ETR4-51-A
ETR4-51-A
    EATON(伊顿)
ETR4-51-A 数据手册
ETR timing relay The power of fusion. 1874 1886 1893 1899 1906 1908 1911 1934 1962 1963 1967 1976 1977 1983 1984 1989 1999 There’s a certain energy at Eaton. It’s the power of uniting some of the world’s most respected names to build a brand you can trust to meet every power management need. The energy created supports our commitment to powering business worldwide. Eaton is dedicated to ensuring that reliable, efficient and safe power is available when it’s needed most. With unparalleled knowledge of electrical power management across industries, experts at Eaton deliver customized, integrated solutions to solve our customers’ most critical challenges. Eaton.com/Electrical. All of the above are trademarks of Eaton Corporation or its affiliates. Eaton has a license to use the Westinghouse brand name in Asia Pacific. ©2012 Eaton Corporation. Contents DILET, ETR timing relay Ordering DILET timing relays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 ETR4 timing relays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 ETR2 timing relays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Engineering DILET, ETR timing relay Contact sequence diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Load limit curves . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Technical data 80 45 43.4 17.5 5 DILET, ETR4 timing relays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 ETR2 timing relays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 58 Dimensions DILET, ETR timing relays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Electronic relays Timing relays Timing relays DILET Rated operational current AC-11 230 V 400 V Conventional thermal current I th Ie Ie A A A A A On-delayed Timing functions Page 8 Component lifespan Page 10 3 Time Range Voltage range Part no. Article No. 24 - 240 V AC, 50/60 Hz 24 - 240 V DC 400 V AC, 50/60 Hz DILET11-30-A 048878 DILET11-30-W 048904 DILET11-M-A 048886 DILET11-M-W 048891 1 off DILET70-A 048893 DILET70-W 048899 1 off 3 6 1.5 - 30 s 3 3 6 1.5 - 30 s 3 3 6 3 3 6 0.05 - 1 s 0.15 - 3 s 0.5 - 10 s 3 - 60 s 0.15 - 3 min 0.5 - 10 min 3 - 60 min 0.15 - 3 h 0.5 - 10 h 3 - 60 h 24 - 240 V AC, 50/60 Hz 24 - 240 V DC 400 V A C , 50/60 H z 0.05 - 1s 0.15 - 3 s 0.2217925 - 10 s 3 - 60 s 0.15 - 3 min 0.5 - 10 min 3 - 60 min 0.15 - 3 h 0.5 - 10 h 3 - 60 h 24 - 240 V AC, 50/60 Hz 24 - 240 V DC 400 V A C , 50/60 H z Price See price list Std. pack 1 off 1 off 1 off Multi-functional with remote potentiometer Timing functions Page 8 Component lifespan Page 10 3 3 6 3 3 6 1 off DILET Resistance Rated power R P kΩ W 10 ≦0.5 10 – – – For use with Part no. Article no. Price See price list Std. pack DILET… ETR4-70 DILET… ETR4-70 M22-R10K 229491 M22S-R10K 232233 1 off EWDIL ETS4-VS3 ETR4 CS-TE 095853 10 off Remote potentiometer, IP66 1 off Screw adapters For screw fixing 2 Electronic relays Timing relays Notes Information relevant for export to North America Fixed 11, On-delayed A2 Product Standards 15 A1 16 UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection 18 15 A1 16 A2 Adjustable 11, On-delayed 21, Fleeting contact on energization 42, Flashing 81, Pulse generating ON-OFF Z2 Cable connection with Y1/Y2, Z1/Z2 Permissible cable length (cable unshielded, with cable cross-section 0.5-1.5 mm 2): Two-core cable Two-core cable in the same cable duct with mains cable, 50/60 Hz Z1 UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection 15 A1 A2 Adjustable 12, Off-delayed 16, On- and off-delayed 22, Fleeting contact on de-energization 82, Pulse shaping ON-OFF 18 Product Standards Z1 16 18 IEC/EN 61812-1; IEC/EN 60947-5-1; UL 508; CSA-22.2 No. 14-05; CE marking E29184 NKCR, NKCR7 12528 3211-03 UL Listed, CSA certified IEC: IP20, UL/CSA Type: - IEC/EN 61812-1; IEC/EN 60947-5-1; UL 508; CSA-22.2 No. 14-05; CE marking E29184 NKCR, NKCR7 12528 3211-03 UL Listed, CSA certified IEC: IP20, UL/CSA Type: - Z2 Y1 A1 Y2 A2 11 ON-DELAYED 21 FLEETING CONTACT ON ENERGIZATION 42 FLASHING 81 PULSE GENERATING CONTACT 15 16 18 Z1 Z2 15 A1 A2 16 18 250 m 50 m Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection IEC/EN 60947-5; UL 508; CSA-C22.2 No. 14-05; CSA-C22.2 No.94-91; CEmarking E29184 NKCR 12528 3211-03 UL Listed, CSA certified UL/CSA part no. 3R, 4X, 12, 13 UL/CSA certification not required 3 Electronic relays Timing relays Electronic timing relays ETR4, 22.5 mm wide Rated operational current AC-15 230 V 400 V Conventional thermal current I th Ie Ie A A A Star-delta switching Timing functions Page 8 3 3 6 3 - 60 s On-delayed Timing functions Page 8 3 3 6 Multifunctional Timing functions Page 8 3 3 6 0.05 - 1 s 0.15 - 3 s 0.5 - 10 s 1.5 - 30 s 5 - 100 s 15 - 300 s 1.5 - 30 min 15 - 300 min 1.5 - 30 h 5 - 100 h Multifunctional with connection for potentiometer, and two changeover contacts that can be converted to two timed contacts or one non-delayed contact and one timed contact. Timing functions Page 8 3 – 6 Notes 400 V AC, 50/60 Hz Std. pack Part no. Article no. ETR4-51-A 031884 1 off ETR4-51-W 031885 1 off ETR4-11-A 031882 1 off ETR4-11-W 031883 1 off ETR4-69-A 031891 1 off ETR4-69-W 031887 1 off ETR4-70-A 031888 1 off Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection 4 Time Range 24 - 240 V AC, 50/60 Hz 24 - 240 V DC Part no. Price Article no. See price list IEC/EN 61812-1; IEC/EN 60947-5-1; UL 508; CSA-22.2 No. 14-05; CE marking E29184 NKCR 12528 3211-03 UL Listed, CSA certified IEC: IP20, UL/CSA Type: - Price See price list Std. pack 1 off Electronic relays Timing relays Notes Function Terminal marking according to EN 50042 Fixed 51, Star-delta Cable connection with B1, Z1/Z2 Permissible cable length (cable unshielded, with cable cross-section 0.5--1.5 mm 2): Two-core cable Two-core cable in the same cable duct with mains cable, 50/60 Hz 17 A1 18 A2 Function 28 Terminal marking according to EN 50042 Fixed 11, On-delayed 15 A1 16 A2 Function 18 Terminal marking according to EN 50042 Adjustable 11, On-delayed 21, Fleeting contact on energization 42, Flashing, pulse initiating 81, Pulse generating ON-OFF Function Function 16 A2 18 Terminal marking according to EN 50042 A2/X1 linked 11, On-delayed 21, Fleeting contact on energization 42, Flashing, pulse initiating 81, Pulse generating ON-OFF A2/X1 not linked 11, On-delayed 21, Fleeting contact on energization 42, Flashing, pulse initiating 81, Pulse generating ON-OFF Z1 Z2 15 A1 X1 Z1 X1 E T R 4- 11 A2 16 Z2 A1 A2 25 18 26 16 28 21 15 18 22 Terminal marking according to EN 50042 Adjustable 12, Off-delayed 16, On- and off-delayed 22, Fleeting contact on de-energization 82, Pulse shaping ON-OFF Function 15 A1 24 B1 A1 15 15 16 A2 18 Terminal marking according to EN 50042 A2/X1 linked 12, Off-delayed 16, On- and off-delayed 22, Fleeting contact on de-energization 82, Pulse shaping ON-OFF A2/X1 not linked 12, Off-delayed 16, On- and Off-delayed 22, Fleeting contact on de-energization 82, Pulse shaping ON-OFF Z1 Z2 B1 A1 X1 A2 Z1 B1 X1 E T R 4- 69 A1 15 25 16 18 26 16 A2 21 15 16 18 22 A2 15 Z1 16 Z1 Z2 15 Z2 21 15 A1 25 18 X1 ON-DELAYED 24 E T R 4- 70 A1 18 28 Z2 A1 A1 A2 250 m 50 m 11 ON-DELAYED 21 FLEETING CONTACT ON ENERGIZATION 42 FLASHING 81 PULSE GENERATING CONTACT A2 16 18 26 28 X1 A2 16 18 22 24 11 ON-DELAYED 21 FLEETING CONTACT ON ENERGIZATION 42 FLASHING 81 PULSE GENERATING CONTACT ETR4-51 A1 A2 ON-DELAYED 17 18 28 B1 A1 A2 15 16 Z1 Z1 Z2 Y1 A1 Y2 A2 15 B1 18 X1 Z1 Z2 A1 15 25 B1 28 X1 Z2 21 A1 15 18 16 12 OFF-DELAYED 16 ON- and OFF-DELAYED 22 FLEETING CONTACT ON DE-ENERGIZATION 82 PULSE SHAPING CONTACT A2 16 18 26 A2 16 18 22 24 12 OFF-DELAYED 16 ON- and OFF-DELAYED 22 FLEETING CONTACT ON DE-ENERGIZATION 82 PULSE SHAPING CONTACT 5 Electronic relays Timing relays Electronic timing relays ETR2, 17.5 mm wide Rated operation current N/O 230 V Conventional thermal current Ie Ie I th A A A – 6 One changeover contact On-delayed 3 Timing functions Page 8 Load limit curves Page 10 Time Range Voltage range Part no. Article no. Price See price list Std. pack 0.05 - 1 s 0.5 - 10 s 5 - 100 s 0.5 - 10 min 5 - 100 min 0.5 - 10 h 5 - 100 h 24 - 240 V AC, 50/60 Hz 24 - 48 V DC ETR2-11 262684 1 off Off-delayed Timing functions Page 8 Load limit curves Page 10 3 – 6 ETR2-12 262686 1 off Fleeting contact on energization Timing functions Page 8 Load limit curves Page 10 3 – 6 ETR2-21 262687 1 off Flashing, pulse initiating Timing functions Page 8 Load limit curves Page 10 3 – 6 ETR2-42 262688 1 off Flashing, 2 speeds (ON/OFF times variable) Timing functions Page 8 Load limit curves Page 10 3 – 6 ETR2-44 262730 1 off Multifunction relay Timing functions Page 8 Load limit curves Page 10 3 – 6 ETR2-69 262689 1 off – 6 ETR2-11-D 119426 1 off ETR2-12-D 119427 1 off ETR2-69-D 119428 1 off Two changeover contacts 3 On-delayed Timing functions Page 8 Load limit curves Page 10 6 230 V (N/C) Off-delayed Timing functions Page 8 Load limit curves Page 10 3 – 6 Multifunctional Timing functions Page 8 Load limit curves Page 10 3 0.75 6 0.05 - 1 s 0.5 - 10 s 5 - 100 s 0.5 - 10 min 5 - 100 min 0.5 - 10 h 5 - 100 h 24 - 240 V AC, 50/60 Hz 24 - 48 V DC 12 - 240 V A C , 50/60 Hz Electronic relays Timing relays Information relevant for export to North America F u n c tio n Fixed 11, On-delayed T e r m in a l m a r k in g a c c o r d in g to E N 50042 16 A2 T e r m in a l m a r k in g a c c o r d in g to E N 50042 F u n c tio n Fixed 21, Fleeting contact on energization T e r m in a l m a r k in g a c c o r d in g to E N 50042 B1 A1 15 16 A2 16 18 15 A1 16 18 T e r m in a l m a r k in g a c c o r d in g to E N 50042 B1 A1 15 16 A2 Adjustable 11, On-delayed 21, Fleeting contact on energization 42, Flashing, pulse initiating 43, Flashing, pause initiating 18 T e r m in a l m a r k in g a c c o r d in g to E N 50042 A2 F u n c tio n Degree of Protection 18 T e r m in a l m a r k in g according to EN 50042 Function Adjustable 12, Off-delayed 22, Fleeting contact on de-energization 82, Pulse shaping 15 A1 16 A2 18 F u n c tio n Fixed 11, On-delayed T e r m in a l m a r k in g a c c o r d in g to E N 50042 F u n c tio n Fixed 12, Off-delayed T e r m in a l m a r k in g a c c o r d in g to E N 50042 F u n c tio n T e r m in a l m a r k in g according to EN 50042 A1 16 A1 A2 26 18 B1 A1 A2 B1 A1 A2 15 16 18 Product Standards 16 18 25 26 18 Degree of Protection Function 26 IEC/EN 61812-1; IEC/EN 60947-5-1; UL 508; CSA-22.2 No. 14-05; CE marking E29184 NKCR,NKCR7 UL report valid 3211-03 UL Listed, Certified by UL for use in Canada IEC: IP20, UL/CSA Type: - 28 25 15 UL File No. UL CCN CSA File No. CSA Class No. NA Certification 28 15 16 Terminal marking according to EN 50042 25 15 A2 Adjustable 11, On-delayed 21, Fleeting contact on energization 42, Flashing, pulse initiating 43, Flashing, pause initiating IEC/EN 61812-1; IEC/EN 60947-5-1; UL 508; CSA-22.2 No. 14-05; CE marking E29184 NKCR,NKCR7 UL report valid 3211-03 UL Listed, Certified by UL for use in Canada IEC: IP20, UL/CSA Type: - 15 A1 A2 F u n c tio n Fixed 44, Flashing, 2 variable times Can be set to either pulse or pause initiating UL File No. UL CCN CSA File No. CSA Class No. NA Certification 18 F u n c tio n Fixed 12, Off-delayed F u n c tio n Fixed 42, Flashing, pulse initiating Product Standards 15 A1 28 Adjustable 12, Off-delayed 22, Fleeting contact on de-energization 82, Pulse shaping Terminal marking according to EN 50042 B1 A1 A2 15 16 18 25 26 28 7 Electronic relays Timing relays Engineering DILET, ETR Electronic timing relays Contact sequence diagram DILET 11 On-delayed 12 Off-delayed 16 On- and Off-delayed A1-A2 A1-A2 A1-A2 15-18 Y1-Y2 t Y1-Y2 15-18 t LED 15-18 t t LED 82 P u ls e s h a p in g LED O n - O ff fu n c tio n A1-A2 A1-A2 15-18 Y1-Y2 15-18 OFF ON OFF t LED LED ETR2..., ETR4... 11 On-delayed 12 Off-delayed 16 On- and Off-delayed A1-A2 A1-A2 A1-A2 B1 15-18 B1 t t 15-18 t t 15-18 Power LED Power LED Power LED Rel LED Rel LED Rel LED 44 Flashing, 2 speeds 81 Pulse generating 82 Pulse shaping A1-A2 A1-A2 A1-A2 A1-B1 15-18 t1 t2 t1 t2 t1 15-18 t t2 B1 0.5 s 15-18 Power LED t Power LED Rel LED A1-B1 Rel LED Rel LED 15-18 t1 t2 t1 t2 t1 t2 Rel LED ETR4-70... A2/X1 linked 11 On-delayed 12 Off-delayed 16 On- and Off-delayed A1-A2 15-18 (25-28) t A1-A2 A1-A2 B1 B1 t Power LED 15-18 (25-28) t t Power LED Power LED Rel 1,2 LED Rel 1,2 LED Rel 1,2 LED 82 P u ls e s h a p in g 15-18 (25-28) O n - O ff fu n c tio n A1-A2 A1-A2 B1 15-18 (25-28) 15-18 (25-28) t Power LED OFF ON OFF Power LED Rel 1,2 LED ETR4-70... A2/X1 not linked 11 On-delayed Rel 1,2 LED 12 Off-delayed 16 On- and Off-delayed A1-A2 15-18 t A1-A2 A1-A2 B1 B1 15-18 15-18 t t t 21-24 21-24 Power LED 21-24 Power LED Power LED Rel 1 LED Rel 1 LED Rel 2 LED Rel 2 LED Rel 1 LED Rel 2 LED 82 P u ls e s h a p in g O n - O ff fu n c tio n A1-A2 A1-A2 B1 15-18 (25-28) 15-18 t OFF OFF Power LED Power LED Rel 1,2 LED Rel 1 LED Rel 2 LED 8 ON 21-24 Electronic relays Timing relays 21 Fleeting contact on energization 22 Fleeting contact on de-energization A1-A2 A1-A2 15-18 Y1-Y2 t 15-18 42 Flashing, pulse initiating 81 Pulse generating A1-A2 A1-A2 15-18 t t t 15-18 0.5 s t t t LED LED LED LED Legend to contact sequence diagrams LED display Time not running, Contact 15 – 18 closed Time running, Contact 15 – 18 closed 21 Fleeting contact on energization 22 Fleeting contact on de-energization Time running, Contact 15 – 18 not closed 42 Flashing, pulse initiating 43 Flashing, pause initiating A1-A2 A1-A2 A1-A2 A1-A2 B1 15-18 t t 15-18 Power LED Power LED 15-18 15-18 t t t t t t t t t LED LED Rel LED Rel LED 51 S ta r - d e lta O n - O ff fu n c tio n A1-A2 17-18 17-28 t A1-A2 15-18 OFF ON OFF tu L e g e n d to c o n ta c t s e q u e n c e d ia g r a m s LED display Time not running, Contact 15 – 18 closed Power LED Power LED Time running, Contact 15 – 18 closed Rel LED LED LED 21 Fleeting contact on energization t 22 Fleeting contact on de-energization Time running, Contact 15 – 18 not closed 81 Pulse generating 42 Flashing A1-A2 A1-A2 A1-A2 A1-A2 15-18 (25-28) B1 15-18 (25-28) 15-18 (25-28) Power LED t 15-18 (25-28) t t t t 0,5 s t Power LED Power LED Power LED Rel 1,2 LED Rel 1,2 LED Rel 1,2 LED Rel 1,2 LED 21 Fleeting contact on energization 22 Fleeting contact on de-energization A1-A2 A1-A2 15-18 B1 15-18 t 21-24 Power LED Rel 1 LED Rel 2 LED 42 Flashing 81 Pulse generating A1-A2 A1-A2 15-18 15-18 t t t t t 0.5 s t 21-24 21-24 Power LED Rel 1 LED Power LED Rel 2 LED 21-24 Power LED Rel 1 LED Rel 2 LED Rel 1 LED Rel 2 LED Legend to contact sequence diagrams LED display Time not running, Contact 15 – 18 closed Time running, Contact 15 – 18 closed Time running, Contact 15 – 18 not closed 9 Electronic relays Timing relays Load limit curves, ETR2-11/12/21/42/44/69 AC load (resistive) DC load (resistive) U [V] U [V] 300 300 200 200 100 80 60 50 40 30 100 80 60 20 20 10 40 30 0.1 0.2 0.5 1 2 4 6 10 10 0.1 0.2 0.5 1 2 4 6 I [A] 10 I [A] Derating factor with inductive AC load Contact life F S 1.0 0.9 10 6 8 6 0.8 4 0.7 3 0.6 2 Derating factor F with inductive load 0.5 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 10 5 1 1.0 2 3 4 5 6 7 Contact life Operations S 220 V 50 Hz AC-1 360 operations/h 8 cos φ I [A] Load limit curves, ETR2...-D AC load (resistive) DC load (resistive) 400 300 U [V] U [V] 400 300 200 200 100 80 60 100 80 60 40 30 40 30 20 20 10 0.1 0.2 0.5 1 2 4 6 10 10 0.1 0.2 0.5 1 2 4 6 I [A] Derating factor with inductive AC load F 10 I [A] Contact life 1.0 10 7 S 0.9 0.8 10 6 0.7 Contact life Operations S 220 V 50 Hz AC-1 360 operations/h 0.6 Derating factor F with inductive load 0.5 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 10 5 1.0 cos φ 10 4 0 1 2 3 4 5 6 7 I [A] DILET (AC-11) Component lifespan (operations) Ie= Rated operational current x 10 6 20 10 5 2 1 0.5 AC-11 0.2 240 V 0.1 0.01 0.02 0.05 0.1 0.2 0.5 1 2 5 10 A Ie 10 8 Electronic relays Timing relays DILET, ETR4 unit DILET-A DILET-W ETR4-A ETR4-W IEC/EN 61812 VDE 0435 IEC/EN 61812 VDE 0435 IEC/EN 61812 VDE 0435 IEC/EN 61812 VDE 0435 x 10 6 30 30 30 30 x 10 6 30 30 30 30 General Standards Lifespan, mechanical AC operated DC operated Switch operations Switch operations Climatic proofing Ambient temperature S to r a g e Open E n c a p s u la te d Mounting position Mechanical shock resi stance (IEC/EN 60068-2-27) Half-sinusoidal shock 20 ms N /O Degree of protection Clamps W e ig h t Terminal capacity S o lid F le x ib le w ith fe r r u le Damp heat, constant, to IEC 60068-2-78; Damp heat, cyclic, to IEC 60068-2-30 °C °C °C -20 - 60 -20 - 45 Any -20 - 60 -20 - 45 Any -45 - 60 -25 - 60 -25 - 45 Any -45 - 60 -25 - 60 -25 - 45 Any g 4 4 4 4 kg IP20 0.09 IP20 0.09 IP20 0.1 IP20 0.1 1 x (0.75 - 2.5) 2 x (0.75 - 2.5) 1 x (0.75 - 1.5) 2 x (0.75 - 1.5) 1 x (18 - 14) 1 x (0.75 - 2.5) 2 x (0.75 - 2.5) 1 x (0.75 - 1.5) 2 x (0.75 - 1.5) 1 x (18 - 14) 1 x (0.75 - 2.5) 2 x (0.75 - 1.5) 1 x (0.75 - 2.5) 2 x (0.75 - 1.5) 1 x (20 - 14) 1 x (0.75 - 2.5) 2 x (0.75 - 1.5) 1 x (0.75 - 2.5) 2 x (0.75 - 1.5) 1 x (20 - 14) 6000 III/2 600 440 6000 III/2 600 440 6000 III/2 600 440 250 250 250 250 250 250 48 50 1.1 48 50 1.1 48 50 1.1 3 3 1.1 3 3 1.1 3 3 1.1 3 3 3 3 3 3 1.5 1.2 6 1.5 1.2 6 1.5 1.2 6 250 6 250 6 250 6 B300 B300 B300 6 6 – 6 6 FAZ-B4/1-HI 6 6 FAZ-B4/1-HI mm2 mm2 S o lid o r s tr a n d e d AWG Contacts Rated impulse withstand voltage U imp V AC 6000 Overvoltage category/pollution degree III/2 V AC 600 Rated insulation voltage Ui V AC 440 Rated operating voltage Ue Safe isolation according to EN 61140 Between coil and auxiliary contacts V AC 250 Between the auxiliary contacts V AC 250 Making capacity AC-14 p.f. φ = 0.3 440 V A 48 AC-15 p.f. φ = 0.3 220 V A 50 1.1 DC-11 L/R≦ 40 m s x Ie Breaking capacity AC-14 p.f. φ = 0.3 440 V A 3 AC-15 p.f. φ = 0.3 220 V A 3 DC-11 L/R≦ 40 m s x Ie 1.1 Rated operation current AC-14 440 V Ie A 3 AC-15 A 3 220 V (230 V) Ie DC-11 1) L/R max. 15 ms 24 V Ie A 1.5 L /R m a x . 50 m s A 1.2 A 6 Conventional thermal current I th General use A C o p e r a te d V 250 A C o p e r a te d A 6 Pilot duty AC operated B300 Short-circuit rating without welding 2) Max. fuse, N/O (normally open) A gG/gL 6 Max. fuse, N/C (normally closed) A gG/gL 6 Max. overcurrent protective device, 220/230 V Part no. – 1) Making and breaking conditions to DC13, time constant as stated Notes 2) When supplied directly from mains or transformer > 1000 VA 11 Electronic relays Timing relays DILET, ETR4 unit DILET-A DILET-W ETR4-A ETR4-W 24 - 240 400 24 - 240 400 P ic k - u p Hz x Uc 24 - 240 47 - 63 0.85 - 1.1 – 47 - 63 0.85 - 1.1 24 - 240 47 - 63 0.85 - 1.1 – 47 - 63 0.85 - 1.1 P ic k - u p x Uc 0.7 - 1.1 – 0.7 - 1.1 – A C p ic k - u p r a tin g VA 2 0.5 2 0.5 A C h o ld in g r a tin g VA 2 0.5 2 0.5 D C p ic k - u p r a tin g W 1.8 – 1.8 – W % d u ty factor O p s /h 1.8 100 – 100 1.8 100 – 100 4000 4000 4000 4000 Magnet systems Rated operating voltage AC DC R a te d fr e q u e n c y A C o p e r a te d D C o p e r a te d Power consumption D C h o ld in g r a tin g D u ty fa c to r M a x im u m o p e r a tin g fr e q u e n c y Minimum command time AC DC R e p e titio n a c c u r a c y ( d e v ia tio n ) Recovery time (after 100% time delay) Contact changeover time 1) Electromagnetic compatibility (EMC) Electrostatic discharge (IEC/EN 61000-4-2, Level 3, ESD) A ir d is c h a r g e tu ms 50 50 50 50 ms % 30 ≦0.5 – ≦0.5 30 ≦0.5 – ≦0.5 ms ms 70 – 70 – 70 4 70 4 kV – – – – kV 8 8 8 8 kV V/m 6 10 6 10 6 10 6 10 Radio interference suppression (EN 55011) EN 55011 Class A EN 55011 Class A EN 55011 Class A EN 55011 Class A Burst pulses (IEC/EN 61000-4-4, level 3) High-energy pulses (surge) (IEC/EN 61000-4-5, level 2) Immunity to line-conducted interference (IEC/EN 61000-4-6) kV 2 1 2 1 2 1 2 1 V 10 10 10 10 C o n ta c t d is c h a r g e Electromagnetic fields (IEC/EN 61000-4-3, RFI) Notes 12 1) ETR4-51: 50 ms Electronic relays Timing relays Technical data ETR2 Part no. Input circuit - power supply circuit Rated control voltage U S A1 - A2 Tolerance of rated control voltage U S Rated frequency Frequency range Typical current/power consumption 12 V DC 24 V DC 230 V AC 115 V AC Mains failure buffering time Input circuit - control circuit Type of actuation Control input, control function Parallel connection possible/polarized Maximum cable length at the control inputs Minimum control pulse length/duration Control voltage potential Power consumption of control input 12 V DC 24 V DC 230 V AC 115 V AC Timing circuit Time ranges 7 time ranges 0.05 s - 100 h Recovery time Accuracy within the rated control voltage tolerance Accuracy within temperature range Operating status indication U control voltage/time running: green LED Relay status R: yellow LED Output circuits Output type 15 - 16/18 15 - 16/18; 25 - 26/28 Contact material Rated operational voltage Ue Minimum switching voltage/minimum switching current Rated operational current (IEC 60947-5-1) AC12 (resistive) 230 V AC15 (inductive) 230 V N/O AC15 (inductive) 230 V N/C DC12 (resistive) 24 V DC13 (inductive) 24 V N/O DC13 (inductive) 24 V N/C Rated operational data AC (UL 508) Utilization category (Control Circuit Rating Code) Max. rated operational voltage Max. thermal continuous current Max. input/output rating (N/O / N/C) Mechanical lifespan Electrical lifespan (AC12, 230 V, 4 A) Short-circuit rating, max. fuse (IEC/EN 60947-5-1) N/C N/O ETR2-11(12, 21, 42, 44, 69) ETR2-69-D ETR2-11-D/ETR2-12-D 24 - 240 V AC/24 - 48 V DC -15 - +10 % DC or 50/60 Hz DC or 47 - 63 Hz 12-240 V AC/DC -15 - +10 % DC or 50/60 Hz DC or 47 - 63 Hz 24 - 240 V AC/24 - 48 V DC -15 - +10 % DC or 50/60 Hz DC or 47 - 63 Hz – 35 mA – 0.6 W 1.3 VA 1.3 VA min. 30 ms – 6.25 mA 34.25 mA min. 30 ms 24.1mA 31.3 mA 20 mA min. 30 ms Non-isolated actuation External time start Yes/yes 50 m - 100 pF/m 30 ms see Rated control voltage Max. 4 mA Non-isolated actuation External time start Yes/yes 50 m - 100 pF/m 30 ms see Rated control voltage Non-isolated actuation External time start Yes/yes 50 m - 100 pF/m 30 ms see Rated control voltage 0.018 mA – – 0.01 mA 0.01 mA 0.92 mA 6.43 mA 3.27 mA 0.05 - 1 s, 0.5 - 10 s, 5 - 100 s, 0.5 - 10 min, 5 - 100 min, 0.5 - 10 h, 5 - 100 h 0.05 - 1 s, 0.5 - 10 s, 5 - 100 s, 0.5 - 10 min, 5 - 100 min, 0.5 - 10 h, 5 - 100 h 0.05 - 1 s, 0.5 - 10 s, 5 - 100 s, 0.5 - 10 min, 5 - 100 min, 0.5 - 10 h, 5 - 100 h < 50 ms Δt < 0.005 %/V < 50 ms Δt < 0.005 %/V < 50 ms Δt < 0.005 %/V Δt < 0.06 %/°C Δt < 0.06 %/°C Δt < 0.06 %/°C – – – – Continuous light: control voltage present; slow flashing: time running Continuous light: output relay 1 Continuous light: output relay 1 picked up or 2 picked up Continuous light: output relay 1 or 2 picked up Relay, 1 changeover contact – – – Cadmium-free 250 V 12 V/100 mA Relay, 2 changeover contacts Cadmium-free 250 V 12 V/100 mA Relay, 2 changeover contacts Cadmium-free 250 V 12 V/100 mA 6A 3A 3A 6A 2A 2A 5A 3A 0.75 A 5A 3A 1A 5A 3A 0.75 A 5A 3A 1A B300 300 V AC at B300 = 5 A at B300 = 3600/360 VA 30 x 10 6 operations 0.1 x 10 6 operations N/O: B300; N/C: C300 300 V AC at B300 = 5 A; at C300 = 2.5 A at B300 = 3600/360 VA; at C300 = 1800/180 VA 30 x 10 6 operations 0.1 x 10 6 operations N/O: B300; N/C: C300 300 V AC at B300 = 5 A; at C300 = 2.5 A at B300 = 3600/360 VA; at C300 = 1800/180 VA 30 x 10 6 operations 0.1 x 10 6 operations 6 A fast 10 A fast 6 A fast 10 A fast 6 A fast 10 A fast 13 Electronic relays Timing relays ETR2 Part no. ETR2-11(12, 21, 42, 44, 69) ETR2-69-D ETR2-11-D/ETR2-12-D General data Duty factor (DF) 100 % 100 % 100 % Repetition accuracy (constant parameters) Δt < 0.5 % Δt < 0.5 % Δt < 0.5 % Weight 0.060 kg 0.065 kg 0.065 kg Enclosure measurements (w x h x d) 17.5 mm x 70 mm x 58 mm (0.69 x 2.76 x 2.28 inches) Any 17.5 mm x 80 mm x 58 mm (0.69 x 3.15 x 2.28 inches) Any 17.5 mm x 80 mm x 58 mm (0.69 x 3.15 x 2.28 inches) Any Mounting position Degree of protection of enclosures/terminals IP50/IP20 IP50/IP20 IP50/IP20 Minimum horizontal/vertical distance to adjacent devices None/none None/none None/none DIN rail (IEC/EN 60715), clip-type toolless DIN rail (IEC/EN 60715), clip-type toolless DIN rail (IEC/EN 60715), clip-type toolless 2 x 0.5 - 1.5 mm 2 (2 x 20 - 16 AWG)/ 1 x 0.5 - 2.5 mm 2 (1 x 20 - 14 AWG) 2 x 0.5 - 1.5 mm 2 (2 x 20 - 16 AWG) 1 x 0.5 - 4 mm 2 (1 x 20 - 12 AWG) 3 x 0.5 - 1.5 mm 2 (2 x 20 - 16 AWG)/ 1 x 0.5 - 2.5 mm 2 (1 x 20 - 14 AWG) 2 x 0.5 - 1.5 mm 2 (2 x 20 - 16 AWG) 1 x 0.5 - 4 mm 2 (1 x 20 - 12 AWG) 4 x 0.5 - 1.5 mm 2 (2 x 20 - 16 AWG)/ 1 x 0.5 - 2.5 mm 2 (1 x 20 - 14 AWG) 2 x 0.5 - 1.5 mm 2 (2 x 20 - 16 AWG) 1 x 0.5 - 4 mm 2 (1 x 20 - 12 AWG) Stripped length 7 mm (0.28 incheses) 7 mm (0.28 incheses) 7 mm (0.28 incheses) Tightening torque Environmental data 0.5 - 0.8 Nm 0.5 - 0.8 Nm 0.5 - 0.8 Nm Mounting Electrical connection Terminal capacity Flexible with/without ferrule Rigid Ambient temperature range, operation/storage -20 - +60 °C/-40 - +85 °C -20 - +60 °C/-40 - +85 °C -20 - +60 °C/-40 - +85 °C Damp heat (cyclic) (IEC/EN 60068-2-30) 6 x 24 h cycle, 55 °C, 95 % RH 6 x 24 h cycle, 55 °C, 95 % RH 6 x 24 h cycle, 55 °C, 95 % RH Vibration (sinusoidal) (IEC/EN 60068-2-6) 40 m/s 2, 20 cycles, 10...150...10 Hz 40 m/s 2, 20 cycles, 10...150...10 Hz 40 m/s 2, 20 cycles, 10...150...10 Hz m/s 2, m/s 2, 100 m/s 2, 11 ms Impact (half-sinusoidal) (IEC/EN 60068-2-27) Insulation data 100 Rated impulse withstand voltage Uimp between all insulated circuits (VDE 0110, IEC/EN 60664-1) Pollution degree (IEC/EN 60664-1, VDE 0110, UL 508) 4 kV; 1.2/50 µs 3 3 3 Overvoltage category (IEC/EN 60664-1, VDE 0110, UL 508) III III III Input circuit/output circuit 300V 300V 300V Output circuit 1/output circuit 2 Basic isolation (IEC/EN 61140) input circuit/output circuit 300 V 300 V 300 V 300 V 300 V 300 V 250 V 250 V 250 V 2.5 kV, 50 Hz, 1s 2.5 kV, 50 Hz, 1s 2.5 kV, 50 Hz, 1s IEC 61812-1, EN 61812-1 + A11, DIN VDE 0435 Part 2021 IEC 61812-1, EN 61812-1 + A11, DIN VDE 0435 Part 2021 IEC 61812-1, EN 61812-1 + A11, DIN VDE 0435 Part 2021 2006/95/EC 2004/108/EC 2002/95/EC 2006/95/EC 2004/108/EC 2002/95/EC 2006/95/EC 2004/108/EC 2002/95/EC IEC/EN 61000-6-1, IEC/EN 61000-6-2 Level 3 (6 kV/8 kV) IEC/EN 61000-6-1, IEC/EN 61000-6-2 Level 3 (6 kV/8 kV) IEC/EN 61000-6-1, IEC/EN 61000-6-2 Level 3 (6 kV/8 kV) 11 ms 100 11 ms 4 kV; 1.2/50 µs 4 kV; 1.2/50 µs Rated insulation voltage Ui Safe isolation (VDE 0106 Part 101 and Part 101/A1; IEC/EN 61140) input circuit/output circuit Power-frequency withstand voltage test (test voltage, part test) between all insulated circuits Directives and standards Product standard Low-Voltage Directive EMC Directive RoHS Directive Electromagnetic compatibility Interference immunity Electrostatic discharge (ESD) IEC/EN 61000-4-2 Electromagnetic field (immunity to RF interference) IEC/EN 61000-4-3 Fast transients (burst) IEC/EN 61000-4-4 Level 3 (10 V/m) Level 3 (10 V/m) Level 3 (10 V/m) Level 3 (2 kV/5 kHz) Level 3 (2 kV/5 kHz) Level 3 (2 kV/5 kHz) High-energy pulses (surge) IEC/EN 61000-4-5 Level 4 (2 kV L-L) Level 4 (2 kV L-L) Level 4 (2 kV L-L) Cable-borne HF IEC/EN 61000-4-6 Emitted interference Level 3 (10 V) IEC/EN 61000-6-3, IEC/EN 61000-6-4 Class B Level 3 (10 V) IEC/EN 61000-6-3, IEC/EN 61000-6-4 Class B Level 3 (10 V) IEC/EN 61000-6-3, IEC/EN 61000-6-4 Class B Class B Class B Class B Electromagnetic field (resistance to RF interference) IEC/CISPR 22, EN 55022 Cable-borne HF IEC/CISPR 22; EN 55022 14 Electronic relays Timing relays, potentiometers Dimensions Electronic timing relays DILET…+HDILE 43 45 52 ETR4-… M4 45 58 58 5,5 65.3 45 50 DILET… 35 ETR2-… 250 x 006 ETR2-…-D 103 98 43.4 80 45 45 78 82.5 70 22.5 17.5 5 43.4 58 17.5 5 58 Potentiometers o 29.5 M22-R…K… 29.7 1–6 32.9 29.2 15 Eaton is dedicated to ensuring that reliable, efficient and safe power is available when it’s needed most. With unparalleled knowledge of electrical power management across industries, experts at Eaton deliver customized, integrated solutions to solve our customers’ most critical challenges. Our focus is on delivering the right solution for the application. But, decision makers demand more than just innovative products. They turn to Eaton for an unwavering commitment to personal support that makes customer success a top priority. For more information, visit www.eaton.com/electrical. Electrical Sector Asia Pacific No.3, Lane 280, Linhong Road, Changning District, Shanghai Eaton Industries Pte Ltd Electrical Sector 4 Loyang Lane #04-01/02 Singapore 508914 © 2012 Eaton Corporation All Rights Reserved Printed in Singapore Eaton is a registered trademark of Eaton Corporation. ETR2-4-SEA-EN All other trademarks are property of their respective owners. July 2012
ETR4-51-A 价格&库存
很抱歉,暂时无法提供与“ETR4-51-A”相匹配的价格&库存,您可以联系我们找货
ETR4-51-A
    • 1+1668.83555
    • 5+1411.40879
    库存:7
