BK/AGC-3-1/2-R
BK/AGC-3-1/2-R
    EATON(伊顿)
    3AB,3AG,1/4" x 1-1/4"
    FUSE GLASS 3.5A 250VAC 3AB 3AG
BK/AGC-3-1/2-R 数据手册
1/4" x 1-1/4" Fuses AGC Series, Fast Acting, Glass Tube Description • Fast-acting, glass tube • Optional axial leads available • 1/4 x 1-1/4 (6.3mm x 32mm) physical size • Glass tube, nickel-plated brass endcap construction • UL Listed product meets standard 248-14 RoHS 2002/95/EC ELECTRICAL CHARACTERISTICS % of Amp Rating Opening Time 100% None 135% 60 Minutes Maximum 200% 120 Seconds Maximum Dimensions (mm⁄in) Drawing Not to Scale Agency Information • UL Listed Card: AGC 1/500-10 • UL Recognition Card: AGC 11-45 • CSA Component Acceptance Card (Class No. 1422 30) • CSA Certification Card (Class No. 1422 01) Environmental Data • Shock: 1/100A thru 3/4A – MIL-STD-202, Method 213, Test Condition I; 1A thru 30A – MIL-STD-202, Method 207, (HI Shock) • Vibration: 1/100A thru 30A – MIL-STD-202, Method 204, Test Condition A (Except 5g, 500HZ) Ordering • Specify packaging, product, and option code Product Code AGC-1/20 AGC-1/16 AGC-1/10 AGC-1/8 AGC-3/16 AGC-2/10 AGC-1/4 AGC-3/10 AGC-3/8 AGC-1/2 AGC-3/4 AGC-1 AGC-1-1/4 AGC-1-1/2 AGC-2 AGC-2-1/4 AGC-2-1/2 AGC-3 AGC-4 AGC-5 AGC-6 AGC-7 AGC-7-1/2 AGC-8 AGC-9 AGC-10 AGC-12 AGC-14 AGC-15 AGC-20 AGC-25 AGC-30 AGC-35 AGC-40 Voltage Rating AC 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 32V 32V 32V 32V 32V 32V 32V 32V SPECIFICATIONS 250V 35A 35A 35A 35A 35A 35A 35A 35A 35A 35A 35A 35A 100A 100A 100A 100A 100A 100A 200A 200A 200A 200A 200A 200A 200A 200A - AC Interrupting Rating 125V 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A - 32V 1000A 1000A 1000A 1000A 1000A 1000A 70A 80A Typical DC Cold Resistance** (ohms) 4.500 29.000 12.565 6.800 4.900 3.360 2.300 1.670 1.203 0.615 0.312 0.190 0.145 0.115 0.078 0.067 0.057 0.045 0.030 0.024 0.020 0.017 0.0146 0.014 0.012 0.008 0.0070 0.0062 0.006 0.004 0.003 0.002 0.0014 0.0019 ** DC Cold Resistance (Measured at ≤10% of rated current) † Typical Melting I2t (A2Sec) (I2t was measured at listed interrupting rating and rated voltage.) ‡ Typical Voltage Drop (Voltage drop was measured at 25°C ambient temperature at rated current) Typical Melting I2t† AC 0.00773 0.000181 0.000787 0.00131 0.00637 0.00435 0.0148 0.0208 0.0321 0.269 0.815 1.615 0.018 0.0149 0.00509 0.00588 0.00879 0.0167 0.0305 0.045 0.071 0.105 0.152 0.21 0.492 0.566 1.438 2.109 3.807 - Typical Voltage Drop‡ 0.67 10.41 6.00 4.67 4.12 4.51 0.89 2.88 4.59 0.59 0.37 0.31 0.35 0.27 0.28 0.26 0.31 0.25 0.22 0.23 0.23 0.23 0.19 0.18 0.20 0.14 0.12 0.11 0.12 - 1/4" x 1-1/4" Fuses AGC Series, Fast Acting, Glass Tube TIME CURRENT CURVE 1-1/2 2 2-1/2 3 4 3/4 1 2/10 1/4 3/10 3/8 1/2 1/10 1/8 TIME IN SECONDS TIME IN SECONDS 1/16 CURRENT IN AMPERES CURRENT IN AMPERES PACKAGING CODE Packaging Code BK BK1 BK8 Description 100 pieces of fuses packed into a cardboard carton with flaps folded 1,000 pieces of fuses packed into a cardboard carton with flaps folded 8,000 pieces of fuses packed into a cardboard carton with flaps folded Option Code B V -R Description Board Washable - Hermetically sealed to withstand aqueous cleaning Axial leads - copper tinned wire with nickel plated brass overcaps RoHS compliant version OPTION CODE Visit us on the web at: www.cooperbussmann.com OC-2543 3/07 © Cooper Electronic Technologies 2007 North America Cooper Electronic Technologies Cooper Bussmann 1225 Broken Sound Parkway NW P.O. Box 14460 Suite F St. Louis, MO 63178-4460 Boca Raton, FL 33487-3533 Tel: 1-636-394-2877 Tel: 1-561-998-4100 Fax: 1-800-544-2570 Fax: 1-561-241-6640 Toll Free: 1-888-414-2645 Europe Cooper Electronic Technologies Cooper Electronic Technologies Cooper (UK) Limited Avda. Santa Eulalia, 290 Burton-on-the-Wolds 08223 Leicestershire • LE12 5TH UK Terrassa, (Barcelona), Spain Tel: +44 (0) 1509 882 737 Tel: +34 937 362 812 Fax: +44 (0) 1509 882 786 +34 937 362 813 Fax: +34 937 362 719 Asia Pacific Cooper Electronic Technologies 1 Jalan Kilang Timor #06-01 Pacific Tech Centre Singapore 159303 Tel: +65 278 6151 Fax: +65 270 4160
BK/AGC-3-1/2-R 价格&库存
很抱歉,暂时无法提供与“BK/AGC-3-1/2-R”相匹配的价格&库存,您可以联系我们找货
BK/AGC-3-1/2-R
    • 1+11.98366
    • 10+9.27624
    • 50+9.00905
    • 100+8.64866
    • 300+8.64244
    • 500+8.51817
    库存:2644
    BK/AGC-3-1/2-R
    • 100+7.56897
    库存:191
