HC8-R75-R
HC8-R75-R
    EATON(伊顿)
    非标准
    750 nH 无屏蔽 鼓芯,绕线式 电感器 18.8 A 3.4 毫欧最大 非标准
HC8-R75-R 数据手册
Technical Data 4120 Effective October 2015 Supersedes March 2007 HC8 High current power inductors Applications Product description • Surface mount inductors, 4.0mm height, designed for higher speed switch mode applications requiring low voltage and high current • Design utilizes high temperature powder iron material with a non-organic binder to eliminate thermal aging • Inductance Range from 0.175 uH to 47.3 uH • Current Range from 2.2 to 76 Amps • Frequency Range 1kHz to 500kHz • Multi-phase regulators • Voltage Regulator Modules (VRMs) • Distributed power systems DC-DC converters • Desktop and server VRMs and EVRDs • Point-of-Load (POL) modules • Field Programmable Gate Array (FPGA) DC-DC converters • Battery power systems • High current power supplies • Data networking and storage systems Environmental data • Storage temperature range (component): -40°C to +155°C • Operating temperature range: -40°C to +155°C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020D compliant Pb HC8 High current power inductors  Technical Data 4120 Effective October 2015 Product specifications Part number6 OCL1 (μH) ±20% lrms2 (amps) lsat3 (amps) 15% rolloff lsat4 (amps) 30% rolloff DCR (mΩ) maximum @ 20°C Volt-μsec5 (V-μs) HC8-R15-R 0.175 39.0 43 76 0.80 1.5 HC8-R39-R 0.390 28.3 26 45 1.55 2.5 HC8-R75-R 0.766 18.8 18.5 32.7 3.40 3.5 HC8-1R2-R 1.32 16.0 14.4 25.5 4.70 4.5 HC8-1R9-R 1.90 12.4 11.8 20.9 7.7 5.5 HC8-2R6-R 2.65 10.2 10.0 17.7 11.4 6.5 HC8-3R5-R 3.52 8.5 8.7 15.3 16.5 7.5 HC8-4R5-R 4.52 8.0 7.7 13.5 18.6 8.5 HC8-5R6-R 5.65 6.7 6.9 12.1 26.3 9.5 HC8-6R9-R 6.90 6.4 6.2 10.9 28.9 10.5 HC8-8R2-R 8.27 5.5 5.7 10.0 39.6 11.5 HC8-100-R 9.77 5.2 5.2 9.2 43.6 12.5 HC8-150-R 15.02 4.1 4.2 7.4 68.6 15.5 HC8-220-R 21.40 3.4 3.5 6.2 99.5 18.6 HC8-330-R 31.65 2.7 2.9 5.1 154 22.6 HC8-470-R 47.28 2.2 2.4 4.2 237 27.6 1. Open Circuit Inductance (OCL) Test Parameters: 100kHz, 1.0Vrms, 0.0Adc, @ +25°C 2. Irms: DC current for an approximately ΔT of 40°C without core loss. Derating is necessary for AC currents. Pad layout, trace thickness and width, airflow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed 155°C under worst case conditions verified in the end application. 3. Peak current for approximately 15% rolloff @+20°C 4. Peak current for approximately 30% rolloff @+20°C 5. Applied Volt-Time product (V-μs) across the inductor. This value represents the applied V-μs at operating frequency necessary to generate additional core loss which contributes to the 40°C temperature rise. De-rating of the Irms is required to prevent excessive temperature rise. The 100% V-μs rating is equivalent to a ripple current Ip-p of 20% of Isat (30% rolloff option). 6. Part number definition: HC8-XXX-R HC8 = Product code and size XXX = Inductance value in uH. R = Decimal point. If no R is present then last character equals number of zeros -R suffix indicates RoHS compliant Dimensions–mm FRONT VIEW TOP VIEW C 10.9 Max HC8-XXX wwll yy R FRONT VIEW TABLE L 10.4 Max 4.0 Max 3.95 2 plcs ref 10.4 Max A ref PN A mm R15 2.1 R39 2.1 R75 2.1 1R 2.1 1R9 thru 470 2.7 RECOMMENDED PAD LAYOUT SIDE VIEW 3.5 typ 2plcs 2.70 ± 0.55 (2x) SCHEMATIC 1 3.0 typ 2plcs 2 4.0 typ Part marking: HC8= (Product code and size)-xxx=(inductance value in uH, R= decimal point. If no R is present then last character equals number of zeros. wwlyly=date code, R=revision level Tolerances are ±0.2 millimeters unless stated otherwise All soldering surfaces to be coplanar within 0.1 millimeters Do not route traces or vias underneath the inductor Packaging information–mm Supplied in tape and reel packaging, 800 parts per reel 4.0 1.5 dia +0.1/-0.0 2.0 1.5 dia min A 11.5 Ao=10.4 mm Bo=11.2 mm Ko=4.3 mm Bo 11.2 24.0 +/-0.3 HC8-XXX wwlly y R Ko SECTION A-A Ao 16.0 A User direction of feed 2 www.eaton.com/elx 1.75 HC8 High current power inductors Technical Data 4120 Effective October 2015  Inductance characteristics OCL vs Isat 100 90 80 % of OCL 70 60 50 40 30 02 10 0 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 150 160 170 180 190 200 % of Isat Core loss Irms DERATING WITH CORE LOSS % Applied Volt-u Seconds 10 30 50 70 90 110 130 150 170 190 % of Irms specified from zero ripple application 84 86 88 90 92 94 96 100kHz 200kHz 300kHz 400kHz 500kHz 98 100 www.eaton.com/elx 3 HC8 High current power inductors  Technical Data 4120 Effective October 2015 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb Solder (Tc) Package Thickness Volume mm3
HC8-R75-R 价格&库存
很抱歉,暂时无法提供与“HC8-R75-R”相匹配的价格&库存,您可以联系我们找货
HC8-R75-R
  • 1+56.843161+6.79563
  • 10+44.1008810+5.27229
  • 25+39.8488925+4.76396
  • 50+36.8996450+4.41138
  • 100+34.15535100+4.08329
  • 250+30.82428250+3.68506
库存:2115
HC8-R75-R
  • 800+26.99802800+3.22763
库存:2115
