DR1050-561-R
DR1050-561-R
    EATON(伊顿)
    SMD,10.3x10.5mm
    560 µH 屏蔽 鼓芯,绕线式 电感器 620 mA 1.213 欧姆最大 非标准
DR1050-561-R 数据手册
Technical Data 4139 Effective April 2016 Supersedes March 2007 DR1050 Shielded power inductors Applications • LED/LCD backlighting • High definition televisions (HDTV) • Server and desktop power supplies • Graphics cards and battery powered systems • Point-of-load (POL) modules • Printers and peripherals • Portable electronics Environmental Data Description • Shielded drum core • Inductance range from 0.7 μH to 1000 μH • Current range from 0.43 A to 13.5 A • 10.5 mm x 10.3 mm footprint surface mount package in a 5.0 mm height • Ferrite core material • Halogen free, lead free, RoHS compliant • Storage temperature range (Component): -40 °C to +125 °C • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020D compliant HALOGEN Pb HF FREE DR1050 Shielded power inductors  Technical Data 4139 Effective April 2016 Product Specifications OCL1 (μH) ±30% Irms2 (A) Isat3 (A) DCR (mΩ) typical @ 20°C DCR (mΩ) maximum @ 20°C K-factor4 DR1050-R80-R 0.70 9.70 13.5 3.2 4.0 20.47 DR1050-1R5-R 1.37 8.60 10.5 4.0 5.0 14.62 DR1050-2R2-R 2.27 7.52 9.3 5.6 6.8 11.37 DR1050-3R3-R 3.21 6.50 8.2 8.0 10 9.30 DR1050-4R7-R 4.43 6.13 6.7 10 12 7.87 DR1050-6R8-R 6.30 5.45 5.8 13 17 6.82 DR1050-8R2-R 8.09 5.24 5.0 15 19 6.02 DR1050-100-R 10.1 4.80 4.6 18 23 5.39 DR1050-120-R 11.6 3.94 4.1 24 30 4.87 DR1050-150-R 14.8 3.80 3.7 26 33 4.45 DR1050-180-R 17.5 3.39 3.3 33 41 4.09 DR1050-220-R 23.5 3.12 3.0 39 48 3.53 DR1050-270-R 26.9 2.82 2.8 43 53 3.30 DR1050-330-R 34.3 2.56 2.5 58 72 2.92 DR1050-390-R 38.3 2.35 2.35 61 76 2.77 DR1050-470-R 47.1 2.06 2.10 89 111 2.50 DR1050-560-R 56.7 1.96 1.94 98 123 2.27 DR1050-680-R 67.2 1.84 1.70 111 139 2.09 DR1050-820-R 84.4 1.60 1.58 147 184 1.86 DR1050-101-R 97.5 1.52 1.45 164 205 1.73 DR1050-121-R 118 1.30 1.30 223 279 1.57 DR1050-151-R 149 1.26 1.15 238 298 1.40 DR1050-181-R 184 1.18 1.08 273 341 1.26 DR1050-221-R 222 1.00 0.98 377 472 1.15 DR1050-271-R 264 0.96 0.90 410 513 1.06 DR1050-331-R 321 0.83 0.80 554 693 0.96 DR1050-391-R 397 0.76 0.72 648 810 0.86 DR1050-471-R 481 0.64 0.62 855 1069 0.78 DR1050-561-R 573 0.62 0.60 970 1213 0.72 DR1050-681-R 708 0.56 0.55 1095 1369 0.64 DR1050-821-R 819 0.54 0.50 1185 1481 0.60 DR1050-102-R 1000 0.43 0.48 1528 1950 0.54 Part Number 5 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C 2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed 125 °C under worst case operating conditions verified in the end application. 3. Isat: Peak current for approximately 35% rolloff @ +25 °C 2 www.eaton.com/elx 4. K-factor: K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (mT), K: (K-factor from table), L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps). 5. Part Number Definition: DR1050-xxx-R DR1050 = Product code and size -xxx= inductance value in μH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant DR1050 Shielded power inductors Technical Data 4139 Effective April 2016  Dimensions (mm) Part marking: inductance value in uH. R = decimal point. If no R is present then last character equals number of zeroes. wwlly = date code, R = revision level Do not route traces or vias underneath the inductor Packaging information (mm) Supplied in tape and reel packaging , 500 parts per 13” diameter reel www.eaton.com/elx 3 DR1050 Shielded power inductors  Technical Data 4139 Effective April 2016 Temperature rise vs. total loss 160 Temperature Rise (°C) 140 120 100 80 60 40 20 0 0.0 0.2 0.4 0.6 0.8 1.0 1.2 Total Loss (W) Core loss vs. Bp-p 10 1MHz 500kHz 300kHz 200kHz 100kHz Core Loss (W) 1 0.1 0.01 0.001 1 10 100 Bp-p (mT) 4 www.eaton.com/elx 1000 DR1050 Shielded power inductors Technical Data 4139 Effective April 2016  Inductance characteristics % of OCL vs. % of Isat 120% 100% % of OCL 80% 60% -40 °C 40% +25 °C 20% 0% +85 °C 0% 20% 40% 60% 80% 100% 120% 140% % of Isat www.eaton.com/elx 5 DR1050 Shielded power inductors  Technical Data 4139 Effective April 2016 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb Solder (Tc) Package Thickness Volume mm3
DR1050-561-R 价格&库存
很抱歉,暂时无法提供与“DR1050-561-R”相匹配的价格&库存,您可以联系我们找货
DR1050-561-R
    DR1050-561-R
    • 2000+4.072112000+0.52658
