BAF-5
BAF-5
    EATON(伊顿)
    5AG,10 x 38.10mm
    FUSE CARTRIDGE 5A 250VAC 5AG
BAF-5 数据手册
Effective December 2015 Supersedes April 2014 Technical Data 2011 BUSSMANN SERIES BAF 13⁄32˝ x 1-1/2˝ 250Vac fast-acting supplemental fuses Catalog symbol – color code Dimensions - in (mm): BAF Green (250Vac max, 1/4 to 30A) • •  Description: 0.41" (10.3) Fast-acting, supplemental fuse. For superior protection, Eaton recommends upgrading to Bussmann series Low-Peak™ Class CC fuses. See data sheet No. 1023. 1.5" (38.1) Features: • Specifications: Color coded green for 250Vac maximum voltage rating • Fiber tube construction Ratings • Nickel-plated endcaps. 250Vac 1/4 to 30A Fuse amp range Interrupting rating at system voltage Agency information 250 Vac UL® 125 Vac CSA® 1/4 to 1 35A 10kA – X 1-1/2 to 2-1/2 100A 10kA – X 3 100A 10kA X X 4 to 10 200A 10kA X X 12 to 15 750A 10kA X X 20 to 30 200A 10kA – – Agency information • CE • UL Listed, Std. 248-14, 250Vac (3 to 15A) Guide JDYX, File E19180 • CSA Certified, 250Vac (1/4 to 15A) Class 1422-01, File 53787 Catalog numbers (amps BAF-1⁄4 BAF-1⁄2 BAF-6⁄10 BAF-8⁄10 BAF-1 BAF-1-1⁄2 BAF-1-8⁄10 BAF-2 BAF-2-1⁄2 BAF-3 BAF-4 BAF-5 BAF-6 BAF-6-1⁄4 BAF-7 BAF-8 BAF-9 BAF-10 Carton quantity Amps 1/4 to 30 Qty. 10 BAF-12 BAF-15 BAF-20 BAF-25 BAF-30 Typical applications • General purpose circuits • Lighting circuit protection • Meter circuits Recommended fuse blocks/fuse holders Catalog Description symbol Blocks BMM 1-, 2- and 3-pole modular blocks with optional covers Data sheet No. 10235 DIN-Rail holders / switches CCP-_-30M 1-, 2- and 3-pole switch 1157 CHM 1-, 2- and 3-pole 3185 Optima NG 3-pole protection module 1109 Optima 3-pole holder 1102 Optima 3-pole holder + switch 1103 Panel mount holders HPM and HPM-D 1-pole holder 2112 HPC-D 1-pole holder 2109 HPS2 2-pole holder 2140 HPF, HPF-C and HPF-WT 1-pole holder 2114 HPS 1-pole holder 2113 HPG and HPD 1-pole holder 2108 HEB 1-pole holder 2127 HEX 2-pole holder 2126 PCB fuseclips 2132 In-line holders Fuseclips 1A3400, 5956 and 5960 Fuse covers CVR(I)-CCM(-QC) Finger-safe fuse cover 10235 Technical Data 2011 BAF 250Vac fast-acting supplemental fuses Effective December 2015 30 15 20 10 100 3 1 Time-current characteristic curves – total clear: Amp rating Amp Rating Time in seconds Time in Seconds 10 1 0.1 Current in Amps 200 Current in amps 100 10 1 0.4 0.01 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2015 Eaton All Rights Reserved Printed in USA Publication No. 1011 – BU-SB14288 December 2015 Eaton, Bussmann and Low-Peak are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Follow us on social media to get the latest product and support information.
BAF-5 价格&库存
很抱歉,暂时无法提供与“BAF-5”相匹配的价格&库存,您可以联系我们找货
