Technical Data 1024
Effective December 2015
Supersedes August 2013
BUSSMANN
SERIES
SC Class G, 600Vac/480Vac, 1⁄2-60A
size-rejecting fuses
Catalog numbers (amps)
SC-1⁄2
SC-6
SC-1
SC-7
SC-1-1⁄2
SC-8
SC-2
SC-10
SC-2-1⁄2
SC-12
SC-3
SC-15
SC-4
SC-20
SC-5
SC-25
SC-30
SC-35
SC-40
SC-45
SC-50
SC-60
Carton quantity:
Amp rating
1/2-20
25–60
Catalog symbol:
Dimensions - in (mm):
SC-(amp)
A
(Length)
Description:
Basic protection Class G size-rejecting, current
limiting fuses. 1/2 to 6A Fast-acting, 7 to 60A
time-delay. Time-delay – 12 seconds (minimum)
at 200% of rated current.
Amp rating
1/2-15
25 to 30
35 to 60
Specifications:
Ratings
Carton qty.
4
2
Volts
• 600Vac/170Vdc (½-20A)
480Vac/300Vdc (25-60A)
Amps 1/2-60A
IR
100kA Vac RMS Sym.
10kA Vdc
Agency information
0.41”
(10.41mm)
A
1.31 (33.3)
1.41 (35.8)
1.62 (41.1)
2.25 (57.1)
Features:
Meets basic protection requirements of
NEC®, Canadian Electrical Code (CEC), UL
and CSA.
Most economical overcurrent protection
solution compared to circuit breakers.
For use in various non-demanding, general
purpose applications.
Compact branch-circuit units with high
interrupting rating and current-limitation.
UL Listed, Std. 248-5, Class G,
Guide JDDZ, File E4273
CSA® Certified, C22.2 No. 248.5,
Class 1422-01, File 53787
With up to a 600V rating, they can be used in
120/208V, 120/240V, and 277/480V circuits.
CE
Size rejection by length helps prevent
overfusing.
RoHS compliant
Fuses 7 amps and above have a degree of
overload time-delay that permits them to
pass temporary overloads.
Technical Data 1024
SC Class G 600Vac/480Vac, 1⁄2-60A size-rejecting fuses
60A
1A
1-1/2A
2A
2-1/2A
3A
4A
5A
6A
8A
10A
12A
15A
20A
30A
300
1/2A
Time-current curves - average melt:
Amp rating
AMP RATING
100
Time in seconds
TIME IN SECONDS
10
1
0.1
0.01
0.7 1
10
100
Current in amps
CURRENT IN AMPS
2
Eaton.com/bussmannseries
1000
2000
Technical Data 1024
60
30
Amp rating
For additional information on the BG and G Series of Class G
fuse blocks, see data sheet No. 1006.
B
10,000
1000
A
100
100,000
3-Pole
BG30013_
BG30023_
BG30033_
G30060-2C_
10,000
2-Pole
BG30012_
BG30022_
BG30032_
G30060-2C_
1000
1-Pole
BG30011_
BG30021_
BG30031_
G30060-1C_
100
Fuse amps
1⁄2-15
35-60
Current-limitation curves:
Fo
Instantaneous peak-let-through current in amps
Recommended fuse blocks:
RMS symmetrical currents in amps
A - B = Asymmetrical Available peak (2.3 x Sym. RMS amps)
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2015 Eaton
All Rights Reserved
Printed in USA
Publication No. 1024 – BU-SB13733
December 2015
Eaton and Bussmann are valuable
trademarks of Eaton in the US and other
countries. You are not permitted to use the
Eaton trademarks without prior written
consent of Eaton.
CSA is a registered trademark of the
Canadian Standards Group.
NEC is a registered trademark of the
National Fire Protection Association, Inc.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Follow us on social media to get the
latest product and support information.
3
很抱歉,暂时无法提供与“BK/SC-15”相匹配的价格&库存,您可以联系我们找货
