4.5
4
Toggle Switches
General Purpose Toggles—AC/DC Rated
Contents
Description
4
Page
Technical Data and Specifications . . . . . . . . . .
Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . .
4
V11-T4-21
V11-T4-21
4
4
4
4
4
4
4
4
4
4
4
4
Product Description
This line of switches employs
a quick-make/quick-break
contact mechanism. The
resultant high-speed
movement eliminates the
“teasing” of the switch and
reduces the pitting of the
Options
contact surfaces due to
arcing. Self-cleaning and
wiping contact action assures
positive contact on switch
operation. These switches
are especially suited for use
in small motor applications.
Standards and
Certifications
Lever—11/16 in
Lever seal
Mounting hardware;
furnished assembled
Other lead lengths
Note
1 Visit www.eaton.com/vcbu for
the most up-to-date list of verified
part numbers.
4
4
UL Recognized
CSA Certified
RoHS Compliant 1
Product Selection
4
AC/DC Rated Toggle Switches—Single-Pole
4
4
Rating
Poles
and
Throw
3A, 250 Vdc
1PST
6A, 125 Vac/Vdc 1PST
3A, 250 Vdc
4
4
1PDT
Circuit with Toggle in …
UP
Position
CENTER
Position
DOWN
Position
Base Circuit
See Page
V11-T4-35
Bushing
Length “B”
Inches (mm)
Lever
Length “A”
Inches (mm)
Catalog Number
Solder
Lugs
Screw
Terminals
Wire
Leads
ON
NONE
OFF
A
0.344 (8.74)
0.500 (12.70)
8280K115
8295K107
8290K115
ON
ON
MOM. ON
NONE
NONE
NONE
OFF
OFF
OFF
A
0.344 (8.74)
0.469 (11.91)
0.469 (11.91)
0.500 (12.70)
0.500 (12.70)
0.500 (12.70)
8381K107
8381K108
8928K478
8396K107
8396K108
8391K107
8391K108
ON
NONE
ON
B
0.469 (11.91)
0.500 (12.70)
8928K479
Base Circuit
See Page
V11-T4-35
Bushing
Length “B”
Inches (mm)
Lever
Length “A”
Inches (mm)
Catalog Number
Solder
Lugs
Screw
Terminals
Wire
Leads
4
4
AC/DC Rated Toggle Switches—Two-Pole
4
Rating
4
7A, 125V
3A, 250 Vdc
4
4
Poles
and
Throw
UP
Position
CENTER
Position
DOWN
Position
2PST
ON
MOM. ON
NONE
NONE
OFF
OFF
C
0.469 (11.91)
0.469 (11.91)
0.500 (12.70)
0.500 (12.70)
8370K107
8928K481 1
8372K107
8928K482 1
8371K107
2PDT
ON
ON
NONE
NONE
ON
ON
D
0.344 (8.74)
0.469 (11.91)
0.500 (12.70)
0.500 (12.70)
8373K108
8373K107
8375K108
8375K107
8374K108
8374K107
Note
1 Rating: 6A, 125 Vac/Vdc and 3A, 250 Vdc.
4
4
V11-T4-20
Volume 11—Vehicle and Commercial Controls CA08100013E—November 2012 www.eaton.com
4.5
Toggle Switches
4
4
Description
Specification
Ratings
See Product Selection table; Switch ratings at 125 Vac also apply to 28 Vdc
Circuits
1PST, 1PDT, 2PST, 2PDT
Maintained and momentary toggle action
Contact mechanism
Quick-make/quick-break wiping action
Contact material
Bronze silver-plated
Terminal types
Screw terminals—brass designed to accept #5-40 x 5/32 in (Cat. No. 11-26) screws
Furnished unassembled
Solder lug terminals—brass silver-plated with 0.085–0.090 in (2.16–2.29 mm) dia. hole
Integrated wire leads—18 gauge, 6 in long and skinned 3/4 in
Special wire leads lengths beyond 6 in are available at additional charge
4
4
4
4
4
Base material
Thermoset molding material
Mounting means
Threaded bushing—0.468 in (11.89 mm) dia., 32 threads/inch
Keyway—0.068 x 0.035 in (1.73 x.89 mm) deep, provides anti-rotation feature
Hardware supplied—1 hexagon locknut (Cat. No. 15-192) and 1 bright nickel-plated knurled
facenut (Cat. No. 15-124F1)
Finish
Bright nickel-plated toggle lever and bushing
Operating temperature range
0° to 150°F (–17.8° to 65.6°C)
4
4
4
4
Dimensions
4
Approximate Dimensions in Inches (mm)
8280K115
1PST Maintained
(Solder Lug)
8290K115
1PST Maintained
(Wire Lead)
Keyway
0.035 (0.88) Deep
0.068 (1.72) Wide
Keyway
0.035 (0.88) Deep
0.068 (1.72) Wide
0.500
(12.70)
8295K107
1PST Maintained
(Screw Terminals)
Keyway
0.035 (0.88) Deep
0.068 (1.72) Wide
0.500
(12.70)
0.532
(13.51)
0.245 (6.22)
Dia.
0.239 (6.07)
1.093
(27.78)
0.245 (6.22)
Dia.
0.239 (6.07)
D
15/32 Dia.−
32 Thds.
BC
A
B
B C
C
0.200
(5.08)
0.562
(14.28)
0.046
(1.19)
0.562
(14.28)
0.968
(24.60)
1.250
(31.75)
#5/40 x 5/32 Lg.
Binding Head Screw
Standard 6.000 (152.40)
Long Wire Leads
4
A
4
B
0.046
(1.19)
0.562
(14.28)
0.968
(24.60)
0.968
(24.60)
0.090 (2.28)
0.085 (2.15)
Dia. Hole
15/32 Dia.−
32 Thds.
A
A
4
4
D
15/32 Dia.−
32 Thds.
4
4
0.245 (6.22)
Dia.
0.239 (6.07)
D
D
15/32 Dia.−
32 Thds.
4
0.671
(17.06)
1.000
(25.40)
0.245 (6.22)
Dia.
0.239 (6.07)
4
Keyway
0.035 (0.88) Deep
0.068 (1.72) Wide
0.500
(12.70)
1.000
(25.40)
1.000
(25.40)
4
8381K107 and K108
1PST Maintained
(Solder Lug)
C
0.687
(17.46)
4
4
0.090 (2.28)
0.085 (2.15)
Dia. Hole
0.203
(5.15)
4
4
4
“A”
Lever
Dim.
“B”
Bushing
Dim.
“C”
Overall
Dim.
“D”
Throw
Dim.
“A”
Lever
Dim.
“B”
Bushing
Dim.
“C”
Overall
Dim.
“D”
Throw
Dim.
“A”
Lever
Dim.
“B”
Bushing
Dim.
“C”
Overall
Dim.
“D”
Throw
Dim.
“A”
Lever
Dim.
“B”
Bushing
Dim.
“C”
Overall
Dim.
“D”
Throw
Dim.
0.500
(12.70)
0.344
(8.74)
1.411
(35.84)
29-1/2°
0.500
(12.70)
0.344
(8.74)
1.406
(35.71)
29-1/2°
0.500
(12.70)
0.344
(8.74)
1.406
(35.71)
29-1/2°
0.500
(12.70)
0.344
(8.74)
1.531
(38.89)
29-1/2°
4
0.500
(12.70)
0.469
(11.91)
1.656
(42.06)
25-1/2°
4
4
4
V11-T4-21
4.5
4
4
8391K107 and K108
1PST Maintained
(Wire Lead)
C
15/32 Dia.−
32 Thds.
15/32 Dia.−
32 Thds.
A
0.685
(17.39)
B
A
B
C
C
0.687
(17.46)
1.093
(27.78)
0.950
(24.13)
Standard
6.000 (152.40)
Long Wire Leads
4
4
D
A
B
4
4
0.242 (6.14) Dia.
D
15/32 Dia.−
32 Thds.
4
1.156
(29.36)
0.245 (6.22)
Dia.
0.239 (6.07)
4
4
0.690
(17.52)
1.390
(35.32)
D
4
Keyway
0.035 (0.88) Deep
0.068 (1.72) Wide
0.671
(17.06)
0.240 (6.09)
4
8928K478
1PST Momentary
(Solder Lug)
Keyway
0.035 (0.88) Deep
0.068 (1.72) Wide
0.664
(16.86)
4
4
8396K107 and K108
1PST Maintained
(Screw Terminals)
Keyway
0.035 (0.88) Deep
0.068 (1.72) Wide
4
4
4
4
Toggle Switches
1.093
(27.78)
0.085 (2.15)
Dia. Hole
#5/40 x 5/32 Lg.
Binding Head Screw
“A”
Lever
Dim.
“B”
Bushing
Dim.
“C”
Overall
Dim.
“D”
Throw
Dim.
“A”
Lever
Dim.
“B”
Bushing
Dim.
“C”
Overall
Dim.
“D”
Throw
Dim.
“A”
Lever
Dim.
“B”
Bushing
Dim.
“C”
Overall
Dim.
“D”
Throw
Dim.
0.500
(12.70)
0.344
(8.74)
1.531
(38.89)
29-1/2°
0.500
(12.70)
0.344
(8.74)
1.531
(38.89)
29-1/2°
0.500
(12.70)
0.344
(8.74)
1.980
(50.29)
29-1/2°
0.500
(12.70)
0.469
(11.91)
1.656
(42.06)
25-1/2°
0.500
(12.70)
0.469
(11.91)
1.656
(42.06)
25-1/2°
0.500
(12.70)
0.469
(11.91)
1.656
(42.06)
25-1/2°
4
4
4
4
4
4
4
4
4
4
4
4
4
V11-T4-22
Toggle Switches
8370 and 8373K107 and
K108
2PST/2PDT Maintained
(Solder Lug)
8371 and 8374K107 and
K108
1PST Maintained
(Wire Lead)
8373 and 8375K107 and
K108
(Screw Terminals)
4
Keyway
0.035 (0.88) Deep
0.068 (1.72) Wide
4
Keyway
0.035 (0.88) Deep
0.068 (1.72) Wide
Keyway
0.035 (0.88) Deep
0.068 (1.72) Wide
0.687
(17.46)
0.245 (6.22)
Dia.
0.239 (6.07)
4
4
1.156
(29.37)
1.656 (42.07)
1.156
(29.36)
0.245 (6.22)
Dia.
0.239 (6.07)
4
0.687
(17.46)
0.687
(17.46)
1.156
(29.36)
4.5
4
4
These Terminals Omitted on
Single-Throw Switches
D
D
15/32 Dia.−
32 Thds.
15/32 Dia.32 Thds.
D
A
B
B
C
0.640
(16.27)
4
0.245 (6.22)
Dia.
0.239 (6.07)
A
4
C
15/32 Dia.−
32 Thds.
1.080 (27.43)
B C
0.873 (22.17)
0.830 (21.08)
1.000 (25.40)
0.090 (2.28)
0.085 (2.15)
Dia. Hole
0.281
Double-Throw (7.14)
Two Solder Lugs
Omitted for
Single-Throw
4
A
4
0.640
(16.27)
4
1.093
(27.78)
#5/40 x 5/32 Lg.
Binding Head Screw
4
0.343
(8.73)
4
Single-Throw
“A”
Lever
Dim.
“B”
Bushing
Dim.
“C”
Overall
Dim.
“D”
Throw
Dim.
“A”
Lever
Dim.
“B”
Bushing
Dim.
“C”
Overall
Dim.
“D”
Throw
Dim.
“A”
Lever
Dim.
“B”
Bushing
Dim.
“C”
Overall
Dim.
“D”
Throw
Dim.
0.500
(12.70)
0.344
(8.74)
1.694
(43.03)
29-1/2°
0.500
(12.70)
0.344
(8.74)
1.484
(37.69)
29-1/2°
0.500
(12.70)
0.344
(8.74)
1.484
(37.69)
29-1/2°
0.500
(12.70)
0.469
(11.91)
1.820
(46.23)
25-1/2°
0.500
(12.70)
0.469
(11.91)
1.515
(38.48)
25-1/2°
0.500
(12.70)
0.469
(11.91)
1.609
(40.87)
25-1/2°
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
V11-T4-23
很抱歉,暂时无法提供与“8282K114”相匹配的价格&库存,您可以联系我们找货
