DEO200
DEO200
    EATON(伊顿)
    Cylindrical,Blade Terminal(Bolt)
    FUSE CRTRDGE 200A 415VAC CYLINDR
DEO200 数据手册
Technical Data 4117 Effective August 2015 Supersedes July 2015 BUSSMANN SERIES Bussmann series DEO Offset bolted tags fuse links Product description Eaton’s Bussmann series range of British Standard fuse links is specifically designed for the protection of general industrial applications e.g. power distribution, cable protection, motor protection. Standard features • Good peak let-through current limitation • 1:1:6 Selective coordination ratio between “minor” and “major” fuse • Suitable for motor protection if gM type selected • Power loss values well within the limits of IEC 60269 Technical Data 4117 Bussmann series DEO Offset bolted tags fuse links Effective August 2015 Catalogue symbol: DEO (Amps) • Technical data: • Rated voltage: 415 V a.c. • Rated current: 125 to 200 A • Breaking capacity: 80kA • Class of operation: gG and gM Standards/approvals: • BS88 • IEC 60269 • Suitable for use in RoHS compliant applications Packaging: MOQ 5 • Table 1. Technical data Part number Rated voltage Rated current (Amps) DEO125 DEO160 DEO200 DEO200M315 415 V a.c. 415 V a.c. 415 V a.c. 415 V a.c. 125 160 200 200M315 Energy integrals I2t (A2S) Watts loss Prearcing Total at 415V W Weight 29,500 57,000 120,000 265,000 71,000 135,000 290,000 635,000 11 13 14 9 138g 138g 138g 145g Dimensions - mm $ % & + ' ) * ( Catalogue numbers DEO125-200 and DEO200M315 2 A 110 B 94 EATON www.eaton.com C 47 D 19 E 10 F 9 G 29.5 H 31 Bussmann series DEO Offset bolted tags fuse links Technical Data 4117 Effective August 2015 Time current curve - DEO125 to DEO200 125A 160A 200A EATON www.eaton.com 3 Technical Data 4117 Bussmann series DEO Offset bolted tags fuse links Effective August 2015 Time current curve - DEO200M315 Changes to the products, to the information contained in this document, and to prices are reserved; so are errors and omissions. Only order confirmations and technical documentation by Eaton is binding. Photos and pictures also do not warrant a specific layout or functionality. Their use in whatever form is subject to prior approval by Eaton. The same applies to Trademarks (especially Eaton, Moeller, and Cutler-Hammer). The Terms and Conditions of Eaton apply, as referenced on Eaton Internet pages and Eaton order confirmations. Eaton EMEA Headquarters Route de la Longeraie 7 1110 Morges, Switzerland Eaton.eu © 2015 Eaton All Rights Reserved Publication No. 4117 August 2015 Eaton is a registered trademark. All other trademarks are property of their respective owners.
DEO200 价格&库存
很抱歉,暂时无法提供与“DEO200”相匹配的价格&库存,您可以联系我们找货
DEO200
  • 1+297.63788
  • 25+285.73486
  • 100+273.83185
库存:47
