max 38.30 53.60 38.50 53.80 52.30 17 (E) 19 (F) 21 (G) B D 23 (H) 36.00 51.30 25 (J) Note: All dimensions are in millimeters (mm) 49 8D Series | Titanium Series PC tail contacts lengths ØA #20 #16 #12 #22D L1 #20 #16 #12 #22D L2 #20 #16 #12 #22D L3 #20 #16 #12 M&F M&F M&F M&F M&F M M F F M M F F M M F F M M F F M M F F M&F M&F M&F M&F M&F M&F M M F F M M F F M M F F M M F F M M F F Max Max Max Max Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Max Max Max Max Max Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Note: All dimensions are in millimeters (mm) 50 PC tail type L&C S C C C L&C L&C L&C L&C S S S S C C C C C C C C C C C C L C S C C C L&C L&C L&C L&C S S S S C C C C C C C C C C C C Shell size 09 (A) 11 (B) 13 (C) 15 C) 17 (E) 19 (F) 21 (G) 23 (H) M: Male contact F: Female contact 0.70 0.50 0.70 1.15 1.65 10.52 11.46 10.19 11.46 10.19 11.46 10.69 11.63 10.36 11.63 10.69 11.63 10.69 11.63 10.69 11.63 10.63 11.56 10.63 11.56 L: Long PC tail C: Short PC tail S: Specific PC tail 10.34 11.28 10.01 11.28 10.01 11.28 10.51 11.45 10.18 11.45 10.51 11.45 10.51 11.45 10.51 11.45 10.45 11.38 10.45 11.38 Receptacle type 7 L1 L2 Receptacle type 0 L3 L2 8.50 4.00 5.10 5.10 5.10 5.10 9.48 10.58 9.15 10.58 9.65 10.75 9.15 10.75 9.65 10.75 9.65 10.75 9.64 10.75 9.64 10.75 10.25 11.21 10.25 11.21 25 (J) ØA #22D Contact type ØA Contact size 9.59 10.69 9.26 10.69 9.76 10.86 9.26 10.86 9.76 10.86 9.76 10.86 9.75 10.86 9.75 10.86 9.95 10.91 9.95 10.91 8D Series | Titanium Series Connectors weight - in gram (±15%) Shell size & Layout 09 11 13 15 17 19 21 23 25 35 98 01 02 04 05 22 35 80 98 99 04 08 26 35 98 05 15 18 19 35 97 02 06 08 26 35 75 99 11 32 35 11 16 35 39 41 48 75 21 35 53 55 07 11 19 24 29 35 37 44 43 46 61 08 20 04 With contacts Plug (type 5) Receptacle (type 0) Without contacts Receptacle (type 7) Plug (type 5) Receptacle (type 0) Receptacle (type 7) Male Female Male Female Male Female Male Female Male Female Male Female 18.23 18.23 23.15 22.78 22.97 23.00 22.64 22.90 25.38 22.87 23.04 32.44 32.82 33.19 32.62 32.48 39.61 40.41 40.62 40.15 40.25 40.08 48.16 43.73 42.72 43.30 43.54 49.14 43.35 55.16 54.37 54.68 64.64 61.74 62.02 63.40 61.94 68.73 73.61 71.07 69.43 69.49 70.24 83.91 91.92 81.78 81.28 79.60 77.39 79.59 99.96 79.64 81.94 76.69 103.02 88.04 80.44 19.81 19.53 26.09 25.32 26.03 26.21 25.06 26.37 29.86 25.63 26.26 36.22 38.00 38.84 38.39 37.10 44.95 47.57 49.50 47.88 49.49 47.13 58.40 53.33 51.45 54.09 57.09 60.43 53.91 68.75 67.77 71.13 84.48 77.02 82.68 83.73 79.31 88.71 90.51 94.32 95.58 91.68 93.31 117.09 111.92 113.79 112.64 108.57 110.22 107.09 127.50 110.32 105.78 103.44 134.85 118.26 110.29 14.37 14.37 18.19 17.82 18.01 18.04 17.68 17.94 20.08 17.91 18.06 23.56 23.94 24.31 23.74 23.60 28.77 29.57 29.78 29.31 29.41 29.24 45.20 40.90 39.89 40.47 40.71 46.31 40.52 44.00 43.21 43.52 54.31 51.41 51.69 53.07 51.61 58.4 63.28 60.57 58.93 58.99 59.74 73.64 81.65 71.51 71.01 69.33 67.12 69.32 89.69 69.37 71.67 66.42 92.75 77.77 70.17 15.95 15.67 21.13 20.36 21.07 21.25 20.10 21.41 24.88 20.67 21.28 27.34 29.12 29.96 29.51 28.22 34.11 36.73 38.66 37.04 38.65 36.29 55.44 50.50 48.62 51.26 54.26 57.60 51.08 57.59 56.61 59.97 74.15 66.69 72.35 73.40 86.29 78.38 80.18 83.82 85.08 81.18 82.81 123.58 101.65 103.52 102.37 98.30 99.95 116.12 134.23 100.05 95.51 93.17 124.58 107.99 100.02 20.14 20.14 25.63 28.1 25.45 25.24 27.96 25.14 30.66 25.35 25.53 34.11 34.49 34.86 34.29 34.15 41.40 42.20 42.41 41.94 42.04 41.87 63.99 54.23 53.22 53.80 54.04 59.64 53.85 61.25 60.46 60.77 71.62 68.72 69.00 70.38 68.92 81.56 86.44 79.15 77.51 77.57 78.32 99.34 94.65 90.20 89.70 88.02 85.81 95.02 115.39 88.06 90.36 85.11 111.44 96.46 88.86 21.72 21.44 28.57 30.64 28.51 28.69 30.38 28.85 35.78 28.11 28.75 37.89 39.67 40.51 40.06 38.77 46.74 49.36 51.29 49.67 51.28 48.92 74.23 63.83 61.95 64.59 67.59 70.93 64.41 74.84 73.86 77.22 91.46 84.00 89.66 90.71 86.29 101.54 103.34 102.40 103.66 99.76 101.39 121.8 127.35 122.21 121.06 116.99 118.64 113.36 134.44 118.74 114.20 111.86 143.27 126.68 118.71 17.81 17.81 22.49 22.16 22.41 22.30 22.36 21.99 22.10 22.03 22.06 31.20 31.70 31.45 31.08 31.08 38.06 38.14 38.10 37.49 37.66 37.72 44.89 39.77 40.24 39.66 39.69 40.14 39.79 51.75 49.89 50.06 57.38 56.78 56.49 57.60 56.20 55.61 55.61 64.56 62.43 62.07 62.54 68.12 71.12 69.24 69.64 70.61 68.43 68.12 66.42 70.22 67.30 68.15 67.02 66.47 71.24 18.31 18.33 24.49 23.76 24.43 24.21 24.06 23.12 22.86 23.23 23.46 33.10 34.80 34.14 32.89 33.10 41.05 41.19 42.30 40.28 40.24 40.81 51.85 43.73 45.21 43.69 43.34 46.43 43.95 60.17 54.97 54.63 66.88 64.54 62.93 67.37 62.91 62.51 62.51 77.94 70.58 70.48 71.31 78.84 84.12 83.39 84.08 85.95 78.22 79.04 77.85 85.52 77.46 79.04 78.85 76.72 84.85 13.95 13.95 17.53 17.2 17.45 17.34 17.40 17.03 16.80 17.07 17.08 22.32 22.82 22.57 22.20 22.20 27.22 27.30 27.26 26.65 26.82 26.88 41.93 36.94 37.41 36.83 36.86 37.31 36.96 40.59 38.73 38.90 47.05 46.45 46.16 47.27 45.87 45.28 45.28 54.06 51.93 51.57 52.04 57.85 60.85 58.97 59.37 60.34 58.16 57.85 56.15 59.95 57.03 57.88 56.75 56.20 60.97 14.45 14.47 19.53 18.8 19.47 19.25 19.10 18.16 17.88 18.27 18.48 24.22 25.92 25.26 24.01 24.22 30.21 30.35 31.46 29.44 29.40 29.97 48.89 40.90 42.38 40.86 40.51 43.60 41.12 66.26 61.06 60.72 73.86 71.52 69.91 74.35 69.89 52.18 52.18 86.02 78.66 78.56 79.39 85.33 73.85 91.81 92.50 94.37 86.64 87.26 86.33 93.94 85.88 87.46 87.27 85.14 93.27 19.72 19.72 24.97 27.48 24.89 24.78 27.68 24.47 27.38 24.51 24.55 32.87 33.37 33.12 32.75 32.75 39.85 39.93 39.89 39.28 39.45 39.51 60.72 50.27 50.74 50.16 50.19 50.64 50.29 40.59 38.73 38.90 47.05 46.45 46.16 47.27 45.87 68.44 68.44 54.06 51.93 51.57 52.04 83.55 86.55 58.97 59.37 60.34 58.16 83.55 81.85 59.95 57.03 57.88 56.75 56.20 60.97 20.22 20.24 26.97 29.08 26.91 26.69 29.38 25.60 28.78 25.71 25.95 34.77 36.47 35.81 34.56 34.77 42.84 42.98 44.09 42.07 42.03 42.60 67.68 54.23 55.71 54.19 53.84 56.93 54.45 66.26 61.06 60.72 73.86 71.52 69.91 74.35 69.89 75.34 75.34 86.02 78.66 78.56 79.39 83.55 99.55 91.81 92.50 94.37 86.64 84.50 84.54 93.94 85.88 87.46 87.27 85.14 93.27 51 8D Series | Bronze Series Connector part numbers Basic Series JVS 16 A 11 35 P N A 0 1 Shell style: 00: Square flange receptacle 07: Jam nut receptacle 16: Plug with RFI shielding Material: A: Bronze housing material Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Contact layout: See pages 13 to 19 Contact type: P: Pin A: Connector supplied less pin contact or with specific contacts (connector marking: A + orientation) S: Socket B: Connector supplied less socket contact or with specific contacts (connector marking: B + orientation) Orientation: N, A, B, C, D, E (see page 75) Specification: 251: Connector provides with power contacts (layouts with contacts #8) CI: Printed board mounting contacts LI: Receptacle with long PC tail (pin or socket #22D) L: For P or S contact type only, connectors delivered without contacts, connectors marking P or S plus orientation CECC part numbers Basic Series C 752 002 B B 98 Shell style: A: Plug B: Square flange receptacle C: Jam nut receptacle Shell size: 09=A, 11=B, 13=C, 15=D, 17=E, 19=F, 21=G, 23=H, 25=J Contact layout: See pages 13 to 19 Contact type: M: Pin F: Socket Type of contact termination: C: Crimp contact Orientation: N, A, B, C, D, E (see page 75) Shell material: A: Aluminum bronze Supply code: 0: Connectors supplied with contacts 1: Connectors supplied without contacts Assessment level: 1: Level 1 Performance level: G: Level G Note: C 752 002 refers to the abbreviated form of the CECC 75 201-002 type designation. 52 M C N G 8D Series | Bronze Series Dimensions Receptacle type 00 (JVS) or type B (CECC) A B D Thread E±0.3 F G 09 (A) M12 x 1-6g 23.8 18.26 15.09 11 (B) M15 x 1-6g 26.2 20.62 18.26 13 (C) M18 x 1-6g 28.6 23.01 20.62 15 (D) M22 x 1-6g 31 24.61 23.01 17 (E) M25 x 1-6g 33.3 26.97 24.61 19 (F) M28 x 1-6g 36.5 29.36 26.97 M31 x 1-6g 39.7 31.75 29.36 M34 x 1-6g 42.9 34.93 31.75 M37 x 1-6g 46 38.1 34.93 Shell size D C A Max B Max C Max H±0.2 J±0.2 5.49 4.93 20.2 E F G 11.4 21 (G) H 23 (H) 2.5 11.8 19.8 3.2 3.25 4.93 11.4 3.91 25 (J) 4.4 6.15 J Receptacle type 07 (JVS) or type C (CECC) C A B D Ø G 22.6 Max Shell size A±0.15 D Thread E Max F±0.4 ØG Max 09 (A) 16.53 M12 x 1-6g 23 27 30.5 11 (B) 19.07 M15 x 1-6g 26 31.8 35.2 13 (C) 23.82 M18 x 1-6g 31 34.9 38.4 15 (D) 26.97 M22 x 1-6g 34 38.1 41.6 17 (E) 30.15 M25 x 1-6g 37 41.3 44.8 19 (F) 33.32 M28 x 1-6g 41 46 49.5 21 (G) 36.50 M31 x 1-6g 46 49.2 52.7 23 (H) 39.67 M34 x 1-6g 47 52.4 55.9 25 (J) 42.85 M37 x 1-6g 51.23 55.6 59 B Max 9.9 C Max 3.2 Recommended coupling torque on panel for jam nut receptacle (type 7) E F Shell 09 (A) 11 (B) 13 (C) 15 (D) 17 (E) 19 (F) 21 (G) 23 (H) 25 (J) Coupling torque (±0.5 N.m) 4 5 7 8 9 10 12 13 14 Note: All dimensions are in millimeters (mm) 53 8D Series | Bronze Series Dimensions Plug type 16 (JVS) or type A (CECC) A ØB Shell size 09 (A) 11 (B) 13 (C) 15 (D) 17 (E) 19 (F) 21 (G) 23 (H) 25 (J) Thread A Max Thread M12 x 1-6g M15 x 1-6g M18 x 1-6g M22 x 1-6g M25 x 1-6g M28 x 1-6g M31 x 1-6g M34 x 1-6g M37 x 1-6g 31.00 ØB Max 21.10 23.80 28.20 31.40 36.50 39.30 42.50 45.30 48.40 Mated connectors dimensions Type 0 with plug Type 7 with plug A C B Shell size 09 (A) 11 (B) 13 (C) 15 (D) 17 (E) 19 (F) 21 (G) 23 (H) 25 (J) D A Max B Max 37.00 52.30 36.00 C Max D Max 38.30 53.60 51.30 Dummy receptacle Orientation: N, A, B, C, D, E Orientation: DU (= all orientations) A A Examples of Part Number: B . JVS BN 02 A 17 N . JVS BN 02 A 17 DU C A A N, DU: Orientation 17: Shell size A: Bronze Equivalent to CECC blind hole. For information only: CECC75201002AxA00A (x = shell size A, B, C, D, ...) CECC75201002EA00A (blind hole) = JVSBN02A17DU (through hole) (no correspondance CECC with N, A, B, C, D, E orientations) Shell size 9 11 13 15 17 19 21 23 25 A+0.3 -0.3 23.8 26.2 28.6 31 33.3 36.5 39.7 42.9 46 B maxi 24.2 24.2 24.2 24.2 24.2 24.2 24.1 24.1 24.1 C maxi 2.5 2.5 2.5 2.5 2.5 2.5 3.2 3.2 3.2 Note: All dimensions are in millimeters (mm) 54 8D Series | Bronze Series PC tail contacts lengths ØA #20 #16 #12 #22D L1 #20 #16 #12 #22D L2 #20 #16 #12 #22D L3 #20 #16 #12 M&F M&F M&F M&F M&F M M F F M M F F M M F F M M F F M M F F M&F M&F M&F M&F M&F M&F M M F F M M F F M M F F M M F F M M F F Max Max Max Max Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Max Max Max Max Max Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max Min Max PC tail type L&C S C C C L&C L&C L&C L&C S S S S C C C C C C C C C C C C L C S C C C L&C L&C L&C L&C S S S S C C C C C C C C C C C C Shell size 09 (A) 11 (B) 13 (C) 15 C) 17 (E) 19 (F) 21 (G) 23 (H) M: Male contact F: Female contact 0.70 0.50 0.70 1.15 1.65 10.52 11.46 10.19 11.46 10.19 11.46 10.69 11.63 10.36 11.63 10.69 11.63 10.69 11.63 10.69 11.63 10.63 11.56 10.63 11.56 25 (J) L: Long PC tail C: Short PC tail S: Specific PC tail 10.34 11.28 10.01 11.28 10.01 11.28 10.51 11.45 10.18 11.45 10.51 11.45 10.51 11.45 10.51 11.45 10.45 11.38 10.45 11.38 Receptacle type 7 L1 L2 ØA #22D Contact type Receptacle type 0 L3 L2 ØA Contact size 8.50 4.00 5.10 5.10 5.10 5.10 9.48 10.58 9.15 10.58 9.65 10.75 9.15 10.75 9.65 10.75 9.65 10.75 9.64 10.75 9.64 10.75 10.25 11.21 10.25 11.21 9.59 10.69 9.26 10.69 9.76 10.86 9.26 10.86 9.76 10.86 9.76 10.86 9.75 10.86 9.75 10.86 9.95 10.91 9.95 10.91 Note: All dimensions are in millimeters (mm) 55 8D Series | Bronze Series Connectors weight - in gram (±15%) With contacts Shell size & Layout 09 11 13 15 17 19 21 23 25 56 35 98 01 02 04 05 22 35 80 98 99 04 08 26 35 98 05 15 18 19 35 97 02 06 08 26 35 75 99 11 32 35 11 16 35 39 41 48 75 21 35 53 55 07 11 19 24 29 35 37 44 43 46 61 08 20 04 Plug (type 5) Without contacts Receptacle (type 0) Receptacle (type 7) Plug (type 5) Receptacle (type 0) Receptacle (type 7) Male Female Male Female Male Female Male Female Male Female Male Female 28.46 28.46 37.17 36.25 36.72 36.79 35.90 36.55 45.40 36.47 36.90 52.20 53.14 54.06 52.65 52.30 64.61 66.59 67.11 65.94 66.19 65.77 71.16 74.18 71.68 73.12 73.71 87.60 73.24 93.71 91.75 92.52 112.91 105.72 106.41 109.83 106.21 103.63 135.19 125.27 121.20 121.35 123.21 153.58 142.64 148.26 147.02 142.86 137.37 153.57 143.71 142.96 148.66 135.64 200.96 163.80 144.94 32.38 31.68 44.46 42.55 44.31 44.76 41.91 45.15 54.33 43.32 44.89 61.58 65.99 68.08 66.96 63.76 77.85 84.35 89.14 85.12 89.12 83.26 103.09 98.00 93.34 99.89 107.33 115.61 99.44 127.42 124.99 133.33 162.13 143.63 157.67 160.27 149.31 133.84 177.13 182.95 186.08 176.40 180.44 179.40 181.90 227.68 224.83 214.73 218.82 170.01 183.40 219.07 207.81 202.00 279.93 238.77 219.00 22.70 22.70 29.80 28.88 29.35 29.42 28.53 29.18 37.96 29.10 29.53 38.98 39.92 40.84 39.42 39.08 48.48 50.46 50.98 49.82 50.07 49.64 66.95 69.99 67.48 68.92 69.52 83.41 69.05 77.08 75.12 75.89 97.53 90.33 91.03 94.45 90.83 88.25 119.80 109.64 105.57 105.72 107.58 138.29 127.35 132.98 131.74 127.57 122.09 138.29 128.18 127.67 133.38 120.35 185.68 148.51 129.66 26.62 25.93 37.09 35.18 36.94 37.39 34.54 37.79 46.89 35.95 37.52 48.35 52.77 54.85 53.74 50.54 61.73 68.23 73.02 69.00 72.99 67.14 86.21 93.81 89.14 95.69 103.14 111.42 95.25 110.8 108.37 116.71 146.75 128.24 142.29 144.89 159.68 118.46 161.74 167.32 170.44 160.77 164.81 186.55 166.61 212.40 209.55 199.45 203.54 177.20 195.16 203.79 192.53 186.72 264.65 223.49 203.71 34.51 34.51 45.08 44.17 44.63 48.33 43.82 43.86 53.35 44.39 44.81 59.89 60.83 61.75 60.34 59.99 73.49 75.47 75.99 74.83 75.08 74.65 93.75 96.76 94.25 95.69 96.29 110.18 95.82 110.70 108.74 109.51 131.96 124.77 125.46 128.89 125.27 122.61 154.25 146.95 142.88 143.03 144.89 176.55 165.62 171.24 170.00 165.83 160.35 176.55 166.69 165.93 171.64 158.61 223.94 186.77 167.91 38.43 37.74 52.37 50.47 52.23 52.67 49.82 53.07 70.43 51.23 52.80 69.27 73.69 75.77 74.65 71.45 86.74 93.24 98.02 94.01 98.00 92.14 113.01 120.58 115.91 122.46 129.91 138.19 122.02 144.42 141.99 109.39 181.19 162.68 176.72 179.33 168.36 152.90 196.18 204.63 207.76 198.08 202.13 202.05 204.80 250.66 247.80 237.70 241.80 192.56 206.58 242.05 230.78 224.98 302.91 261.75 241.97 27.42 27.42 35.53 34.71 35.33 35.06 35.21 34.29 34.23 34.39 34.46 49.12 50.36 49.74 48.83 48.83 60.76 60.96 60.86 59.35 59.77 59.92 64.00 64.36 65.52 64.08 64.16 65.28 64.41 85.25 80.63 81.05 94.90 93.41 92.69 95.44 91.97 90.52 90.52 109.11 103.83 102.94 104.10 114.40 121.84 117.15 118.15 120.55 115.14 114.40 110.17 119.58 112.34 114.45 111.65 110.28 122.11 28.66 28.71 40.49 38.68 40.34 39.80 39.43 37.09 36.45 37.36 37.94 53.84 58.06 56.42 53.32 53.84 68.18 68.53 71.28 66.27 66.17 67.58 73.93 74.18 77.85 74.08 73.21 80.88 74.73 106.14 93.24 92.39 118.47 112.66 108.67 119.68 108.62 107.64 107.64 142.31 124.05 123.8 125.86 141.15 154.10 152.26 153.97 158.61 139.43 141.15 135.50 157.54 137.55 141.47 141.00 135.71 155.88 21.66 21.66 28.16 27.34 27.96 27.69 27.84 26.92 26.79 27.02 27.09 35.90 37.14 36.52 35.60 35.60 44.63 44.83 44.73 43.22 43.64 43.79 59.79 60.16 61.33 59.89 59.97 61.08 60.21 68.62 64.01 64.43 79.52 78.03 77.31 80.06 76.59 75.14 75.14 93.48 88.20 87.31 88.47 99.11 106.55 101.87 102.86 105.27 99.86 99.11 94.64 104.30 97.06 99.17 96.36 95.00 106.83 22.90 22.95 33.12 31.32 32.97 32.43 32.06 29.72 29.08 30.00 30.57 40.61 44.83 43.19 40.09 40.61 52.05 52.40 55.15 50.14 50.04 51.46 69.71 69.99 73.66 69.89 69.02 76.69 70.53 115.19 102.29 101.45 128.84 123.03 119.04 130.05 118.99 92.26 92.26 154.32 136.06 135.81 137.87 148.3 138.81 164.81 166.52 171.16 151.99 148.30 147.50 170.10 150.10 154.02 153.55 148.26 168.44 33.47 33.47 43.44 42.63 43.24 42.97 43.13 42.20 42.77 42.30 42.38 56.81 58.06 57.44 56.52 56.52 69.64 69.84 69.74 68.23 68.65 68.80 86.59 86.93 88.10 86.66 86.74 87.85 86.98 76.56 71.95 72.37 88.20 86.71 85.99 88.75 85.27 109.58 109.58 103.16 97.88 96.98 98.15 137.37 144.82 112.29 113.28 115.69 110.28 137.37 133.15 114.72 107.48 109.59 106.78 105.42 117.25 34.71 34.76 48.40 46.60 48.26 47.71 47.34 45.01 44.37 45.28 45.86 61.53 65.75 64.11 61.01 61.53 77.06 77.41 80.16 75.15 75.05 76.46 96.51 96.76 100.43 96.66 95.79 103.46 97.30 123.13 110.23 109.39 137.52 131.72 127.72 138.74 127.67 126.70 126.70 163.99 145.73 145.49 147.55 163.70 177.08 175.23 176.94 181.58 162.41 163.70 158.68 180.52 160.52 164.44 163.97 158.68 178.86 8D Series | Bronze Series Bronze backshells Part number Basic Series JVS A 11 E 00 C CC Accessory style A : Rear accesssory (backshell) Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Accessory type: A: Screened adaptor for use with compression spring or band strap B: Adaptor with strain relief cable clamp E: Screened adaptor with braid trap G: Environmental cone clamp screened adaptor P: Adaptor for heat shrink boot X: Cone clamp screened adaptor Cable entry codification (see table below): For B, P and X type: 00: Standard, by default choice For other types: 00: Standard, by default choice 03 to 32: Depending on backshell type, please refer to corresponding table Angle: A: Straight backshell (orientation by default) B: 45° backshell (except for «B Type» accessory) C: 90° right angle backshell Variant: For all types: None: Supplied without any other accessory For E and X type: CC: Cable clamp variant How to built a backshell reference for types A, E or G Backshell type Type A&E Shell size Standard correspondance Specific Entry codification Entry size backshell Other entry codication 09 00 04 03 11 00 06 13 00 08 15 00 10 09 to 06 17 00 12 11 to 08 19 00 13 21 00 16 23 00 25 00 Backshell type Shell size Standard correspondance Specific Entry codification Entry size backshell Other entry codication 09 00 - - 05 to 03 11 00 04 - 07 to 04 13 00 06 04 15 00 10 08 to 04 17 00 12 10 to 04 12 to 09 19 00 12 10 to 04 15 to 12 21 00 16 12 to 04 18 17 to 14 23 00 16 12 to 04 20 19 to 16 25 00 16 12 to 04 Type G Examples: To order a right angle backshell type"A" size 15 with entry size 10, placed your order with: JVSA15G00C To order a right angle backshell type "A" size 15 with entry size 06, placed your order with: JVSA15G06C 57 8D Series | Bronze Series Bronze backshells Type A - Screened adaptor for use with compression spring or band strap O-Ring E O-Ring Shell Size 09 11 13 15 17 19 21 23 25 Ø G Ø Example: JVSA09A00A (straight) H F ØB ØB A Thread ØG ØH ØJ Angle C - 90° D ØB O-Ring A Thread Angle B - 45° C A Thread Angle A - straight 30.00 (standard length) A Thread B Max C ±0.5 D ±0.5 E ±0.5 F Max J Min M12 x 1.0 M15 x 1.0 M18 x 1.0 M22 x 1.0 M25 x 1.0 M28 x 1.0 M31 x 1.0 M34 x 1.0 M37 x 1.0 18.0 21.0 24.5 29.0 32.5 35.5 37.0 40.0 43.5 12.0 12.5 13.1 13.5 14.5 15.5 16.0 16.5 17.1 25.1 26.2 26.6 27.5 28.3 28.8 29.7 30.0 30.9 15.5 17.3 18.7 21.3 22.8 24.4 25.1 26.6 28.1 32.4 33.6 34.8 36.6 38.5 40.3 42.0 43.4 44.8 6.7 10.2 13.5 16.2 19.4 21.8 25.1 28.2 31.4 Max Entry* 04 06 08 10 12 13 16 18 20 Entry Size 03 04 05 06 07 08 09 10 11 G H Max 4.7 6.3 7.9 9.5 11.1 12.7 14.2 15.8 17.4 13.9 13.9 15.5 17.2 18.7 20.3 21.9 23.5 25.1 Entry Size 12 13 14 15 16 17 18 19 20 G H Max 19.0 20.6 22.2 23.8 25.4 27.0 28.6 30.2 31.8 26.7 28.3 29.9 31.5 33.1 34.7 36.3 37.9 39.5 ØG ØH * Recommendation only, please consult us for outside entry size Type B - Adaptor with strain relief cable clamp Angle A - straight Angle C - 90° C 15.00 D A Thread E B O-Ring A Thread B O-Ring Shell Size A Thread B Max C Max D Max 09 M12 x 1.0 18.0 21.5 20.0 7.0 11 M15 x 1.0 21.0 21.5 21.0 10.5 13 M18 x 1.0 24.5 23.5 22.0 13.4 15 M22 x 1.0 29 23.5 23.0 16.5 17 M25 x 1.0 32.5 24.5 25.0 19.7 19 M28 x 1.0 35.5 27.5 27.5 22.2 21 M31 x 1.0 37.0 34.5 30.0 25.6 23 M34 x 1.0 40.0 37.5 31.5 28.5 25 M37 x 1.0 43.5 37.5 34.5 31.7 Note: All dimensions are in millimeters (mm) 58 E Max Example: JVSA09B00A (straight) 8D Series | Bronze Series Bronze backshells Type E - Screened adaptor with braid trap Angle A - straight Angle B - 45° 28.00 O-Ring C O-Ring Angle C - 90° E O-Ring Ø Ø H G F ØB A Thread ØB A Thread ØH ØG D ØB A Thread (standard length) Cable clamp option ØG ØH Example: JVSA09E00B (angle 45°) Shell Size 09 11 13 15 17 19 21 23 25 A Thread M12 x 1.0 M15 x 1.0 M18 x 1.0 M22 x 1.0 M25 x 1.0 M28 x 1.0 M31 x 1.0 M34 x 1.0 M37 x 1.0 B Max 18.0 21.0 24.5 29.0 32.5 35.5 37.0 40.0 43.5 C Max 13.1 13.9 14.5 15.5 16.1 16.8 17.1 17.7 18.4 D Max 23.6 24.4 24.8 25.6 26.4 26.8 27.6 28.0 29.0 E Max 25.7 26.7 31.2 37.2 40.2 44.7 49.2 51.7 53.2 F Max 30.5 32.2 33.7 35.2 36.9 38.5 40.1 41.6 43.1 Max Entry 04 06 08 10 12 13 16 18 20 Entry Size 03 04 05 06 07 08 09 10 11 G 4.77 6.35 7.92 9.52 11.10 12.70 14.27 15.88 17.47 H Max 15.0 15.0 16.6 18.2 19.8 21.4 23.0 24.6 26.2 Entry Size 12 13 14 15 16 17 18 19 20 G 19.05 20.62 22.23 23.82 25.40 27.00 28.60 30.20 31.80 H Max 27.7 29.3 30.9 32.5 34.1 35.7 37.3 39.1 40.4 Type G - Environmental cone clamp screened adaptor Angle A - straight Angle B - 45° O-Ring O-Ring F ax M Cable range 0 .0 20 ØB A Thread D O-Ring E ØB A Thread 20.00 Max ØB A Thread 25.4 O-Ring Angle C - 90° C O-Ring C ra abl ng e e Example: JVSA09G00A (straight) Max 20.00 O-Ring Shell Size A Thread B Max C Max D Max E Max F Max 09 M12 x 1.0 18.0 13.1 30.5 15.8 39.2 Max Entry - 11 M15 x 1.0 21.0 13.9 30.5 17.6 42.3 04 Entry Size 13 M18 x 1.0 24.5 14.5 32.5 19.0 42.8 06 04 3.2 - 7.9 15 M22 x 1.0 29.0 15.5 40.3 21.5 50.5 10 06 6.4 - 11.1 17 M25 x 1.0 32.5 16.1 43.1 23.1 52.8 12 19 M28 x 1.0 35.5 16.8 47.9 24.5 57.1 12 08 9.8 - 14.3 21 M31 x 1.0 37.0 17.1 47.9 25.3 57.1 16 Cable Range 10 8.9 - 15.9 12.7 - 19.1 15.9 - 23.8 23 M34 x 1.0 40.0 17.7 56.5 27.5 64.7 16 12 25 M37 x 1.0 43.5 18.4 56.5 28.3 64.7 16 16 Cable range Note: All dimensions are in millimeters (mm) 59 8D Series | Bronze Series Bronze backshells Type P - Adaptor for heat shrink boot Angle A - straight Angle B - 45° Angle C - 90° C 18.00 O-Ring E O-Ring O-Ring H Ø Ø G F ØB A Thread ØB A Thread ØH ØG A Thread ØB D Shell Size A Thread B Max C Max D Max E Max F Max G Max H Max 09 M12 x 1.0 18.0 13.1 17.6 25.7 25.0 6.6 13.5 11 M15 x 1.0 21.0 13.9 18.4 26.7 26.7 10.1 15.4 13 M18 x 1.0 24.5 14.5 19.3 31.2 28.2 13.4 19.7 15 M22 x 1.0 29 15.5 19.6 37.2 29.7 16.1 21.3 17 M25 x 1.0 32.5 16.1 20.4 40.2 31.4 19.3 24.5 19 M28 x 1.0 35.5 16.8 20.8 44.7 33.0 21.7 26.5 21 M31 x 1.0 37.0 17.1 21.6 49.2 34.6 25 31.0 23 M34 x 1.0 40.0 17.7 22.5 51.7 36.1 28.1 34.4 25 M37 x 1.0 43.5 18.4 22.9 53.2 37.6 31.3 36.6 ØG ØH Example: JVSA09P00C (angle 90°) Type X - Cone clamp screened adaptor Angle A - straight Angle B - 45° C 30.50 (standard length) E K ØB A Thread O-Ring ØB A Thread Ø H Ø G F ØH ØG O-Ring D ØB A Thread ØJ O-Ring Angle C - 90° ØG ØH Shell Size 09 11 13 15 17 19 21 23 25 A Thread M12 x 1.0 M15 x 1.0 M18 x 1.0 M22 x 1.0 M25 x 1.0 M28 x 1.0 M31 x 1.0 M34 x 1.0 M37 x 1.0 Note: All dimensions are in millimeters (mm) 60 B Max 18.0 21.0 24.5 27.5 31.0 34.0 37.0 40.0 43.5 C Max 12.0 12.5 13.1 13.5 14.5 15.5 16.0 16.5 17.1 D Max 33.3 34.5 34.9 35.8 36.6 36.6 37.7 38.1 39.0 E Max 21.1 24.2 27.4 31.2 34.3 37.1 39.4 42.5 45.6 F Max 35.2 37.0 38.5 40.0 41.2 43.3 44.9 46.4 47.9 G Min 6.9 9.6 12.7 14.8 17.9 19.9 23.1 26.2 28.8 H Max 18.4 22.0 24.0 27.0 29.5 33.9 37.0 40.8 43.0 J Min 6.7 10.2 13.5 16.2 19.4 21.8 25.1 28.2 31.4 K ±0.5 15.5 17.3 18.7 21.3 22.8 24.4 25.1 26.6 28.1 Example: JVSA09X00B (angle 45°) 8D Series | Bronze Series Bronze caps Basic Series JVS B 09 B 00 A Accessory style: B: Protective cap Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Variant: A: Cap for plug with eyelet (see drawing below) B: Cap for plug with ring (see drawing below) C: Cap for receptacle with eyelet (see drawing below) D: Cap for receptacle with ring (see drawing below) Sub variant: Not applicable Material: A: Bronze Cap for plug 30 Max A Cap for receptacle Variant B Ring E 30 Max A B B D D 127+13 (1) -7 ±0.13 4.75 C (2) 127+13 (1) -7 4.75±0.13 C (2) Variant A Eyelet 6.9 Max (1) Flexible metal link - (2) Number of notch on A diameter A Max B Max 09 (A) 21.1 19.20 11 (B) 23.8 21.80 13 (C) 28.2 26.10 15 (D) 31.4 29.30 17 (E) 36.5 34.40 19 (F) 39.3 37.20 21 (G) 42.5 40.50 23 (H) 45.3 43.10 25 (J) 48.4 46.10 C 8 10 12 16 18 Variant C Eyelet 11.9 Max Ø4.24+0.25 - 0.13 Shell size Variant D Ring E Ø4.24+0.25 - 0.13 (1) Flexible metal link - (2) Number of notch on A diameter Cap for Plug Cap for Receptacle D Max E Min D Max E Min 24.20 13.50 26.80 18.40 26.80 18.40 31.60 23.00 30.50 19.80 36.90 26.20 31.60 23.00 40.10 29.40 36.90 26.20 43.20 32.50 40.10 29.40 46.40 35.70 43.20 32.50 49.20 39.10 46.40 35.70 52.80 42.10 49.20 39.10 55.50 45.30 Equivalent to CECC, for information CECC75201002Bxy00A (x = shell size, y = variant) Example: CECC75201002BAC00A = JVSB09C00A Note: All dimensions are in millimeters (mm) 61 8D SERIES © 2016 SOURIAU - SOURIAU is a registratred trademark 8D Series Common Section Contacts: Crimp contacts ................................................................................................... Straight PC tail contacts ..................................................................................... Coax contacts #12 ............................................................................................. Solder cup .......................................................................................................... Crimp contacts: 1500 mating ............................................................................ Wire wrap contacts ............................................................................................ Quadrax #8 contacts .......................................................................................... Thermocouple contacts ..................................................................................... Dummy contacts ................................................................................................ Filler plugs ......................................................................................................... 64 68 68 68 69 69 69 70 70 70 Wiring instruction .................................................................................................... 71 Tooling: Crimping tools ................................................................................................... Insertion and extraction tools ............................................................................ Backshell tightening tools .................................................................................. Tightening support ............................................................................................ Slackening tools ................................................................................................. 72 73 73 73 73 Accessories: Plastic protective caps ....................................................................................... Gaskets .............................................................................................................. 74 74 Orientations ............................................................................................................ 75 Panel cut-out ........................................................................................................... 75 Coordinates for straight PC tail terminations .......................................................... 76 8D Series | Common Section MIL-DTL-38999 qualified crimp contacts - 1.27μm gold plated Contact size Contact type Part number Pin M39029/58 360 Socket M39029/56 348 Pin M39029/58 363 Socket M39029/56 351 Pin M39029/58 364 Socket M39029/56 352 Pin M39029/76 424 Socket M39029/77 428 Pin M39029/58 365 Socket M39029/56 353 Pin M39029/102 558 Socket M39029/103 559 Pin M39029/28 211 Socket M39029/75 416 Pin M39029/58 528 Socket M39029/56 527 Pin M39029/60 367 Socket M39029/59 366 Pin M39029/90 529 #22D #20 Contact Ø Conductor section AWG Conductor section mm² External Ø over insulator Min Max Min Max Min Max 0.76 26 22 0.12 0.34 0.76 1.37 1.00 24 20 0.21 0.60 1.02 2.11 20 16 0.60 1.34 1.65 2.77 1.65 2.60 2.46 3.61 RG 174 RG 179 RG 316 2.40 2.60 3.20 Please consult us - 2.95 3.64 RG 180 A/U - 2.80 5.50 0,76MIL-C17/176 00002 FILECA F.2703/14 RAYCHEM CHEMINAX 10612 FILOTEX M 17/176 00002 3.15 3.40 #16 1.60 RG 174 RG 179 RG 316 #16 Coax #12 14 2.40 #12 Coax #10 Power #8 Coax #8 Concentric Twinax (= Triax) 64 Socket M39029/91 530 12 1.91 3.18 8D Series | Common Section MIL-DTL-38999 qualified crimp contacts - 1.27μm gold plated Contact size Contact type Profile Color code Pin Black / Blue / Orange #22D Socket Gray / Yellow / Orange Pin Orange / Blue / Orange Socket Brown / Green / Orange #20 Pin Yellow / Blue / Orange Socket Red / Green / Orange Pin Yellow / Red / Yellow #16 #16 Coax Socket Gray / Red / Yellow Pin Green / Blue / Orange #12 Socket Orange / Green / Orange Pin Gray / Green / Green Socket White / Green / Green #12 Coax Pin Brown / Brown / Red Socket Blue / Brown / Yellow Pin Gray / Red / Green Socket Violet / Red / Green #10 Power Pin Violet / Blue / Orange Socket Blue / Blue / Orange Pin White / Red / Green #8 Coax #8 Concentric Twinax (= Triax) Socket Black / Orange / Green Crimp contacts compatibility 1.27μm gold plated = MIL-DTL-38999 qualified crimp contacts 0.8μm gold plated = SOURIAU crimp contacts Contact plating thickness Pin 0.8μm with Socket 1.27μm Pin 0.8μm with Socket 0.8μm Pin 1.27μm with Socket 1.27μm Vibration T° cycling Random vib. 200°C Sine vib. 20°C Sine vib. 200°C Shock High T° exposure OK OK - - - OK OK OK - - OK OK OK OK OK OK OK OK 65 8D Series | Common Section SOURIAU crimp contacts - 0.8μm gold plated, without color code Contact size Contact type Part number Pin 8599-0702 JJ Socket 8599-0706 900 Pin 8599-0703 SA Socket 8599-0707 900 Pin 8599-0704 MJ Socket 8599-0708 900 Pin 8599-0705 MJ Socket 8599-0709 900 Pin 8599-7544 Socket 8599-7541 Pin 8599-7580 Socket 8599-7581 Max Min Max Min Max 0.76 26 22 0.12 0.34 0.76 1.37 1.00 24 20 0.21 0.60 1.02 2.11 1.60 20 16 0.60 1.34 1.65 2.77 2.40 14 12 1.91 3.18 2.46 3.61 - 8 - 8.98 4.10 4.40 8599-4542 - - - - 4.50 6.50 8599-4547 - - - - 2.50 4 2.73 2.77 3.13 3.33 RG 180 A/U - 2.80 0,76MIL-C17/176 00002 FILECA F.2703/14 RAYCHEM CHEMINAX 10612 FILOTEX M 17/176 00002 3.15 3.40 #20 #16 #12 For more information, please see p.106 Conductor section AWG Conductor section mm² External Ø over insulator Min #22D #8 Power Contact Ø 3.64 Boot Reductor 8599-7645 #8 Coax Boot 8590-4571 #8 Concentric Twinax (= Triax) Boot 8590-4571 Pin 8599-7598 900 Socket 8599-7599 900 Pin 8599-7534 Socket 8599-7535 #4 Power For more information, please see p.106 - 3 - 25 - - 5 4 16 21.15 - - - - - - 6.35 7.50 - - - - 4 5.80 5.74 8599-4593 66 5.50 8599-4594 Boot #4 Power with reduced barrel 10 Reductor 8593-2000A Pin 8599-7528 900 Socket 8599-7529 900 Boot 8599-4593 - 6 13.30 5.30 5.70 6 13.30 5.30 5.70 4 5.80 - - - 8D Series | Common Section SOURIAU crimp contacts - 0.8μm gold plated, without color code Contact size Contact type Information Pin - Socket - Pin - Socket - Pin - Socket - Pin - Socket - Pin JVS only Socket JVS only Pin - Socket - #22D #20 #16 #12 #8 Power For more information, please see p.106 For wire #8 Boot For wire #10 Reductor For wire #10 #8 Coax Boot - #8 Concentric Twinax (= Triax) Boot - Pin For wire 21.15 mm². Not included in connector Part number. Must be ordered separately. Socket #4 Power For more information, please see p.106 Pin For wire 21.15 mm² Socket For wire 16 mm² Boot For wire 10 mm² Reductor #4 Power with reduced barrel For wire 10 mm² Pin Mating part #4 / Barrel #6 Socket Boot - 67 8D Series | Common Section Straight PC tail contacts Contact size Contact type PC tail type Part number Pin L 8599-0720 900 Pin M 8599-8028 900 Pin C 8599-0730 900 Pin S 8599-0796 900 Socket L 8599-0721 900 Socket C 8599-0731 900 Socket S 8599-0797 900 Pin M 8599-0658 JJ Socket M 8599-0759 900 Pin C 8599-0724 900 Socket C 8599-0725 900 #22D #20 #16 Pin L 8599-0771 900 Socket L 8599-0772 900 Pin C 8599-0726 900 Socket C 8599-0727 900 Pin C 8599-1000A 900 Pin C 8599-7929 900 Socket C 8599-7932 900 Coax #16 #12 Coax contacts #12 Designation Part number Coax socket solder contact #12 THA1-0151A Coax pin solder contact#12 THA1-0152A Coax pin crimp contact #12 THA1-0155A Coax socket crimp contact #12 THA1-0156A Solder cup Contact size Contact type #22D Pin 8599-0750 900 #20 Pin 8599-0077A 900 #16 Pin 8599-7482A 900 #12 Socket 8599-7485A 900 Part number For other contacts type please consult us. 68 S: Specific PC tail L: Long PC tail M: Medium PC tail C: Short PC tail Note: PC tail contacts without shoulder also available. Please see page 132. 8D Series | Common Section Crimp contacts: 1500 mating Contact size MIL-DTL-38999 contacts Contact type Part number Color code Pin (H) M39029/107 620 Blue / Red / Black Socket (J) M39029/106 614 Blue / Brown / Yellow Pin (H) M39029/107 621 Blue / Red / Brown Socket (J) M39029/106 615 Blue / Brown / Green Pin (H) M39029/107 622 Blue / Red / Red Socket (J) M39029/106 616 Blue / Brown / Blue Pin (H) M39029/107 623 Blue / Red / Orange Socket (J) M39029/106 617 Blue / Brown / Gray #22D #20 #16 #12 Wire wrap contacts Contact size Contact type Part number Contact Ø (mm) #22D Pin 8599-0790 JJ 0.76 0.86 #20 Pin 8599-0791 900 1 0.86 Profile (mm) Quadrax #8 contacts Contact type Pin PC tail L= 4±0.1mm Socket Pin Crimp Socket SOURIAU part number Cross Norm Impedance Release T° Max ETH1-1237A - 100Ω Rear 125°C ETH1-1501A - 150Ω Rear 125°C ETH1-1238A - 100Ω Rear 125°C ETH1-1502A - 150Ω Rear 125°C ETH1-1345A EN 3155-074 100Ω Rear 150°C ETH1-1503A - 150Ω Rear 150°C ETH1-1346A EN 3155-075 100Ω Rear 150°C ETH1-1504A - 150Ω Rear 150°C 69 8D Series | Common Section Thermocouple contacts Contact size Contact type SOURIAU part numbers (without color code) Part numbers - M39029/87-472 Pin MIL-DTL-38999 contacts Profile and color code Ø Contact (mm) Ø Over insulation (mm) Wire section mm2 Awg min max 0.75 28 1 24 min max min max 22 0.095 0.34 0.76 1.37 20 0.21 1.02 2.11 Red / Violet / Yellow #22D Chromel Socket - M39029/88-484 Yellow / Grey / Yellow Pin - M39029/87-471 Brown / Violet / Yellow #22D Alumel Socket - M39029/88-483 Orange / Grey / Yellow Pin 8599-0749 900 8599-0949 900 Blue / Violet / Yellow #20 Chromel Socket 8599-0753 900 8599-0953 900 Grey / Grey / Yellow Pin 8599-0761 900 0.6 8599-0961 900 Green / Violet / Yellow #20 Alumel Socket 8599-0765 900 8599-0965 900 Violet / Grey / Yellow Dummy contacts Filler plugs Size Part number #16 8599-6A016001A Contact size MS Part number (Rev. N) Color #8 8599-0308 #22D MS27488-22-2 #4 8599-0310 #20 MS27488-20-2 #16 #12 SOURIAU Part number Color Black 8660-212 Black Red 8522-389A Red MS27488-16-2 Green 8522-390A Blue MS27488-12-2 Orange 8522-391A Orange 8599-0308 Direction of introduction in grommet 70 These filler plugs are installed at the rear of unwired contact to maintain connector sealing. 8D Series | Common Section Wiring instruction Cable preparation and wire stripping Contact size #26 L #22D #20 #16 4 #12 6 #8 #4 12 L L = length of wire stripping Insertion of wire in contact barrel Conductor insulation 0.5 to 0.8 mm Wire When inserting the stripped wire into the contact barrel check that no strands are left outside and that the wire is visible through the wire inspection hole in the barrel. Barrel Inspection hole Important: - Slide any accessories over wire strands before carrying out the following operations. - Contacts are inserted and extracted from the rear of the connector. Insertion of the contacts Extraction of the contacts 1 - Engage the crimp cable / contact asembly into the longitudinal slot of the plastic tool (coloured tip). Slide the tool down the cable until the tip of the tool abuts the contact retention shoulder. 1 - Engage the appropriate cable into the longitudinal slot of the tool with the white tip towards connector. 2 - Introduce the contact into the required contact cavity in the insulator, pushing tool axialy, until the contact snaps into position in clip. 3 - Withdraw the tool from rear. Check that contact is firmly locked by pulling wire gently. When connector is fully loaded, check the position of contact tips. They should all be in the same plane. Nota: For larger sizes of cable which are stiff enough manual insertion without tool is preferable. 1 2 3 2 - Slide the tool down towards the contact. Insert the tool in the insulator until it abuts the contact shoulder. 3 - Holding the tool-contact and cable assembly together, remove them simultaneously. 1 2 3 71 8D Series | Common Section Tooling Crimping tools Contact size #26 #22D #20 #16 #12 #8 Power #4 Power Contact size Contact type Pin Plier M22520/1-01 Plier M22520/2-01 (SOURIAU 8476-01) Plier M300BT Turret Part number Locator Part number Norm SOURIAU Locator Part number Turret Part number Locator Part number - - 8599-0397 - - - Socket - - 8599-0398 - - - Pin - M22520/2-09 - - - - Socket - M22520/2-06 Pin Socket Pin Socket Pin Socket M22520/1-04 M22520/2-10 M22520/1-04 M22520/1-04 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - SP 593 M22520/23-02 8599-9601 M22520/23-04 M22520/23-11 - - Pin - - - Socket - - - pin - - - - Socket - - - - Contact type Plier M22520/2-01 (SOURIAU 8476-01) Plier M22520/31-01 Plier M22520/4-01 Plier M22520/5-01 Locator Part Number Locator Part number Locator Part Number Die set Part Number #12 Coax Inner - - - M39029/102-558 M39029/103-559 Outer - - - #12 Coax Inner M22520/2-34 - - - M39029/28-211 M39029/75-416 Outer - M22520/31-02 - - #16 Coax #8 Coax #8 Concentric Twinax ( = Triax ) M22520/5-03 Inner M22520/2-35 - - - Outer - - M22520/4-02 - Inner M22520/2-31 - - - Outer - - - M22520/5-05 closure B Inner K709 - - - Middle - - - Y631 closure B Ferrule - - - Y631 closure A Note: for the #10 contact’s plier and locator, please consult us. 72 Pneumatic plier M22520/23-01 8D Series | Common Section Tooling Insertion & extraction tools Part number Color Contact size Material MIL standard SOURIAU Insertion Extraction #26 Plastic - 8599-0399 900 Black White #22D Plastic M81969/14-01 - Green White #20 Plastic M81969/14-10 - Red Orange #16 Plastic M81969/14-03 - Blue White #12 Plastic M81969/14-04 - Yellow White #10 Plastic M81969/14-05 - Grey - #8 #4 Plastic M81969/14-12 - - Green Metallic - 8660-197 - - Plastic M81969/14-07 - - Blue Metallic - 8533-8175 - - Backshell tightening tools Tightening support Backshell tightening pliers, part number: 8498-03 Square jaws (order 2 jaws), part number: 8500-1015 8498-03 8599-0831 Tightening of rear accessories: Shell size Max torque in m/daN 9 11 13 Part number: 8599-0831 This tool is made up of dummy receptacles housings of all 9 sizes for all key polarisation, and secures free connectors during wiring and fitting of rear accessories. Slackening tools 15 0.62 17 19 21 23 1.24 25 8498-04 Strap clamp, part number: 8498-04 Spare strap, part number: 8498-103 73 8D Series | Common Section Accessories Plastic protective caps* Shell size Caps for receptacles Caps for plugs Caps for composite plugs only (J & M) Antistatic caps for receptacles Antistatic caps for plugs Antistatic caps for composite plugs only (J & M) 9 (A) 11 (B) 13 (C) 15 (D) 17 (E) 19 (F) 21 (G) 23 (H) 25 (J) MS90376-10R MS90376-12R MS90376-14R MS90376-16R MS90376-19R MS90376-20R MS90376-22R MS90376-24R 8599-0029 8500-5587 A 8500-5588A 8500-5600 8500-5601 8500-5602 8500-5592 A 8500-5593 A 8500-5593 A J599ABC6009A00 MS90376-12R 8500-5598 8500-5600 8500-5601 8500-5602 8500-5592 A 8500-5593 A MS90376-28R J599ABC6009A00 MS90376-10RF MS90376-12RF MS90376-14RF MS90376-16RF MS90376-18RF MS90376-20RF MS90376-22RF MS90376-24RF 8500-5593N 8500-5587N 70198N 8500-5600N 8500-5601N 8500-5602N 8500-5592N 8500-5593N 8500-5593N MS90376-28RF 8500-5587N 8500-5598N 8500-5600N 8500-5601N 8500-5602N 8500-5592N 8500-5593N 70472N MS90376-28RF * Excepted 8D composite version (X): supplied without cap Gaskets Shell size 9 (A) 11 (B) 13 (C) 15 (D) 17 (E) 19 (F) 21 (G) 23 (H) 25 (J) Gasket for receptacles Type 0* (ordered separately) 8599-5541 8599-5542 8599-5543 8599-5544 8599-5545 8599-5546 8599-5547 8599-5548 8599-5549 * For front mounting 74 O ring for receptacle Type 7 AS3582-019 AS3582-022 AS3582-024 AS3582-026 AS3582-028 AS3582-128 AS3582-130 AS3582-132 AS3582-134 8D Series | Common Section Orientations Shell size Angles N A B C D E A° B° C° D° A° B° C° D° A° B° C° D° A° B° C° D° A° B° C° D° 105 140 215 265 95 141 208 236 95 141 208 236 80 142 196 293 80 142 196 293 102 132 248 320 113 156 182 292 113 156 182 292 135 170 200 310 135 170 200 310 80 118 230 312 90 145 195 252 90 145 195 252 49 169 200 244 49 169 200 244 35 140 205 275 53 156 220 255 53 156 220 255 66 140 200 257 66 140 200 257 64 155 234 304 119 146 176 298 119 146 176 298 62 145 180 280 62 145 180 280 91 131 197 240 51 141 184 242 51 141 184 242 79 153 197 272 79 153 197 272 9 (A) 11 (B) 15 (D) Viewed from front face of receptacle 13 (C) 17 (E) 21 (G) 19 (F) 23 (H) 25 (J) T V - - - - 70 136 218 261 58 162 188 316 75 138 224 268 85 150 191 307 - - Viewed from front face of plug Panel cut-out Square flange receptacle (Type 0) G Jam nut receptacle (Type 7) G ØE ØC Ø B D Ø Rear mounting* Shell size 9 (A) 11 (B) 13 (C) 15 (D) 17 (E) 19 (F) 21 (G) 23 (H) 25 (J) F A A ØC A 18.26 20.62 23.01 24.61 26.97 29.36 31.75 34.93 38.10 Front mounting G 15.09 18.26 20.62 23.01 24.61 26.97 29.36 31.75 34.94 B min. 16.66 20.22 23.42 26.59 30.96 32.94 36.12 39.29 42.47* C ±0.13 3.25 3.91 D min. 13.11 15.88 19.05 23.01 25.81 28.98 32.16 34.93 37.69 E +0.25 -0 17.78 20.96 25.65 28.83 32.01 35.18 38.35 41.53 44.70 F 17.02 19.59 24.26 27.56 30.73 33.91 37.08 40.26 43.43 * For Type 0 composite shell rear mounting: 43.77 mm. Max. thickness panel for receptacle: Type 0: front mounting = 3.2 mm, rear mounting = 2.5 mm Type 7: 3.2 mm Note: All dimensions are in millimeters (mm) 75 8D Series | Common Section Coordinates for straight PC tail terminations Viewed from front face of male insulator Hole sizes: 1mm min. (#22 and #20 contacts) and 1.3mm min. (#16 contact) coordinates in mm. 09 / A 12 35 98 +Y +Y +Y -X +X -X +X -Y -X +X -Y -Y Ctc X Y Ctc X Y Ctc X Y Ctc X Y 1 +0.92 +2.54 7 -2.66 -0.47 1 +1.14 +1.98 A +1.65 +0.97 2 +2.34 +1.35 8 -2.34 +1.35 2 +1.98 -1.14 B 0.00 -1.90 3 +2.66 -0.47 9 -0.92 +2.54 3 0.00 -2.29 C -1.65 +0.97 4 +1.74 -2.07 10 0.00 +1.03 4 -1.98 -1.14 5 0.00 -2.70 11 +0.89 -0.51 5 -1.14 +1.98 6 -1.74 -2.07 12 -0.89 -0.51 6 0.00 0.00 11 / B 02 04 05 26 +Y +Y +Y +Y -X +X -X +X -Y -X +X -Y +X -Y -Y Ctc X Y Ctc X Y Ctc X Y Ctc X Y Ctc X Y A 0.00 +2.41 A +1.65 +1.65 A +1.65 +1.42 1 +1.69 +3.79 14 0.00 +3.50 B 0.00 -2.41 B +1.65 -1.65 B +2.86 -1.65 2 +3.09 +2.77 15 +1.70 +1.76 C -1.65 -1.65 C 0.00 -3.30 3 +3.95 +1.28 16 +2.55 +0.29 D -1.65 +1.65 D -2.86 -1.65 4 +4.13 -0.44 17 +1.70 -1.18 E -1.65 +1.42 5 +3.58 -2.10 18 +0.85 -2.65 6 +2.40 -3.37 19 -0.85 -2.65 7 0.00 -4.13 20 -1.70 -1.18 8 -2.40 -3.37 21 -2.55 +0.29 +1.76 35 +Y Ctc -X +X -Y 76 -X X Y Ctc 1 0.00 +3.71 6 2 +2.16 +3.00 7 3 +3.51 +1.14 8 4 +3.51 -1.14 9 5 +2.16 -3.00 X Y Ctc X Y 0.00 -3.71 10 -2.16 +3.00 9 -3.58 -2.10 22 -1.70 -2.16 -3.00 11 0 +1.42 10 -4.13 -0.44 23 0.00 +1.76 -3.51 -1.14 12 +1.24 -0.89 11 -3.95 +1.28 24 +0.85 +0.29 -3.51 +1.14 13 -1.24 -0.89 12 -3.09 +2.77 25 0.00 -1.18 13 -1.69 +3.79 26 -0.85 +0.29 8D Series | Common Section 11 / B 98 99 Ctc X Y A +1.65 +2.85 +3.30 B +3.30 0.00 0.00 C +1.65 -2.87 D -1.65 -2.87 E -3.30 0.00 F -1.65 +2.87 G 0.00 0.00 +Y +Y Ctc -X +X -Y X Y A 0.00 B +3.30 C +1.65 -2.87 D -1.65 -2.87 E -3.30 0.00 F 0.00 0.00 -X +X -Y 13 / C 04 08 35 43 +Y +Y +Y +Y -X +X -X +X -Y -X +X -Y -X +X -Y -Y Ctc X Y Ctc X Y Ctc X Y Ctc X Y Ctc X Y Ctc X Y A 0.00 +3.81 A +1.65 +3.99 1 +1.14 +5.00 12 -4.62 +2.24 1 +1.80 +5.54 23 +3.92 +1.27 B +3.71 +0.89 B +4.32 0.00 2 +3.20 +4.01 13 -3.20 +4.01 2 +3.42 +4.71 24 +4.10 -0.43 C 0.00 -2.11 C +3.05 -3.05 3 +4.62 +2.24 14 -1.14 +5.00 3 +4.71 +3.42 25 +3.57 -2.06 D -3.71 +0.89 D 0.00 -4.32 4 +5.16 0.00 15 +1.14 +2.72 4 +5.54 +1.80 26 +1.99 -2.74 E -3.05 -3.05 5 +4.62 -2.24 16 +2.97 +0.66 5 +5.82 0.00 27 +0.86 -4.03 F -4.32 0.00 6 +3.20 -4.01 17 +2.36 -1.91 6 +5.54 -1.80 28 -0.86 -4.03 G -1.65 +3.99 7 +1.14 -5.00 18 0.00 -3.05 7 +4.71 -3.42 29 -1.99 -2.74 H 0.00 +1.12 8 -1.14 -5.00 19 -2.36 -1.91 8 +3.42 -4.71 30 -3.57 -2.06 9 -3.20 -4.01 20 -2.97 +0.66 9 +1.80 -5.54 31 -4.10 -0.43 10 -4.62 -2.24 21 -1.24 +2.72 10 0.00 -5.82 32 -3.92 +1.27 11 -5.16 0.00 22 0.00 -0.76 11 -1.80 -5.54 33 -2.54 +2.28 12 -3.42 -4.71 34 -1.68 +3.76 13 -4.71 -3.42 35 0.00 +2.42 14 -5.54 -1.80 36 +1.21 +1.21 15 -5.82 0.00 37 +2.42 0.00 16 -5.54 +1.80 38 +1.21 -1.21 98 +Y -X +X -Y Ctc X Y Ctc X Y 17 -4.71 +3.42 39 0.00 -2.42 A 0.00 +4.95 F -4.17 -2.67 18 -3.42 +4.71 40 -1.21 -1.21 B +3.18 +3.81 G -4.90 +0.76 19 -1.80 +5.54 41 -2.42 0.00 C +4.90 +0.76 H -3.18 +3.81 20 0.00 +4.12 42 -1.21 +1.21 D +4.17 -2.67 J +1.65 -0.38 21 +1.68 +3.76 43 0.00 0.00 E 0.00 -3.43 K -1.65 -0.38 22 +2.54 +2.28 77 8D Series | Common Section 15 / D 05 18 19 +Y +Y +Y -X +X -X +X -Y +X -Y -Y Ctc X Y Ctc X Y Ctc X Y Ctc X Y Ctc X Y A 0 +2.54 A +1.65 +6.40 K -4.95 +2.87 A 0.00 +5.72 L -4.95 +2.87 B +4.42 +0.61 B +4.95 +2.87 L -1.65 +6.40 B +3.30 +5.72 M -3.30 +5.72 C +2.39 +3.76 C +6.60 0.00 M -1.65 +2.87 C +4.95 +2.87 N -1.65 +2.87 D -2.39 -3.76 D +4.95 -2.87 N +1.65 +2.87 D +6.60 0.00 P +1.65 +2.87 E -4.42 +0.61 E +3.30 -5.72 P +3.30 0.00 E +4.95 -2.87 R +3.30 0.00 F 0.00 -5.72 R +1.65 -2.87 F +3.30 -5.72 S +1.65 -2.87 G -3.30 -5.72 S -1.65 -2.87 G 0.00 -5.72 T -1.65 -2.87 H -4.95 -2.87 T -3.30 0.00 H -3.30 -5.72 U -3.30 0.00 J -6.60 0.00 U 0.00 0.00 J -4.95 -2.87 V 0.00 0.00 K -6.60 0.00 35 97 +Y -X +X -Y 78 -X Ctc X Y A +1.65 +5.94 +Y Ctc X Y Ctc X Y 1 +1.14 +6.65 20 +3.12 +3.02 2 +3.12 +5.51 21 +4.32 +1.02 3 +5.36 +4.06 22 +4.32 -1.27 B +4.52 +4.52 C +5.84 -0.58 D +4.52 -4.52 4 +6.45 +2.03 23 +3.12 -3.23 E +1.65 -5.94 5 +6.76 -0.25 24 +1.14 -4.37 F -2.26 -5.97 6 +6.27 -2.49 25 -1.14 -4.37 G -5.26 -2.41 7 +5.08 -4.45 26 -3.12 -3.23 H -5.94 +1.65 8 +3.30 -5.89 27 -4.32 -1.27 J -4.52 +4.52 9 +1.14 -6.65 28 -4.32 +1.02 K -1.65 +5.94 10 -1.14 -6.65 29 -3.12 +3.02 L -1.19 +2.06 11 -3.30 -5.89 30 -1.14 +4.37 M +1.19 -2.06 12 -5.08 -4.45 31 +1.14 +1.88 13 -6.27 -2.49 32 +2.29 -0.10 14 -6.76 -0.25 33 +1.14 -2.08 15 -6.45 +2.03 34 -1.14 -2.08 16 -5.36 +4.06 35 -2.29 -0.10 17 -3.12 +5.51 36 -1.14 +1.88 18 -1.14 +6.65 37 0.00 -0.10 19 +1.14 +4.37 -X +X -Y 8D Series | Common Section 17 / E 06 08 26 +Y +Y +Y -X +X -X +X -Y -X -Y Ctc X Y J -1.70 -7.98 K -4.80 -6.60 L -7.06 -4.09 M -8.10 -0.86 N -7.75 +2.51 +X -Y P -6.07 +5.44 R -3.33 +7.44 S -1.78 +4.50 T +1.78 +4.50 Ctc X Y Ctc X Y Ctc X Y U +4.45 +2.39 A +3.07 +5.31 A 0.00 +5.99 A 0.00 +8.15 V +4.53 -0.91 B +6.12 0.00 B +3.25 +2.18 B +3.33 +7.44 W +3.02 -3.84 C 0.00 -6.12 C +5.84 -1.98 C +6.07 +5.44 X 0.00 -5.16 D -6.12 0.00 D +2.39 -5.49 D +7.75 +2.51 Y -3.02 -3.84 E -3.07 +5.31 E -2.39 -5.49 E +8.10 -0.86 Z -4.53 -0.91 F 0.00 0.00 F -5.84 -1.98 F +7.06 -4.09 a -4.45 +2.39 G -3.25 +2.18 G +4.80 -6.60 b 0.00 +1.65 H 0.00 -1.32 H +1.70 -7.98 c 0.00 -1.65 35 99 +Y +Y -X +X -X -Y Ctc X Y Ctc X Y 25 0.00 +8.36 41 +3.96 +4.47 26 0.00 +4.47 42 +3.96 +2.18 27 0.00 +2.18 43 +3.96 -0.10 +X -Y Ctc X Y Ctc X Y 28 0.00 -0.10 44 +3.96 -2.39 Ctc X Y Ctc X Y 1 -7.92 +2.18 13 -3.96 -0.10 29 0.00 -2.39 45 +3.96 -4.67 A 0.00 +8.15 N -7.75 +2.51 2 -7.92 -0.10 14 -3.96 -2.39 30 0.00 +4.67 46 +3.96 -6.96 B +3.33 +7.44 P -6.07 +5.44 3 -7.92 -2.39 15 -3.96 -4.67 31 0.00 -6.96 47 +6.15 +5.61 C +6.07 +5.44 R -3.33 +7.44 4 -6.15 +5.61 16 -3.96 -6.96 32 +2.26 +8.03 48 +5.94 +3.33 D +7.75 +2.51 S -1.78 +4.50 5 -5.94 +3.33 17 -2.26 +8.03 33 +1.98 +5.61 49 +5.94 +1.04 E +8.10 -0.86 T +1.78 +4.50 6 -5.94 +1.04 18 -1.98 +5.61 34 +1.98 +3.33 50 +5.94 -1.24 F +7.06 -4.09 U +4.45 +2.39 7 -5.94 -1.24 19 -1.98 +3.33 35 +1.98 +1.04 51 +5.94 -3.53 G +4.80 -6.60 V +3.81 -1.91 8 -5.94 -3.53 20 -1.98 +1.04 36 +1.98 -1.24 52 +5.94 -5.82 H +1.70 -7.98 W 0.00 -4.09 9 -5.94 -5.82 21 -1.98 -1.24 37 +1.98 -3.53 53 +7.92 +2.18 J -1.70 -7.98 X -3.81 -1.91 10 -4.37 +7.09 22 -1.98 -3.53 38 +1.98 -5.82 54 +7.92 -0.10 K -4.80 -6.60 Y -4.45 +2.39 11 -3.96 +4.47 23 -1.98 -5.82 39 +1.98 -8.10 55 +7.92 2-.39 L -7.06 -4.09 Z 0.00 +0.64 12 -3.96 +2.18 24 -1.98 -8.10 40 +4.37 +7.09 M -8.10 -0.86 79 8D Series | Common Section 19 / F 11 32 +Y -X +X -Y 35 +Y -X +X -Y 80 +Y Ctc X Y A +2.67 +6.60 Ctc X Y Ctc X Y A +1.68 +8.97 T -1.68 +8.97 B +6.35 +3.35 B +4.80 +7.75 U 0.00 +5.84 C +6.99 -1.35 C +7.26 +5.51 V +3.15 +4.90 D +4.55 -5.46 D +8.76 +2.49 W +5.31 +2.41 E 0.00 -7.14 E +9.07 -0.84 X +5.79 -0.84 F -4.55 -5.46 F +8.15 -4.06 Y +4.42 -3.84 G -6.99 -1.35 G +6.15 -6.73 Z +1.65 -5.61 H -6.35 +3.35 H +3.30 -8.51 a -1.65 -5.61 J -2.67 +6.60 J 0.00 -9.12 b -4.42 -3.84 K 0.00 +2.67 K -3.30 -8.51 c -5.79 -0.84 L 0.00 -2.34 L -6.15 -6.73 d -5.31 +2.41 M -8.15 -4.06 e -3.15 +4.90 N -9.07 -0.84 f 0.00 +2.44 P -8.76 +2.49 g +2.44 0.00 R -7.26 +5.51 h 0.00 -2.44 S -4.80 +7.75 j -2.44 0.00 -X +X -Y Ctc X Y Ctc X Y Ctc X Y Ctc X Y Ctc X Y 1 -9.07 +2.29 15 -5.11 -4.57 28 -1.14 +2.29 41 +1.14 -6.86 54 +5.11 0.00 2 -9.07 0.00 16 -5.11 -6.86 29 -1.14 0.00 42 +1.14 -9.14 55 +5.11 -2.29 3 -9.07 -2.29 17 -3.12 +8.00 30 -1.14 -2.29 43 +3.12 +8.00 56 +5.11 -4.57 4 -7.09 +5.71 18 -3.12 +5.71 31 -1.14 -4.57 44 +3.12 +5.71 57 +5.11 -6.86 5 -7.09 +3.43 19 -3.12 +3.43 32 -1.14 -6.86 45 +3.12 +3.43 58 +7.09 +5.71 6 -7.09 +1.14 20 -3.12 +1.14 33 -1.14 -9.14 46 +3.12 +1.14 59 +7.09 +3.43 7 -7.09 -1.14 21 -3.12 -1.14 34 +1.14 +9.14 47 +3.12 -1.14 60 +7.09 +1.14 8 -7.09 -3.43 22 -3.12 -3.43 35 +1.14 +6.86 48 +3.12 -3.43 61 +7.09 -1.14 9 -7.09 -5.71 23 -3.12 -5.71 36 +1.14 +4.57 49 +3.12 -5.71 62 +7.09 -3.43 10 -5.11 +6.86 24 -3.12 -8.00 37 +1.14 +2.29 50 +3.12 -8.00 63 +7.09 -5.71 11 -5.11 +4.57 25 -1.14 +9.14 38 +1.14 0.00 51 +5.11 +6.86 64 +9.07 +2.29 12 -5.11 +2.29 26 -1.14 +6.86 39 +1.14 -2.29 52 +5.11 +4.57 65 +9.07 0.00 13 -5.11 0.00 27 -1.14 +4.57 40 +1.14 -4.57 53 +5.11 +2.29 66 +9.07 -2.29 14 -5.11 -2.29 8D Series | Common Section 21 / G 16 35 +Y +Y -X +X -X +X -Y -Y Ctc X Y Ctc X Y Ctc X Y 14 +1.35 -10.82 36 +7.90 -3.58 58 +3.40 -5.05 15 -1.35 -10.82 37 +6.55 -5.59 59 +1.22 -6.12 16 -3.71 -10.26 38 +4.67 -7.11 60 -1.22 -6.12 17 -5.89 -9.19 39 +2.49 -8.18 61 -3.40 -5.05 18 -7.77 -7.67 40 0.00 -8.81 62 -5.28 -3.53 19 -9.27 -5.77 41 -2.49 -8.18 63 -6.02 -1.22 20 -10.31 -3.58 42 -4.67 -7.11 64 -6.02 +1.22 21 -10.85 -1.22 43 -6.55 -5.59 65 -5.28 +3.53 Ctc X Y Ctc X Y Ctc X Y 22 -10.85 +1.22 44 -7.90 -3.58 66 -3.40 +5.05 A +3.00 +8.18 J -8.66 +0.91 1 +1.35 +10.82 23 -10.31 +3.58 45 -8.43 -1.22 67 -1.22 +3.71 B +6.88 +5.36 K -6.88 +5.36 2 +3.71 +10.26 24 -9.27 +5.77 46 -8.43 +1.22 68 +1.22 +3.71 +2.29 C +8.66 +0.91 L -3.00 +8.18 3 +5.89 +9.19 25 -7.77 +7.67 47 -7.90 +3.58 69 +3.18 D +7.82 -3.81 M 0.00 +4.45 4 +7.77 +7.67 26 -5.89 +9.19 48 -6.55 +5.59 70 +3.94 0.00 E +4.62 -7.37 N +3.91 +1.57 5 +9.27 +5.77 27 -3.71 +10.26 49 -4.67 +7.11 71 +3.18 -2.29 F 0.00 -8.71 P +2.39 -3.10 6 +10.31 +3.58 28 -1.35 +10.82 50 -2.49 +8.18 72 +1.22 -3.71 G -4.62 -7.37 R -2.39 -3.10 7 +10.85 +1.22 29 0.00 +8.20 51 -1.22 +6.12 73 -1.22 -3.71 H -7.82 -3.81 S -3.91 +1.57 8 +10.85 -1.22 30 +2.49 +8.18 52 +1.22 +6.12 74 -3.18 -2.29 9 +10.31 -3.58 31 +4.67 +7.11 53 +3.40 +5.05 75 -3.94 0.00 10 +9.27 -5.77 32 +6.55 +5.59 54 +5.28 +3.53 76 -3.18 +2.29 11 +7.77 -7.67 33 +7.90 +3.58 55 +6.02 +1.22 77 0.00 +1.35 12 +5.89 -9.19 34 +8.43 +1.22 56 +6.02 -1.22 78 +1.22 -0.74 13 +3.71 -10.26 35 +8.43 -1.22 57 +5.28 -3.53 79 -1.22 -0.74 39 +Y 41 +Y -X +X -X +X -Y Ctc X Y Z +5.92 +4.09 a +7.15 +0.87 b +6.73 -2.55 c +4.78 -5.39 d +1.73 -6.99 e -1.73 -6.99 f -4.78 -5.39 Ctc X Y Ctc X Y Ctc X Y A +1.65 +10.44 P -9.42 -4.80 d +2.84 -6.73 B +4.80 +9.42 R -10.44 -1.65 e -2.84 -6.73 Ctc X Y Ctc X Y g -6.73 -2.55 C +7.47 +7.47 S -10.44 +1.65 f -5.51 -4.80 A 0.00 +10.60 M -3.26 -10.09 h -7.15 +0.87 -Y D +9.42 +4.80 T -9.42 +4.80 g -7.11 -1.88 B +3.28 +10.09 N -6.23 -8.58 i -5.92 +4.09 E +10.44 +1.65 U -7.47 +7.47 h -7.11 +1.45 C +6.23 +8.58 P -8.58 -6.23 j -3.35 +6.38 F +10.44 -1.65 V -4.80 +9.42 i -5.89 +4.55 D +8.58 +6.23 R -10.09 -3.28 k 0.00 +3.81 G +9.42 -4.80 W -1.65 +10.44 j -3.20 +6.50 E +10.09 +3.28 S -10.60 0.00 m +2.98 +2.38 H +7.47 -7.47 X 0.00 +7.49 k 0.00 +4.17 F +10.60 0.00 T -10.09 +3.28 n +3.71 -0.85 J +4.80 -9.42 Y +3.20 +6.50 m +2.90 +1.22 G +10.09 -3.28 U -8.58 +6.23 p +1.66 -3.43 K +1.65 -10.44 Z +5.89 +4.55 n +2.69 -2.72 H +8.58 -6.23 V -6.23 +8.58 q -1.66 -3.43 L -1.65 -10.44 a +7.11 +1.45 p 0.00 -4.80 J +6.23 -8.58 W -3.28 +10.09 r -3.71 -0.85 M -4.80 -9.42 b +7.11 -1.88 q -2.69 -2.72 K +3.28 -10.09 X 0.00 +7.20 s -2.98 +2.38 N -7.47 -7.47 c +5.51 -4.80 r -2.90 +1.22 L 0.00 -10.60 Y +3.35 +6.38 t 0.00 0.00 81 8D Series | Common Section 23 / H 21 Ctc X Y 53 A +3.25 +9.78 +Y +Y -X +X -Y Ctc X Y Ctc X Y m -5.72 +6.60 +8.26 B +7.34 +7.24 N -11.43 +3.30 n -2.84 C +9.80 +3.12 P -8.53 +8.26 p 0.00 +6.60 D +10.16 -1.65 R -5.72 +9.91 q +2.84 +4.95 E +8.33 -6.07 S -2.84 +11.56 r +5.72 +3.30 F +4.65 -9.19 T 0.00 +9.91 s +5.72 0.00 G 0.00 -10.31 U +2.84 +8.26 t +5.72 -3.30 H -4.65 -9.19 V +5.72 +6.60 u +2.84 -4.95 J -8.33 -6.07 W +8.53 +4.95 v 0.00 -6.60 K -10.16 -1.65 X +8.53 +1.65 w -2.84 -4.95 L -9.80 +3.12 Y +8.53 -1.65 x -5.72 -3.30 M -7.34 +7.24 Z +8.53 -4.95 y -5.72 0.00 N -3.25 +9.78 a +5.72 -6.60 z -5.72 +3.30 +4.95 -X +X -Y P 0.00 +6.22 b +2.84 -8.26 AA -2.84 R +4.06 +3.71 Ctc X Y Ctc X Y c 0.00 -9.91 BB 0.00 +3.30 S +5.44 -0.89 A +2.84 +11.56 G +8.53 -8.26 d -2.84 -8.26 CC +2.84 +1.65 T +2.39 -4.93 B +5.72 +9.91 H +5.72 -10.41 e -5.72 -6.60 DD +2.84 -1.65 U -2.39 -4.93 C +8.53 +8.26 J -5.72 -10.41 f -8.53 -4.95 EE 0.00 -3.30 V -5.44 -0.89 D +11.43 +3.30 K -8.53 -8.26 g -8.53 -1.65 FF -2.84 -1.65 W -4.06 +3.71 E +11.43 0.00 L -11.43 -3.30 h -8.53 +1.65 GG -2.84 +1.65 X 0.00 0.00 F +11.43 -3.30 M -11.43 0.00 k -8.53 +4.95 HH 0.00 0.00 25 / J 04 Ctc X Y Ctc X Y 29 Ctc X Y +Y R -8.23 -10.80 q -7.90 -6.38 +Y J -2.31 -11.99 S -10.77 -8.28 r -9.58 -3.35 K -6.68 -10.31 T -12.52 -5.21 s -10.46 0.00 L -10.03 -7.04 U -13.49 -1.75 t -9.58 +3.35 M -11.91 -2.77 V -13.49 +1.75 u -7.90 +6.38 N -11.91 +2.77 W -12.52 +5.21 v -5.38 +8.78 P -10.03 +7.04 X -10.77 +8.28 w -2.18 +10.08 R -6.55 +10.31 Y -8.23 +10.80 x +1.75 +6.66 S -2.31 +8.15 Z -5.16 +12.57 y +4.37 +3.78 T +2.31 +8.15 U +5.79 +4.93 V +8.10 0.00 W +6.10 -4.60 -X +X -Y 82 a -1.75 +13.49 z +6.55 0.00 b +2.18 +10.08 AA +4.37 -3.78 c +5.38 +8.78 BB +1.75 -6.66 -X +X -Y d +7.90 +6.38 CC -1.75 -6.66 Ctc X Y X +2.31 -7.37 Ctc X Y Ctc X Y e +9.58 +3.35 DD -4.37 -3.78 A 0.00 +12.22 Y -2.31 -7.37 A +1.75 +13.49 H +12.52 -5.21 f +10.46 0.00 EE -6.55 0.00 B +6.55 +10.31 Z -6.10 -4.60 B +5.16 +12.57 J +10.77 -8.28 g +9.58 -3.35 FF -4.37 -3.78 C +10.03 +7.04 a -8.10 0.00 C +8.23 +10.80 K +8.23 -10.80 h +7.90 -6.38 GG -1.75 -6.66 D +11.91 +2.77 b -5.79 +4.93 D +10.77 +8.28 L +5.16 -12.57 k +5.38 -8.78 HH 0.00 +3.35 E +11.91 -2.77 c 0.00 +4.09 E +12.52 +5.21 M +1.75 -13.49 m +2.18 -10.08 JJ +2.18 0.00 F +10.03 -7.04 d +3.40 0.00 F +13.49 +1.75 N -1.75 -13.49 n -2.18 -10.08 KK 0.00 -3.35 G +6.68 -10.31 e 0.00 -3.30 G +13.49 -1.75 P -5.16 -12.57 p -5.38 -8.78 LL -2.18 0.00 H +2.31 -11.99 f -3.40 0.00 8D Series | Common Section 25 / J 35 Ctc X Y Ctc X Y Ctc X Y Ctc X Y Ctc X Y +Y 1 -12.17 +7.09 27 -6.32 +7.24 53 -2.11 0.00 79 +2.11 -7.24 104 +6.32 -12.07 2 -13.21 +4.83 28 -6.32 +4.83 54 -2.11 -2.41 80 +2.11 -9.65 105 +8.43 +11.28 3 -13.87 +2.41 29 -6.32 +2.41 55 -2.11 -4.83 81 +2.11 -12.07 106 +8.43 +8.43 4 -14.10 0.00 30 -6.32 0.00 56 -2.11 -7.24 82 +4.06 +13.49 107 +8.43 +6.02 5 -13.87 -2.41 31 -6.32 -2.41 57 -2.11 -9.65 83 +4.22 +10.85 108 +8.43 +3.61 6 -13.21 -4.83 32 -6.32 -4.83 58 -2.11 -12.07 84 +4.22 +8.43 109 +8.43 +1.19 7 -12.17 -7.09 33 -6.32 -7.24 59 0.00 +13.26 85 +4.22 +6.02 110 +8.43 -1.19 8 -10.77 +9.07 34 -6.32 -9.65 60 0.00 +10.85 86 +4.22 +3.61 111 +8.43 -3.61 9 -10.54 +4.83 35 -6.32 -12.07 61 0.00 +8.43 87 +4.22 +1.19 112 +8.43 -6.02 10 -10.54 +2.41 36 -4.06 +13.49 62 0.00 +6.02 88 +4.22 -1.19 113 +8.43 -8.43 11 -10.54 0.00 37 -4.22 +10.85 63 0.00 +3.61 89 +4.22 -3.61 114 +8.43 -10.85 12 -10.54 -2.41 38 -4.22 +8.43 64 0.00 +1.19 90 +4.22 -6.02 115 +10.77 +9.07 13 -10.54 -4.83 39 -4.22 +6.02 65 0.00 -1.19 91 +4.22 -8.43 116 +10.54 +4.83 14 -10.77 -9.07 40 -4.22 +3.61 66 0.00 -3.61 92 +4.22 -10.85 117 +10.54 +2.41 15 -8.43 +11.28 41 -4.22 +1.19 67 0.00 -6.02 93 +4.22 -13.26 118 +10.54 0.00 16 -8.43 +8.43 42 -4.22 -1.19 68 0.00 -8.43 94 +6.32 +12.60 119 +10.54 -2.41 17 -8.43 +6.02 43 -4.22 -3.61 69 0.00 -10.85 95 +6.32 +9.65 120 +10.54 -4.83 18 -8.43 +3.61 44 -4.22 -6.02 70 0.00 -14.10 96 +6.32 +7.24 121 +10.77 -9.07 19 -8.43 +1.19 45 -4.22 -8.43 71 +2.11 +12.07 97 +6.32 +4.83 122 +12.17 +7.09 20 -8.43 -1.19 46 -4.22 -10.85 72 +2.11 +9.65 98 +6.32 +2.41 123 +13.21 +4.83 21 -8.43 -3.61 47 -4.22 -13.26 73 +2.11 +7.24 99 +6.32 0.00 124 +13.87 +2.41 22 -8.43 -6.02 48 -2.11 +12.07 74 +2.11 +4.83 100 +6.32 -2.41 125 +14.10 0.00 23 -8.43 -8.43 49 -2.11 +9.65 75 +2.11 +2.41 101 +6.32 -4.83 126 +13.87 -2.41 24 -8.43 -10.85 50 -2.11 +7.24 76 +2.11 0.00 102 +6.32 -7.24 127 +13.21 -4.83 25 -6.32 +12.60 51 -2.11 +4.83 77 +2.11 -2.41 103 +6.32 -9.65 128 +12.17 -7.09 26 -6.32 +9.65 52 -2.11 +2.41 78 +2.11 -4.83 -X +X -Y 43 +Y -X +X H -Y Ctc X Y Ctc X Y 61 Ctc X Y Ctc X Y A +1.75 +13.49 Z -1.75 +13.4 +Y V -13.39 +2.57 t -7.24 +7.19 +9.22 B +5.16 +12.57 a +4.37 +8.74 W -12.32 +5.84 u -4.39 C +8.23 +10.80 b +6.55 +4.37 X -10.49 +8.71 v 0.00 +8.59 D +10.77 +8.28 c +8.74 0.00 Y -7.98 -11.05 w +3.73 +5.66 E +12.52 +5.21 d +8.74 -4.37 Z -4.98 +12.10 x +6.02 +3.10 F +13.49 +1.75 e +4.37 -8.74 a -1.73 +11.53 y +6.78 -0.25 G +13.49 -1.75 f 0.00 -8.74 b +1.73 +11.53 z +5.79 -3.53 H +12.52 -5.21 g -4.37 -8.74 c +4.39 +9.22 AA +3.33 -5.92 J +10.77 -8.28 h -8.74 -4.37 d +7.24 +7.19 BB 0.00 -6.78 K +8.23 -10.80 k -8.74 0.00 e +9.19 +4.45 CC -3.33 -5.92 L +5.16 -12.57 m -6.55 +4.37 f +10.13 +1.17 DD -5.79 -3.53 M 0.00 -13.49 n -4.37 +8.74 g +9.96 -2.24 EE -6.78 -0.25 N -5.16 -12.57 p 0.00 +8.74 Ctc X Y Ctc X Y h +8.66 -5.41 FF -6.02 +3.10 +5.66 -X +X -Y P -8.23 -10.80 q +2.18 +4.37 A +4.98 +12.70 K +6.58 -11.94 i +6.38 -7.98 GG -3.73 R -10.77 -8.28 r +4.37 0.00 B +7.98 +11.05 L +3.40 -13.18 j +3.38 -9.63 HH 0.00 +5.08 S -12.52 -5.21 s +4.37 -4.37 C +10.49 +8.71 M 0.00 -13.64 k 0.00 -10.21 JJ +2.67 +2.39 T -13.49 -1.75 t 0.00 -4.37 D +12.32 +5.84 N -3.40 -13.18 m -3.38 -9.63 KK +3.43 -1.04 U -13.49 +1.75 u -4.37 -4.37 E +13.39 +2.57 P -6.58 -11.94 n -6.38 -7.98 LL 0.00 -3.35 V -12.52 +5.21 v -4.37 0.00 F +13.61 -0.76 R -9.35 -9.93 p -8.66 -5.41 MM -3.43 -1.04 W -10.77 +8.28 w -2.18 +4.37 G +12.98 -4.17 S -11.53 -7.29 q -9.96 -2.24 NN -2.67 +2.39 X -8.23 +10.80 x 0.00 0.00 H +11.53 -7.29 T -12.98 -4.17 r -10.13 +1.17 PP 0.00 0.00 Y -5.16 +12.57 J +9.35 -9.93 U -13.61 -0.76 s -9.19 +4.45 83 8D SERIES © 2016 SOURIAU - SOURIAU is a registratred trademark 8D Series Derived Series High speed solutions: Twinax and Quadrax contacts ............................................................................ BMA coaxial contacts ......................................................................................... ELIO® fiber optic contacts .................................................................................. ELIOBEAM fiber optic contacts ......................................................................... 86 92 96 102 Power solutions: Power contacts ................................................................................................... High power contacts .......................................................................................... 106 111 Compact solutions: High density ....................................................................................................... Plug with integrated backshell ........................................................................... 116 118 Smart design solutions: High vibration plug: 8DV Series ......................................................................... Receptacle with clinch nuts or helicoils .............................................................. 122 126 PC tail contacts solutions: Double flange receptacle ................................................................................... PCB contacts without shoulder .......................................................................... 129 132 Reinforced sealing: Resin sealed connector ...................................................................................... Glass sealed connector ...................................................................................... 134 137 8D Series | Twinax & Quadrax Contacts Description • Front and rear removable versions available • Twinax: crimp version available • Quadrax: crimp and PC tail versions available • Standard #8 cavity insertion and removal tools • Ground connection of the cable braid to the shell possible through the external shell of the #8 contact • Compatible with star quad cable • Characteristic impedance of 100 Ohms • Mixed layouts not grounded Technical features Mechanical Electrical • Operating temperature: -65°C up to 150°C • ISO/IEC 11801 category 6 compliant: . Next (cross talk): > 46 db at 250 MHz . Return loss: > 16 db at 250 MHz . Shield effectiveness: > 36 db at 80 MHz • Inner contact: copper alloy • Contact body: copper alloy • Contact insulator: thermoplastic resin • Contact plating: gold over nickel • Shell plating: . Aluminum shell: Cadmium olive drab (W) Nickel (F) Black zinc nickel (Z) Green zinc cobalt (ZC) . Composite shell: Cadmium olive drab (J) Nickel (M) Without plating (X) . Stainless steel shell: Passivated (K) Nickel (S) . Titanium shell: Without plating (TT) Nickel (TF) . Bronze shell: Without plating Next (dB) • Contact to shell continuity: < 10 mΩ • Contact resistance (low level): . Initial 15 mΩ . After tests 30 mΩ Frequency (MHz) Return loss (dB) • Dielectric withstanding voltage: Altitude Service I sea level 500 Vrms 21 000 m 125 Vrms • Insulation resistance: . At ambient temperature: > 5000 MΩ . At high temperature: > 1000 MΩ • #24 contact cable size acceptance: AWG 22 to AWG 26 Frequency (MHz) Shield effectiveness (dB) Frequency (MHz) 86 8D Series | Twinax & Quadrax Contacts Contact layouts Contact #22D Contact #12 Contact #20 Contact #8, Twinax or Quadrax Contact #16 09 11 17 05* 81 80 81 82 1#8 1#8 2#12 2#8 38#22D 1#8 2#8 19 21 84 78 80 84 86 14#22D 4#8 17#22D 2#8 18#20 2#8 4#8 6#8 23 25 80 81 82 86 87 88 10#20, 13#16 4#12, 3#8 22#22D 3#20, 11#16 2#12, 3#8 97#22D 2#8 40#20, 4#16 2#8 36#22D 6#8 8#8 * 09-05 layout with twinax or quadrax contact: - grounded version only - plug with female contact & receptacle with male contact only Note: Mixed layouts not grounded. 87 8D Series | Twinax & Quadrax Contacts Ordering information Aluminum, Composite, Stainless steel & Titanium connector Basic Series 8D 0 Q 11 W 81 P N 284 L 284 L Shell style: 0: Square flange receptacle 5: Plug 7: Jam nut receptacle Type: C: Quadrax PC tail contacts* Q: Quadrax crimp contacts Shell size: 9 - 11 - 17 - 19 - 21 - 23 - 25 (see next page) Plating: Aluminum shell: W: Olive green cadmium F: Nickel Z: Black zinc nickel ZC: Green zinc cobalt Stainless steel shell: K: Passivated S: Nickel Composite shell: J: Olive green cadmium M: Nickel X: Without plating Titanium shell: TF: Nickel TT: Without plating Contact layout: See previous page Contact type: P: Pin S: Socket Orientation: N, A, B, C, D & E Specification: 284: Quadrax grounded PC tail contact (100Ω)* 308: Quadrax not grounded PC tail contact (100Ω) 384: Quadrax grounded crimp contact (150Ω)* 408: Quadrax not grounded crimp contact (150Ω) 620: Quadrax grounded crimp contact (100Ω)* 621: Quadrax not grounded crimp contact (100Ω) 550: Tin plated Quadrax not grounded PCB contact SnPb 550S: Tin plated Quadrax not grounded PCB contact SAC305 550E: Tin plated Quadrax not grounded PCB contact Sn pur L: For P or S contact type only, connectors delivered without contacts, connectors marking P or S plus orientation Bronze connector Basic Series JVS C 00A 09 35 P N Type: C: Quadrax PC tail contacts* Q: Quadrax crimp contacts Shell style: 00A: Square flange receptacle 16A: Plug 07A: Jam nut receptacle Shell size: 9 - 11 - 17 - 19 - 21 - 23 - 25 (see next page) Contact layout: See previous page Contact type: P: Pin S: Socket Orientation: N, A, B, C, D & E Specification: 284: Quadrax grounded PC tail contact (100Ω)* 308: Quadrax not grounded PC tail contact (100Ω) 384: Quadrax grounded crimp contact (150Ω)* 408: Quadrax not grounded crimp contact (150Ω) 620: Quadrax grounded crimp contact (100Ω)* 621: Quadrax not grounded crimp contact (100Ω) 550: Tin plated Quadrax not grounded PCB contact SnPb 550S: Tin plated Quadrax not grounded PCB contact SAC305 550E: Tin plated Quadrax not grounded PCB contact Sn pur L: For P or S contact type only, connectors delivered without contacts, connectors marking P or S plus orientation * For PC tail contacts or grounded versions please consult us. 88 8D Series | Twinax & Quadrax Contacts Dimensions Square flange receptacle - Type 0 B C PC Tail contacts Crimp contacts A A Max Shell size Aluminum Composite B Min Stainless steel, Titanium & Bronze Aluminum Composite B Max Stainless steel, Titanium & Bronze C Max Aluminum Composite Stainless steel, Titanium & Bronze All materials 11 to 19 10.72 11.96 11.4 11.5 12.5 12 13.5 13.5 14 29 21 to 25 11.54 12.76 11.8 12 14.5 12.5 14 15.5 14.5 30 Jam nut receptacle - Type 7 E Plug - Type 5 F G D PC Tail contacts Material Shell size 11 to 25 Crimp contacts Aluminum, Stainless steel, Titanium & Bronze D Max E Min E Max F Max 9.9 9.5 12 27 All materials Shell size 11 to 25 G Max 48 Note: All dimensions are in millimeters (mm) 89 8D Series | Twinax & Quadrax Contacts Dimensions Quadrax crimp contact 15.88 Max 7.69±0.2 0.79±0.5 0.79±0.5 1 Ø 7.99±0.04 15.95 Max Male contact Female contact Ø 7.31 Max 5 Min 22.75 Max 2 Ø 6.97±0.4 Ø 5.53±0.02 Ø 6.97±0.4 2 1 45° Quadrax PCB contact 19.85 Max 14.45 0.79±0.5 15.96±0.5 14.45±0.5 7.69±0.2 ±0.5 0.79±0.5 1 2 4.72 Min Ø 7.31 Max 3.75±0.15 Ø 6.97±0.4 2 1 45° Ø 7.99±0.04 3.75±0.15 19.8 Max Male contact Female contact Drill dimensions for PCB mount Ø 1.2 Min 45° 1.41 1.41 Ø 1.2 Min Ø 0.75 Min 2.24 1.41 1.41 2.24 2.24 Ø 0.75 Min 2.24 45° Male contact Note: All dimensions are in millimeters (mm) 90 Female contact 8D Series | Twinax & Quadrax Contacts Dimensions .0 2 Twinax crimp contact 15.88 Max 1. 5 ±0 Ø 7.99±0.03 2 1 Ø 6.96±0.02 45° 0.76 Max Ø 7.29 Max 0.78±0.03 Ø 6.96±0.02 7.69±0.02 0.78±0.03 0.76 Max 21.94 ±0.05 15.14 4.72 Min Male contact ±0.05 Female contact Contact ordering information In-line alignment key. All crimp contacts are sealed thru a sealing boot. Crimp contacts ordered separately are delivered with sealing boot. SOURIAU part number Contact type PC tail L= 4±0.1mm Quadrax contact Pin Socket Pin Crimp Socket Twinax contact Crimp Cross Norm Impedance Release T° Max ETH1-1237A - 100Ω Rear 125°C ETH1-1501A - 150Ω Rear 125°C ETH1-1238A - 100Ω Rear 125°C ETH1-1502A - 150Ω Rear 125°C ETH1-1345A EN 3155-074 100Ω Rear 150°C ETH1-1503A - 150Ω Rear 150°C ETH1-1346A EN 3155-075 100Ω Rear 150°C ETH1-1504A - 150Ω Rear 150°C Pin ETH2-110A - 100Ω Rear 150°C Socket ETH2-111A - 100Ω Rear 150°C Tooling • Inner contacts: M22520/2-01 crimping tool and K709 locator • Outer body: M22520/5-01 crimping tool and M22520/5-45 die set locator die set • Insertion/extraction tool, standard size 8 cavity tools: 8660-197 (metallic) or M81969/14-06 (plastic) Metallic tool Plastic tool Recommanded cable Impedance Reference Cable type Number of pairs 100Ω ABS 1503 KD24 Star quad 2 Note: All dimensions are in millimeters (mm) 91 8D Series | BMA Coaxial Contacts Description • Quick screw coupling D38999 connector • Shell available in aluminum, composite, Stainless steel, Titanium & Bronze • 16 layouts available with coaxial contact • High Frequency coaxial contact: DC 18GHz • Qualified coaxial contact according to MIL-STD-348A/321 • Removable coaxial contact • Contacts delivered with boots Technical features BMA contact features • Moisture resistance: MIL-STD-202, method 106 • Corrosion: Salt spray test according to MIL-STD-202, method 101, condition B Electrical • Impedance: 50Ω • Frequency range: DC 18GHz • Vibration: MIL-STD-202, method 204, condition D • Shock: MIL-STD-202, method 213, condition I Electrical • Insulation resistance: ≥ 5 000 MΩ Connector features • Contact resistance: . center contact: ≤ 2 mΩ . outer contact: ≤ 2 mΩ Mechanical • RF leakage interface only (fully mated): ≥ 90 dB f (GHz) measured at interface with reference planes being in true alignment. • RF testing voltage: 1.0 kVrms, 5 MHz (at sea level) • Admissible power: ≤ 300 W at 3 GHz (at sea level & room T°) • Shell material & plating: . Aluminum: Cadmium olive drab (W) Nickel (F) Black zinc nickel (Z) Green zinc cobalt (ZC) . Composite: Cadmium olive drab (J) Nickel (M) Without plating (X) . Stainless steel: Passivated (K) Nickel (S) . Titanium: Without plating (TT) Nickel (TF) . Bronze: Without plating • Insulator: Thermoplastic Environmental • Grommet and interfacial seal: Silicone elastomer • Temperature range: -65°C +125°C • Contact endurance: 1000 mating cycles • Thermal shock: MIL-STD-202, method 107, condition B 92 • Vibration: . Sinus: . 10 à 2000 Hz, 3x12 hrs (60g, 140 - 2000 Hz) with T° cycling . Random: . 50 to 2000 Hz, 2x8 Hrs (1g2/ Hz, 100 - 2000Hz) at T° max. . 25 to 2000 Hz, 2x8 Hrs (5g2/ Hz, 100 - 300Hz) at ambiant T° Test with accessories in acc with EN2591-D3 /!\ Caution: be careful that your application doesn’t exceed contact specification. • Dielectric withstanding voltage: 1.5 kVrms, 50Hz (at sea level) • Return loss (DC-18GHz): < -17dB (mated connector) • Shock: 300g, 3 ms (EN 2591-D2 method A) • Connector endurance: 500 mating cycles • Shell continuity: . F, S & TF: 1 mΩ . W, Z & ZC: 2.5 mΩ . K & TT: 10 mΩ • Shielding: . F & M: . K & TT: . W & Z: . F, S & TF: . Bronze: . J: . ZC: . J & M: 3 mΩ . Bronze: 5 mΩ 85 db at 1 GHz 45 db at 10 Ghz 50 db at 10 GHz 65 db at 10 GHz 85 db at 10 GHz 90 db at 10 GHz Consult us Environmental • Temperature range: . W, ZC, J, X & bronze: . F, Z, M, K, S, TT & TF: -65°C +175°C -65°C +200°C • Salt spray: . F, S & TF: . ZC: . W, Z, K, TT & bronze: . J, M & X: 48 Hours 250 Hours 500 Hours 2000 Hours 8D Series | BMA Coaxial Contacts Contact layouts Specification 737 mandatory Contact #22D Contact #12 Contact #20 Contact #8 Coax Contact #16 11 17 80 02 22 75 1#8 Coax 38#22D 1#8 Coax 2#12 2#8 Coax 2#8 Coax 19 21 18 20 48 75 77 06 14#22D 4#8 Coax 18#20 2#8 Coax 4#8 Coax 4#8 Coax 17#22D 2#8 Coax 6#8 Coax 23 25 07 08 17 20 41 46 2#8 Coax 97#22D 8#8 Coax 36#22D 6#8 Coax 10#20, 13#16 4#12 Coax 3#8 Coax 22#22D, 3#20 11#16, 2#12 3#8 Coax 40#20, 4#16 2#8 Coax 93 8D Series | BMA Coaxial Contacts Ordering information 8D Basic Series 0 25 W Shell style: 0: Square flange receptacle 1: In line receptacle 7: Jam nut receptacle 5: Plug with RFI shielding Shell size: 11, 17, 19, 21, 23, 25 Aluminum plating: W: Olive drab cadmium F: Nickel Z: Black zinc nickel Contact layout: See previous page Contact type: P: Pin S: Socket Orientation: N, A, B, C, D, E Specification (mandatory): 737: Coaxial contacts - for .086’’ flexible cable 747: Coaxial contacts - for .141’’ flexible cable For other material and configuration (integrated clinch nuts, double flange, other cables, ...) please consult us. Recommended cables Designation Part number .086’’ flexible cable Multiflex 86 .141’’ flexible cable Multiflex 141 For other cables please consult us. 94 Description Outer conductor contact Soldered 46 P N 737 8D Series | BMA Coaxial Contacts Assembly instruction C D B No shrinking sleeve allowed. A Picture Process Feature / Check Tools required 10.5 Dip the cut length of cable in flux and tin. 7 Cut the jacket to the braid. Remove jacket. A The solder must flow at rear for min. 7 mm. Stanley blade Do not damage inner conductor, dielectric and braid of cable. Stanley blade Tip trimmer Remove cable dielectric and tinned braid according to diagram. B 2.6 Form tip of centre contact to a 90° cone. 2 Slide Taper sleeve A and nipple B over cable. Slide ferrule C over cable, flush to dielectric. C X Solder at X. Avoid excessive heat, immediately cool down and clean with alcohol. B A Push prepared cable into connector body D and tighten nipple B. D B A Taper sleeve A will be used for MIL-connector. If the cable does not fit into the cable entry, use a flat-nose plier to calibrate the braid. Soldering iron Solder Flat-nose pliers Center conductor of cable must be exactly centered. Male contact: Torque wrench AF.6 (3 Nm) Spanner AF.5.5 Torque: 3 Nm. Female contact: Torque wrench AF.6 (3 Nm) Spanner AF.6 95 8D Series | ELIO® Fiber Optic Contact Description • Robust spring-loaded butt-joint optical contact using ST style ferrule (diameter 2.5mm) Multimode contact • Contact size equivalent to a #16 contact • Anti-rotation of the contact for better vibration withstanding and optical performance • Boot-grommet for rear sealing and protection of the cable against excessive bending • Compatibility with loose and tight structure cables • High level optical performance even after aging Singlemode contact • Bayonet locking system: no tool needed for mounting/dismounting • Compatible with singlemode, multimode and POF cable Technical features Optical • Multimode contact - Insertion Loss (IL): 0.1dB typical < 0.3dB over 95% of the samples as per EN2591-601, < 0.7dB maximum on 100% of the samples after tests • Multimode contact - Return Loss (RL): > 21dB before and after tests as per EN2591-605 • Singlemode contact - Insertion Loss (IL): 0.3dB typical < 0.5dB over 95% of the samples as per EN2591-601, < 0.9dB maximum on 100% of the samples after tests • Shock: 300g, 3 ms as per EN 2591-6402 method A • Cable cyclic flexing*: 100 cycles, load 40N as per EN2591-609 • Cable pulling*: 111N • Cable torsion*: 100 cycles, load 40N as per EN2591-611 * With multimode EN4641-100 cable and following the cabling process described in the ‘‘Technical Bulletin N°204 - ELIO® assembly wiring instructions’’ and the maintenance procedure in the document ‘‘Technical Bulletin N°170 - Fiber optics installation and maintenance procedure’’. Environmental • Salt spray: See the connector standard • Singlemode contact - Return Loss (RL): > 55dB typical and > 50dB mininum • Temperature range*: - 65°C to +125°C (1000 hours) Resistance to fluids as per MIL-DTL-38999/EN3645 standard • Fuel: JP5 • Mineral Hydraulic fluid: MIL-PRF-5606 ( NATO H-515) • Synthetic hydraulic fluid: AS1241 (Skydrol 500B4, LD4) • Mineral lubricant: MIL-PRF-7870 (NATO O-142) • Synthetic lubricant: MIL-PRF-23699 (NATO O-156), MIL-PRF-7808 ( NATO O-148) • Cleaning fluid: MIL-PRF-87937 diluted, Propanol, white spirit, Azeotrope R113 + Methanol • De-icing fluid: AMS 1424 ( NATO S-742) Mechanical • Endurance: Minimum 500 mating/unmating operations • Vibration: In MIL-DTL-38999 Series III/EN3645 connectors: . Sine 5Hz to 3000Hz as per EN2591-6403 method A . Random as per EN2591-6403 method B 96 • Rapid temperature change: 10 cycles - 65°C / +150°C (30min/30min) • Air leakage: Max leakage 16 cm3/h, 2 hours, 40kPa differential pressure • Damp heat and low temperature: 5 cycles of 48h -65°C/+70°C with stage at 40°C with 95% of humidity as per EN2591- 6303 method A • Extinguishing fluid: Bromochloromethane • Cooling fluid: Coolanol 8D Series | ELIO® Fiber Optic Contact Ordering information ELIO® multimode & singlemode contact ELIO 09N G L A Cable external diameter & Contact sealing: 09N: 0.9±0.1mm. Non waterproof 18N: from 1.5mm to 1.9mm. Non waterproof 18W: 1.8±0.1mm. Waterproof 20N: from 1.7mm to 2.1mm. Non waterproof 20W: 2.0±0.1mm. Waterproof Fibre type: G: ELIO® Multimode E: ELIO® Singlemode Boot type: L: Long boot S: Short boot N: No boot (non waterproof version only) Contact version index Note: For ABS1379/EN4531 cross reference, please consult us. ELIO® contact dimensions O-ring Bayonnet Protective cap Long boot 27 max Ø5 Ø2.5 21 Ferrule holder Spring 12 max (shape may vary) Cable Short boot 6 max No boot Recommended cables SOURIAU can offer a wide range of cables in its assemblies, from low cost to high performance aeronautical cables. ELIO® contact is compatible with singlemode and multimode cable, with tactical and breakout cable. ELIO® contact is suitable with loose and tight structure cable. See SOURIAU ‘‘ELIO® Fiber Optic Technology» catalog. Note: All dimensions are in millimeters (mm) 97 8D Series | ELIO® Fiber Optic Contact MIL-DTL-38999 Series III/EN3645 with ELIO® high density insert • Standard MIL-DTL-38999/EN3645 shells without shielding ring (aluminum, composite, stainless steel, bronze) • Environmental performance as per EN4531 based on MIL-DTL-38999/EN3645 • Temperature range: - 65°C to +125°C (cable limitation) Contact layouts 09 11 13 15 01 02 04 06 1 optical way 2 optical ways 4 optical ways 6 optical ways 19 21 25 08 12 24 8 optical ways 12 optical ways 24 optical ways Ordering information, Accessories & Tooling See SOURIAU ‘‘ELIO® Fiber Optic Technology» catalog. 98 Note: Layouts 15-06 and 21-12: limited availability, please consult us. 8D Series | ELIO® Fiber Optic Contact MIL-DTL-38999 Series III/EN3645 with ELIO® contact multimode or singlemode + ELIO® AQ Adaptor for Quadrax #8 cavities • ELIO® AQ is an adaptor to enable the ELIO® contact to fit in any #8 cavities multimode or + ELIO singlemode contact ® + AQ adaptor • Multiple possibilities to mix optical and electrical signals in the same insert • Compatible with standard MIL-DTL-38999 Series III/EN3645 connectors (aluminum, composite, stainless steel, bronze) • Design ensures ELIO® optical performance #8 cavity • Environmental performance as per MIL-DTL-38999 and EN3645 standard • Temperature range: - 65°C to +150°C (cable limitation) Contact layouts 19 11 17 81 80 81 82 84 1#8 2 #12 2 #8 38 #22D 1 #8 2 #8 14 #22D 4 #8 21 25 78 84 80 81 82 86 87 88 17 #22D 2 #8 4 #8 10 #20 13 #16 4 #12, 3 #8 22 #22D 3 #20, 11 #16 2 #12, 3 #8 97 #22D 2 #8 40 #20 4 #16 2 #8 36 #22D 6 #8 8 #8 Ordering information, Accessories & Tooling See SOURIAU ‘‘ELIO® Fiber Optic Technology» catalog. 99 8D Series | ELIO® Fiber Optic Contact Dimensions Plug and receptacles - mated / unmated 3.17 Max (Bronze) 3.20 Max (Aluminum & Stainless steel) L B A L 9.90 22.60 Max 31.00 Max Type 7 Jam Nut Receptacle Type 5 Plug L C Type 0 Square Flange Receptacle A Receptacle Type 0 & 7 Metal Receptacle Type 0 Composite B C L Shell size 09 to 19 Shell size 25 Shell size 09 to 19 Shell size 25 Shell size 09 to 19 Shell size 25 20.90 Max 20.10 Max 12.50 Max 13.00 Max 2.50 Max 3.20 Max 13.00 Max 3.65 Max 4.35 Max 20.90 Max 20.10 Max 12.50 Max D Female insulator 4 Max 6.60 Max F E G D E F G Shell size 09 to 19 Shell size 25 Shell size 09 to 19 Shell size 25 Shell size 09 to 11 Shell size 13 to 25 Shell size 09 to 11 Shell size 13 to 25 Plug + Receptacle Type 0 & 7 Metal 37.00 Max 36.50 Max 52.30 Max 51.50 Max 39.00 Max 39.00 Max 54.00 Max 54.00 Max Plug + Receptacle Type 0 Composite 37.00 Max 36.50 Max 52.30 Max 51.50 Max N/A N/A N/A N/A Note: All dimensions are in millimeters (mm) 100 Male insulator 8D Series | ELIO® Fiber Optic Contact Lengths - connectors with contacts 38999 Series III/EN3645 with ELIO® contacts in ELIO® high-density insert 38999 Series III/EN3645 with ELIO® contacts in ELIO® AQ adaptors L AQ adaptor Sealing boot R (see supplier datasheet) Q Without boot Without boot Short boot Short boot Long boot Long boot ELIO® high density insert L ELIO® AQ adaptors Contact length Male Female Without insulator insulator boot Short boot Long boot Plug Square flange receptacle 4 Max 6.60 Max 6 Max 12 Max Contact length Q 27 Max Jam nut receptacle Long boot Short boot Without boot Male Female Male Female Male Female Male Female insulator insulator insulator insulator insulator insulator insulator insulator 12 Max 9.5 Max 34.5 Max 32 Max 19.5 Max 17 Max 12.5 Max 10 Max 12.5 Max 10 Max 35 Max 32.5 Max 20 Max 17.5 Max 13 Max 10.5 Max 12 Max 9.5 Max 34.5 Max 32 Max 19.5 Max 17 Max 12.5 Max 10 Max Total length example Square flange receptacle + plug + ELIO® contacts in ELIO® high-density insert Unmated = C* + E* + L + 12 + R Mated = C* + D* + L + 12 + R + 5mm * See previous page Note: All dimensions are in millimeters (mm) 101 8D Series | ELIOBEAM Fiber Optic Contact ELIOBEAM contacts • Anti-rotation of the contact for better vibration withstanding and optical performance • Boot-grommet for rear sealing and protection of the cable against excessive bending • Compatibility with loose and tight structure cables • High level optical performance even after aging • Bayonet locking system: no tool needed for mounting/dismounting • Compatible with singlemode and multimode cables EN4531 Style ABS1379 Style Technical features Mechanical Environmental • Endurance: Minimum 500 mating/unmating operations • Salt spray: See the connector standard • Shock: 300 g, 3ms as per EN 2591-6402 method A • Vibration: In MIL-DTL-38999 Series III/EN3645 connectors: - Sine 5Hz to 3000Hz as per EN2591-6403 method A - Random as per EN2591-6403 method B • Cable cyclic flexing*: 100 cycles, load 40N as per EN2591-609 • Cable pulling*: 111N • Cable torsion*: 100 cycles, load 40N as per EN2591-611 • Temperature range*: - 65°C to +125°C (1000 hours) • Fuel: JP5 • Rapid temperature change: 10 cycles - 65°C / +150°C (30min/30min) • Mineral Hydraulic fluid: MIL-PRF-5606 ( NATO H-515) • Air leakage: Max leakage 16 cm3/h, 2 hours, 40kPa differential pressure • Synthetic hydraulic fluid: AS1241 (Skydrol 500B4, LD4) • Damp heat and low temperature: 5 cycles of 48h -65°C/+70°C with stage at 40°C with 95% of humidity as per EN2591- 6303 method A Optical • Multimode contact - Insertion Loss (IL): < 0.7dB mean 95% of the samples as per EN2591-601, < 1.0dB maximum on 100% of the samples after tests • Multimode contact - Return Loss (RL): > 16dB before and after tests as per EN2591-605 102 Resistance to fluids as per MIL-DTL-38999/EN3645 standard • Mineral lubricant: MIL-PRF-7870 (NATO O-142) • Synthetic lubricant: MIL-PRF-23699 (NATO O-156), MIL-PRF-7808 ( NATO O-148) • Cleaning fluid: MIL-PRF-87937 diluted, Propanol, white spirit, Azeotrope R113 + Methanol • De-icing fluid: AMS 1424 ( NATO S-742) • Extinguishing fluid: Chlorobromethane • Cooling fluid: Coolanol * With multimode EN4641-100 and EN4641-301 cables and following the maintenance procedure in the document ‘‘Technical Bulletin N°170 - Fiber optics installation and maintenance procedure’’. 8D Series | ELIOBEAM Fiber Optic Contact Principle of expanded beam The expanded beam concept expands and collimates the beam from the launch fiber. Without mechanical contact of the optical elements, the beam remains collimated until it is focused down to the receiving fiber. The beam expansion at the interface provides protection of the fiber from contaminants. Z axis Fiber Large beam at the connection interface ELIOBEAM ordering information EOB1 09N G L A Cable external diameter & Contact sealing: 09N: 0.9±0.1mm. Non waterproof 18N: from 1.5mm to 1.9mm. Non waterproof 18W: 1.8±0.1mm. Waterproof 20N: from 1.7mm to 2.1mm. Non waterproof 20W: 2.0±0.1mm. Waterproof Fibre type: G: ELIOBEAM® Multimode fibre, 50/125 or 62.5/125 Boot type: L: Long boot S: Short boot N: No boot (non waterproof version only) Contact version index ELIOBEAM contact dimensions Bayonnet Protective cap O-ring Long boot 27 max Ø5 Ø2.5 21 Ferrule holder Spring 12 max (shape may vary) All dimensions are in millimeters. Cable Short boot 6 max No boot 103 8D Series | ELIOBEAM® Fiber Optic Contact Recommended cables SOURIAU can offer a wide range of cables in its assemblies, from low cost to high performance aeronautical cables. ELIOBEAM contact is compatible with singlemode and multimode cables, with tactical and breakout cables. ELIOBEAM contact is suitable with loose and tight structure cable. See next page and SOURIAU ‘‘ELIO® Fiber Optic Technology’’ catalog. #8 Adaptors, Accessories & Tooling See SOURIAU ‘‘ELIO® Fiber Optic Technology’’ catalog. Your optical patchcord in 3 steps! Patchcord Cable/Terminus Combination Code 2 1 2 Select Termini End 1 Select cable Select Termini End 2 3 Determine total length Patchcord Length Optical patchcord ordering information HA02 Patchcord cable/terminus combination code: XXXX: See tables next page Patchcord length: In meter when possible. Examples: - for a 3 meter assembly, use 003(M) and not 300(CM) - for a 3.5 meter assembly, use 350(CM) Length unit: M: Meter CM: Centimeter Patchcord version index 104 XXXX Standard length tolerances Patchcord from 30 cm to 1 m 0 / + 5 cm Patchcord from 1 m to 4 m 0 / + 10 cm Patchcord from 4 m to 15 m 0 / + 20 cm Patchcord > 15 m 0 / + 30 cm XXX M A 8D Series | ELIOBEAM® Fiber Optic Contact 1 Select cable OM2 4.0/2.0 -55°C to +125°C 20 OM2 4.0/2.0 1.8 -65°C to +135°C 200 OM3 50/125 1.8 -40°C to +85°C 130 62.5/125 1.8 -40°C to +85°C 130 1.8 -55°C to +125°C 0.9 50/125 62.5/125 FOR FLYING USE High performance 62.5/125 cables FOR HARSH ENVIRONMENT Cost efficient cables Weight (kg.km-1) Attenuation (dB.km-1)* 250 Temperature range Fiber type Application Min. bend radius (mm) OM class Cable diameter Tensile strength (N) SOURIAU offers a wide range of cables, from cost efficient to high performance aeronautical cables. Select your optical fiber’s properties. Temperature range can be critical for your applications. If you need any help on a criteria selection, please contact us. Structure outer jacket Standard Cable type 20 4 Tight ABS0963-003LF, EN4641-102 FCABLE11 10 1 NA EN4641-101 FCABLE41 4.0/2.0 5 4 Tight EN4641-301 FCABLE22 OM3 3.0/1.0 25 2.2 Loose - FCABLE42 OM1 3.5/1.5 25 2.2 Loose - FCABLE61 * 1st value @850nm for multimode cable, 2nd value @1300nm for multimode (respectivly 1300nm and 1550nm for singlemode) Consult us for other harsh environment cables. 2 Select termini end 1 & 2 according to your selected cable, and get your final Patchcord cable/Terminus combination code Most common cables with most common contacts - For other combinations please consult us. All contacts are UPC polished otherwise specified. Termini End 2 Termini End 1 EOB118WGLA EOB109NGLA Cable types Cable type FCABLE11 FCABLE22 FCABLE42 FCABLE61 FCABLE41 ELIO18NGLA 3060 3071 3091 3102 N/A ELIO18NGNA 3061 3072 3092 3103 N/A ELIO18NGSA 3062 3073 3093 3104 N/A ELIO18WGLA 3063 3074 3094 3105 N/A ELIO18WGSA 3064 3075 3095 3106 N/A LC Simplex 3065 3076 3097 3108 3086 ARINC801 1.25mm 3066 3077 3098 3109 3087 FC/PC 3067 3078 3096 3107 3085 SC 3068 3079 3099 3110 3088 ST 3069 N/A 3100 3111 3089 ST2 N/A 3080 N/A N/A N/A EOB118WGLA 3070 3081 3101 3112 N/A ELIO09NGLA N/A N/A N/A N/A 3082 ELIO09NGNA N/A N/A N/A N/A 3083 ELIO09NGSA N/A N/A N/A N/A 3084 EOB109NGLA N/A N/A N/A N/A 3090 105 8D Series | Power Contacts Description • Quick screw coupling connector with removable crimp contact • Shell available in aluminum, composite, Stainless steel, Titanium & Bronze • Six layouts with different current rating • Consult us for power hermetic version • High Power offer available on demand Technical features Mechanical Electrical Environmental • Shell: Aluminum alloy, Composite, Bronze, Stainless steel, Titanium • Dielectric withstanding: Test voltage rating (Vrms) • Temperature range: . W, J, X, JVS = - 65°C +175°C . F, M, K, S, TT, TF = - 65°C +200°C • Plating: . Olive green cadmium (W/J) . Nickel (F/M/TF/S) . Without plating (X for composite, TT for titanium and JVS for Bronze) . Passivated (K) • Grommet and seal: Silicon elastomer • Insulator: Thermoset Service Sea level at 21 000 m M 1 300 800 I 1 800 1 000 • Insulation Resistance: 5000 MΩ under 500 Vdc • Contact body: Copper Alloy • Max current rating per contact: . #4 = 80A . #8 = 45A • Contact retention: . #4 = 200N . #8 = 111N • Contact resistance: . #4 = 2mΩ . #8 = 3mΩ • Shock: 300g during 3ms • Shielding: As per MIL DTL 38999 • Endurance: 500 mating / unmating operations • Shell continuity: . W = 2.5 mΩ . F = 1mΩ . J, M = 3 mΩ . JVS = 5 mΩ • Vibration: As per MIL DTL 38999 106 • Sealing: As per MIL DTL 38999 • Damp Heat: As per MIL DTL 38999 • Salt Spray: . W, TT, TF, K, JVS = 500 hours . F, S = 48 hours . J,M,X = 2000 hours • Fire resistance: As per EN 2591 - C 17 method A • Resistance to fluid: As per MIL DTL 38999 8D Series | Power Contacts Connector part numbers Aluminum, Composite, Stainless steel & Titanium connector 8D Basic Series 0 - 11 W 80 P N 251 16 A 11 80 P N 251 Style: 0: Square flange receptacle 5: Plug with RFI shielding 7: Jam nut receptacle Type: Crimp contact Shell size: 11, 17, 19, 21, 23, 25 Plating: Aluminum shell: W: Olive drab cadmium F: Nickel ZC: Green zinc cobalt Z: Black zinc nickel Composite shell: J: Olive green cadmium M: Nickel X: Without plating Stainless steel shell: K: Corrosion resistant S: Nickel Titanium shell: TT: Without plating TF: Nickel Contact layouts: See next page Contact style: P: Pin contact S: Socket contact A: Male connector supplied without contact B: Female connector supplied without contact Orientation: N, A, B, C, D, E Specification: 251: Mandatory for some layouts supplied with power contacts (see next page) Bronze connector Basic Series JVS Style: 00: Square flange receptacle 07: Jam nut receptacle 16: Plug Material: A: Bronze shell material Shell size: 11, 17, 19, 21, 23, 25 Contact layouts: See next page Contact style: P: Pin contact S: Socket contact A: Male connector supplied without contact B: Female connector supplied without contact Orientation: N, A, B, C, D, E Specification: 251: Mandatory for some layouts supplied with power contacts (see next page) 107 8D Series | Power Contacts Contact layouts Contact #22D Contact #12 Contact #20 Contact #8 Power Contact #16 Contact #4 Power 11 17 19 80 02 22 75 18 Spec 251 Spec 251 Spec 251 Spec 251 Spec 251 1#8 38#22D 1#8 2#12 2#8 2#8 14#22D 4#8 21 20 23 42* 48* 72* Spec 251 18#20 2#8 2#4 4#8 6#16 2#4 75 77 06 Spec 251 Spec 251 Spec 251 4#8 17#22D 2#8 6#8 44* 25 07 08 17 20 41 Spec 251 Spec 251 Spec 251 Spec 251 Spec 251 97#22D 2#8 8#8 36 #22D 6 #8 10#20 13#16 4#12 3#8 22#22D, 3#20 11#16, 2#12 3#8 * Power contacts on standard, no spec. 251 needed. 108 46 Spec 251 4#16 4#4 40#20 4#16 2#8 8D Series | Power Contacts Power contacts Contact size Contact type Part number Male 85997598900* Female 85997599900* Male 85997534 Female 85997535 Male 85997524 Female 85997525 Male 85997534 Female 85997535 Male 85997528900 Female 85997529900 Male 85997580 Female 85997581 Male 85997580 Female 85997581 #4 #8 #8 according to EN 3155 #8 JVS only Cable section AWG Male 85996215900 85996217900 Male 85996216900 Female 85996218900 Male 85997544 85997541 Male 85997544 Female 85997541 #22 Boot AWG mm² N/A 25 mm² AWG 4 16 to 21 mm² AWG8 9 mm² 85932000A AWG6 10 mm² Without AWG6 10 mm² Without AWG8 9 mm² 85994542 85997645 AWG10 6 mm² 85994547 AWG8 9 mm² 85994542 AWG10 6 mm² 85994547 Without AWG8 9 mm² 85994542 85997645 AWG10 6 mm² 85994547 Without Female Female Cable size max. Reducer N/A not sealed 85994594 for cable 16mm² N/A not sealed 85994593 Without #20 #16 #12 #10 #8 #4 mm² maxi 0.34 0.6 1.34 3.18 5.8 9 21 mm² mini 0.095 0.21 0.6 1.91 3.8 5.8 16 * Not included in connector P/N. Must be ordered separately. Bus bar contact Thread Recommended lug Contact Thread size ±0.3 12 12 Max Ø Part number Male Female Boots Lug Ø #4 M5x0.8 85930873A900 85930875A900 85994594 5.2 #8 M3x0.5 85930872A900 85930874A900 85994542 3.2 Contacts available separately only. Lug: tin over copper recommended. Dimensions for indication only. 28.1/29.4 Note: All dimensions are in millimeters (mm) 109 8D Series | Power Contacts Power tools Crimping tool Contact size Contact type Contact reference Cable AWG Automatic tool: M22520/23-01 Die set #4 #8 JVS only #8 Male 8599-7534 Female 8599-7535 Male 8599-7544 Female 8599-7541 Male 8599-7580 Female 8599-7581 #4-5 or #10-16mm² #8 or #10 Automatic tool for contacts #4 & #8 Crimping tool M22520/23-01 110 Die set Locator Locator M22520/23-04 M22520/23-11 M22520/23-02 8599-9601 Manual hand tool: M300 BT Locator Contact Contact extraction tool extraction tool (metallic) (plastic) N/A 8533-8175 M81969/14-07 SP 593 8660-197 M81969/14-12 Manual hand tool for contacts #8 Extraction tool Crimping tool M300 BT Metallic tool Locator 8D Series | High Power Contacts Description • Threaded coupling connector with single power contact • Aluminum shell • 3 shell sizes available: - size 19: Up to 450 A at 40°C - size 23: Up to 650 A at 40°C - size 25: Up to 850 A at 40°C • Silver plated contact • Pin contact is equipped with a plastic cap to prevent electrical shock • Modular design: . Removable backshell: straight, right angle or threaded contact . Backshell termination: shrink boot Technical features Mechanical • Shell: Aluminum alloy • Shell plating: Black zinc nickel (Z) Cadmium olive drab (W) • Insulator: Thermoplastic 80°C 40°C 19 • Vibration: According Def Stan 00-35 4.2 g rms vert - 6h/3 axes 120°C ze • Endurance: 500 mating/unmating operations Max temperature use Recommended use 160°C Si • Contact body: Copper alloy -- 200°C 9 e1 Siz • Grommet and interfacial seal: Silicone elastomer • Connector rating Si ze Si ze 23 23 Siz e2 5 Siz e2 5 0 0 200A 400A 600A 800A 500A Example for 500A: Shell size 25 with contact diameter 20: max temperature 135°C; recommended 120°C Shell size 23 with contact diameter 18: max temperature 90°C; recommended 80 °C Shell size 19 with contact diameter 14: not recommended Wire must be compatible with current and temperature used for the connector. 1000A Electrical Environmental Resistance to fluids • Test voltage > 1500 V • Temperature range: -65°C +175°C • Shell to shell continuity (no backshell) < 2.5 mΩ • Sealing: IP67 on mated connector (1 meter/30 min) • According to MIL-DTL-38999 standard . Gasoline: JP5 (OTAN F44) . Mineral hydraulic fluid: MIL-H-5606 (OTAN H515) . Synthetic hydraulic fluid: Skydrol 500 B4 • EMI 85 dB @ 1GHz (F) • Salt spray: 500 hours • Creepage and clearance: Min length in mm according to IEC60664-1 Shell size Creepage Clearance 19 2.805 2.492 23 2.830 4.492 25 2.715 4.492 • LD4 (SAE AS 1241) . Mineral lubricating: MIL-L-7870A (OTAN 0142) . Synthetic lubricating: MIL-L-23699 (OTAN 0156), MIL-L-7808 . Cleaning fluid: MIL-C-87936 diluted . De-icing fluid: MIL-A-8243 . Extinguishing fluid: Bromochloromethane . Cooling fluid: Coolanol 111 8D Series | High Power Contacts Contact layouts 19 23 25 H1 H1 H1 Other size: Please consult us. Ordering information 8D Basic Series 0 25 W Style: 0: Square flange receptacle 5: Plug (available with backshell D1, R1, G0 & W0 Types) 7: Jam nut receptacle Shell size: 19, 23, 25 Plating: Z: Zinc Nickel W: Olive green cadmium H1: Single power Contact style: P: Pin contact S: Socket contact Orientation: N, A, B, C, D, E Backshell type: D1: Straight backshell shrink boot & EMI (crimp version) R1: Right angle backshell shrink boot & EMI (crimp version) G0: Backshell low profile (threaded termination) W0: Without backshell (threaded termination) Specification for backshells D1 & R1 Types (crimp version): Specification Shell size A B C D 19 19 19 23 23 25 25 E F Admissible cable (mm) Outer Ø max Nominal core Ø 17 10.15 17 11.1 17 12 22 14.05 22 16.3 26.5 26.5 19 Specification for backshells G0 & W0 Types (only threaded termination): Specification C Shell size 19, 23 & 25 Thread M12 Note: Plug not available with backshell W0 Type. Other thread, please consult us. Note: For other configuration, please consult us. 112 Barrel diameter (mm ±0.05) 10.8 11.8 12.5 15 17 20.5 H1 P N R1 A 8D Series | High Power Contacts Backshell type Description D1: Straight backshell shrink boot & EMI (crimp version) G0: Backshell low profile (threaded termination) R1: Right angle backshell shrink boot & EMI (crimp version) W0: Without backshell (threaded termination) Dimensions Plug & receptacles 8D5 Square flange receptacle 8D7 Jam nut receptacle Plug F E 8D0 H A ØG D ØJ B C Shell size A±0.1 B±0.1 C±0.1 D±0.1 E±0.1 F Max ØG Max H±0.25 ØJ±0.25 19 36.5 26.97 29.36 3.29 4.98 41 38.5 45.95 49.15 23 42.9 31.75 34.93 52.35 55.55 34.93 38.1 6.2 44.9 46 3.96 47 25 52 48 55.55 58.65 Note: All dimensions are in millimeters (mm) 113 8D Series | High Power Contacts Dimensions Backshell D1 type A F E F G ØC ØD F G ØC A With 8D7 (jam nut receptacle) ØC ØD B With 8D5 (plug) ØD With 8D0 (square flange receptacle) G K M N H P Shell size A Max 19 23 2.65 25 B Max ØC±0.1 ØD±0.1 E±0.1 20.9 25.6 31.6 2.26 32.4 38.6 35.6 42.1 20.1 2.97 F±0.2 G±0.2 H Max K Max M±0.25 N Max P Max 12 4 62.5 62 3.25 22.8 63 Backshell R1 type With 8D5 (plug) With 8D7 (jam nut receptacle) H G A H G B M H L K J G With 8D0 (square flange receptacle) N F F F E A ØC ØD Shell size A Max 19 23 25 2.85 B Max ØC±0.1 ØD±0.1 E±0.1 20.9 25.6 31.3 2.26 32.4 38.1 35.6 41.3 20.1 Note: All dimensions are in millimeters (mm) 114 ØC ØC ØD 2.97 F±0.2 12 G±0.2 4 ØD H Max J Max K Max L Max 51.1 59.8 59.3 59.8 54.4 63.2 62.7 63.2 56.1 64.8 64.3 64.8 M±0.25 N Max 3.25 22.8 8D Series | High Power Contacts Dimensions Backshell G0 type With 8D0 (square flange receptacle) With 8D5 (plug) With 8D7 (jam nut receptacle) E B C F A D J G J F G J G A K Shell size A Max 19 23 2.65 B Max C Max 20.9 29 20.1 25 D Max E±0.1 F±0.2 ØG±0.1 2.26 39.4 29.8 2.97 F M D H L D H Max J Max K Max 88.1 M12 x 1.75 22.6 L Max 31.3 25 38.1 M±0.25 27.6 28.4 41.3 3.25 Backshell W0 type With 8D7 (jam nut receptacle) E B J J With 8D0 (square flange receptacle) F C K Shell size B Max 19 20.9 23 25 20.1 F M D C Max D Max 14 40 E±0.1 L D F±0.2 J Max K Max L Max M±0.25 25 M12 x 1.75 22.6 12 3.25 2.26 2.97 Note: All dimensions are in millimeters (mm) 115 8D Series | High Density Description • Derived from standards: - MIL-DTL-38999 Series III (8D) • 100% scoop proof • Available in 3 shell sizes • Contacts #26 for cable AWG 26 to 30 (24 to 30 under request) • Double flange & clinch nut version available Technical features Mechanical Electrical Environmental • Shell: . Aluminium, Composite, Stainless steel • Contact resistance: Size 26: 16 mΩ • Temperature range: -55°c to +175°C -55°c to +200°C (Nickel version) • Shell palting: . 8D Aluminum: Cadmium olive drab (W) Nickel (F) Black zinc nickel (Z) . 8D Composite: Cadmium olive drab (J) Nickel (M) • Insultation resitance: ≥5000MΩ (at 500Vdc) • Insulator: Thermoplastic • Seal: Liquid Silicone rubber • Contact: Copper alloy • Contact plating: Gold • Endurance: 500 matings/unmatings • Shock & Vibration: According to 38999 specification • Contact rating: Size 26: 3Amp • Shell continuity: . Aluminum shell: Cadmium olive drab (W): 2.5 mΩ Nickel (F): 1 mΩ Black zinc nickel (Z): 2.5 mΩ . Composite shell: Cadmium olive drab (J): 3 mΩ Nickel (M): 3 mΩ . Stainless steel shell: Passivated (K): 10 mΩ Nickel (S): 1 mΩ • Sealing mated connectors: IP 67 (1 metre for 30 min minimum) • Salt spray: . Aluminum shell: W: 500 Hrs F: 48 Hrs Z: 500 Hrs . Composite shell: 2000 Hrs . Stainless steel shell: 500 Hrs Resistance to fluids • According to MIL-DTL-38999 standard . Gasoline: JP5 (OTAN F44) . Mineral hydraulic fluid: MIL-H-5606 (OTAN H515) . Synthetic hydraulic fluid: Skydrol 500 B4 • LD4 (SAE AS 1241) . Mineral lubricating: MIL-L-7870A (OTAN 0142) . Synthetic lubricating: MIL-L-23699 (OTAN 0156), MIL-L-7808 . Cleaning fluid: MIL-C-87936 diluted . De-icing fluid: MIL-A-8243 . Extinguishing fluid: Bromochloromethane . Cooling fluid: Coolanol 116 8D Series | High Density Contact layouts 09 11 13 12 26 43 PCB hole drilling and position information See pages 76 & 77. 12#26 26#26 43#26 Ordering information Basic Series 8D 0 - 11 W 26 P N Shell style: 0: Square flange receptacle 1: In line receptacle (Aluminum only) 7: Jam nut receptacle (Aluminum, Stainless steel & Titanium only) 5: Plug with RFI shielding Type: - : Connectors with standard crimp contacts L: Receptacle with PC tail (available with Pin contact only) Shell size: 09, 11, 13 Plating: W: Olive drab cadmium (Aluminum only) F: Nickel (Aluminum only) Z: Black zinc nickel (Aluminum only) J: Olive drab cadmium (Composite only) M: Nickel (Composite only) Contact layout: See above Contact type: P: Pin S: Socket Orientation: N, A, B, C, D, E Specifications: L: Delivered without contact 900 (mandatory for PC tail version): PC tail contacts without shoulder 901 (mandatory for PC tail version): Tin plated PC tail contacts without shoulder Contact, tooling & accessories See «Common Section» page 63. Recommanded cable Standard military cable as M22759 or EN2267 and derivated. 117 8D Series | Plug with Integrated Backshell Description • Derived from standard MIL-DTL-38999 Series III • Plug in 9 sizes (from size 09 to 25) • Black zinc nickel, cadmium and nickel plating Technical features Mechanical Electrical Environmental • Shell: Aluminum • Contact resistance: • Temperature range: -55°c to +175°C (Z & W) -55°c to +200°C (F) • Shell palting: . Nickel (F) . Black zinc nickel (Z) . Olive drab cadmium: (W) Contacts size 22 20 16 12 8 4 Resistance mΩ 14.6 7.3 3.8 3.5 3 2 • Insulator: Thermoplastic • Insulation resitance: ≥5000mΩ (at 500Vdc) • Seal: Silicone elastomer • Contact rating: • Contact: Copper alloy • Contact plating: Gold over nickel • Endurance: 500 matings/unmatings • Shock & Vibration: According to 38999 specification Contacts size 22 20 16 12 8 Rating (A) • Sealing mated connectors: IP 67 (1 meter for 30 min minimum) • Salt spray: . 48 hours (F) . 500 hours (Z & W) 4 5 7.5 13 23 45 80 Resistance to fluids • Shell continuity . Nickel (F): 1 mΩ . Black zinc nickel (Z): 2.5 mΩ . Olive drab cadmium (W): 2.5 mΩ • According to MIL-DTL-38999 standard . Gasoline: JP5 (OTAN F44) . Mineral hydraulic fluid: MIL-H-5606 (OTAN H515) . Synthetic hydraulic fluid: Skydrol 500 B4 • LD4 (SAE AS 1241) . Mineral lubricating: MIL-L-7870A (OTAN 0142) . Synthetic lubricating: MIL-L-23699 (OTAN 0156), MIL-L-7808 . Cleaning fluid: MIL-C-87936 diluted . De-icing fluid: MIL-A-8243 . Extinguishing fluid: Bromochloromethane . Cooling fluid: Coolanol 118 8D Series | Plug with Integrated Backshell Ordering information Basic series 8DA 5 - 13 Z 35 P N Shell type: 5: Plug with RFI shielding Style: -: Connector with standard crimp contacts Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Plating: Z: Black zinc nickel F: Nickel W: Olive drab cadmium Contact layout: See pages 13 to 17 Contact type: P: Male S: Female Orientation: N, A, B, C, D, E L: Without contact Note: Power, Quadrax and Optical layouts, please consult us. Type 0 and Type 7 on request. 3D models 8D Integrated Backshell 3D models are available on www.traceparts.online.net Registration is quick and the downloads are free! Dimensions Plug Type 5 42.2/1.66 Max 17.5/0.69 ±0.1 ØB Max 3.5/0.14 Max ØA Max 12.1/0.48 09 11 13 15 17 19 21 23 25 ØA 11.1/0.44 14.1/0.55 17.1/0.67 21.1/0.83 24.1/0.95 27.1/1.07 30.1/1.18 33.1/1.30 36.1/1.42 ØB 21.8/0.86 25.0/0.98 29.4/1.16 32.5/1.28 35.7/1.41 38.5/1.52 41.7/1.64 44.9/1.77 48.0/1.89 (mm)inches (mm/inch) Note: All dimensions are in millimeters and 119 8D Series | Plug with Integrated Backshell Connectors weight - in gram (±15%) Shell size & layout 9-35 11-35 13-35 15-35 17-35 19-35 21-35 23-35 25-35 Weight with contacts 14.92 20.62 29.82 40.37 48.33 59.51 70.23 82.41 96.86 Accessories & Tooling Recommended accessories for wiring Shell size Shield band (recommended) Hand banding tool Rear diameter to fit with boot 9 11.1/0.44 11 14.1/0.55 13 17.1/0.67 85930337A (individualy coiled) 85930338A (not individualy coiled) 15 85930339A 21.1/0.83 17 24.1/0.95 19 27.1/1.07 21 30.1/1.18 23 33.1/1.30 85999344 (not individualy coiled) 85999345 (individualy coiled) 25 85999346 36.1/1.42 To order braid, boot or other accessories, please contact your SOURIAU distributor. Shield Band Dimension C B A Note: All dimensions are in millimeters and inches (mm/inch) 120 85930337A or 85930338A 85999344 or 85999345 A 200/7.87 Min 362.1/14.26 ±1.5 B 3.0/0.12 6.0/0.24 C 0.4/0.016 Max 0.5/0. 019 8D Series | Plug with Integrated Backshell Accessories & Tooling Recommended installation torque Shell Size Installation Torque (Inch-Pounds) 09, 11, 13, 15, 17 & 19 40 21, 23 & 25 80 Tightening support 8599-0831 Part number: 8599-0831 This tool is made up of dummy receptacles housings of all 9 sizes for all key polarisation, and secures free connectors during wiring and fitting of rear accessories. Note: Torque values are based on 80% of the coupling thread strength specified in SAE-AS85049 standard. Crimping tools - for standard contacts Contact size #22D #20 #16 #12 Plier M22520/1-01 Plier M22520/2-01 (SOURIAU 8476-01) Turret Part number MIL Spec Locator Part number MIL Spec Contact type Contact Part number Pin 8599-0702 JJ - M22520/2-09 Socket 8599-0706 900 - M22520/2-06 Pin 8599-0703 SA Socket 8599-0707 900 M22520/1-04 M22520/2-10 Pin 8599-0704 MJ Socket 8599-0708 900 Pin 8599-0705 MJ Socket 8599-0709 900 - M22520/1-04 - M22520/1-04 - Insertion & extraction tools - for standard contacts Contact size Material Part number #22D Plastic M81969/14-01 #20 Plastic #16 Plastic #12 #10 Color Insertion Extraction Green White M81969/14-10 Red Orange M81969/14-03 Blue White Plastic M81969/14-04 Yellow White Plastic M81969/14-05 Grey - Other Accessories, Tooling & Contacts See "Common Section" page 63. 121 8DV Series | High Vibration Reinforced Locking Description • Threaded coupling • Shell sizes from 9 to 25 • Contact protection: 100% Scoop proof • RFI - EMI shielding and shell-to-shell conductivity • Contact fretting minimized • Accessories available (protective caps, backshells, etc… ) • Intermatable with Standards: . MIL-DTL-38999 Series III . EN3645 . BACC63DC Technical features Mechanical Electrical Environmental • Shell: Stainless steel • Test voltage rating (Vrms): • Temperature range: K: -65°C +200°C S: -65°C +200°C Peak temperature: 260°C • Shell plating: Passivated (K) Nickel (S) • Insulator: Thermoplastic • Grommet and interfacial seal: Silicone elastomer • Contacts: Copper alloy Service Sea level R M N I II 400 1 300 1 000 1 800 2 300 21 000 m 70,000 ft N/A 800 600 1 000 1 000 • Contact resistance: • Contacts plating: Gold over nickel plated Contact size 20 16 12 8 4 Resistance mΩ 14.6 7.3 22 3.8 3.5 3 2 • Endurance: 500 mating cycles • Shock: 300g, 3ms according EN2591-402 method A and EIA-364-27 • Insulation resistance: ≥ 5,000 MΩ (under 500 Vdc) • Contact rating: • Vibration: Sinusoidal: . 10 à 2000 Hz, 3x12 hrs (60g, 140 - 2000 Hz) with T° cycling Random: . 50 to 2000 Hz, 2x8 Hrs (1g2/ Hz, 100 - 2000Hz) at T° max. . 25 to 2000 Hz, 2x8 Hrs (5g2/ Hz, 100 - 300Hz) at ambiant T° Test with accessories in accordance with EN2591-403 and EIA-364-28 8 20 16 12 8 4 5 7.5 13 23 45 80 • Shielding: K: 45 db at 10 GHz S: 65 db at 10 GHz 22 20 16 Min force in N 44 67 111 111 111 200 122 12 22 Rating (A) • Shell continuity: K: 10 mΩ S: 1 mΩ • Contact retention: Contacts size Contact size 4 • Sealing: Mated connectors meet altitude immersion requirements of MIL-DTL-38999. • Salt spray: K: 500 Hrs S: 500 Hrs Resistance to fluids • According to MIL-DTL-38999 standard: . Gasoline: JP5 (OTAN F44) . Mineral hydraulic fluid: MIL-H-5606 (OTAN H515) . Synthetic hydraulic fluid: Skydrol 500 B4 • LD4 (SAE AS 1241): . Mineral lubricating: MIL-L-7870A (OTAN 0142) . Synthetic lubricating: MIL-L-23699 (OTAN 0156), MIL-L-7808 . Cleaning fluid: MIL-DTL-25769 diluted . De-icing fluid: MIL-A-8243 . Extinguishing fluid: Bromochloromethane . Cooling fluid: Coolanol 8DV Series | High Vibration Reinforced Locking 8DV overview • Full stainless steel design giving the plug the necessary robustness for harsh environments: vibration, fire resistance, corrosion, temperature peak up to 260°C. The metallic stop of plug to receptacle maintains the continuity of electrical ground regardless of the level of vibration. • Coupling with all types of D38999 receptacles and M85049 backshells. • Reduced contact fretting, contact conductivity guaranteed. • Security lock with vibration levels beyond D38999 standards values. The lock-on system increases the pressure force between plug and receptacle: excellent electrical conductivity between boxes coupled. • Easy implementation of rear accessories at high temperatures when harnessed. • Basic mechanical, electrical and environmental characteristics are identical to stainless steel D38999 connectors. 8DV coupling possibilities Sealed receptacles 8DV Plug or Hermetic receptacles or Dummy receptacle Type 21 Square flange Type 0 Square flange + Type 23 Jam nut Type 5 Reinforced locking Type 7 Jam nut Type 25 Solder mount 123 8DV Series | High Vibration Reinforced Locking Connector part numbers Basic Series 8D V5 11 K 35 P N L Shell style: V5: Plug with RFI shielding & reinforced locking Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Plating: K: Passivated S: Nickel Contact layout: See pages 13 to 17 Contact type: P: Pin A: Connector supplied less pin contact or with specific contacts (connector marking: A + orientation) S: Socket B: Connector supplied less socket contact or with specific contacts (connector marking: B + orientation) Orientation: N, A, B, C, D, E Specification: 251: Connector provided with power contacts (layouts with contact #8) 022: Fuel tank Special custom: None: Standard plastic cap M: Anti-static plastic cap L: For P or S contact type only, connectors delivered without contacts, connectors marking P or S plus orientation. Connectors weight - in gram (±10%) Layout 9-35 9-98 11-01 11-04 11-05 11-35 11-98 13-04 13-08 13-26 13-35 13-98 15-05 15-15 15-18 15-19 15-35 15-97 17-06 17-08 17-26 17-35 17-75 17-99 124 with contacts Male Female 32.53 34.11 32.53 33.83 41.53 44.47 41.35 44.41 41.38 44.59 41.28 44.75 41.25 44.01 56.64 60.42 57.02 62.20 57.39 63.04 56.82 62.59 56.68 61.30 68.49 73.83 69.29 76.45 69.50 78.38 69.03 76.76 69.13 78.37 68.96 76.01 73.97 83.57 72.96 81.69 73.54 84.33 73.78 87.33 79.38 90.67 73.59 84.15 without contacts Male Female 32.11 32.61 32.11 32.63 40.87 42.87 40.79 42.81 40.68 42.59 40.37 41.50 40.41 41.61 55.40 57.30 55.90 59.00 55.65 58.34 55.28 57.09 55.28 57.30 66.94 69.93 67.02 70.07 66.98 71.18 66.37 69.16 66.54 69.12 66.60 69.69 70.01 73.97 70.48 75.45 69.90 73.93 69.93 73.58 70.38 76.67 70.03 74.19 Layout 19-11 19-32 19-35 21-11 21-16 21-35 21-39 21-41 23-21 23-35 23-53 23-55 25-19 25-24 25-29 25-35 25-43 25-46 25-61 25-08 25-20 25-04 with contacts Male Female 87.99 101.58 87.20 100.60 87.51 103.96 101.71 121.55 98.81 114.09 99.09 119.75 100.47 120.80 99.01 116.38 118.01 141.26 116.37 142.52 116.43 138.62 117.18 140.25 130.34 162.35 129.84 161.20 128.16 157.13 125.95 158.78 128.20 158.88 130.50 154.34 125.25 152.00 151.58 183.41 136.60 166.82 129.00 158.85 without contacts Male Female 84.58 93.00 82.72 87.80 82.89 87.46 94.45 103.95 93.85 101.61 93.56 100.00 94.67 104.44 93.27 99.98 111.50 124.88 109.37 117.52 109.01 117.42 109.48 118.25 117.80 131.95 118.20 132.64 119.17 134.51 116.99 126.78 118.78 134.08 115.86 126.02 116.71 127.60 115.58 127.41 115.03 125.28 119.80 133.41 8DV Series | High Vibration Reinforced Locking Dimensions Plug type 5 reinforced locking (8DV) Shell size A ØB A Max Thread ØB Max 09 (A) M12 x 1-6g 21.80 11 (B) M15 x 1-6g 25.00 13 (C) M18 x 1-6g 29.40 15 (D) M22 x 1-6g 32.50 17 (E) Thread M25 x 1-6g 35.70 19 (F) 31.00 M28 x 1-6g 38.50 21 (G) M31 x 1-6g 41.70 23 (H) M34 x 1-6g 44.90 25 (J) M37 x 1-6g 48.00 Mated connectors dimensions Type 0 with plug Type 7 with plug A C Shell size A Max B Max 09 (A) 11 (B) 13 (C) 15 (D) 37.00 C Max D Max 38.30 53.60 38.50 53.80 52.30 17 (E) 19 (F) 21 (G) B D 23 (H) 36.00 51.30 25 (J) Note: All dimensions are in millimeters (mm) 125 8D Series | Receptacle with Clinch Nuts or Helicoils Description • Square flange receptacle with 4 clinch nuts or 4 helicoils • Clinch nut & helicoils are self-locking • Rear mounting • Easy to install, time saving • Equivalent MIL level qualification as 38999 Series III • Clinch nut & helicoil tested: . Impact test (drop 0.4kg from height of 100mm) . Push out test (130N during 15s max) . Wrench out test (1N/m) Technical features Mechanical Electrical Environmental • Shell: Aluminum • Test voltage rating (Vrms) • Temperature range: W: -65°C +175°C Z & F: -65°C +200°C Service R M N I II • Shells plating: Black zinc nickel (Z) Cadmium olive drab (W) Nickel (F) • Insulator: Thermoplastic • Grommet and interfacial seal: Silicone elastomer sea level 400 1 300 1 000 1 800 2 300 • Contact resistance • Contact: Copper alloy • Contact plating: Gold over nickel plated Contacts size 26 22 20 16 12 8 4 Resistance mΩ 16 14.6 7.3 3.8 3.5 3 2 • Insulation resistance: ≥ 5 000 MΩ (under 500 Vdc) • Shock: 300g, 3ms according EN2591-D2 method A • Contact rating: • Vibration: . Sinus: . 10 à 2000 Hz, 3x12 hrs (60g, 140 - 2000 Hz) with T° cycling . Random: . 50 to 2000 Hz, 2x8 Hrs (1g2/ Hz, 100 - 2000Hz) at T° max. . 25 to 2000 Hz, 2x8 Hrs (5g2/ Hz, 100 - 300Hz) at ambiant T° Test with accessories in acc with EN2591-D3 • Contact retention: 8 • Sealing: Mated connectors meet altitude immersion requirements of MIL-DTL-38999. • Salt spray: Z & W: 500 Hours F: 48 Hours Resistance to fluids • Endurance: . 500 mating/unmating operations Contacts size 26 22 20 16 12 Min force in N 30 44 67 111 111 111 200 126 at 21000 m N/A 800 600 1 000 1 000 4 Contacts size 26 22 20 16 12 8 Rating (A) 3 4 5 7.5 13 23 45 80 • Shell continuity Black zinc nickel (Z): 2.5 mΩ Cadmium olive drab (W): 2.5 mΩ Nickel (F): 1 mΩ • Shielding: F: 65 db at 10 GHz Z, F & W: 85 db at 1 GHz Z & W: 50 db at 10 GHz • According to MIL-DTL-38999 standard . Gasoline: JP5 (OTAN F44) . Mineral hydrolic fluid: MIL-H-5606 (OTAN H515) . Synthetic hydraulic fluid: Skydrol 500 B4 • LD4 (SAE AS 1241) . Mineral lubricating: MIL-L-7870A (OTAN 0142) . Synthetic lubricating: MIL-L-23699 (OTAN 0156), MIL-L-7808 . Cleaning fluid: MIL-C-87936 diluted . De-icing fluid: MIL-A-8243 . Extinguishing fluid: Bromochloromethane . Cooling fluid: Coolanol 8D Series | Receptacle with Clinch Nuts or Helicoils Ordering information Basic Series 8D 34 - 19 F 35 S N Shell style: 34: Square flange receptacle with M3 clinch nuts, F & W only 35: Square flange receptacle with M3 helicoils, Z only 37: Square flange receptacle with UNC 4-40 helicoils, Z only 39: Square flange receptacle with UNC 4-40 clinch nuts, F & W only Contact lenght: (consult us) - : Connectors with standard crimp contacts C: Short PC tail L: Long PC tail Shell size: 9 - 11 - 13 - 15 - 17 - 19 - 21 - 23 - 25 Plating: Z: Black zinc nickel F: Nickel W: Olive green cadmium Contact layout: See pages 13 to 17 Contact type: P: Pin S: Socket Orientation: N, A, B, C, D, E Specification: 046: Tin plated contact SnPb 046E: Tin plated contact Sn pure 046S: Tin plated contact SAC305 900: Contact without shoulder (gold plated) 901: Tin plated contact without shoulder SnPb 901E: Tin plated contact without shoulder Sn pure 901S: Tin plated contact without shoulder SAC305 Dimensions Mounted connectors (with 8D5 connector) 2.5 Max. 3.95 Min. (shell 9 to 19) 3.15 Min. (shell 21 to 25) Panel Note: All dimensions are in millimeters (mm) 127 8D Series | Receptacle with Clinch Nuts or Helicoils Dimensions Ø3.96 Max. Square flange receptacle - type 34 & type 39 G Shell Size 2.3 Max. H ØK A ±0.30 B E Max. 4 Clinch Nuts C Max. Thread D Max. A ±0.3 B C Max D Max E Max Thread 9 27.79 18.26 M12x1-6g 11 30.15 20.62 M15x1-6g 13 32.54 23.01 15 34.14 24.61 17 36.5 26.97 M25x1-6g 19 38.89 29.36 M28x1-6g 21 41.27 31.75 M31x1-6g 23 44.45 34.93 25 47.62 38.1 20.90 10.60 20.10 M18x1-6g 2.50 11.40 M22x1-6g 3.20 M34x1-6g M37x1-6g Short contact length Min / Max - For other length please consult us G Shell size H #22D #20 K #16 #22D #20 & #16 #22D & #20 #16 P S P S P&S P&S P&S P&S P&S 9 to 19 9.47 / 10.54 9.09 / 10.54 9.64 / 10.71 9.26 / 10.71 9.64 / 10.75 21 to 25 9.58 / 10.65 9.20 / 10.65 9.75 / 10.82 9.37 / 10.82 9.75 / 10.86 3.8 / 4.0 4.9 / 5.1 0.65 / 0.70 1.09 / 1.15 Square flange receptacle - type 35 & type 37 A B D 4 Helicoils Short contact length See table above. Note: All dimensions are in millimeters (mm) 128 31.5 Max. C Shell Size A B 9 23.8 18.26 11 26.2 20.62 13 28.6 23.01 15 31 24.61 17 33.3 26.97 19 36.5 29.36 21 39.7 31.75 23 42.9 34.93 25 46 38.1 C D 20.83 3 20.07 8D Series | Double Flange Description • High level vibration resistance in harsh environments • Offers the same level of performance as the MIL-DTL-38999 Series III connector • Jam nut or square flange receptacle • No risk of breaking contacts • No risk of micro-cuts • Allow direct grounding from PCB to the flange • PC tails contacts without shoulder: #16, #20 and #22 • Resin sealed version, please consult us Technical features Mechanical Electrical Environmental • Shell: Aluminum • Test voltage rating (Vrms) • Temperature range: . W: -65°C +175°C . F: -65°C +200°C . Z: -65°C +200°C Service M N I II • Shell plating: . Cadmium olive drab (W) . Nickel (F) . Black zinc nickel (Z) • Insulator: Thermoplastic • Grommet and interfacial seal: Silicone elastomer sea level 1 300 1 000 1 800 2 300 at 21000 m 800 600 1 000 1 000 • Contact resistance Contacts size • Contacts: Copper alloy 22 Resistance mΩ 14.6 20 16 12 7.3 3.8 3.5 • Sealing: Mated connectors meet altitude immersion requirements of MIL-DTL-38999. • Salt spray: . W: 500 Hrs . F: 48 Hrs . Z: 500 Hrs • Contacts plating: Gold over nickel plated • Insulation resistance: ≥ 5 000 MΩ (under 500 Vdc) • Endurance: 500 mating cycles • Shock: 300g, 3ms according EN2591-D2 method A • Vibration: . Sinus: . 10 à 2000 Hz, 3x12 hrs (60g, 140 - 2000 Hz) with T° cycling . Random: . 50 to 2000 Hz, 2x8 Hrs (1g2/ Hz, 100 - 2000Hz) at T° max. . 25 to 2000 Hz, 2x8 Hrs (5g2/ Hz, 100 - 300Hz) at ambiant T° Test with accessories in acc with EN2591-D3 • Contact retention: Contacts size 22 20 16 12 Min force in N 44 67 111 111 Resistance to fluids • Contact rating: Contacts size 22 20 16 12 Rating (A) 5 7.5 13 23 • Shell continuity: . Cadmium olive drab (W): 2.5 Ωh . Nickel (F): 1 Ωh . Black zinc nickel (Z): 2.5 Ωh • Shielding: . F: 65 db at 10 GHz; 85 db at 1 GHz . W: 50 db at 10 GHz . Z: Consult us • According to MIL-DTL-38999 standard . Gasoline: JP5 (OTAN F44) . Mineral hydrolic fluid: MIL-H-5606 (OTAN H515) . Synthetic hydraulic fluid: Skydrol 500 B4 • LD4 (SAE AS 1241) . Mineral lubricating: MIL-L-7870A (OTAN 0142) . Synthetic lubricating: MIL-L-23699 (OTAN 0156), MIL-L-7808 . Cleaning fluid: MIL-C-87936 diluted . De-icing fluid: MIL-A-8243 . Extinguishing fluid: Bromochloromethane . Cooling fluid: Coolanol 129 8D Series | Double Flange Ordering information Basic Series 8D 87 11 C 17 W 35 P N Shell type: 80: Square flange receptacle 87: Jam nut receptacle Length between panel & PCB (in mm) For other length, please consult us. Type: C: Receptacle with short PC tail L: Receptacle with long PC tail Shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 Plating: W: Olive green cadmium F: Nickel (RoHS) Z: Zinc nickel (RoHS) Contact layout: Consult us for available layouts Contact type: P: Pin S: Socket Orientation: N, A, B, C, D, E Specification: None: Standard L: Without contacts For other specification, please contact us 046: Tin plated contact SnPb 046E: Tin plated contact Sn pure (RoHS) 046S: Tin plated contact SAC305 (RoHS) Dimensions Jam nut receptacle (type 87) Sizes 9 & 11 Sizes 13 to 25 X Panel 4 holes M3 45° ØA ØC ØA O’ring D 90° .2 ±0 6 from flat) F (dimensions ØC ØB Long contact (L) Short contact (S) ØB E E 9 11 13 15 17 19 21 23 25 ØA ± 0.15 ØB ± 0.15 15.10 19.90 19.90 23.00 26.00 29.50 32.50 35.50 38.60 Note: All dimensions are in millimeters (mm) 130 26.00 30.80 30.80 33.90 36.80 40.40 43.20 46.50 49.60 2.4±0.2 5±0.2 11±0.2 22.6 Max 120° Shell size ØJ Maxi 3 holes M3 120° ØC D +0 -0.2 E ± 0.4 F ± 0.15 20.50 25.20 25.25 28.42 31.42 35.03 37.82 41.12 44.30 12 14 16 18 20 23 25 27.00 31.80 34.90 38.10 41.30 46.00 49.20 52.40 55.60 16.53 19.07 23.82 26.97 30.15 33.32 36.50 39.67 42.85 Contact Contact PC tail size type length 22D 20 16 M&F M&F M&F M&F M&F M&F Long Short Long Short Long Short Size 09 Size 13 & 11 to 25 X Min 7.1 3.6 7.1 3.6 7.1 3.6 X Min 7.1 3.6 7.1 4.2 7.1 4.2 ØJ max 0.7 0.9 1.35 L 8D Series | Double Flange Dimensions Square flange receptacle (type 80) Sizes 13 to 25 ØB 45° ØB 120° 22.3±0.1 (size 13 to 25) 22.12±0.1 (size 9 & 11) E G 11±0.1 3+0.3 0 90° ØJ Maxi Sizes 9 & 11 ØC ØF D 6 ±0.1 3 holes M3 ØC ØA ØA 4 holes M3 X 4 helicoils M3x0.5 2.4±0.1 5±0.1 Shell size ØA ± 0.1 ØB ± 0.1 ØC ± 0.1 D ± 0.1 E ± 0.2 ØF ± 0.1 G ± 0.1 9 15.1 26 20.5 - 23.75 15.67 18.26 11 19.9 30.8 25.2 - 26.14 18.67 20.62 13 19.9 30.8 25.25 12 28.55 22.07 23.01 15 23 33.9 28.42 14 30.94 25.25 24.61 17 26 36.8 31.42 16 33.25 30 26.97 19 29.5 40.4 35.03 18 36.45 31.57 29.36 21 32.5 43.2 37.82 20 39.65 34.75 31.75 23 35.5 46.5 41.12 23 42.85 37.92 34.93 25 38.6 49.6 44.3 25 45.95 41.1 Contact Contact PC tail size type length M 22D F M 20 F M 16 38.1 F Long Short Long Short Long Short Long Short Long Short Long Short Size 09 Size 13 & 11 to 25 X Min 7.39 4.39 7.12 4.12 7.39 4.39 7.40 4.40 7.39 4.39 7.34 7.34 X Min 7.21 4.21 6.94 3.94 7.21 4.21 7.22 4.22 7.21 4.21 7.16 4.16 ØJ max 0.70 0.90 1.35 Note: All dimensions are in millimeters (mm) Comparison Before After Risk of breaking contacts Risk of micro-cuts Double flange Printed Circuit Board Box Panel 131 8D Series | PCB Contacts without Shoulder Description • Pin & socket PCB contacts without shoulder #20 & #22D as per MIL-DTL-38999 Series I, II & III. Contacts without shoulder allows a more flexible mounting on variable PCB thicknesses or depths. • Ruggedized contacts: . Material: copper alloy . Finish: gold per MIL-G-45204 type I class 1 over nickel plate . Sleeve: stainless steel • Flexible mounting: . Various PCB thicknesses . Multiple PCB positioning Ordering information 8D Series connector with PCB contacts without shoulder Basic Series: 8D 0 Shell type 0: Square flange receptacle 7: Jam nut receptacle 34: Square flange receptacle with M3 clinch nut (F or W plating, aluminum shell only) 35: Square flange receptacle with M3 helicoils (Z plating, aluminum shell only) 37: Square flange receptacle with UNC 4-40 helicoils (Z plating, aluminum shell only) 39: Square flange receptacle with UNC 4-40 clinch nut (F or W plating, aluminum shell only) PCB contact without shoulder type (see next page for information & dimensions) C: Short PC tail M: Medium PC tail L: Long PC tail shell size: 09, 11, 13, 15, 17, 19, 21, 23, 25 8D aluminum plating F: Nickel Z: Black zinc nickel W: Olive green cadmium ZC: Green zinc cobalt 8D stainless steel plating K: Passivated S: Nickel 8D composite plating J: Olive green cadmium M: Nickel X: Without plating 8D titanium plating TT: Without plating TF: Nickel Contact layout: See pages 13 to 17 Contact type P: Male S: Female Orientation: N, A, B, C, D, E Specification 900: Contact without shoulder with gold plated barrel (termination area) 901: Contact without shoulder with tin plated SnPb barrel (termination area) 901E: Contact without shoulder with tin plated Sn pure barrel (termination area) 901S: Contact without shoulder with tin plated SAC305 barrel (termination area) Special custom None: Standard plastic cap M: Antistatic plastic cap Note: For JVS (8D Bronze Series, please consult us) 132 C 11 F 35 P N 900 8D Series | PCB Contacts without Shoulder Dimensions Type 0 & type 7 Square flange receptacle 8D0 (8D34 / 8D35 / 8D37 / 8D39) Jam nut receptacle 8D7 Z Z C C L L Contact size #22D & #20 #22D & #20 Shell type Contact Type Pin Socket Ø C Max Square flange receptacle 8D0 / 8D34 / 8D35 / 8D37 / 8D39 Jam nut receptacle 8D7 Z Min Z Max Z Min Z Max C: Short PC tail 0.50 3.96 4.88 3.56 4.63 M: Medium PC tail 0.50 5.99 6.91 5.59 6.66 L: Long PC tail 0.50 7.51 8.43 7.11 8.18 C: Short PC tail 0.50 3.96 5.21 3.56 4.81 M: Medium PC tail 0.50 5.99 7.24 5.59 6.84 L: Long PC tail 0.50 7.51 8.76 7.11 8.36 Square flange receptacle 8D0 / 8D34 / 8D35 / 8D37 / 8D39 Jam nut receptacle 8D7 Shell size 9 to 19 21 to 25 9 to 25 L Max 10.7 11.5 9.90 Note: All dimensions are in millimeters (mm) 133 8D Series | Reinforced Sealing Description • Reinforced sealed receptacle with male or female straight PC tail contacts • Strong sealing performance: 10-7 atm.cm3/s • Designed for unpressurized area • 125°C max (operational temperature) • 100 % scoop proof • Full RoHS solution • High density connectors • Weight saving compared to hermetic version • Other SOURIAU ranges on request Technical features Mechanical Electrical Environmental • Shell plating: . 8D aluminum shell: . Black zinc nickel (Z) . Olive drab cadmium (W) . Nickel (F) . 8D composite shell: . Olive drab cadmium (J) . Nickel (M) . 8D stainless steel shell: . Nickel (S) . Passivated (K) . 8D titanium shell: . Nickel (TF) . Without plating (TT) • Contact resistance: • Temperature range: -55°C +125°C • Insulator: Thermoplastic • Interfacial seal: Silicone elastomer • Contacts: Copper alloy • Contacts plating: Gold over nickel plated • Endurance: 500 mating/unmating operations 134 Contacts size 22 20 16 Resistance mΩ 14.6 7.3 3.8 • Shielding: . F; S; TF: 65db - 10GHz . F; Z; W; J; M: 85db - 1GHz . Z; W: 50db - 10GHz . K; TT: 45db - 10GHz • Shell continuity: . F; TF; S: 1mΩ . Z; ZC; W: 2.5mΩ . J; M: 3mΩ . JVS: 5mΩ . TT; K: 10mΩ • Sealing (initial): 10-7 atm.cm3/s • Salt spray: . F; S; TF: 48h . Z; W; JVS; TT; K; S: 500h . J; M: 2000h 8D Series | Reinforced Sealing Ordering information 8D part number Basic Series: 8DR 0 C 09 Z 35 P N Shell type: 0: Square flange receptacle 1: In line receptacle (8D aluminum only) 7: Jam nut receptacle (except 8D Composite) Contact type: C: Receptacle with short PC tail (male and female #22D, #20, #16, #12) L: Connector with long PC tail (male and female #22D) S: Connector with specific PC Tail (male and female #22D) M: Connector with medium PC tail (male #22D) P: Connector with solder cup: . Pin: #22D, #20 & #16; Socket: #12 . Socket: #22D, #20 & #16; Pin: #12 - Please consult us Shell size 09, 11, 13, 15, 17, 19, 21, 23, 25 Aluminum plating: F: Nickel Z: Black zinc nickel W: Olive drab cadmium Composite plating: J: Olive drab cadmium M: Nickel Stainless steel plating: K: Passivated S: Nickel Titanium plating: TT: Without plating TF: Nickel Contact layout See next page Contact type: P: Male S: Female Orientation N, A, B, C, D, E Double flange receptacle available, please consult us. Receptacle with integrated clinch nuts or helicoils available, please consult us. Contacts without shoulder available, please consult us. 135 8D Series | Reinforced Sealing Contact layouts For C or L contact type. For other contact type or layouts, please consult us. 09 / A 11 / B 13 / C 35 98 05 35 35 98 6#22D Service M 3#20 Service I 5#20 Service I 13#22D Service M 22#22D Service M 10#20 Service I 15 / D 17 / E 19 / F 18 35 97 26 35 35 18#20 Service I 37#22D Service M 4#16 8#20 Service I 26#20 Service I 55#22D Service M 66#22D Service M 21 / G 23 / H 35 35 25 / J Contact #22D 35 61 Contact #20 Contact #16 79#22D Service M 136 100#22D Service M 128#22D Service M 61#20 Service I 8D Series | Hermetic Series Description • Glass sealed hermetic: . high hermeticity perfomance . compact low profile • Quick screw coupling according to EN3645 and MIL-DTL-38999 Series III standards • Robust stainless steel adapted for any weld or solder operation • Various mounting styles: . compact solder mount receptacle . easy to install square flange receptacle . easy to replace jam nut receptacle • Signal and power contacts • Various PCB contact versions available • Special fuel tank versions for long term fuel immersion • 230V qualified versions where higher voltage is used to reduce cable weight Technical features Mechanical • Shell: . Class Y: passivated stainless steel . Class N: nickel plated stainless steel • Seals: . Silicone elastomer • Contact: . Gold plated ferrous alloy • Endurance: . 500 mating/unmating operations Electrical Environmental • Max current rating per contact: • Operating temperature: -65°C to 200°C Contact size 22D 20 16 12 8 Rating (A) 3 5 10 17 33 • Dielectric withstanding voltage: Service M I II Sea level 30 000 m 1 300 Vrms 800 Vrms 1 800 Vrms 1 000 Vrms 2 300 Vrms 1 000 Vrms • Shielding: . Class Y: 45 dB min at 10 GHz . Class N: 65 dB min at 10 GHz • Insulation resistance: . 5000 MΩ (under 500 Vdc) 4 60 • Hermeticity: leak rate
D38999/24FJ46SN-LC 价格&库存
很抱歉,暂时无法提供与“D38999/24FJ46SN-LC”相匹配的价格&库存,您可以联系我们找货
