C22-WRS-MS1-K11-P62
C22-WRS-MS1-K11-P62
    EATON(伊顿)
    EATON CUTLER HAMMER - C22-WRS-MS1-K11-P62 - KEYLOCK SW, SPST-NO/NC, 2 POS, 4A, 24VAC
C22-WRS-MS1-K11-P62 数据手册
DATASHEET - C22-WRS-MS1-K11-P62 Key-operated actuator, classic, maintained, 2 positions, MS1, 1 N/C, 1 N/ O, cable (black) with non-terminated end, 4 pole, 1 m Delivery program Part no.  Catalog No.      C22-WRS-MS1-K11-P62 186260 Product range     RMQ compact solution Basic function     Key-operated buttons Single unit/Complete unit     Complete unit       maintained Function:           Connection type     Cable (black) with non-terminated end, 4 pole Cable Length   m 1       Not suitable for master key systems       2 positions Lock mechanism     MS1 Key withdrawable in position             I       0 Degree of Protection     IP66 (front) IP65 (on rear) Front ring     Bezel: titanium Connection to SmartWire-DT     no Contacts       N/C = Normally closed     N/O = Normally open     Notes             mm   4.65 Maximum travel mm   5.7 Minimum force for positive opening 20   Actuator travel and actuation force as per DIN EN 60947-5-1, K.5.4.1 60° 1 NC 1 N/O = safety function, by positive opening to IEC/EN 60947-5-1 N   Contact sequence     Contact travel■ = Contact closed□ = Contact open         Positive opening (ZW)     yes Information about equipment supplied     With 1 key 03/19/2018 Eaton 186260 ED2018 V42.0 EN Contact diagram   1/3 Technical data General Standards     IEC/EN 60947-5-1 VDE 0660 Certifications     CE, UL, CSA Operating frequency Operations/h   ≦ 100 Operating torque   Nm ≦ 0.5 Tightening torque Threaded ring   Nm 2 Climatic proofing     Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60068-2-30 Degree of Protection     IP66 (front) IP65 (on rear) Mounting position     As required Mechanical shock resistance, shock duration 11 ms   g > 30 Rated impulse withstand voltage Uimp V AC 800 Rated insulation voltage Ui V 30 Overvoltage category/pollution degree     III/3 Control circuit reliability       HF   N/O contact: statistically determined 1 failure per 17 × 106 operations       Contacts At 17 V DC/7 mA Max. short-circuit protective device Fuse 6 N/C contact: statistically determined 1 failure per 0.9 × 10 Operations gG/gL A 4 Rated conditional short-circuit current Iq kA 1 Rated operational current Ie A         Ie A 4       Ie A 3 Switching capacity AC-15 24 V DC-13 24 V Cable characteristics       Design     Cable end open Cable Length   m 1 Material characteristic     PUR Diameter ⌀ mm 4.7       Operating ambient temperature min.   °C -25 Operating ambient temperature max.   °C 70 Design verification as per IEC/EN 61439 Technical data for design verification Technical data ETIM 6.0 Low-voltage industrial components (EG000017) / Selector switch, complete (EC001029) Electric engineering, automation, process control engineering / Low-voltage switch technology / Command and alarm device / Selector switch, complete unit (ecl@ss8.1-27-37-12-43 [ACN984008]) Number of switch positions     2 Type of control element     Key Suitable for illumination     No With lamp     No Colour button     Black Hole diameter   mm 22 Width opening   mm 0 Height meter opening   mm 0 Switching function latching     Yes Spring-return     No Degree of protection (IP)     IP66 Supply voltage   V 0-0 03/19/2018 Eaton 186260 ED2018 V42.0 EN 2/3 Number of contacts as normally open contact     1 Number of contacts as normally closed contact     1 Number of contacts as change-over contact     0 Type of electric connection     Other With front ring     Yes Material front ring     Plastic Colour front ring     Other Dimensions Assets (Links) Declaration of Conformity 00002596 Additional product information (links) IL047016ZU RMQ compact solution IL047016ZU RMQ compact solution 03/19/2018 ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL047016ZU2017_01.pdf Eaton Industries GmbH http://www.eaton.eu © 03/2018 by Eaton Industries GmbH Eaton 186260 ED2018 V42.0 EN 3/3
C22-WRS-MS1-K11-P62 价格&库存
很抱歉,暂时无法提供与“C22-WRS-MS1-K11-P62”相匹配的价格&库存,您可以联系我们找货
