Bussmann®
Telpower DC Power Protection Systems
TPSFH
Spare Fuseholders
Common Prefix TPSFHCW
M
inches
mm
70
Spare Fuseholders
• Durable construction using black thermoplastic with
UL 94V-0 flammability rating.
• Common mounting (.16 dia. hole) using #6 screws or bolts on
5-inch centers.
• Dovetailed interlocking between fuseholders simplifies installation and reduces needed hardware.
• Common footprint allows for any combination of
fuseholders to be mounted together.
• Built-in retaining clips secure fuses.
• TPSFH-CW fuseholder holds four TPC fuses, or two TPW
fuses, or two TPC fuses and one TPW fuse.
Catalog
Numbers
Capacity
TPSFH-CW
4-position
For use with TPC and / or TPWfuses
TPSFH-M
4-position
For use with TPM fuses
TPSFH-70
12-position
For use with Series 70 fuses
TPSFH-LC
1-position
For use with TPL-C series fuses
TPSFH-LB
1-position
For use with TPL-B series fuses
TPSFH-N60
1-position
For use with TPN (35-60A) fuses
TPSFH-N30
4-position
For use with TPN (1-30A) fuses
TPSFH-AS
6-position
For use with TPA & TPS fuses
TPSFH-T
10-position
For use with GMT fuses
5-28-03
LC
SB03090
LB
Form No. TPSFH
Page 1 of 2
Data Sheet: 5014
Bussmann®
TPSFH
Spare Fuseholders
N60
inches
mm
N30
5TPH
TPA and TPA-B Fuse Spare Fuseholder
Size: 2.98” wide x 1.03” high x .63” deep
• 5-position spare fuseholder for midget size fuses
(13/32” diameter).
• Constructed of grey thermoplastic.
• Adhesive tape on back for easy mounting on cabinet doors.
AS
T
The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this Data Sheet are by definition uncontrolled. This bulletin is intended to clearly
present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products
and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it
should be tested by the user in all possible applications.
5-28-03
SB03090
Form No. TPSFH
Page 2 of 2
Data Sheet: 5014
很抱歉,暂时无法提供与“5TPH”相匹配的价格&库存,您可以联系我们找货
