C22-D-G-K10-P5
C22-D-G-K10-P5
    EATON(伊顿)
    EATON CUTLER HAMMER - C22-D-G-K10-P5 - PB SWITCH, SPST-NO, 4A, 24VAC, CONNECTOR
C22-D-G-K10-P5 数据手册
DATASHEET - C22-D-G-K10-P5 Pushbutton, flat; momentary; green; 1 N/O; with cable 1m and M12A plug Delivery program Part no.  Catalog No.      C22-D-G-K10-P5 181041 Product range     RMQ compact solution Basic function     Pushbutton actuators Single unit/Complete unit     Complete unit Design     Flat       momentary Connection type     Cable (black) with M12A plug, 4 pole Cable Length   m 1 Button plate       button plate     green Button plate           Blank Name     None Degree of Protection     IP66, IP67, IP69K (front) IP65 (on rear) Front ring     Bezel: titanium Connection to SmartWire-DT     no Contacts       1 N/O     Contact sequence N/O = Normally open     Contact travel■ = Contact closed□ = Contact open         Standards     03/19/2018 Eaton 181041 ED2018 V42.0 EN Contact diagram   Technical data General IEC/EN 60947-5-1 1/4 VDE 0660 Certifications   Lifespan, mechanical Operations Operating frequency Operations/h   ≦ 3600 Actuating force   n ≦5 Plug tightening torque   N/m 1 Tightening torque Threaded ring   Nm 2 Climatic proofing     Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60068-2-30 Degree of Protection     IP66, IP67, IP69K (front) IP65 (on rear) Mounting position     As required Mechanical shock resistance, shock duration 11 ms   g > 30 Rated impulse withstand voltage Uimp V AC 800 Rated insulation voltage Ui V 30 Overvoltage category/pollution degree     III/3 Control circuit reliability       HF   N/O: 1 failure per 17 × 10 switching operations, statistically determined       gG/gL A 4 Rated conditional short-circuit current Iq kA 1 Rated operational current Ie A         Ie A 4       Ie A 3       Design     M12A Cable Length   m 1 Material characteristic     PUR Diameter ⌀ mm 4.7       Operating ambient temperature min.   °C -25 Operating ambient temperature max.   °C 70 Contacts At 17 V DC/7 mA Max. short-circuit protective device Fuse Switching capacity AC-15 24 V DC-13 24 V Cable characteristics Design verification as per IEC/EN 61439 Technical data for design verification   x 10 CE, UL, CSA 6 >5 6 Technical data ETIM 6.0 Low-voltage industrial components (EG000017) / Push button, complete (EC001028) Electric engineering, automation, process control engineering / Low-voltage switch technology / Command and alarm device / Push-button actuator, complete unit (ecl@ss8.1-27-37-12-28 [AKF046011]) Number of command positions     1 Colour button     Green Construction type lens     Round Hole diameter   mm 22 Width opening   mm 0 Height meter opening   mm 0 Degree of protection (IP)     Other Type of button     Flat Suitable for illumination     No Switching function latching     No Spring-return     Yes Supply voltage lamp   V 0 Number of contacts as normally open contact     1 03/19/2018 Eaton 181041 ED2018 V42.0 EN 2/4 Number of contacts as normally closed contact     0 Number of contacts as change-over contact     0 Type of electric connection     Other With front ring     Yes Material front ring     Plastic Colour front ring     Grey Product Standards     IEC/EN 60947-5-1; UL 508; CAN/CSA-C22.2 No. 14-05 und 94-M91; CE marking UL File No.     E29184 UL Category Control No.     NKCR CSA File No.     165628 CSA Class No.     321103 North America Certification     UL listed, CSA certified Degree of Protection     1,3R,4X,12,13 Approvals Dimensions Static: Fixed routing 03/19/2018 Eaton 181041 ED2018 V42.0 EN 3/4 Flexible use Assets (Links) Declaration of Conformity 00002596 Additional product information (links) IL047016ZU RMQ compact solution IL047016ZU RMQ compact solution 03/19/2018 ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL047016ZU2017_01.pdf Eaton Industries GmbH http://www.eaton.eu © 03/2018 by Eaton Industries GmbH Eaton 181041 ED2018 V42.0 EN 4/4
C22-D-G-K10-P5 价格&库存
很抱歉,暂时无法提供与“C22-D-G-K10-P5”相匹配的价格&库存,您可以联系我们找货
