EASY-E4-UC-12RC1
EASY-E4-UC-12RC1
    EATON(伊顿)
    EATON MOELLER - EASY-E4-UC-12RC1 - CONTROL RELAY W/DISPLAY, 24VDC/VAC
EASY-E4-UC-12RC1 数据手册
DATASHEET - EASY-E4-UC-12RC1 Control relays easyE4 with display (expandable, Ethernet), 12/24 V DC, 24 V AC, Inputs Digital: 8, of which can be used as analog: 4, screw terminal Delivery program Part no.  Catalog No.    EL-Nummer (Norway)  EASY-E4-UC-12RC1 197211 4500546 Basic function     easyE4 basic device Description     Electronic control relay with display with Ethernet interface Expandable with the easyE4 series of digital input/output expansions with easy-E4CONNECT1 connector (Item Y7-197225) Rated operating voltage 12V DC, 24V DC or 24V AC 8 digital inputs, No. of these can be used as analog inputs - 4 Digital outputs: 4 relays Screw terminals Delivery with customized user program is possible via Item (Y7) -2010781 EASYCOMBINATION Inputs       Digital     8 of which can be used as analog     4       Quantity of outputs     Relay: 4 Additional features       Real time clock     # Display & keypad Outputs     # Expansions     Expandable networkable (Ethernet) Supply voltage     12/24 V DC 24 V AC Software     EASYSOFT-SWLIC/easySoft 7 Standards     EN 61000-6-2 EN 61000-6-3 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-30 IEC 61131-2 EN 61010 EN 50178 Approvals Technical data General       Approvals     cULus certificate     CE shipping classification     DNV GL       Dimensions (W x H x D)   mm 71.5 x 90 x 58 Weight   kg 0.215 Mounting     Top-hat rail IEC/EN 60715, 35 mm or screw fixing using fixing brackets ZB4-101-GF1 (accessories) Connection type     screw terminal Ethernet       Connections     RJ45 plug, 8-pin Cable     CAT5       Terminal capacities Screw terminals 02/18/2020 Eaton Y7-197211 ED2020 V65.0 EN 1/8 Solid   mm 2 0.2 - 4 flexible   mm 2 0.2 - 2.5 Solid or flexible conductor, with ferrule   mm 2 0,2 - 2,5 Solid or stranded   AWG 22 - 12 Standard screwdriver   mm 0.8 x 3.5 Tightening torque   Nm 0.5 - 0.7 Stripping length   mm 6.5 Display - Type     Monochrome Lines x characters     6 x 16 Operating ambient temperature   °C -25 to 55, cold as per IEC 60068-2-1, heat as per IEC 60068-2-2 Condensation     Take appropriate measures to prevent condensation LCD display (clearly legible)   °C 0 - 55 Storage ϑ °C -40 - +70 relative humidity   % in accordance with IEC 60068-2-30, IEC 60068-2-78 5 - 95 Air pressure (operation)   hPa 795 - 1080 Protection type (IEC/EN 60529, EN50178, VBG 4)     IP20 Vibrations   Hz In accordance with IEC 60068-2-6 constant amplitude 0.15 mm: 10 - 57 constant acceleration 2 g: 57 - 150 Mechanical shock resistance (IEC/EN 60068-2-27) semi-sinusoidal 15 g/11 ms   Impacts 18 Drop to IEC/EN 60068-2-31 Drop height mm 50 Free fall, packaged (IEC/EN 60068-2-32)   m 0.3 Mounting position     Vertical or horizontal Overvoltage category/pollution degree     III/2 Electrostatic discharge (ESD)       applied standard     according to IEC EN 61000-4-2 Air discharge   kV 8 Contact discharge   kV 6 Electromagnetic fields (RFI) to IEC EN 61000-4-3   V/m 0.8 - 1.0 GHz: 10 1.4 - 2 GHz: 3 2.0 - 2.7 GHz: 1 Radio interference suppression     EN 61000-6-3 Class B Burst   kV according to IEC/EN 61000-4-4 Supply cables: 2 Signal cables: 2 power pulses (Surge)     according to IEC/EN 61000-4-5 1 kV (supply cables, symmetrical) 2 kV (supply cables, asymmetrical) Immunity to line-conducted interference to (IEC/EN 61000-4-6)   V 10 Clearance in air and creepage distances     nach EN 50178, EN 61010-2-201, UL61010-2-201, CSA-C22.2 NO. 61010-2-201 Insulation resistance     per EN 50178, EN 61010-2-201, UL61010-2-201, CSA-C22.2 NO. 61010-2-201 Back-up of real-time clock           ① Backup time (hours) with fully charged double layer capacitor ② Service life (years) Accuracy of real-time clock to inputs   s/day typ. ± 2 (± 0.2 h⁄Year)       depending on ambient air temperature fluctuations of up to ± 5 s/day (± 0.5 h⁄year) are possible Accuracy of timing relays (of values)   % ± 0.02 Resolution         ms 5 Display Climatic environmental conditions Ambient conditions, mechanical Electromagnetic compatibility (EMC) Insulation resistance Back-up of real-time clock Repetition accuracy of timing relays Range “S” 02/18/2020 Eaton Y7-197211 ED2020 V65.0 EN 2/8 Range “M:S”   s 1 Range “H:M”   min 1 Rated operational voltage Ue V 12/24 DC (-15/+20%) 24 AC (-15/+10%) Permissible range Ue   10.2 - 28.8 V DC 20.4 - 26.4 V AC Residual ripple   % ≦5 Siemens MPI, (optional)     yes Frequency   Hz 50/60 (± 5%) Input current     max. 200 mA at 12 V DC max. 125 mA at 24 V DC Voltage dips   ms ≤ 20 ms at 24 V AC 10 ms at 24 V DC 1 ms at 12 V DC Fuse   A ≧ 1A (T) Power loss P W Normally 3 Heat dissipation at 24 V DC   W 3 Number     8 Status Display     LCD-Display Potential isolation     from power supply: no to the memory card: no to Ethernet: yes between inputs: no from the outputs: yes to expansion devices: yes Rated operational voltage Ue V DC 12 Input voltage   V DC Condition 0: ≦ 5 (I1 - I8) Condition 1: ≧ 8 (I1 - I8) Input current at signal 1   mA 1.75 mA (I1 - I4) 0.9 mA (I5 - I8) Deceleration time   ms 20 (0 -> 1/1 -> 0, Debounce ON) type 0.015 (0 -> 1/1 -> 0, Debounce OFF) Cable length   m 100 (unshielded) Frequency counter           Notes on this, see under Digital inputs 24 V DC           Notes on this, see under Digital inputs 24 V DC       Note     Notes on this, see under Digital inputs 24 V DC Number     8 Inputs can be used as analog inputs     4 (I5, I6, I7, I8) Status Display     LCD-Display Potential isolation     from power supply: no to the memory card: no to Ethernet: yes between inputs: no from the outputs: yes to expansion devices: yes Rated operational voltage Ue V DC 24 Input voltage   V DC Signal 0: ≦ 5 (I1 - I8) Condition 1: ≧ 15 (I1 - I8) Input current at signal 1   mA 3.3 (I1 – I4) 1.8 (I5 – I8) Deceleration time   ms 20 (0 -> 1/1 -> 0, Debounce ON) type 0.015 (0 -> 1/1 -> 0, Debounce OFF) Cable length   m 100 (unshielded) Frequency counter Power supply Digital inputs 12 V DC Note Incremental counter Note Rapid counter inputs Digital inputs 24 V DC       Number     4 (I1, I2, I3, I4) Counter frequency   kHz ≦ 10 Pulse shape     Square Pulse pause ratio     1:1 02/18/2020 Eaton Y7-197211 ED2020 V65.0 EN 3/8 Cable length   m ≦ 20 (screened) Incremental counter       Number of counter inputs     2 (I1 + I2, I3 + I4) Value range     -2147483648 to +2147483647 Counter frequency   kHz ≦ 10 Pulse shape     Square Signal offset     90° Pulse pause ratio     1:1 Cable length   m ≦ 20 (screened) Rapid counter inputs       Number     4 (I1, I2, I3, I4) Value range     -2147483648 to +2147483647 Counter frequency   kHz ≦ 10 Pulse shape     Square Pulse pause ratio     1:1 Cable length   m ≦ 20 (screened) Number     8 Status Display     LCD-Display Potential isolation     from power supply: no to the memory card: no to Ethernet: yes between inputs: no from the outputs: yes to expansion devices: yes Rated operational voltage Ue V AC 24 Input voltage (AC = sinusoidal) Ue V Status 0: ≦ 5 (I1 - I8) Condition 1: ≧ 14 (I1 - I8) Rated frequency   Hz 50/60 Input current at signal 1   mA I1 - I4: 3.5 (at 24 VAC/DC) I5 - I8: 1.8 (at 24 VAC/DC) Deceleration time   ms 45/38 (0 -> 1/1 -> 0, debounce ON 50/60Hz) type 25⁄21 (0 - > 1/1 -> 0, debounce OFF 50/60Hz) Cable length   m 40 (unshielded) Number     4 (I5, I6, I7, I8) Potential isolation     from power supply: no to the memory card: no to Ethernet: yes between inputs: no from the outputs: yes to expansion devices: yes Input type     DC voltage Signal range     0-10 V DC Resolution     12 Bit (value 0 - 4095) Input impedance   kΩ 13.3 Accuracy of actual value       two devices from series   % ± 3 , ± 0.12 V Within a single device Digital inputs 24 V AC Analog inputs   % ± 2, ± 0.12 V Conversion time, analog/digital   ms each CPU cycle Input current   mA 500 Rated impulse withstand voltage Uimp of contact coil   kV 6 Rated operational voltage Ue V AC 240 Rated insulation voltage Ui V AC 240 Safe isolation according to EN 50178   V AC 300 between coil and contact 300 between two contacts Making capacity       AC–-15, 250 V AC, 3 A (600 ops./h) Operations   300000 DC-13, L/R ≦ 150 ms, 24 V DC, 1 A (500 S/h) Operations   200000       AC-15, 250 V AC, 3 A (600 Ops./h) Operations   300000 DC-13, L/R ≦ 150 ms, 24 V DC, 1 A (500 S/h) Operations   200000 Breaking capacity Filament bulb load       1000 W at 230/240 V AC Operations   25000 500 W at 115/120 V AC Operations   25000             With upstream electrical device Operations   25000 Uncompensated Operations   25000 Operations   25000     Fluorescent lamp load Fluorescent lamp load 10 x 58 W at 230/240 V AC Fluorescent lamp load 1 x 58 W at 230/240 V AC, conventional, compensated Switching frequency   Mechanical operations   x 10 Switching frequency   Hz 10 Resistive load/lamp load   Hz 2 Inductive load   Hz 0.5       Uninterrupted current at 240 V AC   A 10 Uninterrupted current at 24 V DC   A 8 AC UL/CSA 6 10       Control Circuit Rating Codes (utilization category)     B 300 Light Pilot Duty Max. rated operational voltage   V AC 300 max. thermal continuous current cos ϕ = 1 at B 300   A 5 max. make/break cos ϕ ≠ capacity 1 at B 300   VA 3600/360 DC       Control Circuit Rating Codes (utilization category)     R 300 Light Pilot Duty Max. rated operational voltage   V DC 300 Max. thermal uninterrupted current at R 300   A 1 Max. make/break capacity at R 300   VA 28/28 Power loss P W 3 Data transfer rate   Mbit/s 10/100 Connections     RJ45 plug, 8-pin Cable     CAT5       Static heat dissipation, non-current-dependent Pvs W 3 Operating ambient temperature min.   °C -25 Operating ambient temperature max.   °C 55 Supply voltage UAux Ethernet Design verification as per IEC/EN 61439 Technical data for design verification IEC/EN 61439 design verification       10.2 Strength of materials and parts       10.2.2 Corrosion resistance     Meets the product standard's requirements. 02/18/2020 Eaton Y7-197211 ED2020 V65.0 EN 5/8 10.2.3.1 Verification of thermal stability of enclosures     Meets the product standard's requirements. 10.2.3.2 Verification of resistance of insulating materials to normal heat     Meets the product standard's requirements. 10.2.3.3 Verification of resistance of insulating materials to abnormal heat and fire due to internal electric effects     Meets the product standard's requirements. 10.2.4 Resistance to ultra-violet (UV) radiation     Meets the product standard's requirements. 10.2.5 Lifting     Does not apply, since the entire switchgear needs to be evaluated. 10.2.6 Mechanical impact     Does not apply, since the entire switchgear needs to be evaluated. 10.2.7 Inscriptions     Meets the product standard's requirements. 10.3 Degree of protection of ASSEMBLIES     Meets the product standard's requirements. 10.4 Clearances and creepage distances     Meets the product standard's requirements. 10.5 Protection against electric shock     Does not apply, since the entire switchgear needs to be evaluated. 10.6 Incorporation of switching devices and components     Does not apply, since the entire switchgear needs to be evaluated. 10.7 Internal electrical circuits and connections     Is the panel builder's responsibility. 10.8 Connections for external conductors     Is the panel builder's responsibility. 10.9 Insulation properties       10.9.2 Power-frequency electric strength     Is the panel builder's responsibility. 10.9.3 Impulse withstand voltage     Is the panel builder's responsibility. 10.9.4 Testing of enclosures made of insulating material     Is the panel builder's responsibility. 10.10 Temperature rise     The panel builder is responsible for the temperature rise calculation. Eaton will provide heat dissipation data for the devices. 10.11 Short-circuit rating     Is the panel builder's responsibility. 10.12 Electromagnetic compatibility     Is the panel builder's responsibility. 10.13 Mechanical function     The device meets the requirements, provided the information in the instruction leaflet (IL) is observed. Technical data ETIM 7.0 PLC's (EG000024) / Logic module (EC001417) Electric engineering, automation, process control engineering / Control / Programmable logic control (SPS) / Logic module (ecl@ss10.0.1-27-24-22-16 [AKE539014]) Supply voltage AC 50 Hz   V 20.4 - 28.8 Supply voltage AC 60 Hz   V 20.4 - 28.8 Supply voltage DC   V 10.2 - 28.8 Voltage type of supply voltage     AC/DC Switching current   A 8 Number of analogue inputs     4 Number of analogue outputs     0 Number of digital inputs     8 Number of digital outputs     4 With relay output     Yes Number of HW-interfaces industrial Ethernet     1 Number of interfaces PROFINET     0 Number of HW-interfaces RS-232     0 Number of HW-interfaces RS-422     0 Number of HW-interfaces RS-485     0 Number of HW-interfaces serial TTY     0 Number of HW-interfaces USB     0 Number of HW-interfaces parallel     0 Number of HW-interfaces Wireless     0 Number of HW-interfaces other     1 With optical interface     No Supporting protocol for TCP/IP     Yes Supporting protocol for PROFIBUS     No Supporting protocol for CAN     No Supporting protocol for INTERBUS     No Supporting protocol for ASI     No Supporting protocol for KNX     No Supporting protocol for MODBUS     Yes 02/18/2020 Eaton Y7-197211 ED2020 V65.0 EN 6/8 Supporting protocol for Data-Highway     No Supporting protocol for DeviceNet     No Supporting protocol for SUCONET     No Supporting protocol for LON     No Supporting protocol for PROFINET IO     No Supporting protocol for PROFINET CBA     No Supporting protocol for SERCOS     No Supporting protocol for Foundation Fieldbus     No Supporting protocol for EtherNet/IP     No Supporting protocol for AS-Interface Safety at Work     No Supporting protocol for DeviceNet Safety     No Supporting protocol for INTERBUS-Safety     No Supporting protocol for PROFIsafe     No Supporting protocol for SafetyBUS p     No Supporting protocol for other bus systems     No Radio standard Bluetooth     No Radio standard WLAN 802.11     No Radio standard GPRS     No Radio standard GSM     No Radio standard UMTS     No IO link master     No Redundancy     No With display     Yes Degree of protection (IP)     IP20 Basic device     Yes Expandable     Yes Expansion device     No With timer     Yes Rail mounting possible     Yes Wall mounting/direct mounting     Yes Front build in possible     Yes Rack-assembly possible     No Suitable for safety functions     No Category according to EN 954-1     None SIL according to IEC 61508     None Performance level acc. EN ISO 13849-1     None Appendant operation agent (Ex ia)     No Appendant operation agent (Ex ib)     No Explosion safety category for gas     None Explosion safety category for dust     None Width   mm 71.5 Height   mm 90 Depth   mm 58 UL File No.     E205091 UL Category Control No.     NRAQ/7 North America Certification     UL listed Degree of Protection     IEC: IP20, UL/CSA Type: - Approvals 02/18/2020 Eaton Y7-197211 ED2020 V65.0 EN 7/8 Dimensions Assets (links) Declaration of CE Conformity 00003208 Instruction Leaflets IL050020ZU2019_02 Manuals MN050009_EN (English) Additional product information (links) assembly instructions easyE4 IL050020ZU assembly instructions easyE4 IL050020ZU ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL050020ZU2019_02.pdf easyE4 (MN050009) manual easyE4 – Handbuch (MN050009) - Deutsch ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_DE.pdf easyE4 (MN050009) manual - English ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_EN.pdf Manuale easy E4 (MN050009) - italiano ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_IT.pdf instrukcja easyE4 (MN050009) - polski ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_PL.pdf f1=1454&f2=1174&f3=1755;Download Software http://applications.eaton.eu/sdlc?LX=11& easySoft V7 Product overview (WEB) 02/18/2020 http://www.eaton.eu/easyE4 Eaton Industries GmbH http://www.eaton.eu © 02/2020 by Eaton Industries GmbH Eaton Y7-197211 ED2020 V65.0 EN 8/8
EASY-E4-UC-12RC1 价格&库存
很抱歉,暂时无法提供与“EASY-E4-UC-12RC1”相匹配的价格&库存,您可以联系我们找货
EASY-E4-UC-12RC1
  • 1+2365.554961+306.42210
  • 5+2196.580525+284.53400
库存:2
