BK/MDA-6-R
BK/MDA-6-R
    EATON(伊顿)
    D6.35xL31.75mm
    一次性保险丝(熔断) 6A 125V
BK/MDA-6-R 数据手册
Effective November 2023 Supersedes November 2021 Technical Data 2002 MDA 1/4” x 1-1/4” time delay ceramic fuse Applications Primary circuit protection: Photo is representative Product features • LED and general lighting • LED/LCD televisions • Appliances and white goods • Printers and peripherals • Test equipment • Uninterruptible power supplies (UPS) • Ceramic tube time delay fuse Environmental compliance • 250 Vac/125 Vdc, 0.25 A to 30 A • Compact 3AB footprint: ¼” x 1 ¼” (6.3 x 32 mm) HF FREE • Cartridge and axial lead versions available • Fuse accessories (cartridge version): 1Axxxx HBH-I/ HBV-I HTB HK HKP HMR HGA HTJ HRK HHB HFA HHK HHN HFB HHJ S-4000 Agency information • UL Listed Card: MDA 1/4 A - 20 A (Guide JDYX, File E19180) • UL Recognized Card: MDA 25 A - 30 A (Guide JDYX2, File E19180) • CSA Certification Card: MDA 1/4 A - 20 A (Class No. 1422-01) • CSA Component Acceptance: MDA 25 A 30 A (Class No. 1422-30) HALOGEN Pb Ordering part number BK-MDA-BV-30-R Packaging prefix Family name Option code Ampere rating RoHS compliance Packaging prefix BlankMDA-XXX-R: 5 pieces in tin tray. MDA-V-XXX-R, MDA-BV-XXX-R : 4 pieces in tin tray. BKMDA-XXX-R, MDA-V-XXX-R, MDA-BV-XXX-R: 100 pieces in a box. TRMDA-V-XXX-R: 500 pieces on reel. Option code -B Board washable -V Axial leads MDA 1/4” x 1-1/4” time delay ceramic fuse  Technical Data 2002 Effective November 2023 Electrical characteristics Rating % Amp rating Opening time 250 mA to 30 A 100% 4 hours 250 mA to 30 A 135% 60 minutes maximum 250 mA to 30 A 200% 120 seconds maximum Product specifications Part number Current rating (A) Voltage rating (Vac) (Vdc) Interrupting rating @ rated voltage1 Typical resistance2 (mΩ) Typical voltage drop3 (mV) Typical melting4 I2t (A2sec) MDA-1/4-R 0.25 250 - 200 A @ 250 Vac, 10000 A @ 125 Vac 9100 2900 0.28 MDA-1/2-R 0.50 250 - 200 A @ 250 Vac, 10000 A @ 125 Vac 2600 1650 1.2 MDA-3/4-R 0.75 250 - 200 A @ 250 Vac, 10000 A @ 125 Vac 520 495 0.42 MDA-1-R 1.0 250 - 200 A @ 250 Vac, 10000 A @ 125 Vac 380 470 0.90 MDA-1-1/2-R 1.5 250 - 200 A @ 250 Vac, 10000 A @ 125 Vac 190 370 3.4 MDA-2-R 2.0 250 - 200 A @ 250 Vac, 10000 A @ 125 Vac 120 295 8.8 MDA-2-1/2-R 2.5 250 125 200 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc 66 246 7.2 MDA-3-R 3.0 250 125 200 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc 48 215 15.9 31 176 37.2 MDA-4-R 4.0 250 125 200 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc MDA-5-R 5.0 250 125 200 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc 23 173 65 18 166 98.1 MDA-6-R 6.0 250 125 200 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc MDA-7-R 7.0 250 125 200 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc 15 158 135 13 162 188 MDA-8-R 8.0 250 125 200 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc MDA-10-R 10 250 125 200 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc 9.5 142 332 125 750 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc 7.6 128 125.2 5.7 107 336.8 MDA-12-R 12 250 MDA-15-R 15 250 125 750 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc MDA-20-R 20 250 125 1500 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc 4.1 95 483.5 3.1 105 734.7 2.5 110 1096.7 MDA-25-R 25 250 125 1500 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc MDA-30-R 30 250 125 1500 A @ 250 Vac, 10000 A @ 125 Vac 10000 A @ 125 Vdc 1. Interrupting ratings measured at 70% ~ 80% power factor on AC, (20 A and 30 A, 90% - 100% ower factor on AC). 2. Typical resistance measured at 12 A, I2t measured at interrupting rating and rated voltage) 2 www.eaton.com/electronics Technical Data 2002 MDA 1/4” x 1-1/4” time delay ceramic fuse Effective November 2023  Dimensions- mm Drawing not to scale Cartridge Dimensions Size A 31.75 ± 0.79 B 6.35 ± 0.1 G 4.8 ref for 10 A and below 6.48 ref for above 10 A Axial lead Dimensions Size C 32.82 ± 0.79 D 38.1mm ref E 6.76 ref F 0.81 ± 0.05 for 15 A and below 1.02 ± 0.05 for 20 A and above General specifications Operating temperature: -55 °C to +125 °C with proper derating factor applied. Mechanical shock test 1/4 A to 10 A: MIL-STD 202 method 213. Condition C Mechanical shock test 12 A to 30 A: MIL-STD 202G method 213. Condition J Vibration test 1/4 A to 30 A: MIL-STD-202 method 204, test condition C Packaging information Packaging prefix Description Blank MDA-XXX-R: 5 pieces in tin tray. MDA-V-XXX-R, MDA-BV-XXX-R: 4 pieces in tin tray. BK- MDA-XXX-R, MDA-V-XXX-R, MDP-BV-XXX-R: 100 pieces in a box. TR- MDA-V-XXX-R: 500 pieces on reel. www.eaton.com/electronics 3 MDA 1/4” x 1-1/4” time delay ceramic fuse  Technical Data 2002 Effective November 2023 Temperature derating curve 120% Derating factor 110% 100% 90% 80% 70% 60% -80 -60 -40 -20 0 20 40 60 80 100 120 140 Temperature (°C) Current vs. time curve Current vs. time curve 1.00E+03 1.00E+05 12A 1/4 A 1.00E+04 1/2A 1.00E+02 15A 3/4A 1.00E+02 1A 1.00E+01 1-1/2A 2A 1.00E+00 2-1/2A 1.00E-01 3A 1.00E-02 4A 1.00E-03 5A 1.00E-04 6A 1.00E+01 Time (seconds) Time (seconds) 1.00E+03 20A 1.00E+00 25A 1.00E-01 30A 1.00E-02 7A 1.00E-05 8A 1.00E-06 1.00E-03 10A 1.00E-07 0.1 1 10 Current (A) 4 www.eaton.com/electronics 100 1000 1.00E-04 1 10 100 Current (A) 1000 Technical Data 2002 MDA 1/4” x 1-1/4” time delay ceramic fuse Effective November 2023  I2t vs. current curve I2t vs current curve 1.00E+07 1.00E+06 1/4 A 1.00E+06 12A 1/2A 3/4A 1.00E+05 1A 15A 1.00E+05 1-1/2A 1.00E+04 2A 2-1/2A 3A 1.00E+02 20A I2t (A2s) I2t (A2s) 1.00E+03 1.00E+04 25A 4A 1.00E+01 5A 30A 6A 1.00E+00 1.00E+03 7A 8A 1.00E-01 10A 1.00E-02 0.1 1 10 100 1.00E+02 1000 1 10 Current (A) 100 1000 Current (A) I2t vs. time curve I2t vs time curve 1.00E+06 1.00E+07 1/4 A 12A 1/2A 1.00E+06 3/4A 15A 1.00E+05 1A 1.00E+05 1-1/2A 20A 2A 2-1/2A 1.00E+03 3A I2t (A2s) I2t (A2s) 1.00E+04 25A 1.00E+04 30A 4A 1.00E+02 5A 6A 1.00E+01 1.00E+03 7A 1.00E+00 8A 10A 1.00E-01 0.000001 0.001 1 Time (seconds) 1000 1000000 1.00E+02 0.0001 0.001 0.01 0.1 1 10 100 1000 Time (seconds) www.eaton.com/electronics 5 Technical Data 2002 MDA 1/4” x 1-1/4” time delay ceramic fuse  Effective November 2023 Wave solder profile--(axial lead version only) tp Temperature Tp First Wave Second Wave Tsmax Tstyp Tsmin Preheat area Cool down area Time Reference EN 61760-1:2006 Profile feature Standard SnPb solder Lead (Pb) free solder • Temperature min. (Tsmin) 100 °C 100 °C • Temperature typ. (Tstyp) 120 °C 120 °C • Temperature max. (Tsmax) 130 °C 130 °C • Time (Tsmin to Tsmax) (ts) 70 seconds 70 seconds D preheat to max Temperature 150 °C max. 150 °C max. Peak temperature (TP)* 235 °C – 260 °C 250 °C – 260 °C Time at peak temperature (tp) 10 seconds max 5 seconds max each wave 10 seconds max 5 seconds max each wave Ramp-down rate ~ 2 K/s min ~3.5 K/s typ ~5 K/s max ~ 2 K/s min ~3.5 K/s typ ~5 K/s max Time 25 °C to 25 °C 4 minutes 4 minutes Preheat Manual solder +350 °C (4-5 seconds by soldering iron), generally manual/hand soldering is not recommended Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2023 Eaton All Rights Reserved Printed in USA Publication No. 2002 PCN23025 November 2023 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
BK/MDA-6-R 价格&库存
很抱歉,暂时无法提供与“BK/MDA-6-R”相匹配的价格&库存,您可以联系我们找货
BK/MDA-6-R
    BK/MDA-6-R
      • 1+2.35743
      • 200+0.91239
      • 500+0.88031
      • 1000+0.86444
