Bussmann®
BS88, IEC269
Industrial HRC Fuse Links
ESD
Offset Blade Tags 550V ac and 415V ac
Time-Current Characteristic Curves
Non Motor Rated
Motor Rated
16A
20A
25A
32A
40A
50A
63A
63M80
63M100
2A
4A
6A
10A
Dimensional Data
The ESD range of Fuse Links
comply with general purpose
gG characteristics and fit into
the SAFELOC Fuse Holders
and into the CAMLOC
Distribution Fuseboard
System.
Packaging - 20 per carton
2
Catalog'
Number
I t (Amp2 Seconds)
Amp
Ratings
Pre- Total at
Arcing 415V
Nom.
Watts
Loss
ESD2
2
1.3
4.6
0.9
ESD4
4
8
27
1.4
ESD6
6
29
100
1.8
ESD10
10
120
400
2.1
ESD16
16
120
470
1.8
ESD20
1070
1.8
ESD25
25
560
2300
2.0
ESD32
32
710
3000
2.9
ESD40
40
1500
6000
3.2
ESD50
50
2700
8700
3.9
5000
ESD63
13,300
4.6
63M80
12,700 40,000
3.4
ESD63M100 63M100
20,700 70,000
2.5
ESD63M80
63
Rated
Voltage
Dimensions (inches/mm)
A
B
D
E
F
N
2.65
68.0
.58
15.0
.05
1.2
.14
3.5
.54
13.8
550 ac
1.43
35.5
415 ac
0.69
17.5
0.84
21.0
This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with
design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or
limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information
contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
Bussmann Division
Cooper (U.K.) Ltd
Burton-on-the-Wolds
Leicestershire, LE12 5TH
United Kingdom
Tel: (44) (0)1509 88 27 37
Fax: (44) (0)1509 88 27 86
Head Office
St. Louis, MO, U.S.A. Tel: (314) 527-3877 Fax: (800) 544-2570 International Fax: (314) 527-1445
B i F
Bussmann Information Fax (00 1) 314 527 1450
ESD 09.96
Doc. No. 4101
很抱歉,暂时无法提供与“ESD63”相匹配的价格&库存,您可以联系我们找货
