DATASHEET - FAZ-B25/3-NA
Miniature circuit breaker (MCB), 25 A, 3p, characteristic: B
Similar to illustration
Part no.
Catalog No.
Alternate Catalog
No.
EL-Nummer
(Norway)
FAZ-B25/3-NA
132726
FAZ-B25/3-NA
0001691561
Delivery program
Basic function
Miniature circuit-breakers
Number of poles
3 pole
Tripping characteristic
B
Application
Switchgear for export to North America (UL-listed)
Rated current
In
A
25
Rated switching capacity acc. to IEC/EN 60947-2
Icu
kA
15
Product range
FAZ-NA
Standards
UL 489, CSA C22.2 No. 5
IEC 60947-2
Rated operational voltage
Ue
V
Ue
V AC
277/480 Y
V DC
60
Rated voltage according to IEC/EN 60947-2
Un
V AC
440
Rated voltage according to UL
Un
V AC
480Y/277
Icu
kA
15
Breaking capacity according to UL
kA
14 (UL489)
Characteristic
B, C, D
Selectivity Class
3
lifespan
Technical data
Electrical
Operations
> 20000
Direction of incoming supply
Lifespan
as required
Standard front dimension
mm
45
Enclosure height
mm
105
Mounting width per pole
mm
17.7
Mounting
IEC/EN 60715 top-hat rail
Degree of Protection
IP20, IP40 (when fitted)
Terminals top and bottom
Twin-purpose terminals
Terminal protection
Finger and back-of-hand proof to BGV A2
Tightening torque of fixing screws
N/m
max. 2.4
UL:
#18-12 AWG: 2.4 Nm (21 lb-in)
#10-8 AWG: 2.8 Nm (25 lb-in)
#6 AWG: 4 Nm (36 lb-in)
Mounting position
As required
Mechanical
Design verification as per IEC/EN 61439
Technical data for design verification
Rated operational current for specified heat dissipation
In
A
25
Heat dissipation per pole, current-dependent
Pvid
W
Equipment heat dissipation, current-dependent
Pvid
W
9.3
Static heat dissipation, non-current-dependent
Pvs
W
Eaton 132726 ED2020 V69.0 EN
1/2
Heat dissipation capacity
Pdiss
W
Operating ambient temperature min.
°C
-25
Operating ambient temperature max.
°C
75
linear, per +1 °C, results in a 0.5% reduction of current carrying capacity
Technical data ETIM 7.0
Circuit breakers and fuses (EG000020) / Miniature circuit breaker (MCB) (EC000042)
Electric engineering, automation, process control engineering / Electrical installation, device / Miniature circuit breaker system (MCB) / Miniature circuit breaker (MCB)
(ecl@ss10.0.1-27-14-19-01 [AAB905014])
Release characteristic
B
Number of poles (total)
3
Number of protected poles
3
Rated current
A
25
Rated voltage
V
415
Rated insulation voltage Ui
V
440
Rated impulse withstand voltage Uimp
kV
4
Rated short-circuit breaking capacity Icn EN 60898 at 230 V
kA
Rated short-circuit breaking capacity Icn EN 60898 at 400 V
kA
Rated short-circuit breaking capacity Icu IEC 60947-2 at 230 V
kA
15
Rated short-circuit breaking capacity Icu IEC 60947-2 at 400 V
kA
15
Voltage type
AC
Frequency
Hz
50 - 60
Current limiting class
3
Suitable for flush-mounted installation
No
Concurrently switching N-neutral
No
Over voltage category
3
Pollution degree
2
Additional equipment possible
Yes
Width in number of modular spacings
3
Built-in depth
mm
70.5
Degree of protection (IP)
IP20
Ambient temperature during operating
°C
-25 - 75
Connectable conductor cross section multi-wired
mm²
1 - 25
Connectable conductor cross section solid-core
mm²
1 - 25
Product Standards
IEC/EN 60947-2; UL 489; CSA-C22.2 No. 5-09; CE marking
UL File No.
E235139
UL Category Control No.
DIVQ
CSA File No.
204453
CSA Class No.
1432-01
North America Certification
UL listed, CSA certified
Specially designed for North America
Yes, suitable as BCPD
Suitable for
Feeder circuits, branch circuits
Current Limiting Circuit-Breaker
Yes
Max. Voltage Rating
≤ 32 A
IEC: IP20, UL/CSA Type: -
Approvals
Additional product information (links)
Temperature dependency, derating
06/29/2020
https://www.eaton.com/content/dam/eaton/technicaldocumentation/technical-data-tables/Derating table
FAZ-NA-RT.pdf
Eaton Industries GmbH
http://www.eaton.eu
© 06/2020 by Eaton Industries GmbH
2/2
很抱歉,暂时无法提供与“FAZ-B25/3-NA”相匹配的价格&库存,您可以联系我们找货
