DILM12-10(24V50HZ)
DILM12-10(24V50HZ)
    EATON(伊顿)
DILM12-10(24V50HZ) 数据手册
Type: DILM12−10(24V50HZ) Article No.: 276817 Ordering information Rated operational current AC−3 400 V Ie A 12 Max. rating for three−phase motors, 50 – 60 Hz AC−3 230 V P kW 3.5 Max. rating for three−phase motors, 50 – 60 Hz AC−3 400 V P kW 5.5 Max. rating for three−phase motors, 50 – 60 Hz AC−3 690 V P kW 6.5 Max. rating for three−phase motors, 50 – 60 Hz AC−4 230 V P kW 2 Max. rating for three−phase motors, 50 – 60 Hz AC−4 400 V P kW 3 Max. rating for three−phase motors, 50 – 60 Hz AC−4 690 V P kW 4.4 General Standards IEC/EN 60947, VDE 0660, UL, CSA Lifespan, mechanical AC operated DC operated Operations × 106 10 Operations 106 10 × Operating frequency, mechanical AC operated Operations/h 9000 DC operated Operations/h 9000 Damp heat, constant, to IEC 60068−2−78 Damp heat, cyclical, to IEC 60068−2−30 Climatic proofing Ambient temperature Open °C −25/60 Enclosed °C −25/40 Storage °C −40/80 1 Mechanical shock resistance (IEC/EN 60068−2−27) Half−sinusoidal shock, 20 ms Main contacts Make contact g 10 Auxiliary contacts Make contact g 7 Break contact g 5 Protection type IP20 Protection against direct contact when actuated from front (IEC 536) Finger− and back−of−hand proof Weight AC operated kg 0,23 DC operated kg 0,28 Terminal capacity Main cable Solid mm2 1 × (0.75 – 4) 2 × (0.75 – 2.5) Flexible with ferrule mm2 1 × (0.75 – 2.5) 2 × (0.75 – 2,5) Solid or stranded AWG 18 – 14 Anschlussschraube Hauptleiter Tightening torque M3.5 Nm 1.2 Solid mm2 1 × (0.75 – 4) 2 × (0.75 – 2.5) Flexible with ferrule mm2 1 × (0.75 – 2.5) 2 × (0.75 – 2.5) Solid or stranded AWG 18 – 14 Terminal capacity Control circuit cables Anschlussschraube Hilfsleiter Tightening torque M3.5 Nm 1.2 Pozidriv screwdriver Size 2 Standard screwdriver mm 0.8 × 5.5 1×6 Pozidriv screwdriver Size 2 Standard screwdriver mm 0.8 × 5.5 1×6 Solid mm2 0.75 – 2.5 flexible mm2 0.75 – 2.5 flexible with ferrules mm2 0.75 – 2.5 Solid or stranded AWG 18 – 14 Solid mm2 0.75 – 2.5 Flexible mm2 0.75 – 2.5 Flexible with ferrule mm2 0.75 – 2.5 Tool Main cable Control circuit cables Terminal capacity Main cable Terminal capacity Control circuit cables 2 Solid or stranded AWG 18 – 14 Tool Stripping length mm 10 Screwdriver blade width mm 3,5 Main conducting paths Rated impulse withstand voltage Uimp V AC Overvoltage category/pollution degree 8000 III/3 Rated insulation voltage AC Ui V AC 690 Rated operational voltage Ue V AC 690 Safe isolation to VDE 0106 Part 101 and Part 101/A1 between coil and contacts V AC 400 between the contacts V AC 400 A 144 Making capacity (cos Õ to IEC/EN 60947) up to 690 V Breaking capacity 220/230 V A 120 380/400 V A 120 500 V A 100 660/690 V A 70 Component lifespan AC−3/AC−4 Tripping characteristics Maximum operating frequency AC−1; 400 V Ie Ops/h 800 AC−3; 400 V Ie Ops/h 1000 AC−4; 400 V Ie Ops/h 300 400 V gG/gL 500 V A 20 690 V gG/gL 690 V A 20 400 V gG/gL 500 V A 35 690 V gG/gL 690 V A 25 at 40 °C Ith A 22 at 50 °C Ith A 21 at 55 °C Ith A 21 at 60 °C Ith A 20 Enclosed Ith A 18 Short−circuit rating Short−circuit protection Maximum fuse Type “2” coordination Type “1” coordination AC AC−1 duty conv. therm. current 3−pole 50 – 60 Hz open Conventional free air thermal current, 1−pole 3 open Ith A 50 Enclosed Ith A 45 220/230 V Ie A 12 240 V Ie A 12 380/400 V Ie A 12 415 V Ie A 12 440V Ie A 12 500 V Ie A 10 660/690 V Ie A 7 220/230 V P kW 3,5 240V P kW 4 380/400 V P kW 5,5 415 V P kW 7 440 V P kW 7,5 500 V P kW 7 660/690 V P kW 6,5 220/230 V Ie A 7 240 V Ie A 7 380/400 V Ie A 7 415 V Ie A 7 440 V Ie A 7 500 V Ie A 6 660/690 V Ie A 5 220/230 V P kW 2 240 V P kW 2,2 380/400 V P kW 3 415 V P kW 3,4 440 V P kW 3,6 500 V P kW 3,5 660/690 V P kW 4,4 60 V Ie A 20 110 V Ie A 20 220 V Ie A 15 440 V Ie A 1,3 Ie A 20 AC−3 duty Rated operational current AC−3 open, 50 – 60 Hz, 3−pole Motor rating AC−4 duty Rated operational current AC−4 open, 50 – 60 Hz, 3−pole Motor rating DC of three−phase capacitors open DC−1 operation DC−3 operation 60 V 4 110 V Ie A 20 220 V Ie A 1,5 440 V Ie A 0,2 60 V Ie A 20 110 V Ie A 20 220 V Ie A 1,5 440 V Ie A 0,2 DC−5 operation Current heat loss (3−pole) Current heat loss at Ith W 4,7 Current heat loss at Ie to AC−3/400 V W 1,1 Impedance per pole m& 2,5 Pick−up × Uc 0,8 – 1,1 Abfall × Uc 0,3 – 0,6 Pick−up × Uc 0,8 – 1,1 Abfall × Uc 0,15–0,6 50 Hz Pick−up VA 24 50 Hz Pick−up W 19 50 Hz Sealing VA 4 50 Hz Sealing W 1,2 60 Hz Pick−up VA 29 60 Hz Pick−up W 23 60 Hz Sealing 60 Hz Sealing VA 1,3 50/60 Hz Pick−up VA 28 26 50/60 Hz Pick−up W 22 21 50/60 Hz Sealing VA 4,6 3,9 50/60 Hz Sealing W 1,4 1,2 DC operated Pick−up W 4.5 DC operated Sealing W 4.5 % DF 100 ms 20 Magnet systems Voltage tolerance AC operated AC operated Drop−out voltage AC operated Drop−out voltage AC operated DC operated DC operated DC operated DC operated Power consumption of the coil in a cold state and 1.0 × Uc Duty factor 4,4 Switching times at 100 % Uc (approximate values) Main contacts AC operated Closing delay 5 Opening delay ms 15 ms 35 DC operated Closing delay Opening delay ms 15 Arcing time ms 10 Electromagnetic compatibility (EMC) Emitted interference to EN 60947−1 Interference immunity to EN 60947−1 Mounting position Mounting position, AC− and DC operated Moeller GmbH, Hein−Moeller−Str. 7−11, D−53115 Bonn E−Mail: catalog@moeller.net, Internet: www.moeller.net, http://catalog.moeller.net Copyright 2005 by Moeller GmbH. Subject to modifications. HPL−C2005GB−INT V3.0 6
DILM12-10(24V50HZ) 价格&库存
很抱歉,暂时无法提供与“DILM12-10(24V50HZ)”相匹配的价格&库存,您可以联系我们找货
