HVP-HH-R
HVP-HH-R
    EATON(伊顿)
    FUSE HOLDER 480V 30A QC
HVP-HH-R 数据手册
Technical Data 11045 Effective February 2020 HVP 1/4” x 1-1/4” High voltage panel mount fuse holder Agency information • UL Recognized: IZLT2, E14853 General specifications • Product features • Compact, front panel mount fuse holder ¼” x 1 ¼” (6.3 mm x 32 mm) fuses • High voltage rating and current rating, up to 480 V and 30 A for higher power assemblies • Bayonet-type knob as fuse carrier • Robust design provides vibration resistance • Tin plated brass terminals • Thermoset fuse holder body and knob • Threaded thermoplastic nut as standard • Optional accessories available for field replacement Temperature rating (RTI): • The mounting body for all devices has a temperature rating of +150 °C. • The knob for these devices is molded plastic with a temperature rating of +150 °C. • Plastic body meets UL 94HB • Terminal strength: 5 pounds • Torque: Mounting – 20 inch-pound • Salt spray (corrosion): Test condition B HVP 1/4” x 1-1/4” High voltage panel mount fuse holder  Technical Data 11045 Effective February 2020 Specifications Part number Description Voltage rating (V) Current rating (A) HVP-R Standard HVP fuse holder 480 30 HVP-W-R Drip proof fuse knob (IP53 rated) 480 30 HVP-HH-R 1/4” Quick connects 480 15 HVP-L-R 2250 V Stand-off barrier 480 30 HVP-LW-HH-R Drip proof knob, 2250 V stand-off, 1/4” quick connects 480 15 HVP-OO-R Snap-lock design 480 30 HVP-CC-R Extended panel mount 480 30 Ordering details Ordering number is the part number plus the packaging prefix. i.e. BK-HVP-R Packaging code prefix Description Blank 10 fuse holders with components bagged separately BK- 100 fuse holders with components bagged separately Additional accessories Ordering number Description BK-1A4287 100 unit package of plastic fastening nuts BK-1A4806-2 100 unit package of metal fastening nuts 9435-1/2 10 unit package of bayonet fuse knobs BK-9435-1/2 100 unit package of bayonet fuse knobs 9732 10 unit pakage of neoprene washers BK-9732 100 unit package of neoprene washers Dimensions- mm [inches] HVP-OO-R Mounting: HVP-OO-R 59.1 [2.33] with fuse installed 39.7 [1.56] max. 2.9 [0.115] 19.1 [0.75] max. Hole for panel mounting 20.6 [0.81] + 0.76 [0.003] + 0.076 [0.003] dia. hole in terminals 16.7 [0.66] 22.6 [0.89] + 0.127 [0.005] for panels 0.635 - 1.98 thick [0.025] - [0.078] panel 2 www.eaton.com/electronics HVP 1/4” x 1-1/4” High voltage panel mount fuse holder  Technical Data 11045 Effective February 2020  Dimensions- mm [inches] HVP-HH-R HVP-R, HVP-L-R, HVP-W-R 59.1 [2.33] max. with fuse installed 11.9 [.47] 67.1 [2.64] max. when fuse is inserted 56.4 [2.22] max. 60.3 [2.38] max. 1/2 ”- 24 threads 17.37 [0.684] 17.5 [.69] 17.5 [0.69] max. 19.1 [.75] max. 32.9 [1.30] 2.92 +- .08 [.115 +- .003] panel front HVP-CC-R HVP-LW-HH-R panel front 67.1 [2.64] 29.4 [1.16] max. 22.2 [0.88] when fuse is inserted 62.0 [2.44] max. 17.42 [0.686] 17.5 [0.69] max. 19.1 [0.75] max. 32.9 [1.30] body marking buss HVP 30A 480V Reference B/P: 9631-29 Mounting: HVP-R, HVP-L-R, HVP-W-R, HVPHH-R, HVP-LW-HH-R, HVP-CC-R Hole for panel mounting punched hole drilled hole 6.8 [0.27] 12.0 [0.47] locking key - 2.39 [.094] dia. thickness not to be greater than panel thickness 12.8 [0.51] #41 drill 12.7 drill [0.50] Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2020 Eaton All Rights Reserved Printed in USA Publication No. 11045 BU-MC20021 February 2020 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
HVP-HH-R 价格&库存
很抱歉,暂时无法提供与“HVP-HH-R”相匹配的价格&库存,您可以联系我们找货
HVP-HH-R
    • 5+76.06892
    库存:35
