Technical Data 4141
Effective April 2014
Supersedes November 2011
Coiltronics DR124 Series
Low profile power inductors
Applications
Notebook power, LCD panels
Computer, DVD players, and portable power
devices
DC-DC Converters
Buck, boost, forward, and resonant converters
Noise filtering and filter chokes
Environmental data
Product description
Lead free, RoHS compliant
125°C maximum total temperature
operation
Low profile surface mount inductor
12.5mm x 12.5mm x 4.5mm shielded
drum core
Inductance range from 0.47μH to
1000μH
Current range from 24.4 to 0.44 Amps
Frequency range up to 1MHz
Ferrite core material
Storage temperature range (Component):
-40°C to +125°C
Operating temperature range: -40°C to +125°C
(ambient + self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
Packaging:
Supplied in tape and reel packaging, 750 per reel
Pb
The Coiltronics brand of
magnetics (formerly of
the Bussmann Division of
Cooper Industries)
is now part of
Eaton’s Electrical Group,
Electronics Division.
Coiltronics is now
part of Eaton
Same great
products plus
even more.
Technical Data 4141
DR124 Series
Product specifications
Part Number
Rated
Inductance
(μH)
OCL1
μH±20%
Irms2
Amps
Isat3
Amps
DCR
mΩ @20°C
Typ
DCR
mΩ @20°C
Max
K-factor4
DR124-R47-R
0.47
0.42
16.0
24.40
2.2
2.7
17.51
DR124-1R0-R
1.0
0.83
13.9
18.00
3.00
3.6
12.50
DR124-1R5-R
1.5
1.37
11.1
14.00
4.75
5.7
9.73
DR124-2R2-R
2.2
2.04
9.1
11.45
5.92
7.1
7.96
DR124-3R9-R
3.9
3.80
7.0
8.40
12.50
15.0
5.84
DR124-4R7-R
4.7
4.88
6.5
7.65
13.50
16.2
5.15
DR124-6R8-R
6.8
6.10
5.6
6.47
18.06
21.7
4.61
DR124-8R2-R
8.2
7.45
5.2
6.22
21.67
26.0
4.17
DR124-100-R
10
8.94
4.5
5.80
23.33
28.0
3.81
DR124-120-R
12
11.5
4.1
4.96
31.67
38.0
3.50
DR124-150-R
15
14.2
3.6
4.62
37.30
44.8
3.02
DR124-180-R
18
16.2
3.4
4.32
46.97
56.4
2.82
DR124-220-R
22
20.7
3.2
3.83
53.99
64.8
2.50
DR124-270-R
27
25.7
2.8
3.44
66.67
80.0
2.24
DR124-330-R
33
31.2
2.6
3.12
80.83
97.0
2.04
DR124-390-R
39
37.3
2.3
2.85
110.00
132.0
1.86
DR124-470-R
47
44.0
2.2
2.63
124.66
149.6
1.72
DR124-560-R
56
54.9
2.0
2.35
144.32
173.2
1.54
DR124-680-R
68
67.1
1.8
2.13
183.33
220.0
1.39
DR124-820-R
82
80.5
1.7
1.94
212.72
255.3
1.27
DR124-101-R
100
95.1
1.5
1.79
256.67
308.0
1.17
DR124-121-R
120
111
1.3
1.65
311.18
373.4
1.08
DR124-151-R
150
146
1.3
1.44
371.02
445.2
0.94
DR124-181-R
180
179
1.1
1.30
501.66
602.0
0.87
DR124-221-R
220
216
1.0
1.15
558.00
669.6
0.77
DR124-271-R
270
256
0.88
1.09
725.00
870.0
0.71
DR124-331-R
330
327
0.83
0.92
825.00
990.0
0.63
DR124-471-R
470
460
0.68
0.74
1242.50
1491.0
0.53
DR124-681-R
680
669
0.56
0.65
1845.83
2215.0
0.45
DR124-821-R
820
825
0.53
0.62
2109.17
2351.0
0.40
DR124-102-R
1000
998
0.44
0.53
2898.00
3477.00
0.37
1. Open Circuit Inductance Test Parameters: 100kHz, 0.25V, 0.0Adc.
2. Irms: DC current for an approximate ∆T of 40°C without core loss. Derating is
necessary for AC currents. PCB layout, trace thickness and width, air-flow,
and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not
exceed 125°C under worst case operating conditions verified in the end
application.
3. Isat Amps peak for approximately 25% rolloff (@25°C).
2
www.eaton.com/elx
4. K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K*L*∆I, Bp-p (mT), K: (K factor from table), L: (Inductance in μH),
∆I (Peak to peak ripple current in Amps).
5. Part Number Definition: DR124-xxx-R
- DR124 = Product code and size; -xxx = Inductance value in uH;
- R = decimal point; If no R is present, third character = # of zeros.
- “-R” suffix = RoHS compliant
DR124 Series
Technical Data 4141
Dimensions - mm
FRONT VIEW
BOTTOM VIEW
TOP VIEW
SCHEMATIC
RECOMMENDED PCB LAYOUT
2.05
Typ.
13.8
5.00 1
Typ
2
4.5
Max
12.50
Max
1
1
12.50
Max
DR124-###
wwllyy R
2
5.50
2
10
3.85
Dimensions are in millimeters.
wwlly = Date code, R = Revision level.
Packaging information - mm
1.5 dia
+0.1/-0.0
1.5 dia
min
A
1.75
4.0
12.6
Bo
B1
Ko
11
DR124-###
wwllyy R
Ao=13.2 mm
Bo=13.2 mm
A1=10mm
B1=10 mm
Ko=5.2 mm
A1
Ao
SECTION A-A
16.0
24.0
A
User direction of feed
Parts packaged on 13" Diameter reel, 750 parts per reel.
Core loss
100
500kHz
1MHz
10
100kHz
1
Core Loss (W)
300kHz
200kHz
0.1
0.01
0.001
0.0001
1
10
100
1000
Bp-p (m T)
www.eaton.com/elx
3
Technical Data 4141
DR124 Series
Temperature rise vs. loss
120
Temperature Rise (°C)
100
80
60
40
0.8
1.2
1.6
2
Total Pow er Loss (W)
Inductance characteristics
OCL vs. Isat
120.0
100.0
+85°C
% OCL
80.0
+25°C
60.0
40.0
-40°C
20.0
0.0
0.0
20.0
40.0
60.0
% Isat
4
www.eaton.com/elx
80.0
100.0
120.0
DR124 Series
Technical Data 4141
Solder reflow profile
TP
TC -5°C
Temperature
25°C
Preheat
A
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
Package
Thickness
2.5mm
ts
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020D
Profile Feature
Preheat and Soak
Standard SnPb Solder
100°C
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
North America
1225 Broken Sound Parkway NW
Suite F
Boca Raton, FL 33487-3533
Tel: 1-561-998-4100
Fax: 1-561-241-6640
Toll Free: 1-888-414-2645
P.O. Box 14460
St. Louis, MO 63178-4460
Tel: 1-636-394-2877
Fax: 1-636-527-1607
Europe
Burton-on-the-Wolds
Leicestershire, LE 12 5th UK
Phone: +44 (0) 1509 882 600
Fax: +44 (0) 1509 882 786
Avda Santa Eulalia, 290
Terrassa, Barcelona 08223 Spain
Phone: +34-93-736-2813
Fax: +34-93-783-5055
Asia Pacific
No.2, #06-01
Serangoon North Avenue 5
Singapore 554911
Tel: +65 6645 9888
Fax: +65 6728 3155
The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is
intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change
design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained
in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
Life Support Policy: Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support
systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result
in significant injury to the user.
114 Old State Road
Ellisville, MO 63021
United States
www.eaton.com/elx
© 2014 Eaton
All Rights Reserved
Publication No. 4141 — BU-SB14114
April 2014
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
www.eaton.com/elx
5
很抱歉,暂时无法提供与“DR124-100-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 750+3.84642750+0.48041
- 1500+3.828451500+0.47817
- 2250+3.828362250+0.47816
- 3000+3.828283000+0.47815
- 3750+3.828203750+0.47814
