ECMS1V1306-701-R
ECMS1V1306-701-R
    EATON(伊顿)
    水平式,4 PC 板
    2 线路共模扼流圈 表面贴装型 700 Ohms @ 100 MHz 8A DCR 6 毫欧
ECMS1V1306-701-R 数据手册
Technical Data ELX1114 Effective December 2021 ECMS1V1306 Common mode choke, surface mount Applications Product features • High frequency filter • Square type closed magnetic core • Current rating up to 10 A • 13 mm x 11.3 mm surface mount package in a 6.4 mm height • Moisture sensitivity level (MSL): 1 • Battery backup • Renewable energy products • High tech consumer products • Appliances • LED lighting • Smart meters • Industrial IoT equipment • Motion controls • Power supplies • Medical equipment Environmental compliance and general specifications • Storage temperature (component): -40 °C to +125 °C • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE ECMS1V1306 Common mode choke, surface mount  Technical Data ELX1114 Effective December 2021 Product specifications Impedance1 (Ω) mimimum Impedance1 (Ω ) typical DCR2 (mΩ) @ +25 °C maximum Rated current3 (A) maximum Rated voltage (Vdc) maximum Insulation resistance4 @ (MΩ) minimum ECMS1V1306-231-R 80 230 2.0 10 80 10 ECMS1V1306-701-R 500 700 6.0 8.0 80 10 ECMS1V1306-801-R 600 800 8.0 8.0 80 10 ECMS1V1306-102-R 750 1000 14 6.0 80 10 Part number 5 1. Impedance test parameters: 100 MHz, 0.1 Vrms, parallel connection (1,2 - 4,3), +25 °C 2. DCR test parameters: parallel connection (1,2 - 4,3), 4-wire method measured at +25°C 3. Rated current: DC current for an approximate temperature rise of 40 °C without core loss. It is recommended that the temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application. 4. Insulation resistance: Coil to coil 5. Part Number Definition: ECMS1Vxxxx-yyy-R ECMS1V = Product code xxxx= Size indicator yyy= Typical impedance value in ohms. R= decimal point, if no R is present then last digit indicates the number of zeros -R suffix = RoHS compliant Mechanical parameters, schematic, pad layout (mm) Recommended PCB Layout Schematic Dimension Value A 12.0 ±0.5 A1 12.5 ±0.5 B 10.8 ±0.5 C 6.4 maximum D 2.7 typical E 2.5 typical F 7.0 typical Part marking: xxx= Typical impedance value in ohms All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.5 millimeters unless stated otherwise Traces or vias underneath the inductor is not recommended 2 www.eaton.com/electronics ECMS1V1306 Common mode choke, surface mount Technical Data ELX1114 Effective December 2021  Packaging information (mm) Supplied in tape and reel packaging, 13” diameter reel (EIA-481 compliant) 500 parts per reel Dimension Value W 24.0 ±0.3 F 11.5 ±0.1 E1 1.75 ±0.1 E2 na P0 4.0 ±0.1 P1 16 ±0.1 P2 2.0 ±0.1 D0 1.5 +0.1/-0 D1 1.5 +0.1/-0 A0 12.5 ±0.1 B0 11.5 ±0.1 K0 6.6 ±0.1 T 0.4 ±0.05 www.eaton.com/electronics 3 Technical Data ELX1114 Effective December 2021 Impedance vs frequency 4 www.eaton.com/electronics ECMS1V1306 Common mode choke, surface mount  Technical Data ELX1114 ECMS1V1306 Common mode choke, surface mount Effective December 2021  Solder reflow profile Table 1 - Standard SnPb solder (Tc) Package Thickness Volume mm3
ECMS1V1306-701-R 价格&库存
很抱歉,暂时无法提供与“ECMS1V1306-701-R”相匹配的价格&库存,您可以联系我们找货
ECMS1V1306-701-R
    • 1+1.66007
    • 200+0.64250
    • 500+0.61982
    • 1000+0.60869
