EASY719-AC-RC
EASY719-AC-RC
    EATON(伊顿)
EASY719-AC-RC 数据手册
EZ Intelligent Relay Product Focus Easy operation with maximum benefits The Eaton EZ intelligent relays provide basic functions that users could only implement previously with individually installed and wired devices. The EZD multi-function displays offer powerful visualization functions. Because of the extensive EZ product range, users can always find the best solution for their needs. Solutions can be as simple as a compact stand-alone intelligent relay with a few timing relays and a timer switch, or as complex as a large-scale network of EZ intelligent relays that are processing several hundred 2 I/O with local and remote expansion modules and graphic visualization. The need for user-friendly operation and programming is consistently met and forms the basis for the outstanding features found in the EZ family of products. Eaton’s EZ line really is easy to use. In association with EZD, it offers everything you need from a state-of-the-art automation system: flexible networking, local and remote expansion modules, visualization, scalability. Simplicity and user-friendly operation EZ and EZD products are known for their user-friendly operation and programming. Every rung or circuit connection is wired just like you remember: Contact – Contact – Contact – Coil – Done! The devices allow the “wiring” of 128 or 256 rungs or circuit connections. Series and parallel connections, which make up a major part of a control circuit, are easily created without previous programming knowledge. Ready-to-use function blocks are simply integrated in the wiring with coils, and contacts are provided for additional functions. Everything needed is built-in Depending on the device selected, EZ and EZD products provide users with timing relays, flash relays, counters, comparators, timer switches and other ready-to-use functions. The circuit diagram display of serial and parallel connections, unlike the display of AND and OR operations in a function block diagram, offers a more manageable display of the circuit. Every EZ and EZD intelligent relay features an integrated power flow display to ensure safe operation during commissioning and helps identify errors in the circuit diagram. For ease-of-use, energized rungs are highlighted, and non-energized rungs are dimmed. Security means safety The finished circuit diagram is stored internally and can also be saved externally on a memory module (EEPROM) for transport, security and backup. Multi-level password protection secures your circuit diagram from unauthorized viewing, editing, copying or deleting. 3 Technical overview: The right device for every application EZ500 intelligent relay EZ700 intelligent relay EZ800 intelligent relay EZD intelligent relay For controlling small applications with up to 12 input/output signals For controlling medium-sized applications with up to 40 input/output signals For controlling large-scale applications with up to 300 input/output signals For controlling large-scale applications with powerful visualization functions • 8 digital inputs • 12 digital inputs • 12 digital inputs • 12 digital inputs • 4 digital inputs or optionally • 6 digital relay outputs or optionally • 6 digital relay outputs or optionally • 4 digital relay outputs or optionally 4 transistor outputs 8 transistor outputs 8 transistor outputs • 128 rungs of 3 contacts and 1 coil each • 128 rungs of 3 contacts and 1 coil each • 256 rungs of 4 contacts and 1 coil each • 256 rungs of 4 contacts and 1 coil each • 16 operating and message texts • 16 operating and message texts • 32 operating and message texts • 24 KB mask memory on a fully graphical, backlit display (64 x 132 pixels) • 2 analog inputs (10-bit) optional (not with 230 VAC • 4 analog inputs (10-bit) optional (not with 230 VAC) • 4 analog inputs (10-bit) optional (not with 230 VAC) • 4 analog inputs (10-bit) optional (not with 230 V AC) • 2 high-speed inputs, 1 kHz (only DC devices) • 2 high-speed inputs, 1 kHz (only DC devices) • 4 high-speed inputs, 3/5 kHz (only DC devices) • 4 high-speed inputs, 3/5 kHz (only DC devices) • 1 digital expansion or network connection • 1 digital expansion or network connection • 1 digital expansion or network connection • Networkable via EZ-NET with up to 8 stations • Networkable via EZ-NET with up to 8 stations • 1 analog input (10 bit) 4 4 transistor outputs • 1 analog input (10 bit) EZ800 and EZD intelligent relays The EZ800 and EZD intelligent relays provide expanded capabilities. Users can network up to eight modules to easily support applications with over 300 I/O points. A control system can be designed by using a single local program or by using several programs on different distributed devices. Up to 1000 meters can be covered by the network. The intelligent relays can also be easily integrated with higherlevel automation networks such as PROFIBUS-DP, CANopen, DeviceNet and AS-Interface. EZD multi-function display The EZD supports all of the functions of the EZ800 and provides a full graphical display. It replaces the 7-segment display and indicates fault messages and operating steps graphically or in plain text. The function buttons on the EZD can be used to display and modify set points during operation. High-speed signal counting, frequency measurement and incremental encoder processing can all be seamlessly implemented with an EZ800 or an EZD. 5 Communication made easy. Simple and inexpensive networking. EZ-NET By integrating the EZ-NET network, which allows up to eight stations consisting of EZ800 or EZD devices, communication can be accomplished up to a distance of 1000 meters. It does not matter if the devices involved are running their own programs or are only used as remote input/output modules. 6 Furthermore, all stations can be expanded locally using the EZ-LINK interface. This enables EZ and EZD devices to be used seamlessly with applications involving 12 to more than 300 I/O points. The EZD also features the option of a simple point-topoint connection with an EZ800 or another EZD via a serial interface. Communication modules are available that allow EZ and EZD intelligent relays to be connected to AS-Interface, PROFIBUS-DP, CANopen and DeviceNet network systems. Communication modules provide automation interaction Communication connections to the production process give more flexibility and control. Commanding, signaling, monitoring and controlling on bit level A network connection is often worthwhile for simple operating steps often found in production processes. The Actuator-Sensor Interface, or AS-I, can provide 31 slaves simultaneously with 248 binary data items. For machine building applications, AS-I is the optimal network connection choice because input/output data can be transferred with a very fast reaction time of only 5 ms. As a result, it is possible to start up several motors simultaneously in a materials handling application. The EZ205-ASI communication module makes network connection easy. It can be connected via the EZ-LINK connection to all expandable EZ units. The two-wire AS-I cable is simply wired to the module– that's it! Data exchange is then organized by a higher level AS-I master. Transferring complex data More powerful fieldbus systems like the PROFIBUS-DP are used for complex automation tasks. These may involve transporting large data sets, such as several analog values, setpoints, counter states or timer parameters. With PROFIBUS-DP, up to 20 bytes of data per station can be transferred with each scan, and up to 126 nodes can be linked together over a distance of 1200 meters. The EZ204-DP gateway makes EZ intelligent relays more flexible and powerful. Entire parameter sets of EZ can be read or exchanged by a network connection. If recipes require different parameter sets to be transferred to EZ, clock times, counter states, setpoints and actual values can be controlled by a suitable master on this powerful network system. Connection to world standard fieldbus systems Similar to the EZ204-DP, the EZ221-CO network communication module for CANopen and the EZ222-DN for DeviceNet offer the same functions. 7 Stand alone EZ display with a high degree of protection EZ intelligent relay with EZD display provides IP65 protection The EZD-CP4-500 or EZD-CP4-800 supply and communication module can be combined with an EZD display and EZ intelligent relay providing users with the option of using a stand-alone display with IP65 protection for all EZ500/700 and EZ800 applications. 1 2 3 4 1 & 2 Plug & play display to be mounted up to five meters away from the intelligent relay. protected to IP65. The display includes a backlight that offers optimum legibility. 1, 3 & 4 EZD provides HMI-Control No software or drivers are needed for the connection EZD-CP4 is a genuine plug & play device. I/O wiring can be kept in the control panel and the EZD-CP4 simply snaps to the EZD display. When properly mounted, the display is Two EZ-CP4 modules are available: EZD-CP4-500 is used with all EZ500/700s and the EZD-CP4-800 is used with all EZ800 and EZD-CP8 devices. Plug & play technology allows users to connect an EZD display (EZD-80 or EZD-80-B) to an EZ intelligent relay via an EZD-CP4 supply and communication module. The EZD-CP4 module is factory shipped with five meters of serial connection cable that can be cut to any required length allowing the 8 When an EZD display is directly connected to an EZD-CP8 with optional input/output modules, the EZD becomes a compact HMI control device. It combines the functionality of an EZ800 with powerful visualization functions. The two modules are simply plugged together. More input/output Central and Decentralized Expansion Made Easy The EZ700, EZ800 and EZD accommodate I/O expansion locally or remotely using a variety of different configurations. 1 2 3 1 2 3 By connecting an EZ618-AC-RE, EZ618-DC-RE or EZ620-DC-TE expansion module, users can create an intelligent relay with 24 inputs and up to 16 outputs. These three expansion modules are simply fitted onto the EZ controller and directly connected using the EZ-LINK interface connector. Alternatively, a connection can be set up using the EZ200-EZ coupling module and a 2-wire cable allowing an expansion module to be remotely mounted up to 30 meters away. The EZ202-RE expansion module provides two additional relay outputs that can be connected directly using the EZ-LINK connector. 9 Supply voltage 24 V AC 100 - 240 V AC 12 V DC 24 V DC 5 VA 5 VA 2W 2W Heat dissipation EZ 512 -DC -RC X EZ 512 -DC -RC EZ 512 -DC -R EZ 251 2-D A-R CX Type EZ 512 -DA -RC Stand-alone operation EZ 512 -AC -R Application EZ 512 -AB -RC X 500 basic units EZ 512 -AB -RC Basic units EZ512-DA-RC EZ 512 -AC -RC X EZ512-DC-TCX EZ 512 -AC -RC EZ512-AC-RC Inputs, digital 8 8 8 8 8 8 8 8 8 8 Inputs, analog 0 - 10 V (optional) 2 2 - - - 2 2 2 2 2 4R 4R 4R 4R 4R 4R 4R 4R 4R 4R - - - - - - - - - - LCD display / keypad Yes / Yes -/- Yes / Yes Yes / Yes -/- Yes / Yes -/- Yes / Yes Yes / Yes -/- 7-day / year time switch Yes / Yes Yes / Yes -/- Yes / Yes Yes / Yes Yes / Yes Yes / Yes -/- Yes / Yes Yes / Yes 8A 8A 8A 8A 8A 8A 8A 8A 8A 8A Outputs, digital (R=relay,T=trans.) Outputs, analog 0 - 10 V Continuous current outputs [1] Short-circuit proof with power factor 1 Line protection B16, 600 A Short-circuit proof with power factor 0.7... 0.7 Line protection B16, 900 A Connection cables Degree of protection RFI suppression 0.2 - 4.0 mm2 (AWG 22-12), solid 0.2 - 2.5 mm2 (AWG 22-12), flexible IP 20 EN 55011, EN 55022 Class B, IEC 61000-6-1, 2, 3, 4 Ambient operating temperature - 25 °C ... + 55 °C Transport and storage temperature - 40 °C ... + 70 °C Certification, standards Mounting Dimensions (W x H x D) mm EN 50178, IEC/EN 60947, UL, CSA On top-hat rail to DIN 50022, 35 mm or screw mounting with EZB4-101-GF1 fixing brackets 71.5 x 90 x 58 mm [1] Relay = 8 A (10 A to UL) with resistive load, 3 A with inductive load/transistor outputs = 0.5 A / 24 V DC, max 4 outputs switchable in parallel. [2] With backlight in continuous operation - 10 °C ... 0 °C. [3] In stand-alone operation the EZD-...CP8-... CPU slices can also be mounted on a DIN 50022 top-hat rail, 35 mm or as screw mounting with EZB4-101-GF1 fixing brackets. 10 EZ719-AC-RCX EZ721-DC-TC 700 basic units 24 V AC 100 - 240 V AC 12 V DC 24 V CD 7 VA 10 VA 3.5 W 3.5 W EZ 721 -DC -TC X EZ 721 -DC -TC EZ 719 -DC -RC X EZ 719 -DC -RC EZ 719 -DA -RC X EZ 719 -DA -RC EZ 719 -AC -RC X EZ 719 -AC -RC EZ 719 -AB -RC X EZ 719 -AB -RC EZ 512 -DC -TC X EZ 512 -DC -TC Expandable (EZ2…EZ6…) 8 8 12 12 12 12 12 12 12 12 12 12 2 2 4 4 - - 4 4 4 4 4 4 4T 4T 6R 6R 6R 6R 6R 6R 6R 6R 6R 8T - - - - - - - - - - - - Yes / Yes -/- Yes / Yes -/- Yes / Yes -/- Yes / Yes -/- Yes / Yes -/- Yes / Yes -/- Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes 0.5A 0.5A 8A 8A 8A 8A 8A 8A 8A 8A 8A 0.5 A - - Line protection B16, 600 A - - - - Line protection B16, 900 A - - 0.2 - 4.0 mm2 (AWG 22-12), solid 0.2 - 2.5 mm2 (AWG 22-12), flexible IP 20 EN 55011, EN 55022 Class B, IEC 61000-6-1, 2, 3, 4 - 25 °C ... + 55 °C - 40 °C ... + 70 °C EN 50178, IEC/EN 60947, UL, CSA On top-hat rail to DIN 50022, 35 mm or screw mounting with EZB4-101-GF1 fixing brackets 107.5 x 90 x 58 mm 11 EZ819-AC-RC EZ822-DC-TC EZD-80-B EZD-CP4 Expandable (EZ2…, EZ6…), networkable (EZ-NET) EZ 822 -DC -TC X 12 12 12 12 12 12 - - 4 4 4 4 4 4 4 4 6R 6R 6R 6R 6R 6R 8T 8T 8T 8T - - - - 1 1 - - 1 1 LCD display / keypad Yes / Yes -/- Yes / Yes -/- Yes / Yes -/- Yes / Yes -/- Yes / Yes -/- 7-day / year time switch Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes Yes / Yes 8A 8A 8A 8A 8A 8A 0.5A 0.5A 0.5A 0.5A - - - - - - - - 24 V DC 10 VA 3.4 W Inputs, analog 0 - 10 V (optional) Outputs, digital (R=relay,T=trans.) Outputs, analog 0 - 10 V Continuous current outputs [1] Short-circuit proof with power factor 1 Line protection 816, 600 A Short-circuit proof with power factor 0.7... 0.7 Line protection 816, 900 A EZ 821 -DC -TC X 12 EZ 821 -DC -TC 12 100 - 240 V AC Heat dissipation Inputs, digital EZ 820 -DC -RC 12 Supply voltage EZ 819 -DC -RC 12 Type EZ 819 -AC -RC EZ 822 -DC -TC EZ 820 -DC -RC X Application EZ 819 -DC -RC X 800 basic units EZ 819 -AC -RC X Basic units 0.2 - 4.0 mm (AWG 22-12), solid 0.2 - 2.5 mm2 (AWG 22-12), flexible 2 Connection cables Degree of protection RFI suppression IP 20 EN 55011, EN 55022 Class B, IEC 61000-6-1, 2, 3, 4 Ambient operating temperature - 25 °C ... + 55 °C Transport and storage temperature - 40 °C ... + 70 °C Certification, standards Mounting Dimensions (W x H x D) mm EN 50178, IEC/EN 60947, UL, CSA On top-hat rail to DIN 50022, 35 mm or screw mounting with EZB4-101-GF1 fixing brackets 107.5 x 90 x 72 mm [1] Relay = 8 A (10 A to UL) with resistive load, 3 A with inductive load/transistor outputs = 0.5 A / 24 V DC, max 4 outputs switchable in parallel. [2] With backlight in continuous operation - 10 °C ... 0 °C. [3] In stand-alone operation the EZD-...CP8-... CPU slices can also be mounted on a DIN 50022 top-hat rail, 35 mm or as screw mounting with EZB4-101-GF1 fixing brackets. 12 EZD-CP8-NT EZD-R16 EZD-TA17 EZD EZ D-T A1 7 - - - - - - - 12 12 12 12 12 - - - - - - - - - 4 4 4 4 - - - - - - - - 4R 4R 4R 4R - - - - - - - - - - 1 - Yes / Yes Yes / Yes -/- -/- -/- -/- -/- -/- -/- -/- -/- -/- -/- -/- -/- -/- -/- Yes / Yes Yes / Yes Yes / Yes Yes / Yes -/- -/- -/- -/- -/- - - - - - - - - 8A 8A 8A 0.5 A - - - - - - - - Line protection B16, 600 A - - - - - - - - - - Line protection B16, 900 A - - - - 24 V DC EZ D-8 0 Supply via ...-CP… 3W 1.5 W EZ D-R 16 - EZ D-8 0-B EZ D-T 16 EZ D-R A1 7 EZ D-A C-R 16 EZ D-C P8NT EZ D-A C-C P8NT Inputs / outputs EZ D-A C-C P8ME Power supply / CPU EZ D-C P8ME EZ D-C P4800 EZ D-C P4500 Power supply/ Coupling Display 100 - 240 V AC Supply via …-CP8-.. 8VA 0.5 W 3W 0.2 - 4.0 mm (AWG 22-12), solid 0.2 - 2.5 mm2 (AWG 22-12), flexible 4R 1 0.5 A 2 IP 65 0.2 - 2.5 mm2 (AWG 22-12), flexible IP 20 EN 55011, EN 55022 Class B, IEC 61000-6-1, 2, 3, 4 Clearly legible at - 5 °C ...+ 50 °C [2]" - 25 °C ... + 55 °C - 40 °C ... + 70 °C EN 50178, IEC/EN 60947, UL, CSA Front mounting in 2 x n/a [3] (snap fitted on EZD-80...) 22.5 mm standard drill holes 86.5 x 86.5 x 20 mm 78 x 58 x 36.2 mm 107.5 x 90 x 29.5 mm n/a (snap fitted on EZD-…CP8-…) 88.1 x 90 x 25 mm 13 EZ202-RE EZ618-DC-RE EZ204-DP EZ205-ASI Communication - 24 V AC 24 V AC Heat dissipation 1W 10 VA 4W 1W 2W 1W 1W 1W Inputs, digital - 12 12 12 - - - - - Inputs, analog 0 - 10 V (optional) - - - - - - - - - 2R 6R 6R 8T - - - - - - - - - - - - - - LCD display / keypad -/- -/- -/- -/- -/- - - - - 7-day / year time switch -/- -/- -/- -/- -/- - - - - Continuous current outputs [1] 8A 8A 8A 0.5 A - - - - - EZ 222 -DN EASY620DC-TE 212313 Outputs. anllog 0 - 10 V EASY618DC-RE 232112 Outputs, digital (R=relay, T=trans.) EZ 205 -AS I 24 V AC EZ 620 -DC -TE - EZ 618 -DC -RE 24 V DC EASY222DN 233540 100-240 V AC EASY221CO 233539 EASY205ASI 221598 - EASY204DP 212316 EASY200EASY 212315 Supply voltage Type EASY618AC-RE 212314 EASY202RE 232186 EZ 221 -CO Digital inputs / outputs 107.5 x 90 x 58 mm EZ 204 -DP Application EZ 200 -EZ Expansion modules EZ 618 -AC -RE Expansion modules EZ 202 -RE Accessories Short-circuit proof with power factor 1 Line protection B16, 600 A - - - - - Short-circuit proof with power factor 0.7... Line protection B16, 900 A - - - - - 0.2 - 4.0 mm2 (AWG 22-12), solid 0.2 - 2.5 mm2 (AWG 22-12), flexible 0.2 - 4.0 mm2 (AWG 22-12), solid 0.2 - 2.5 mm2 (AWG 22-12), flexible IP 20 IP 20 EN 55011, EN 55022 Class B, IEC 61000-6-1, 2, 3, 4 EN 55011, EN 55022 Class B, IEC 61000-6-1, 2, 3, 4 Ambient operating temperature - 25 °C ... + 55 °C - 25 °C ... + 55 °C Transport and storage temperature - 40 °C ... + 70 °C - 40 °C ... + 70 °C EN 50178, IEC/EN 60947, UL, CSA EN 50178, IEC/EN 60947, UL, CSA On top-hat rail to DIN 50022, 35 mm or screw mounting with EZB4-101-GF1 fixing brackets On top-hat rail to DIN 50022, 35 mm or screw mounting with EZB4-101-GF1 fixing brackets Connection cables Degree of protection RFI suppression Certification, standards Mounting 14 EZ221-CO Accessories EZ222-DN EZ200-POW EZ400-POW Switched-mode power supply units Application EZ 200 -PO W EZ 400 -PO W EASY400POW 212319 EASY200POW 229424 Type Supply voltage 100 - 240 V AC Maximum range 85 - 264 V AC Output voltage 24 V DC (+/- 3%) Output current (rated value) 0.25 A 1.25 A Overcurrent limitation form 0.3 A 1.4 A Short-circuit proof (secondary) Yes Yes Overload proof Yes Yes Potential isolation (prim./sec.) Yes, SELV (to EN 600950, VDE 805) Additional output voltage 12 DC, 20 mA Others - 0.2 - 4.0 mm2 (AWG 22-12), solid 0.2 - 2.5 mm2 (AWG 22-12), flexible Connection cables Degree of protection RFI suppression IP 20 EN 55011, EN 55022 Class B, IEC 61000- 6-1, 2, 3, 4 Ambient operating temperature - 25 °C ... + 55 °C Transport and storage temperature - 40 °C ... + 70 °C Certification, standards Mounting EN 50178, IEC/EN 60947, UL, CSA On top-hat rail to DIN 50022, 35 mm or screw mounting with EZB4-101-GF1 fixing brackets 15 EZSoft the user-friendly circuit diagram editor EZSoft makes things particularly easy for users. The graphical editor shows the circuit diagram immediately in the display format required. Selection menus and drag & drop functions simplify circuit diagram creation. Simply select contacts and coils and connect with the mouse – that's it! In addition to the editing functions, the scaled software packages EZSoftBasic and EZSoft are available for straightforward circuit diagram input. All software includes user-friendly menus and Help screens. EZSoft offers the following display formats for viewing, editing and printing out your program: • IEC format, with contact and coil symbols using international standards • EZ circuit diagram, same as what is seen when programming from the EZ front panel • ANSI format, in compliance with American standards EZSoft supports users who are configuring, programming and defining parameters for EZ intelligent relays and creating visualization functions for EZD displays. When intelligent relays are connected to EZ-NET, all connected devices can be accessed and their programs loaded from a single intelligent relay. The integrated offline simulation tool allows users to test the functionality of the circuit diagram before commissioning, without the need for a connected device. The comment function for contacts, coils and function blocks helps provide a clear overview of the circuit diagram. A cover sheet with a customized company logo and different text fields, as well as the cross-reference list with comments, can turn printouts into the perfect documentation for applications. EZ is maintenance-free The finished program is stored in EZ's non-volatile memory until modified. Additional auxiliary power or batteries are not required. The intelligent relays are entirely maintenance-free. Circuit diagrams and parameters are saved in the event of a power failure. If a power failure occurs, the EZ controller stores switch positions and values such as operating hours, meters, counters and timing relays. When power is restored the values are restored. This retentive feature for the different function blocks and data is available on all EZ intelligent relay models. 16 17 Eaton’s electrical business is a global leader in electrical control, power distribution, and industrial automation products and services. Through advanced product development, world-class manufacturing methods, and global engineering services and support, Eaton’s electrical business provides customer-driven solutions under brand names such as Cutler-Hammer , Powerware, Durant , Heinemann , Holec and MEM , which globally serve the changing needs of the industrial, utility, light commercial, residential, and OEM markets. For more information, visit www.EatonElectrical.com. ® ® ® ® ® ® Eaton Corporation is a diversified industrial manufacturer with 2004 sales of $9.8 billion. Eaton is a global leader in electrical systems and components for power quality, distribution and control; fluid power systems and services for industrial, mobile and aircraft equipment; intelligent truck drivetrain systems for safety and fuel economy; and automotive engine air management systems, powertrain solutions and specialty controls for performance, fuel economy and safety. Eaton has 56,000 employees and sells products to customers in more than 125 countries. For more information, visit www.eaton.com. Eaton Electrical Inc. 1000 Cherrington Parkway Moon Township, PA 15108 United States tel: 1-800-809-2772 www.EatonElectrical.com © 2005 Eaton Corporation All Rights Reserved Printed in USA Form No. BR05013001E May 2005 2 2
EASY719-AC-RC 价格&库存
很抱歉,暂时无法提供与“EASY719-AC-RC”相匹配的价格&库存,您可以联系我们找货
