BK/PCC-2-R
BK/PCC-2-R
    EATON(伊顿)
    Radial,Box
    FUSE BOARD MNT 2A 250VAC 450VDC
BK/PCC-2-R 数据手册
Subminiature, Radial Leaded, Fast-Acting Fuses PC-Tron Series Part Number System/Ordering - An Option Code Must Be Selected Radial Leaded Device • Specify packaging code prefix, product and option code suffix BK PCB- 1/2 -R Packaging Code Prefix Fuse Series Amp Rating Option Code Suffix DC Application The PC-Tron subminiature fuse is UL Recognized for DC supplementary overcurrent protection to provide individual protection for components or internal circuits in equipment. Suitability for a specific application is dependent on time constants and capacitance values. It is the responsibility of the customer to evaluate the information provided for applicability to their particular application. Description • • • • • Radial leaded, fast-acting thru-hole fuse Ideal for high voltage DC applications Board washable Optional mounting socket available (PCS) Available in different lead configurations PCS Mounting Socket (RoHS compliant) • Available as option. Specify catalog number BK/PCS (100 in a polybag) and short fuse lead length — PCC or PCE AC Time-Current Characteristics % of Amp Rating Opening Time 100% 4 hours minimum 200% 10 second maximum 0.030" (2.41mm) 0.300" (7.62mm) Agency Information 0.200" (5.08mm) • UL Recognized: E19180 • CSA: 42731 0.095" (2.41mm) 0.290" (7.37mm) 0.12" 0.010" (3.05mm 0.25mm) Specifications Catalog Number PCB-1/2, 3/4, 1, 1-1/2, 2, 2-1/2 PCB-3 PCB-4 PCC-1/2, 3/4, 1, 1-1/2, 2, 2-1/2 PCC-3 PCC-4 PCD-5 PCE-5 PCF-1/2, 3/4, 1, 1-1/2, 2, 2-1/2 PCF-3 PCG-5 PCH-1/2, 3/4, 1, 1-1/2, 2, 2-1/2 PCH-3 PCH-4 PCI-5 Lead Length Full - 0.750" (straight) Full - 0.750" (straight) Full - 0.750” (straight) Short 0.100" (straight) Short 0.100" (straight) Short 0.100" (straight) Full - 0.750" (straight) Short 0.100" (straight) 0.475" 0.475" 0.475" 0.125" 0.125" 0.125" 0.125" AC Voltage Rating 250V 250V 250V 250V 125V 125V 250V 250V 125V 250V 250V 125V AC Interrupting 50A@250V - 10kA@125V 50A@250V 50A@250V - 10kA@125V 50A@250V - 10kA@125V 10kA@125V 10kA@125V 50A@250V - 10kA@125V 50A@250V - 10kA@125V 10kA@125V 50A@250V - 10kA@125V 50A@250V - 10kA@125V 10kA@125V DC Voltage Rating 450V 450V 450V 450V 450V 450V 400V 400V 450V 450V 400V 450V 450V 450V 400V DC Interrupting Min. Max. 300 5900A 300 4400A 300 2500A 300 5900A 300 4400A 300 2500A 300 1000A 300 1000A 300 5900A 300 4400A 300 1000A 300 5900A 300 4400A 300 2500A 300 1000A Device designed to carry rated current for four hours minimum. An operating current of 80% or less of rated current is recommended, with further derating required at elevated ambient temperatures. 0211 BU-SB11083 Page 1 of 2 Data Sheet 2034 Dimensions - mm (±0.005”/0.13mm) 1.5 2 2.5 3 4 5 10 0.75 1 Standard Fuse (PCB, PCD) 0.5 Time-Current Characteristic Curves–Average Melt Amp Rating Time In Seconds 1 .1 Dimensional Data (PCH, PCI) .350" .184" (8.89mm) (4.67mm) .345" .020" .200" + .008" (0.51mm + .127mm) .015" .075" (0.38mm) (1.91mm) (3.81mm) 125V Amp Rating 1 /2A 3 /4A 1A 1-1/2A 2A 2-1/2A 3A 5A .184" .345" R .15" Max. Total Clearing I2t (Amps2 Sec.) Dimensional Data (PCF, PCG) BUSS PCG 200 Current In Amps (0.51mm) .350" 100 .01 10 (0.64mm) 250V 1 .0.25" (8.76mm) .4 BUSS PC_ 0.25" 125Vac 50A 0.006 0.016 0.020 0.090 0.200 0.300 0.750 5.0 1,000A 0.006 0.016 0.020 0.090 0.200 0.300 0.750 5.0 10,000A 0.006 0.016 0.020 0.090 0.200 0.300 0.750 5.0 250Vac 35A & 50A 0.006 0.016 0.020 0.090 0.200 0.300 0.750 — Note: Power Factor > 0.90. .500" MIN. .020" .015" .400" REF. Option Code Packaging Code Packaging Code Prefix Blank BK TR* Description/Quantity 5 fuses 100 fuses in a carton 500 fuses on Tape-and-Reel Option Code Suffix -R -SD Description RoHS Compliant Solder Dipped * Only for PCB and PCD The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Cooper Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. © 2011 Cooper Bussmann www.cooperbussmann.com 0211 BU-SB11083 Page 2 of 2 Data Sheet 2034
BK/PCC-2-R 价格&库存
很抱歉,暂时无法提供与“BK/PCC-2-R”相匹配的价格&库存,您可以联系我们找货
BK/PCC-2-R
    • 30+36.79873
    • 75+35.23735
    • 100+32.32474
