CHSA3920R0005F
CHSA3920R0005F
    EATON(伊顿)
    EATON BUSSMANN - CHSA3920R0005F - SMD Current Sense Resistor, 500 µohm, CHSA Series, 3920 [10052 Met...
CHSA3920R0005F 数据手册
Technical Data ELX1223 Effective August 2022 CHSA SMD current sensing resistor-metal shunt Applications Product features • Electronic power steering (EPS) modules • DC/DC converters, including automotive • Automotive on-board chargers (OBC) • Brushless DC (BLDC) motor control Environmental compliance • Ultra low and stable resistance • 2512 (6432 metric) to 5930 (15076 metric) package • High power ratings, up to 15 W • AEC-Q200 compliant • Moisture sensitivity level (MSL): 1 HALOGEN Pb HF FREE Table 1.  Part numbering configuration scheme CHS @ xxxx Rxxxx F Family name CHS Grade option Resistance tolerance option A = automotive grade F = ±1% Footprint EIA option 2512, 3920, 5930 Resistance option Rxxxx = xxx.x mΩ ex: R0002 = 0.2 mΩ See electrical specification table for option details CHSA SMD current sensing resistor-metal shunt  Technical Data ELX1223 Effective August 2022 Mechanical parameters- Inches [mm] Construction Resistive Element Cu Terminal Family Size code L W C CHSA2512 2512 [6432] 0.248 ± 0.008 [6.30 ± 0.20] 0.122 ± 0.012 [3.10 ± 0.30] 0.047 ± 0.012 [1.20 ± 0.30] T CHSA3920 3920 [10052] 0.394 ± 0.012 [10.0 ± 0.30] 0.205 ± 0.016 [5.20 ± 0.40] 0.087 ± 0.008 [2.20 ± 0.20] CHSA5930 5930 [15076] 0.591 ± 0.012 [15.0 ± 0.30] 0.299 ± 0.016 [7.60 ± 0.40] 0.165 ± 0.016 [4.20 ± 0.40] See electrical specifications table for details Recommended PCB layout- mm Family a b L CHSA2512 3.4 1.8 3.4 CHSA3920 6.2 2.7 5.6 CHSA5930 8.75 5.2 5.6 1. The copper foil minimum thickness of PCB needs 3 oz. 2. PCB layout dimension tolerance is +/-0.1 mm. 3. The resistance will change slightly after soldered; it is dependent on PCB pad size deign and it’s necessary to consider the effect of the resistance increase or decrease. Part marking Family Resistance Value (mΩ) Marking Family Resistance Value (mΩ) Marking CHSA2512 0.2 R0002 1% CHSA5930 0.1 R0001 1% CHSA2512 0.3 0.3mR 1% CHSA5930 0.2 0.2mR 1% CHSA2512 0.5 0.5mR 1% CHSA5930 0.3 R0003 1% CHSA2512 1 R001 1% CHSA5930 0.5 0.5mR 1% CHSA2512 2 R002 1% CHSA5930 0.75 R00075 1% CHSA2512 3 R003 1% CHSA5930 1 R001 1% CHSA2512 4 R004 1% CHSA5930 2 R002 1% CHSA2512 5 R005 1% CHSA5930 3 R003 1% CHSA3920 0.2 R0002 1% CHSA3920 0.3 0.3mR 1% CHSA3920 0.5 0.5mR 1% CHSA3920 1 R001 1% CHSA3920 2 R002 1% CHSA3920 3 R003 1% CHSA3920 4 R004 1% CHSA3920 5 R005 F 2 www.eaton.com/electronics Technical Data ELX1223 CHSA SMD current sensing resistor-metal shunt  Effective August 2022  Electrical specifications Part number Size Grade option Resistance value mΩ (Part number code) Resistance tolerance (Part number code) Power (W) Dimension T (mm) ±0.1 mm TCR (ppm/°C) Operating temperature CHS@2512Rxxxx* 2512 (6432 metric) A 0.2 (0002) ±1% (F) 6 1.00 ±175 -55 °C to +170 °C CHS@2512Rxxxx* 2512 (6432 metric) A 0.3 (0003) ±1% (F) 6 1.00 ±175 -55 °C to +170 °C CHS@2512Rxxxx* 2512 (6432 metric) A 0.5 (0005) ±1% (F) 6 0.84 ±115 -55 °C to +170 °C CHS@2512Rxxxx* 2512 (6432 metric) A 1 (0010) ±1% (F) 5 0.42 ±100 -55 °C to +170 °C CHS@2512Rxxxx* 2512 (6432 metric) A 2 (0020) ±1% (F) 5 0.70 ±50 -55 °C to +170 °C CHS@2512Rxxxx* 2512 (6432 metric) A 3 (0030) ±1% (F) 4 0.47 ±50 -55 °C to +170 °C CHS@2512Rxxxx* 2512 (6432 metric) A 4 (0040) ±1% (F) 3 0.35 ±50 -55 °C to +170 °C CHS@2512Rxxxx* 2512 (6432 metric) A 5 (0050) ±1% (F) 3 0.28 ±50 -55 °C to +170 °C CHS@3920Rxxxx* 3920 (10052 metric) A 0.2 (0002) ±1% (F) 12 1.66 ±125 -55 °C to +170 °C CHS@3920Rxxxx* 3920 (10052 metric) A 0.3 (0003) ±1% (F) 10 1.42 ±150 -55 °C to +170 °C CHS@3920Rxxxx* 3920 (10052 metric) A 0.5 (0005) ±1% (F) 9 0.82 ±70 -55 °C to +170 °C CHS@3920Rxxxx* 3920 (10052 metric) A 1 (0010) ±1% (F) 8 0.41 ±50 -55 °C to +170 °C CHS@3920Rxxxx* 3920 (10052 metric) A 2 (0020) ±1% (F) 6 0.64 ±50 -55 °C to +170 °C CHS@3920Rxxxx* 3920 (10052 metric) A 3 (0030) ±1% (F) 5 0.43 ±50 -55 °C to +170 °C CHS@3920Rxxxx* 3920 (10052 metric) A 4 (0040) ±1% (F) 5 0.32 ±50 -55 °C to +170 °C CHS@3920Rxxxx* 3920 (10052 metric) A 5 (0050) ±1% (F) 5 0.26 ±50 -55 °C to +170 °C CHS@5390Rxxxx* 5390 (15076 metric) A 0.1 (0001) ±1% (F) 15 1.90 ±200 -55 °C to +170 °C CHS@5390Rxxxx* 5390 (15076 metric) A 0.2 (0002) ±1% (F) 15 1.42 ±100 -55 °C to +170 °C CHS@5390Rxxxx* 5390 (15076 metric) A 0.3 (0003) ±1% (F) 10 0.98 ±75 -55 °C to +170 °C CHS@5390Rxxxx* 5390 (15076 metric) A 0.5 (0005) ±1% (F) 10 0.56 ±75 -55 °C to +170 °C CHS@5390Rxxxx* 5390 (15076 metric) A 0.75 (0008) ±1% (F) 10 0.41 ±75 -55 °C to +170 °C CHS@5390Rxxxx* 5390 (15076 metric) A 1 (0010) ±1% (F) 9 0.90 ±50 -55 °C to +170 °C CHS@5390Rxxxx* 5390 (15076 metric) A 2 (0020) ±1% (F) 7 0.48 ±50 -55 °C to +170 °C CHS@5390Rxxxx* 5390 (15076 metric) A 3 (0030) ±1% (F) 7 0.32 ±50 -55 °C to +170 °C @= Enter grade option from table above (A=Automotive) Rxxxx = Enter resistance code option from table above xxxx= resistance code (xxx.x mΩ ex: R0002 = 0.2 mΩ, R0008 = 0.75 mΩ) *= Enter resistance tolerance code option from table above (F= ±1%) www.eaton.com/electronics 3 CHSA SMD current sensing resistor-metal shunt  Technical Data ELX1223 Effective August 2022 Packaging information- mm Supplied in tape and reel on a 13” diameter reel (EIA-481 compliant) Size Tape Quantity 2512 13 inch (330 mm) embossed 4K 3920 13 inch (330 mm) embossed 3K 5930 13 inch (330 mm) embossed 1.5K Tape carrier and dimensions Dimension 2512 3920 5930 E 1.75± 0.1 1.75 ± 0.1 1.75 ± 0.1 F 5.5 ± 0.05 7.5 ± 0.05 11.5 ± 0.05 P2 2.0 ± 0.1 2.0 ± 0.1 2.0 ± 0.1 D0 1.50 ± 0.1 1.50 ± 0.1 1.50 ± 0.1 P0 4.0 ± 0.1 4.0 ± 0.1 4.0 ± 0.1 W 12.0 ± 0.1 16.0 ± 0.1 24.0 ± 0.1 P1 8.0 ± 0.1 8.0 ± 0.1 12.0 ± 0.1 A 3.6 ± 0.2 5.7 ± 0.2 8.3 ± 0.2 B 6.7 ± 0.2 10.5 ± 0.2 15.6 ± 0.2 t 1.7 ± 0.15 2.25 ± 0.15 2.4 ± 0.15 Reel dimensions Family A B C D N W1 W2 W3 CHSA2512 330 ± 2.0 5.0 ± 0.5 13.0 ± 1.0 15.0 ± 1.0 100 ± 1.0 12.0 ± 1.0 16.0 ± 1.0 na CHSA3920 330 ± 2.0 5.0 ± 0.5 13.0 ± 1.0 15.0 ± 1.0 100 ± 1.0 16.0 ± 1.0 20.0 ± 1.0 na CHSA5930 330 ± 2.0 5.0 ± 0.5 13.0 ± 1.0 15.0 ± 1.0 100 ± 1.0 24.0 ± 1.0 28.0 ± 1.0 na 4 www.eaton.com/electronics CHSA SMD current sensing resistor-metal shunt  Technical Data ELX1223 Effective August 2022  General specifications Temperature coefficient of resistance: IEC60115-1 4.8, +25 to +125 °C Short time overload: IEC60115-1 4.13, 5 X rated power for 5 s High temperature exposure (storage): AEC-Q200-REV D-Test 3, MIL-STD202 Method 108, 1000 hours, +170 °C Temperature cycling: AEC-Q200-REV D-Test 4, JESD22 Method JA-104, 1000 Cycles (-55 °C to +125 °C) Moisture resistance: AEC-Q200-REV D-Test 6 , MIL-STD-202 Method 106, T=24 hours / Cycle ,10 Cycles, Notes: Steps 7a& 7b not required. Unpowered Biased humidity: AEC-Q200-REV D-Test 7, MIL-STD-202 Method 103, 1000 hours +85 °C/85% RH. Note: Specified conditions: 10% of operating power (not exceeding max working voltage). Operational life: AEC-Q200-REV D-Test 8, MIL-STD-202 Method 108, 1000 hours, +125 °C at rated derating power Resistance to solvents: AEC-Q200-REV D-Test 12, MIL-STD-202 Method 215, a: Isopropyl Alcohol : Mineral Spirits= 1 : 3, b: Terpene Defluxer (Bioact EC-7R) c: Deionized water : Propylene Glycol Monomethyl Ether : monoethanolamine = 42 : 1 : 1 Mechanical shock: AEC-Q200-REV D-Test 13, MIL-STD-202 Method 213, Wave Form Peak value is 100 g’s. 6 ms Vibration: AEC-Q200-REV D-Test 14, MIL-STD-202 Method 204, 5 g’s for 20 min., 12 cycles each of 3 orientations, Test from 10-2000 Hz Resistance to soldering heat: AEC-Q200-REV D-Test 15, MIL-STD-202 Method 210, Condition B : Immerse the specimens in and eutectic solder at +260 ± 5 °C for 10 ± 1 s Thermal shock: AEC-Q200-REV D-Test 16, MIL-STD-202 Method 107, -55 °C/+155 °C. Note: Number of cycles required 300, Maximum transfer time 20 seconds, Dwell time 15 minutes. Air-Air. ESD: AEC-Q200-REV D-Test 17, AEC-Q200-002 or ISO/DIS 10605, verify the voltage setting at 500 V Solderability: AEC-Q200-REV D-Test 18, J-STD-002, Method B, aging 4 hours at 155 °C dry heat Lead-free solder bath at 235 ± 3 °C, Dipping time: 3 ± 0.5 seconds, > 95% area covered with tin Flammability: AEC-Q200-REV D-Test 20, UL-94, V-0 or V-1 are acceptable. Without plastic part. Use final goods burn with methane twice, each 10 s Board flex (bending): AEC-Q200-REV D-Test 21, AEC-Q200-005, The duration of the applied forces shall be 60 (+ 5) Sec, 2 mm deflection Terminal strength (SMD): AEC-Q200-REV D-Test 22, AEC-Q200-006, Force of 1.8 kg for 60 seconds Rated power in % Temperature derating curve Temperature (°C) Rated current & voltage The rated Current and Voltage are calculated by the following formula: I: Rated current (A) V: Rated voltage (V) P: Rated power (W) R: Resistance value (Ω) www.eaton.com/electronics 5 CHSA SMD current sensing resistor-metal shunt  Technical Data ELX1223 Effective August 2022 tp Tp TL Tsmax Tsmin tL ts Soldering Preheat Profile feature Preheat and soak Lead (Pb) free solder • Temperature min. (Tsmin) 150 °C • Temperature max. (Tsmax) 200 °C • Time (Tsmin to Tsmax) (ts) 60-150 seconds Average ramp-up rate (Tsmax to Tp) Liquidous temperature (Tl) Time (tL) maintained above TL 3 °C/ second max. Peak package body temperature (TP)* 260 °C Time (tp) within +5 °C/- 0 °C 10 seconds Ramp-down rate (Tp to TL) 6 °C/ second max. Time 25 °C to peak temperature 8 minutes max. 217 °C 60-120 seconds Manual solder +350 °C ±10 °C , 3 +1/-0 seconds 1 time (by soldering iron), generally manual, hand soldering is not recommended Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2022 Eaton All Rights Reserved Printed in USA Publication No. ELX1223 BU-ELX22083 August 2022 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
CHSA3920R0005F 价格&库存
很抱歉,暂时无法提供与“CHSA3920R0005F”相匹配的价格&库存,您可以联系我们找货
