HCM1A1307V2-6R8-R
HCM1A1307V2-6R8-R
    EATON(伊顿)
    非标准
    6.8 µH 屏蔽 电感器 10 A 11.5 毫欧最大 非标准
HCM1A1307V2-6R8-R 数据手册
Technical Data 10905 Effective April 2019 HCM1A1307V2 Automotive grade high current power inductors Applications • • Product features • AEC-Q200 qualified • High current carrying capacity • Magnetically shielded, low EMI • DC-DC converter applications up to 1 MHz • Filtering applications up to Self Resonant Frequency (SRF) [See product specification table] • Inductance range from 0.22 μH to 56 μH • Current range from 4.0 A to 100 A • 13.8 mm x 12.9 mm footprint surface mount package in a 6.5 mm height • Moisture Sensitivity Level (MSL): 1 • Alloy powder core material • • • Body electronics • Central body control module • Headlamps, tail lamps and interior lighting and LED lighting • Heating ventilation and air conditioning controllers (HVAC) • Doors, window lift and seat control Advanced driver assistance systems • Adaptive cruise control (ACC) • Automatic parking control • Collision avoidance system/ Car black box system Infotainment and cluster electronics • Audio subsystem: head unit and trunk amp • Digital instrument cluster • In-vehicle infotainment (IVI) and navigation Chassis and safety electronics • Airbag control unit • Electronic stability control system (ESC) • Electric parking brake • Electronic power steering (EPS) Engine and Powertrain Systems • Electric pumps, motor control and auxiliaries • Powertrain control module (PCU)/ Engine Control unit (ECU) • Transmission Control Unit (TCU) Environmental data • Storage temperature range (Component): -55 °C to +155 °C • Operating temperature range: -55 °C to +155 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE HCM1A1307V2 Automotive grade high current power inductors  Technical Data 10905 Effective April 2019 Product specifications Part number6 OCL1 (μH) ± 20% FLL2 (μH) minimum Irms3 (A) Isat4 (A) DCR (mΩ) typical @ +20 °C DCR (mΩ) maximum @ +20 °C SRF (MHz) typical K-factor5 HCM1A1307V2-R22-R 0.22 0.14 52 100 0.46 0.60 135 244 HCM1A1307V2-R33-R 0.33 0.21 47 70 0.58 0.69 80 219 HCM1A1307V2-R47-R 0.47 0.30 43 56 0.73 0.87 59 186 HCM1A1307V2-1R0-R 1.0 0.64 28 34 1.49 1.75 34 149 HCM1A1307V2-1R2-R 1.2 0.76 22.5 30 1.78 2.10 34 117 HCM1A1307V2-1R5-R 1.5 0.96 21 25 2.04 2.40 31 126 HCM1A1307V2-1R8-R 1.8 1.15 19 24 2.55 2.94 26 105 HCM1A1307V2-2R2-R 2.2 1.40 18.5 23 2.62 3.10 24 95 HCM1A1307V2-3R3-R 3.3 2.11 16.5 18 3.55 4.10 18 90 HCM1A1307V2-4R7-R 4.7 3.00 13 20 6.25 7.25 14 71 HCM1A1307V2-5R6-R 5.6 3.58 12 18 7.21 8.30 11 64 HCM1A1307V2-6R8-R 6.8 4.35 10 15 9.50 11.5 9 52 HCM1A1307V2-7R8-R 7.8 4.99 10 16 10.25 11.78 9 46 HCM1A1307V2-8R2-R 8.2 5.25 10 14 10.3 11.85 8 46 HCM1A1307V2-100-R 10 6.40 8.3 13.5 15.0 17.2 7 43 HCM1A1307V2-120-R 12 7.68 8.0 12.5 16.4 18.9 6 38 HCM1A1307V2-150-R 15 9.60 7.0 11 20.3 23.4 6 35 HCM1A1307V2-220-R 22 14.1 6.0 8 28.8 33.1 5 28 HCM1A1307V2-330-R 33 21.0 5.0 7.5 40.8 45.0 3 26 HCM1A1307V2-560-R 56 35.8 4.0 4.3 55.0 65.0 2 23 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C 2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, , +25 °C 3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +155 °C under worst case operating conditions verified in the end application. 2 www.eaton.com/electronics 4. Isat: Peak current for approximately 20% rolloff @ +25 °C 5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table), L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps). 6. Part Number Definition: HCM1A1307V2-xxx-R HCM1A1307V2 = Product code and size xxx= inductance value in μH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Technical Data 10905 HCM1A1307V2 Automotive grade high current power inductors Effective April 2019  Dimensions (mm) Schematic Dimension A HCM1A1307V2-R22 through R47-R, HCM1A1307V2-1R0 through 3R3-R HCM1A1307V24R7 through 560-R 4.4 ±0.3 3.68 ±0.3 4.7 ±0.3 1 2 Part marking: 1AxxxV2, xxx=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros. xxxx=Lot code All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.3 millimeters unless stated otherwise Pad layout tolerances are ±0.1 millimeters unless stated otherwise DCR measured from point “a” to point “b” Do not route traces or vias underneath the inductor Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 250 parts per 13” diameter reel www.eaton.com/electronics 3 HCM1A1307V2 Automotive grade high current power inductors  Technical Data 10905 Effective April 2019 Core loss vs Bp-p HCM1A1307V2-R33-R HCM1A1307V2-R22-R 10000 10000 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 100 10 1 100 10 1 0.1 0.1 0.01 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 1000 Core Loss (mW) Core Loss (mW) 1000 0.01 100 1000 100 1000 Bp-p (Gauss) Bp-p (Gauss) HCM1A1307V2-1R0-R HCM1A1307V2-R47-R 10000 10000 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 100 Core Loss (mW) Core Loss (mW) 1000 10 1 100 kHz 50 kHz 100 10 1 0.1 0.1 0.01 700 kHz 500 kHz 300 kHz 1000 0.01 100 1000 100 1000 Bp-p (Gauss) Bp-p (Gauss) HCM1A1307V2-1R2-R HCM1A1307V2-1R5-R 10000 10000 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 100 10 1 0.1 0.01 100 kHz 50 kHz 100 10 1 0.1 100 1000 Bp-p (Gauss) 4 700 kHz 500 kHz 300 kHz 1000 Core Loss (mW) Core Loss (mW) 1000 www.eaton.com/electronics 0.01 100 1000 Bp-p (Gauss) Technical Data 10905 HCM1A1307V2 Automotive grade high current power inductors Effective April 2019  Core loss vs Bp-p HCM1A1307V2-1R8-R HCM1A1307V2-2R2-R 10000 10000 700 kHz 500 kHz 300 kHz 100 10 1 10 1 0.1 100 0.01 1000 Bp-p (Gauss) 10000 100 700 kHz 500 kHz 300 kHz 1000 100 kHz 50 kHz 100 10 1 Core Loss (mW) 1000 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 10 1 0.1 0.1 0.01 100 1000 100 HCM1A1307V2-6R8-R HCM1A1307V2-5R6-R 10000 10000 100 10 1 700 kHz 500 kHz 300 kHz 1000 100 kHz 50 kHz 100 Core Loss (mW) 1000 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 10 1 0.1 0.1 0.01 1000 Bp-p (Gauss) Bp-p (Gauss) Core Loss (mW) 1000 HCM1A1307V2-4R7-R HCM1A1307V2-3R3-R 0.01 100 Bp-p (Gauss) 10000 Core Loss (mW) 100 kHz 50 kHz 100 0.1 0.01 700 kHz 500 kHz 300 kHz 1000 100 kHz 50 kHz Core Loss (mW) Core Loss (mW) 1000 0.01 100 1000 Bp-p (Gauss) 1000 100 Bp-p (Gauss) www.eaton.com/electronics 5 HCM1A1307V2 Automotive grade high current power inductors  Technical Data 10905 Effective April 2019 Core loss vs Bp-p HCM1A1307V2-8R2-R HCM1A1307V2-7R8-R 10000 10000 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 100 Core Loss (mW) Core Loss (mW) 1000 10 1 100 kHz 50 kHz 100 10 1 0.1 0.1 0.01 700 kHz 500 kHz 300 kHz 1000 0.01 100 1000 Bp-p (Gauss) HCM1A1307V2-120-R HCM1A1307V2-100-R 10000 10000 Core Loss (mW) 100 10 1 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 1000 Core Loss (mW) 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 1000 100 10 1 0.1 0.1 0.01 0.01 100 1000 100 HCM1A1307V2-220-R HCM1A1307V2-150-R 10000 10000 700 kHz 500 kHz 300 kHz 100 10 1 700 kHz 500 kHz 300 kHz 1000 100 kHz 50 kHz Core Loss (mW) Core Loss (mW) 1000 100 kHz 50 kHz 100 10 1 0.1 0.1 0.01 1000 Bp-p (Gauss) Bp-p (Gauss) 6 1000 100 Bp-p (Gauss) 0.01 100 www.eaton.com/electronics Bp-p (Gauss) 1000 100 1000 Bp-p (Gauss) Technical Data 10905 HCM1A1307V2 Automotive grade high current power inductors Effective April 2019  Core loss vs Bp-p HCM1A1307V2-330-R HCM1A1307V2-560-R 10000 700 kHz 500 kHz 300 kHz 1000 100 kHz 50 kHz 100 10 1 100 kHz 50 kHz 100 10 1 0.1 0.01 700 kHz 500 kHz 300 kHz 1000 Core Loss (mW) Core Loss (mW) 10000 0.1 100 0.01 1000 Bp-p (Gauss) 100 1000 Bp-p (Gauss) Inductance and impedance vs. frequency HCM1A1307V2-R22-R 1000 0.5 0.45 0.15 1 0.1 100 0.7 Impedance 0.6 10 0.5 0.4 Inductance 0.3 1 0.2 0.05 0.1 0.1 1 10 0.1 100 0 Frequency (MHz) 0.1 1 10 0.1 100 Frequency (MHz) HCM1A1307V2-R47-R HCM1A1307V2-1R0-R 5 10000 2 10000 4.5 1000 1.2 100 Impedance 1 10 0.8 0.6 Inductance 1 0.4 0.2 4 Inductance (uH) 1.4 Impedance (Ohm) 1.6 1000 3.5 3 100 Impedance 2.5 2 10 1.5 1 Impedance (Ohm) 1.8 Inductance (uH) Impedance (Ohm) 10 Inductance 0.2 Inductance (uH) 0.3 0.25 0.8 100 Impedance Impedance (Ohm) Inductance (uH) 0.35 0 1000 0.9 0.4 0 HCM1A1307V2-R33-R 1 1 Inductance 0.5 0.1 1 10 Frequency (MHz) 100 0.1 0 0.1 1 10 100 0.1 Frequency (MHz) www.eaton.com/electronics 7 HCM1A1307V2 Automotive grade high current power inductors  Technical Data 10905 Effective April 2019 Inductance and impedance vs. frequency HCM1A1307V2-1R2-R 10000 6 10000 7 100 3 10 2 Inductance (uH) Impedance Impedance (Ohm) 4 1000 6 5 Impedance 100 4 10 3 2 1 0 1 Inductance 0.1 1 10 100 0 0.1 0.1 1 10 HCM1A1307V2-1R8-R 10000 100 6 10 4 Inductance (uH) Impedance 8 1000 Impedance (Ohm) Inductance (uH) 15 1000 10 10 Impedance 100 10 5 1 2 0 0.1 HCM1A1307V2-2R2-R 10000 12 100 Frequency (MHz) Frequency (MHz) 14 1 Inductance 1 1 Inductance 0.1 1 Impedance (Ohm) 1000 Impedance (Ohm) 5 Inductance (uH) HCM1A1307V2-1R5-R 8 Inductance 10 100 0.1 0 Frequency (MHz) 0.1 1 10 100 0.1 Frequency (MHz) HCM1A1307V2-4R7-R HCM1A1307V2-3R3-R 30 10000 40 10000 35 Impedance 100 15 10 10 1 5 Inductance 0 0.1 1 10 Frequency (MHz) 8 www.eaton.com/electronics 100 0.1 Inductance (uH) 20 1000 30 Impedance 25 100 20 10 15 10 1 5 0 Inductance 0.1 1 10 Frequency (MHz) 100 0.1 Impedance (Ohm) 1000 Impedance (Ohm) Inductance (uH) 25 Technical Data 10905 HCM1A1307V2 Automotive grade high current power inductors Effective April 2019  Inductance and impedance vs. frequency HCM1A1307V2-5R6-R 1000 50 Impedance 40 100 30 10 20 0.1 1 10 100 Impedance 100 30 10 20 1 Inductance 0.1 0 Frequency (MHz) 0.1 1 10 100 0.1 Frequency (MHz) HCM1A1307V2-8R2-R HCM1A1307V2-7R8-R 80 100000 80 10000 70 Impedance (Ohm) 60 1000 Impedance 40 100 30 10 40 10 100 10 30 Inductance 1 100 1 10 1 0.1 Impedance 50 20 20 10 1000 60 0 0.1 Inductance 0.1 1 10 100 0.1 Frequency (MHz) Frequency (MHz) HCM1A1307V2-120-R HCM1A1307V2-100-R 140 10000 120 100000 120 80 Impedance 100 60 10 40 1 20 0 Inductance 0.1 1 10 Frequency (MHz) 100 0.1 Inductance (uH) 1000 Impedance (Ohm) Inductance (uH) 100 10000 100 1000 Impedance 80 100 60 10 40 20 0 1 Inductance 0.1 Impedance (Ohm) 50 Inductance (uH) 10000 Impedance (Ohm) 70 Inductance (uH) 40 10 Inductance 0 1000 1 10 0 10000 Impedance (Ohm) 60 Inductance (uH) Inductance (uH) 50 HCM1A1307V2-6R8-R 10000 Impedance (Ohm) 60 1 10 100 0.1 Frequency (MHz) www.eaton.com/electronics 9 HCM1A1307V2 Automotive grade high current power inductors  Technical Data 10905 Effective April 2019 Inductance and impedance vs. frequency HCM1A1307V2-150-R HCM1A1307V2-220-R 10000 60 10 40 0.1 50 10 100 0.1 0 Frequency (MHz) 100000 250 1000 Impedance 100 150 10 100 1 Inductance 1 10 Frequency (MHz) 10 www.eaton.com/electronics 100 0.1 Inductance (uH) 10000 Impedance (Ohm) Inductance (uH) 300 0.1 1 10 100 0.1 HCM1A1307V2-560-R 350 0 0.1 Frequency (MHz) HCM1A1307V2-330-R 50 1 Inductance 1 200 100 100 600 100000 500 10000 400 1000 Impedance 300 100 200 10 100 0 1 Inductance 0.1 1 10 Frequency (MHz) 100 0.1 Impedance (Ohm) 0 1000 Impedance 150 10 1 Inductance 20 Inductance (uH) 100 80 Impedance (Ohm) 1000 Impedance 10000 200 120 100 100000 Impedance (Ohm) 140 Inductance (uH) 250 100000 160 Technical Data 10905 HCM1A1307V2 Automotive grade high current power inductors Effective April 2019  Inductance and temperature rise vs. current HCM1A1307V2-R22-R 90 0.20 60 0.12 50 0.10 40 30 Temperature rise 0.06 0.02 10 0.00 0 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 150 60 0.20 50 0.15 40 0.10 20 0.04 70 20 0.05 10 0.00 0 Idc (A) 10 20 30 40 HCM1A1307V2-R47-R Inductance 80 0.90 0.35 70 0.30 60 0.25 50 0.20 40 0.15 30 Temperature rise 0.10 20 0.05 10 0.00 0 30 40 50 60 70 80 90 100 110 120 130 140 150 100 Inductance 70 60 0.60 50 0.50 40 0.40 0.30 20 0.10 10 0 10 20 60 70 0 80 70 0.80 60 0.70 50 0.60 40 0.50 0.40 30 Temperature rise 20 0.20 10 0.10 40 50 60 70 0 100 90 80 1.20 70 1.00 OCL (uH) 0.90 Temperature rise (℃) OCL (uH) 1.00 Idc (A) 50 Inductance 1.40 80 30 40 1.60 90 1.10 20 30 HCM1A1307V2-1R5-R Inductance 10 30 Temperature rise 0.20 0.00 100 0 90 80 HCM1A1307V2-1R2-R 0.00 0 Idc (A) 1.30 0.30 90 100 110 120 130 140 150 0.70 Idc (A) 1.20 80 0.80 OCL (uH) Temperature rise (℃) OCL (uH) 1.00 0.40 20 70 1.10 90 10 60 HCM1A1307V2-1R0-R 100 0 50 Idc (A) 0.50 0.45 30 Temperature rise Temperature rise (℃) 0.08 80 0.25 OCL (uH) 0.14 Temperature rise (℃) 70 0.16 90 0.30 80 0.18 100 Inductance Temperature rise (℃) Inductance 0.35 60 0.80 50 40 0.60 30 0.40 Temperature rise 20 0.20 0.00 Temperature rise (℃) 0.22 OCL (uH) HCM1A1307V2-R33-R 100 0.24 10 0 5 10 15 20 25 30 35 40 45 50 55 0 Idc (A) www.eaton.com/electronics 11 HCM1A1307V2 Automotive grade high current power inductors  Technical Data 10905 Effective April 2019 Inductance and temperature rise vs. current HCM1A1307V2-1R8-R 2.20 1.60 80 1.40 70 1.20 60 1.00 50 0.80 40 0.60 10 0.00 0 5 10 15 20 25 30 35 40 45 50 55 70 1.60 1.40 60 1.20 50 1.00 40 0.80 30 0.60 Temperature rise 10 0.20 0.00 Idc (A) 0 5 10 15 OCL (uH) 2.5 2.0 Temperature rise 80 70 3.5 70 3.0 60 2.5 50 2.0 40 30 35 40 45 50 100 Inductance 90 1.5 20 1.0 10 0.5 0 0.0 30 Temperature rise 0 5 10 15 20 60 3.0 50 2.5 40 2.0 30 1.5 Temperature rise 0.5 10 0.0 0 0 5 10 15 20 Idc (A) www.eaton.com/electronics 25 30 35 40 0 100 Inductance 90 80 70 60 4.0 50 3.0 40 2.0 30 Temperature rise 20 1.0 40 5.0 OCL (uH) OCL (uH) 3.5 Temperature rise (℃) 70 4.0 35 6.0 80 4.5 12 7.0 90 5.0 30 HCM1A1307V2-6R8-R 100 Inductance 25 Idc (A) HCM1A1307V2-5R6-R 6.0 20 10 Idc (A) 5.5 0 4.0 30 1.0 25 50 80 40 20 45 90 50 1.5 15 40 4.5 60 10 35 5.0 OCL (uH) 3.0 5 30 100 Temperature rise (℃) Inductance 0 25 HCM1A1307V2-4R7-R HCM1A1307V2-3R3-R 0.0 20 Idc (A) 3.5 0.5 20 0.40 Temperature rise (℃) 0 80 1.80 20 0.20 90 Inductance 2.00 30 Temperature rise 0.40 100 Temperature rise (℃) 90 20 1.0 0.0 10 0 5 10 15 20 Idc (A) 25 30 35 0 Temperature rise (℃) OCL (uH) 2.40 OCL (uH) Inductance 1.80 HCM1A1307V2-2R2-R 100 Temperature rise (℃) 2.00 Technical Data 10905 HCM1A1307V2 Automotive grade high current power inductors Effective April 2019  Inductance and temperature rise vs. current HCM1A1307V2-7R8-R Inductance 9.0 90 8.0 6.0 60 5.0 50 4.0 40 3.0 30 Temperature rise 1.0 0.0 0 0.0 20 25 30 35 40 3.0 10 15 50 4.0 1.0 10 60 5.0 2.0 5 70 6.0 20 0 80 30 Temperature rise 10 0 Idc (A) 6 8 10 90 16 18 20 22 24 26 28 30 90 Inductance 80 50 5 40 4 30 3 Temperature rise 10 0 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 70 60 8 50 6 40 4 20 1 0 10 OCL (uH) 60 6 2 20 2 0 10 0 2 4 6 8 10 10 8 2 Idc (A) 16 0 18 20 22 24 100 80 16 70 14 60 30 Temperature rise 14 26 18 40 6 12 24 80 50 10 22 20 60 8 20 90 70 6 18 22 OCL (uH) 12 4 16 100 Temperature rise (℃) Inductance 2 14 HCM1A1307V2-220-R 16 0 12 Idc (A) HCM1A1307V2-150-R 4 30 Temperature rise Idc (A) 14 0 100 12 Temperature rise (℃) 70 7 OCL (uH) 14 80 8 0 12 HCM1A1307V2-120-R 9 OCL (uH) 4 14 100 Inductance 10 2 Idc (A) HCM1A1307V2-100-R 11 20 Temperature rise (℃) 2.0 90 7.0 OCL (uH) 70 Temperature rise (℃) 80 7.0 100 Inductance 90 12 50 10 40 8 4 10 2 0 30 Temperature rise 6 20 0 Inductance Temperature rise (℃) 8.0 OCL (uH) HCM1A1307V2-8R2-R 100 Temperature rise (℃) 9.0 20 10 0 2 4 6 8 10 12 14 16 18 0 Idc (A) www.eaton.com/electronics 13 HCM1A1307V2 Automotive grade high current power inductors  Technical Data 10905 Effective April 2019 Inductance and temperature rise vs. current HCM1A1307V2-560-R Inductance 50 15 40 10 30 Temperature rise 5 0 1 2 3 4 5 6 7 Idc (A) 14 www.eaton.com/electronics 8 9 10 11 12 13 14 70 35 60 30 50 25 40 20 30 15 20 10 10 5 0 80 40 OCL (uH) 60 20 90 45 Temperature rise (℃) OCL (uH) 70 Inductance 50 80 25 0 55 90 30 100 60 100 0 Temperature rise 20 10 0 1 2 3 4 5 Idc (A) 6 7 8 9 10 0 Temperature rise (℃) HCM1A1307V2-330-R 35 Technical Data 10905 HCM1A1307V2 Automotive grade high current power inductors Effective April 2019  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax Package thickness Volume mm3
HCM1A1307V2-6R8-R
物料型号:HCM1A1307V2
器件简介:这是汽车级高电流功率电感器,具有AEC-Q200认证,高电流承载能力,磁屏蔽低电磁干扰,适用于高达1MHz的DC-DC转换器应用和自谐振频率(SRF)的滤波应用。
引脚分配:文档中没有提供具体的引脚分配图,但通常这类电感器会有至少两个引脚用于直流电流的输入和输出。
参数特性: - 电感范围:0.22μH至56μH - 电流范围:4.0A至100A - 尺寸:13.8mm x 12.9mm,高度6.5mm的表面贴装封装 - 湿度敏感等级(MSL):1 - 合金粉末芯材料
功能详解: - 适用于多种汽车电子应用,包括车身电子、中央车身控制模块、大灯、尾灯和室内照明、加热通风和空调控制器(HVAC)、门窗升降和座椅控制、高级驾驶辅助系统、自适应巡航控制(ACC)、自动停车控制、碰撞避免系统/汽车黑匣子系统、信息娱乐和集群电子、音频子系统、数字仪表盘、车载信息娱乐(IVI)和导航、底盘和安全电子、气囊控制单元、电子稳定控制系统(ESC)、电子驻车制动、电子助力转向(EPS)、发动机和动力传动系统、电动泵、电机控制和辅助设备、动力传动控制模块(PCU)/发动机控制单元(ECU)、传动控制单元(TCU)。
应用信息:适用于汽车电子系统中的多种应用,包括车身控制、照明、HVAC、门窗控制、驾驶辅助、信息娱乐等。
封装信息:13.8mm x 12.9mm的表面贴装封装,高度为6.5mm。
环境数据: - 存储温度范围:-55°C至+155°C - 工作温度范围:-55°C至+155°C(环境温度加上自身温升) - 焊接回流温度:符合J-STD-020(最新修订版)
符合RoHS指令,无卤素,无镓。
技术数据表提供了不同型号的电感器的详细规格,包括标称电感值、最小满载电感、直流电阻、典型值和最大值,以及自谐振频率和K因子等参数。
HCM1A1307V2-6R8-R 价格&库存
很抱歉,暂时无法提供与“HCM1A1307V2-6R8-R”相匹配的价格&库存,您可以联系我们找货
HCM1A1307V2-6R8-R
  • 250+10.14407250+1.21273
  • 500+9.38943500+1.12251
  • 750+8.97306750+1.07274
  • 1250+8.473171250+1.01298
  • 1750+8.158221750+0.97532
  • 2500+7.836252500+0.93683
  • 6250+7.490316250+0.89547
库存:347
HCM1A1307V2-6R8-R
  • 1+18.662051+2.23106
  • 10+14.4722410+1.73017
  • 25+13.0884125+1.56473
  • 50+12.1247450+1.44952
  • 100+11.23017100+1.34258
库存:347
HCM1A1307V2-6R8-R
  • 250+6.44451
库存:750
