DILM12-01(24V50/60HZ)
    EATON(伊顿)
    EATON MOELLER - DILM12-01(24V50/60HZ) - Relay Contactor, DILM Series, 3PST-NO, 3P, 7 A, 6.5 kW, 690 ...
DILM12-01(24V50/60HZ) 数据手册
DATASHEET - DILM12-01(24V50/60HZ) Contactor, 3 pole, 380 V 400 V 5.5 kW, 1 NC, 24 V 50/60 Hz, AC operation, Screw terminals Delivery program Part no.  Catalog No.  Alternate Catalog No.    DILM12-01(24V50/60HZ) 276869 XTCE012B01T Product range     Contactors Application     Contactors for Motors Subrange     Contactors up to 170 A, 3 pole Utilization category     AC-1: Non-inductive or slightly inductive loads, resistance furnaces NAC-3: Normal AC induction motors: starting, switch off during running AC-4: Normal AC induction motors: starting, plugging, reversing, inching       Notes     Also suitable for motors with efficiency class IE3. IE3-ready devices are identified by the logo on their packaging. Connection technique     Screw terminals Number of poles     3 pole Rated operational current             Notes     At maximum permissible ambient temperature (open.) 380 V 400 V Ie A 12                   Ith =Ie A 22 Ith A 18       open Ith A 50 enclosed Ith A 45       AC-3 AC-1 Conventional free air thermal current, 3 pole, 50 - 60 Hz Open at 40 °C enclosed Conventional free air thermal current, 1 pole Max. rating for three-phase motors, 50 - 60 Hz AC-3       220 V 230 V P kW 3.5 380 V 400 V P kW 5.5 660 V 690 V P kW 6.5 AC-4       220 V 230 V P kW 2 380 V 400 V P kW 3 660 V 690 V P kW 4.4           1 NC Contact sequence     Instructions     Contacts to EN 50 012. with mirror contact. Can be combined with auxiliary contact     DILA-XHI(V).. Actuating voltage     24 V 50/60 Hz Voltage AC/DC     AC operation Connection to SmartWire-DT     no 07/10/2020 Eaton 276869 ED2020 V70.0 EN Contacts N/C = Normally closed 1 / 14 Technical data General Standards     IEC/EN 60947, VDE 0660, UL, CSA Lifespan, mechanical       Operations x 10     AC operated Operating frequency, mechanical AC operated 6 10   Operations/h   9000 Climatic proofing     Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60068-2-30 Ambient temperature       Open   °C -25 - +60 Enclosed   °C - 25 - 40 Storage - 40 - 80   °C Mounting position     Mechanical shock resistance (IEC/EN 60068-2-27)                   Half-sinusoidal shock, 10 ms Main contacts N/O contact   g 10 Auxiliary contacts       N/O contact   g 7 N/C contact   g 5                   Mechanical shock resistance (IEC/EN 60068-2-27) when tabletop-mounted Half-sinusoidal shock, 10 ms Main contacts N/O contact   g 5.7 Auxiliary contacts       N/O contact   g 3.4 N/C contact   g 3.4 Degree of Protection     IP20 Protection against direct contact when actuated from front (EN 50274)     Finger and back-of-hand proof Altitude   m Max. 2000 Weight         kg 0.24           AC operated Screw connector terminals Terminal capacity main cable   Solid   2 mm 1 x (0.75 - 4) 2 x (0.75 - 2.5) Flexible with ferrule   mm 2 1 x (0.75 - 2.5) 2 x (0.75 - 2,5) Solid or stranded Stripping length   AWG single 18 - 10, double 18 - 14   mm 10 Terminal screw     M3.5 Tightening torque   Nm 1.2 Tool       Pozidriv screwdriver   Size 2 Standard screwdriver   mm 0.8 x 5.5 1x6       Terminal capacity control circuit cables Solid   mm Flexible with ferrule   mm 1 x (0.75 - 2.5) 2 x (0.75 - 2.5) Solid or stranded   AWG 18 - 14 07/10/2020 2 1 x (0.75 - 4) 2 x (0.75 - 2.5) 2 Eaton 276869 ED2020 V70.0 EN 2 / 14 Stripping length   mm 10 Terminal screw     M3.5 Tightening torque   Nm 1.2 Tool       Pozidriv screwdriver   Size 2 Standard screwdriver   mm 0.8 x 5.5 1x6 Rated impulse withstand voltage Uimp V AC 8000 Overvoltage category/pollution degree     III/3 Rated insulation voltage Ui V AC 690 Rated operational voltage Ue V AC 690 Safe isolation to EN 61140 Main conducting paths       between coil and contacts   V AC 400 between the contacts   V AC 400       Up to 690 V A 144 Breaking capacity       220 V 230 V   A 120 380 V 400 V   A 120 500 V   A 100 660 V 690 V   A 70 Short-circuit rating             Making capacity (p.f. to IEC/EN 60947)   Short-circuit protection maximum fuse Type “2” coordination       400 V gG/gL 500 V A 20 690 V gG/gL 690 V A 20 Type “1” coordination AC       400 V gG/gL 500 V A 35 690 V gG/gL 690 V A 25                   AC-1 Rated operational current Conventional free air thermal current, 3 pole, 50 - 60 Hz Open       at 40 °C Ith =Ie A 22 at 50 °C Ith =Ie A 21 at 55 °C Ith =Ie A 21 at 60 °C Ith =Ie A 20 Ith A 18 enclosed Conventional free air thermal current, 1 pole       open Ith A 50 enclosed Ith A 45                   Notes     At maximum permissible ambient temperature (open.) 220 V 230 V Ie A 12 240 V Ie A 12 380 V 400 V Ie A 12 415 V Ie A 12 440V Ie A 12 500 V Ie A 10 660 V 690 V Ie A 7 380 V 400 V Ie A 12 AC-3 Rated operational current Open, 3-pole: 50 – 60 Hz 07/10/2020 Eaton 276869 ED2020 V70.0 EN 3 / 14 Motor rating P kWh   220 V 230 V P kW 3.5 240V P kW 4 380 V 400 V P kW 5.5 415 V P kW 7 440 V P kW 7.5 500 V P kW 7 660 V 690 V P kW 6.5       AC-4 Open, 3-pole: 50 – 60 Hz       220 V 230 V Ie A 7 240 V Ie A 7 380 V 400 V Ie A 7 415 V Ie A 7 440 V Ie A 7 500 V Ie A 6 660 V 690 V Ie A 5 P kWh   220 V 230 V P kW 2 240 V P kW 2.2 380 V 400 V P kW 3 415 V P kW 3.4 440 V P kW 3.6 500 V P kW 3.5 660 V 690 V P kW 4.4             60 V Ie A 20 110 V Ie A 20 220 V Ie A 15 3 pole, at Ith (60°)   W 2.5 Current heat loss at Ie to AC-3/400 V   W 0.9 Impedance per pole   mΩ 2.5 Voltage tolerance       AC operated Pick-up x Uc 0.8 - 1.1 Drop-out voltage AC operated Drop-out x Uc 0.3 - 0.6 Motor rating DC Rated operational current, open DC-1 Current heat loss Magnet systems Power consumption of the coil in a cold state and 1.0 x US       50/60 Hz Pick-up VA 27 25 50/60 Hz Sealing VA 4.2 3.3 50/60 Hz Sealing W 1.4 1.2 Duty factor   % DF 100 Changeover time at 100 % US (recommended value)             Main contacts AC operated       Closing delay   ms 15 - 21 Opening delay   ms 9 - 18   ms 10   x 10 Emitted interference     07/10/2020 Eaton 276869 ED2020 V70.0 EN Arcing time Lifespan, mechanical; Coil 50/60 Hz Electromagnetic compatibility (EMC) 6 Mechanical lifespan at 50 Hz approx. 30% lower than under → Technical data general to EN 60947-1 4 / 14 Interference immunity     to EN 60947-1 Switching capacity             Three-phase       200 V 208 V   HP 3 230 V 240 V   HP 3 460 V 480 V   HP 10 575 V 600 V   HP 10 Single-phase       115 V 120 V   HP 1 230 V 240 V   HP 2 General use   A 20 Auxiliary contacts       Pilot Duty       AC operated     A600 DC operated     P300       AC   V 600 AC   A 10 DC   V 250 DC   A 1 Rating data for approved types Maximum motor rating General Use Short Circuit Current Rating   SCCR   Basic Rating       SCCR   kA 5 max. Fuse   A 45 max. CB   A 60 480 V High Fault       SCCR (fuse)   kA 30/100 max. Fuse   A 25 Class RK5/45 Class J 600 V High Fault       SCCR (fuse)   kA 30/100 max. Fuse   A 25 Class RK5/45 Class J Special Purpose Ratings             480V 60Hz 3phase, 277V 60Hz 1phase   A 20 600V 60Hz 3phase, 347V 60Hz 1phase   A 20 Electrical Discharge Lamps (Ballast) Incandescent Lamps (Tungsten)       480V 60Hz 3phase, 277V 60Hz 1phase   A 14 600V 60Hz 3phase, 347V 60Hz 1phase   A 14       480V 60Hz 3phase, 277V 60Hz 1phase   A 20 600V 60Hz 3phase, 347V 60Hz 1phase   A 20       LRA 480V 60Hz 3phase   A 60 FLA 480V 60Hz 3phase   A 10 LRA 600V 60Hz 3phase   A 60 FLA 600V 60Hz 3phase   A 10       LRA 480V 60Hz 3phase   A 72 FLA 480V 60Hz 3phase   A 12       Resistance Air Heating Refrigeration Control (CSA only) Definite Purpose Ratings (100,000 cycles acc. to UL 1995) Elevator Control 07/10/2020 Eaton 276869 ED2020 V70.0 EN 5 / 14 200V 60Hz 3phase   HP 2 200V 60Hz 3phase   A 7.8 240V 60Hz 3phase   HP 2 240V 60Hz 3phase   A 6.8 480V 60Hz 3phase   HP 7.5 480V 60Hz 3phase   A 11 600V 60Hz 3phase   HP 7.5 600V 60Hz 3phase   A 9       Rated operational current for specified heat dissipation In A 12 Heat dissipation per pole, current-dependent Pvid W 0.3 Equipment heat dissipation, current-dependent Pvid W 0 Static heat dissipation, non-current-dependent Pvs W 1.4 Heat dissipation capacity Pdiss W 0 Operating ambient temperature min.   °C -25 Operating ambient temperature max.   °C 60       10.2 Strength of materials and parts       10.2.2 Corrosion resistance     Meets the product standard's requirements. 10.2.3.1 Verification of thermal stability of enclosures     Meets the product standard's requirements. 10.2.3.2 Verification of resistance of insulating materials to normal heat     Meets the product standard's requirements. 10.2.3.3 Verification of resistance of insulating materials to abnormal heat and fire due to internal electric effects     Meets the product standard's requirements. 10.2.4 Resistance to ultra-violet (UV) radiation     Meets the product standard's requirements. 10.2.5 Lifting     Does not apply, since the entire switchgear needs to be evaluated. 10.2.6 Mechanical impact     Does not apply, since the entire switchgear needs to be evaluated. 10.2.7 Inscriptions Design verification as per IEC/EN 61439 Technical data for design verification IEC/EN 61439 design verification     Meets the product standard's requirements. 10.3 Degree of protection of ASSEMBLIES     Does not apply, since the entire switchgear needs to be evaluated. 10.4 Clearances and creepage distances     Meets the product standard's requirements. 10.5 Protection against electric shock     Does not apply, since the entire switchgear needs to be evaluated. 10.6 Incorporation of switching devices and components     Does not apply, since the entire switchgear needs to be evaluated. 10.7 Internal electrical circuits and connections     Is the panel builder's responsibility. 10.8 Connections for external conductors     Is the panel builder's responsibility. 10.9 Insulation properties       10.9.2 Power-frequency electric strength     Is the panel builder's responsibility. 10.9.3 Impulse withstand voltage     Is the panel builder's responsibility. 10.9.4 Testing of enclosures made of insulating material     Is the panel builder's responsibility. 10.10 Temperature rise     The panel builder is responsible for the temperature rise calculation. Eaton will provide heat dissipation data for the devices. 10.11 Short-circuit rating     Is the panel builder's responsibility. The specifications for the switchgear must be observed. 10.12 Electromagnetic compatibility     Is the panel builder's responsibility. The specifications for the switchgear must be observed. 10.13 Mechanical function     The device meets the requirements, provided the information in the instruction leaflet (IL) is observed. Technical data ETIM 7.0 Low-voltage industrial components (EG000017) / Power contactor, AC switching (EC000066) Electric engineering, automation, process control engineering / Low-voltage switch technology / Contactor (LV) / Power contactor, AC switching (ecl@ss10.0.1-27-37-10-03 [AAB718015]) Rated control supply voltage Us at AC 50HZ   V 24 - 24 Rated control supply voltage Us at AC 60HZ   V 24 - 24 Rated control supply voltage Us at DC   V 0-0 Voltage type for actuating     AC Rated operation current Ie at AC-1, 400 V   A 22 Rated operation current Ie at AC-3, 400 V   A 12 07/10/2020 Eaton 276869 ED2020 V70.0 EN 6 / 14 Rated operation power at AC-3, 400 V   kW 5.5 Rated operation current Ie at AC-4, 400 V   A 7 Rated operation power at AC-4, 400 V   kW 3 Rated operation power NEMA   kW 7.4 Modular version     No Number of auxiliary contacts as normally open contact     0 Number of auxiliary contacts as normally closed contact     1 Type of electrical connection of main circuit     Screw connection Number of normally closed contacts as main contact     0 Number of main contacts as normally open contact     3 Product Standards     IEC/EN 60947-4-1; UL 60947-4-1; CSA - C22.2 No. 60947-4-1-14; CE marking UL File No.     E29096 UL Category Control No.     NLDX CSA File No.     012528 CSA Class No.     2411-03, 3211-04 North America Certification     UL listed, CSA certified Specially designed for North America     No 07/10/2020 Eaton 276869 ED2020 V70.0 EN Approvals 7 / 14 Characteristics 1: Overload relay 2: Suppressor 3: Auxiliary contact modules 07/10/2020 Eaton 276869 ED2020 V70.0 EN 8 / 14 Squirrel-cage motor Operating characteristics Starting:from rest Stopping:after attaining full running speed Electrical characteristics Make: up to 6 x rated motor current Break: up to 1 x rated motor current Utilization category 100 % AC-3 Typical applications Compressors Lifts Mixers Pumps Escalators Agitators Fans Conveyor belts Centrifuges Hinged flaps Bucket-elevators Air conditioning system General drives in manufacturing and processing machines 07/10/2020 Eaton 276869 ED2020 V70.0 EN 9 / 14 Extreme switching duty Squirrel-cage motor Operating characteristics Inching, plugging, reversing Electrical characteristics Make: up to 6 x rated motor current Break: up to 6 x rated motor current Utilization category 100 % AC-4 Typical applications Printing presses Wire-drawing machines Centrifuges Special drives for manufacturing and processing machines 07/10/2020 Eaton 276869 ED2020 V70.0 EN 10 / 14 Switching conditions for non-motor consumers, 3 pole, 4 pole Operating characteristics Non inductive and slightly inductive loads Electrical characteristics Switch on: 1 x rated operational current Switch off: 1 x rated operational current Utilization category 100 % AC-1 Typical examples of application Electric heat 07/10/2020 Eaton 276869 ED2020 V70.0 EN 11 / 14 Dimensions Contactor with auxiliary contact module DILM32-XHI.../DILA-XHI... Contactor with auxiliary contact module DILA-XHIT… 07/10/2020 Eaton 276869 ED2020 V70.0 EN 12 / 14 Additional product information (links) IL03407013Z (AWA2100-2126) Contactors IL03407013Z (AWA2100-2126) Contactors ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL03407013Z2020_05.pdf Motor starters and "Special Purpose Ratings" for the North American market http://www.eaton.eu/ecm/groups/public/@pub/@europe/@electrical/documents/content/pct_3258146.pdf Switchgear of Power Factor Correction Systems http://www.moeller.net/binary/ver_techpapers/ver934en.pdf X-Start - Modern Switching Installations Efficiently Fitted and Wired Securely http://www.moeller.net/binary/ver_techpapers/ver938en.pdf Mirror Contacts for Highly-Reliable Information http://www.moeller.net/binary/ver_techpapers/ver944en.pdf Relating to Safety-Related Control Functions Effect of the Cabel Capacitance of Long Control http://www.moeller.net/binary/ver_techpapers/ver949en.pdf Cables on the Actuation of Contactors Switchgear for Luminaires 07/10/2020 http://www.moeller.net/binary/ver_techpapers/ver955en.pdf Eaton 276869 ED2020 V70.0 EN 13 / 14 http://www.moeller.net/binary/ver_techpapers/ver956en.pdf Standard Compliant and Functionally Safe Engineering Design with Mechanical Auxiliary Contacts The Interaction of Contactors with PLCs http://www.moeller.net/binary/ver_techpapers/ver957en.pdf Busbar Component Adapters for modern Industrial control panels http://www.moeller.net/binary/ver_techpapers/ver960en.pdf 07/10/2020 Eaton Industries GmbH http://www.eaton.eu © 07/2020 by Eaton Industries GmbH Eaton 276869 ED2020 V70.0 EN 14 / 14
DILM12-01(24V50/60HZ) 价格&库存
很抱歉,暂时无法提供与“DILM12-01(24V50/60HZ)”相匹配的价格&库存,您可以联系我们找货
