C22-DL-R-K01-24-P1
C22-DL-R-K01-24-P1
    EATON(伊顿)
    EATON CUTLER HAMMER - C22-DL-R-K01-24-P1 - PB SW, ILLUM, SPST-NC, RED, CONNECTOR
C22-DL-R-K01-24-P1 数据手册
DATASHEET - C22-DL-R-K01-24-P1 Illuminated pushbutton actuator, classic, flat, tasted, 1 N/C, red, 24 V AC/ DC, cable (black) with m12a plug, 4 pole, 0.2 m Delivery program Part no.  Catalog No.      C22-DL-R-K01-24-P1 185555 Product range     RMQ compact solution Basic function     Illuminated pushbutton actuators Single unit/Complete unit     Complete unit Design     Flat       momentary Connection type     Cable (black) with M12A plug, 4 pole Cable Length   m 0.2 Colour       LED     LED     Red Button plate       button plate     red Button plate           Blank Rated operational voltage LED     24 V AC/DC Name     None Degree of Protection     IP66, IP67, IP69K (front) IP65 (on rear) Front ring     Bezel: titanium Connection to SmartWire-DT     no Contacts       N/C = Normally closed     Notes             mm   4.65 Maximum travel mm   5.7 Minimum force for positive opening N   15 Actuator travel and actuation force as per DIN EN 60947-5-1, K.5.4.1 03/19/2018 1 NC = safety function, by positive opening to IEC/EN 60947-5-1 Eaton 185555 ED2018 V42.0 EN 1/3 Contact sequence     Contact travel■ = Contact closed□ = Contact open             yes Standards     IEC/EN 60947-5-1 VDE 0660 Certifications     Lifespan, mechanical Operations Operating frequency Operations/h   ≦ 3600 Actuating force   n ≦5 Plug tightening torque   N/m 1 Tightening torque Threaded ring   Nm 2 Climatic proofing     Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60068-2-30 Degree of Protection     IP66, IP67, IP69K (front) IP65 (on rear) Mounting position     As required Mechanical shock resistance, shock duration 11 ms   g > 30 Rated impulse withstand voltage Uimp V AC 800 Rated insulation voltage Ui V 30 Overvoltage category/pollution degree     III/3 Control circuit reliability       HF   N/C contact: statistically determined 1 failure per 0.9 × 10 Operations       gG/gL A 4 Rated conditional short-circuit current Iq kA 1 Rated operational current Ie A         Ie A 4       Ie A 3       Design     M12A Cable Length   m 0.2 Material characteristic     PUR Diameter ⌀ mm 4.7         °C -25 Contact diagram Positive opening (ZW)   Technical data General Contacts At 17 V DC/7 mA Max. short-circuit protective device Fuse Switching capacity AC-15 24 V DC-13 24 V Cable characteristics Design verification as per IEC/EN 61439 Technical data for design verification Operating ambient temperature min. 03/19/2018 x 10 CE, UL, CSA 6 >5 6 Eaton 185555 ED2018 V42.0 EN 2/3 Operating ambient temperature max.   °C 70 Technical data ETIM 6.0 Low-voltage industrial components (EG000017) / Push button, complete (EC001028) Electric engineering, automation, process control engineering / Low-voltage switch technology / Command and alarm device / Push-button actuator, complete unit (ecl@ss8.1-27-37-12-28 [AKF046011]) Number of command positions     1 Colour button     Red Construction type lens     Round Hole diameter   mm 22 Width opening   mm 0 Height meter opening   mm 0 Degree of protection (IP)     Other Type of button     Flat Suitable for illumination     Yes Switching function latching     No Spring-return     Yes Supply voltage lamp   V 24 Number of contacts as normally open contact     0 Number of contacts as normally closed contact     1 Number of contacts as change-over contact     0 Type of electric connection     Other With front ring     Yes Material front ring     Plastic Colour front ring     Grey Dimensions Assets (Links) Declaration of Conformity 00002596 Additional product information (links) IL047016ZU RMQ compact solution IL047016ZU RMQ compact solution 03/19/2018 ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL047016ZU2017_01.pdf Eaton Industries GmbH http://www.eaton.eu © 03/2018 by Eaton Industries GmbH Eaton 185555 ED2018 V42.0 EN 3/3
C22-DL-R-K01-24-P1 价格&库存
很抱歉,暂时无法提供与“C22-DL-R-K01-24-P1”相匹配的价格&库存,您可以联系我们找货
