Technical Data 4110
Effective December 2015
Supersedes July 2014
FP2
Low profile, high current power inductors
Applications
Product description
High current carrying capacity
Dual conductors allow for low inductance
and high current or high inductance and
lower current
Inductance range from 0.047uH to 0.480uH
Current range 9.0 to 42 Amps
7.2 x 6.7mm footprint surface mount package
in a 3.0 or 5.0mm heights
Ferrite core material
Halogen free, lead free, RoHS compliant
Servers
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs)
• Server and desktop
Central processing unit (CPU)
Graphics processing unit (GPU)
Application specific integrated circuit (ASIC)
High power density
Notebook regulators
Battery power systems
Graphics cards
Environmental data
Storage temperature range (component):
-40°C to +125°C
Operating temperature range: -40°C to +125°C
(Ambient plus self temperature rise)
Solder reflow temperature: J-STD-020D
compliant
HALOGEN
Pb HF
FREE
FP2
Technical Data 4110
Product specifications
OCL1
(μH) ±15%
lrms2
(amps)
lsat3
(amps)
DCR (Ω) typical
@ 20°C
Height
maximum
Volt-μsec4 (V-μs)
FP2-S047-R
0.047
39
42
0.00024
3
0.75
FP2-S068-R
0.068
39
32
0.00024
3
0.75
FP2-S082-R
0.082
39
26
0.00024
3
0.75
FP2-S100-R
0.100
39
22
0.00024
3
0.75
FP2-S120-R
0.120
39
18
0.00024
3
0.75
FP2-S200-R
0.200
37
19
0.00028
5
0.99
FP2-V050-R
0.050
37
70
0.00028
5
0.99
FP2-V100-R
0.100
37
40
0.00028
5
0.99
FP2-V120-R
0.120
37
33
0.00028
5
0.99
FP2-V150-R
0.150
37
25.5
0.00028
5
0.99
FP2-D047-R
0.047
37
42
0.00026
3
0.75
FP2-D068-R
0.068
37
32
0.00026
3
0.75
FP2-D082-R
0.082
37
26
0.00026
3
0.75
FP2-D100-R
0.100
37
22
0.00026
3
0.75
FP2-D120-R
0.120
37
18
0.00026
3
0.75
OCL1
(μH) ±15%
lrms2
(amps)
lsat3
(amps)
DCR (Ω) typical
@ 20°C
Height
maximum
Volt-μsec4 (V-μs)
FP2-D047-R
0.188
16
21
0.0013
3
1.5
FP2-D068-R
0.272
16
16
0.0013
3
1.5
FP2-D082-R
0.328
16
13
0.0013
3
1.5
FP2-D100-R
0.400
16
11
0.0013
3
1.5
FP2-D120-R
0.480
16
9
0.0013
3
1.5
Part number5
Single conductor
Double conductor
Series mode
Part number5
Double conductor
1. Open Circuit Inductance (OCL) Test parameters: 1.0MHz, 0.25Vrms, ).0Adc, +25°C
2. Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is necessary
for AC currents. PCB layout, trace thickness and width, airflow, and proximity of other heat generating
components will affect the temperature rise. It is recommended that the temperature of the part
not exceed 125°C under worst case operating conditions verified in the end application.
3. Isat : Peak current for approximately 30% rolloff @ +20°C.
2
www.eaton.com/elx
4. Applied Volt-Time product (V-μs) across the inductor. This value represents the applied V-μs at
500kHz necessary to generate a core loss equal to 10% of the total losses for 40°C temperature rise.
5. Part Number Definition: FP2-xyyy-R
FP2 = Product code and size
x = Version indicator, S = single conductor, V = single conductor, D = dual conductor
yyy = Inductance value in uH, R = decimal point
-R suffix = RoHS compliant
FP2
Technical Data 4110
Dimensions–mm
Single conductor
Dual conductor
Part marking: FPS, V or D (S= single conductor,
V= single conductor, D= dual conductor),
xxx (xxx= inductance value in uH, R= decimal point)
yww= date code
Tolerances are ±0.2 millimeters unless stated otherwise
All soldering surfaces to be coplanar within 0.15 millimeters
Do not route traces or vias underneath the inductor
Packaging information
Supplied in tape and reel packaging.
FP2-S,FP2-D: 1,700 parts per 13” diameter reel.
FP2-S200, FP2-V: 950 parts per 13” diameter reel.
4.0
min.
+0.1/-0.0
2.0
Ao=6.6mm
Bo=7.1mm
Ko=3.2mm
1
7.5
+/-0.3
Bo
2
(FP2-S,FP2-D)
Ko=5.2mm
(FP2-S200,FP2-V)
1.75
A
Ko
A
Ao
12.0
Direction of Feed
www.eaton.com/elx
3
FP2
Technical Data 4110
Inductance characteristics
Core loss
IRMS DERATING WITH CORE LOSS
50
60
Hz
Hz
0K
10
0K
0K
KH
z
80
Hz
70
1M
Hz
% of Losses from Irms (maximum)
92
94
95
96
97
98
99
10
4
www.eaton.com/elx
40
50
60
80
100
200
300
% of Applied Volt-μ-Seconds
400 500 600
800 1000
FP2
Technical Data 4110
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP2-V150-R”相匹配的价格&库存,您可以联系我们找货
