Technical Data ELX1191
Effective June 2022
ECSTA1V0805
Automotive grade SMT current sense transformer
Applications
Product features
AEC-Q200 qualified
EE5.0 SMT package
(8.38 mm x 8.0 mm x 5.5 mm)
Very low DC resistance
Wide selection of turns ratios
Sensed current – primary rated for 10 A
Frequency range: 50 kHz to 1 MHz
Moisture sensitivity level (MSL): 1
Motor drive
On-board chargers
DC/DC converters
Wireless chargers
Battery management systems (BMS)
EV charging
Feedback control
Overload sensing
Environmental compliance and general
specifications
Storage temperature (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb
HALOGEN
HF
FREE
ECSTA1V0805
Effective June 2022
Product specifications
Part number3
Turns ratio
sec :pri
Secondary
inductance (µH)
@ 100 kHz 0.1 V
minimum
DCR sec (Ω)
maximum
DCR pri (mΩ)
reference
Hi-pot pri to sec
@ 0.5 mA 3 seconds
50 Hz
Sensed
current1 (A)
maximum
ECSTA1V0805-1020-R
20:1
80
0.4
0.7
500 Vac
10
ECSTA1V0805-1030-R
30:1
180
0.87
0.7
500 Vac
10
ECSTA1V0805-1040-R
40:1
320
1.14
0.7
500 Vac
10
ECSTA1V0805-1050-R
50:1
500
1.85
0.7
500 Vac
10
ECSTA1V0805-1060-R
60:1
730
2.3
0.7
500 Vac
10
ECSTA1V0805-1070-R
70:1
980
4.75
0.7
500 Vac
10
ECSTA1V0805-1100-R
100:1
2000
5.5
0.7
500 Vac
10
ECSTA1V0805-1125-R
125:1
3000
11.5
0.7
500 Vac
10
1. Primary current of 10 A causes less than 40°C temperature rise @ +2 5°C ambient. Higher current causes a greater
temperature rise
2. Electrical specifications at +25 °C
3. Part Number Definition: ECSTA1V0805-1xxx-R
ECSTA1V0805 = Product code and size
1xxx= Turns ratio sec:pri 1=pri, xxx=sec; 1020= 20:1
-R suffix = RoHS compliant
Mechanical parameters, schematic, pad layout (mm)
Recommended PCB Layout
Schematic
Dimension
Value
A
8.38 maximum
B
8.00 maximum
C
5.50 maximum
D
1.85 ±0.3
E
0.6
F
0.25
G
0.7 ±0.2
Part marking: White dot, Pin 1 indicator
All soldering surfaces to be coplanar within 0.15 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Traces or vias underneath the inductor is not recommended
2
www.eaton.com/electronics
ECSTA1V0805
Effective June 2022
Temperature rise vs current
3
Effective June 2022
ECSTA1V0805
Packaging information (mm)
Supplied in tape and reel packaging, 13” diameter reel (EIA-481 compliant)
1000 parts per reel
4
Dimension
Value
W
16.0 ±0.3
P1
12.0 ±0.1
E1
1.75 ±0.1
F
7.50 ±0.05
P2
2.0 ±0.05
D0
1.5 +0.1/-0
D1
1.5 +0.1/-0
B0
8.45 ±0.1
A0
7.70 ±0.1
K0
5.50 ±0.1
P0
4.0 ±0.1
T
0.40 ±0.05
Dimension
Value
A
330 ±3.0
B
2.6 ±0.3
N
100 ±1.0
C
13+0.5/-0.2
D
21.5 ±0.5
W1
16.4+2.0/-0.0
W2
22.4 max
W3
na
ECSTA1V0805
Effective June 2022
Solder reflow profile
Table 1 - Standard SnPb solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“ECSTA1V0805-1100-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+25.627851+3.33100
- 国内价格 香港价格
- 1+28.411801+3.69270
- 10+24.3752010+3.16810
- 25+22.1833025+2.88320
- 50+21.4766050+2.79130
- 100+20.78180100+2.70110
- 250+20.25480250+2.63260
- 500+19.81160500+2.57500
- 1000+17.883201000+2.32430
- 2000+17.272302000+2.24490
