A1X1PK
A1X1PK
    EATON(伊顿)
    EATON CUTLER HAMMER - A1X1PK - AUXILIARY SWITCH, F-FRAMEC, CKT BREAKER
A1X1PK 数据手册
CA_Supplement.fm Page 1 Thursday, June 2, 2011 10:11 AM Engine Generator Circuit Breakers Engine Generator Circuit Breakers Molded Case Circuit Breakers Product Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Application Description. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Catalog Number Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Product Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Breaker Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Engine Generator Circuit Breakers CA01214001E—June 2011 www.eaton.com 2 2 2 2 3 4 6 9 1 CA0_.fm Page 2 Thursday, June 2, 2011 11:28 AM Engine Generator Circuit Breakers Molded Case Circuit Breakers Engine Generator Circuit Breakers Product Description Eaton’s engine generator molded case circuit breakers are designed specifically for application on diesel engine powered standby generators where high interrupting circuit breakers are not required. The JG through NG breakers are equipped with a special trip unit, that includes standard thermal (overload) protection and special low magnetic pickup range (FG includes a fixed thermalmagnetic pickup). The standard thermal trip unit provides overload protection for conductors per the National Electrical Code®. The low magnetic pickup range is approximately two to five times the continuous rating and provides closer low-level short-circuit protection when applied on generators that have very low short-circuit capacity. This combination allows the user to customize the breaker to the generator output. Standards and Certifications Technical Data and Specifications Engine generator molded case circuit breakers are designed to conform with the following standards: UL 489 Interrupting Capacity Ratings ● ● ● Underwriters Laboratories Standard UL 489, Molded Case Circuit Breakers and Circuit Breaker Enclosures File E7819 Canadian Standards Association Standard C22.2 No. 5, Service Entrance and Branch Circuit Breakers International Electrotechnical Commission Recommendations IEC 947-2, Circuit Breakers Volts AC (50/60 Hz) Interrupting Capacity (Symmetrical Amperes) 240 18,000 480 14,000 600 10,000 IEC 947-2 Interrupting Capacity Ratings Volts AC (50/60 Hz) Interrupting Capacity (Symmetrical Amperes) Icu/Ics 220, 240 18,000/ 9,000 380, 415 14,000/ 7,000 660, 690 18,000/ 9,000 14,000/ 7,000 10,000/5,000 Conformance with these standards satisfies most local and international codes, assuming user acceptability and simplified application. Application Description Engine generator circuit breakers are suitable for reverse feed application. 2 Engine Generator Circuit Breakers CA01214001E—June 2011 www.eaton.com CA0_.fm Page 3 Thursday, June 2, 2011 11:28 AM Engine Generator Circuit Breakers Molded Case Circuit Breakers Catalog Number Selection This information is presented only as an aid to understanding catalog numbers. It is not to be used to build catalog numbers for circuit breakers. ● FG breakers include both line and load side terminals ● ● JG, KG, LG and NG breakers with W catalog number suffix do not include any terminals JG, KG, LG and NG breakers without W catalog number suffix include both line and load terminals ● ● Contact Eaton for additional ratings and internal/external accessories Accessories shown for F-Frame have a quick ship availability Circuit Breakers FG, JG, KG, LG and NG FG 3 100 W A06 Frame FG  Number of Poles 3 = Three-pole Trip Amperes 015 020 025 030 035 040 045 050 060 070 080 090 100 125 150 175 200 225 JG 175 200 225 250 KG 300 350 400 LG 450 500 600 NG 700 800 900 1000 1200 Suffix W = Without terminals Blank = Terminals included Accessory  A06 = 1A–1B A13 = 2A–2B B06 = 1 Mk–1 Brk C05 = 1A–1B/Mk Brk S02 = 12–24 Vac S06 = 48–127 Vac S18 = 12–24 Vac S22 = 48–127 Vac N02 = 24 Vdc U14 = 110–127 Vdc Accessories shown are for common F-Frame only; other configurations are available. See catalog for other frame sizes. Engine Generator Circuit Breakers CA01214001E—June 2011 www.eaton.com 3 CA0_.fm Page 4 Thursday, June 2, 2011 11:28 AM Engine Generator Circuit Breakers Molded Case Circuit Breakers Product Selection The following table lists FG through NG engine generator breakers with the maximum generator kVA and kW rating. Engine generator breakers are applied at 115% of the generator full load current rating (FLA). The maximum kW rating is based on threephase generators at 80% power factor. Breakers shown below include line and load terminals. Thermal-Magnetic Engine Generator Breaker  Magnetic Pickup Range Maximum Generator Rating 60 Hz 240 Vac kVA  kW  480 Vac kVA  kW  600 Vac kVA  kW  Catalog Number Fixed 5 4 11 9 14 11 FG3015 Fixed 7 6 14 12 18 14 FG3020 Fixed 9 7 18 14 23 18 FG3025 Fixed 11 9 22 17 27 22 FG3030 Fixed 13 10 25 20 32 25 FG3035 Fixed 14 12 29 23 36 29 FG3040 Fixed 16 13 32 26 41 32 FG3045 Fixed 18 14 36 29 45 36 FG3050 Fixed 22 17 43 35 54 43 FG3060 Fixed 25 20 51 40 63 51 FG3070 Fixed 29 23 58 46 72 58 FG3080 Fixed 32 26 65 52 81 65 FG3090 Fixed 36 29 72 58 90 72 FG3100 Fixed 40 32 79 64 99 79 FG3110 Fixed 45 36 90 72 113 90 FG3125 Fixed 54 43 108 87 135 108 FG3150 Fixed 63 51 126 101 158 126 FG3175 Fixed 72 58 144 116 181 144 FG3200 Fixed 81 65 162 130 203 162 FG3225 350–700 63 51 126 101 158 126 JG3175 350–700 72 58 144 116 181 144 JG3200 350–700 81 65 162 130 203 162 JG3225 350–700 90 72 181 144 226 181 JG3250 500–1000 108 87 217 173 271 217 KG3300 500–1000 126 101 253 202 316 253 KG3350 1000–2000 144 116 289 231 361 289 KG3400 Notes  Breaker continuous current is based on 115% of the generator full load ampere rating.  Based on three-phase generators at 80% power factor.  FG, JG, KG include thermal-magnetic trip units; LG and NG include electronic trip units. The following catalog numbers have center tap studs for dual voltage applications: JG3070CT, JG3100CT, JG3125CT, KG3175CT, LG3300CTW. 4 Engine Generator Circuit Breakers CA01214001E—June 2011 www.eaton.com CA0_.fm Page 5 Thursday, June 2, 2011 11:28 AM Engine Generator Circuit Breakers Molded Case Circuit Breakers Electronic Engine Generator Breaker  Magnetic Pickup Range Maximum Generator Rating 60 Hz 240 Vac kVA  kW  480 Vac kVA  kW  600 Vac kVA  kW  Catalog Number 500–2500 162 130 325 260 406 325 LG3450  500–2500 181 144 361 289 451 361 LG3500  500–2500 217 173 433 347 542 433 LG3600  500–2500 253 202 505 404 632 505 NG3700  500–2500 289 231 578 462 722 578 NG3800  1250–5000 325 260 650 520 812 650 NG3900  1250–5000 361 289 722 578 903 722 NG31000  1250–5000 433 347 867 693 1083 867 NG31200  Notes Breaker continuous current is based on 115% of the generator full load ampere rating.  Based on three-phase generators at 80% power factor.  FG, JG, KG include thermal-magnetic trip units; LG and NG include electronic trip units.  Breaker includes line and load terminals.  The following catalog numbers have center tap studs for dual voltage applications: JG3070CT, JG3100CT, JG3125CT, KG3175CT, LG3300CTW. Engine Generator Circuit Breakers CA01214001E—June 2011 www.eaton.com 5 CA0_.fm Page 6 Thursday, June 2, 2011 11:28 AM Engine Generator Circuit Breakers Molded Case Circuit Breakers Accessories Selection Guide and Ordering Information Enclosures Type 1 General Purpose ● ● ● Type 12 Dustproof Surface Mounting Surface or flush mounting 15–1200 ampere range 600 Vac, 500 Vdc ● ● Type 1 enclosed breakers are designed for use in commercial buildings, apartment buildings and other areas where a general purpose enclosure is applicable. The breaker is front operable and is capable of being padlocked in either the ON or OFF position. Ratings through 1200 amperes are listed with Underwriters Laboratories as approved for service entrance application. Both surface and flush mounted enclosures are available. ● No knockouts or other openings 15–1200 ampere range 600 Vac, 500 Vdc The Type 12 enclosure is designed in line with specifications for special industry applications where unusually severe conditions involving oil, coolant, dust and other foreign materials exist in the operating atmosphere. The handle padlocks in the OFF position and the cover is interlocked with the handle mechanism to prevent opening the cover with the circuit breaker in the ON position. Ratings through 1200 amperes are listed by Underwriters Laboratories as suitable for service entrance application. Type 3R Rainproof Surface Mounting Interchangeable hubs (through 400 amperes) 15–1200 ampere range 600 Vac, 500 Vdc ● ● ● This general purpose outdoor service center employs a circuit breaker inside a weatherproof sheet steel breaker enclosure to serve as a main disconnect and protective device for feeder circuits. Ratings through 1200 amperes are listed by Underwriters Laboratories as suitable for service entrance application. Enclosure Selection Data Breaker Frame Amperes FG 15–225 JG 175–250 KG 300–400 LG 450–600 NG 700–1200 6 Enclosure Type Class A B C D E Approx. Weight Lbs (kg) Conduit Sizes, Inches Catalog Number Type 1 23.25 (590.6) 8.41 (213.6) 6.28 (159.5) 18.75 (476.3) 1.20 (30.5) 15 (7) 0.25, 0.50, 0.75, 1, 1.25, 1.50, 2, 2.50 SFDN225 Type 3R 25.66 (651.8) 8.84 (224.7) 9.31 (236.5) 24.28 (616.7) 1.70 (43.2) 19 (9) 0.25, 0.50, 0.75, 1, 1.25, 1.50, 2, 2.50 RFDN225 Type 12 25.66 (651.8) 8.84 (224.7) 9.31 (236.5) 24.28 (616.7) 1.70 (43.2) 18 (8) — JFDN225 Type 1 34.70 (881.4) 10.92 (277.4) 7.20 (182.9) 30.00 (762.0) 1.88 (47.8) 31 (14) 0.25, 0.50, 2, 2.50, 3 SJDN250 Type 3R 37.50 (952.5) 11.56 (293.6) 10.22 (259.6) 35.77 (908.6) 1.94 (49.3) 40 (18) 0.25, 0.50, 2, 2.50, 3 RJDN250 Type 12 37.53 (953.3) 11.56 (293.6) 10.22 (259.6) 35.77 (908.6) 1.94 (49.3) 37 (17) — JJDN250 Type 1 38.81 (985.8) 11.06 (280.9) 10.94 (277.9) 34.00 (863.6) 2.28 (57.9) 53 (24) 0.25, 0.50, 0.75, 1.50, 2, 2.50, 3, 3.50 SKDN400 Type 3R 41.69 (1058.9) 11.75 (298.5) 14.06 (357.1) 39.90 (1013.5) 1.97 (50.0) 60 (27) 0.25, 0.50, 0.75, 2.50, 3, 3.50 RKDN400 Type 12 41.69 (1058.9) 11.75 (298.5) 14.06 (357.1) 39.90 (1013.5) 1.97 (50.0) 53 (24) — JKDN400 Type 1 45.88 (1165.4) 14.31 (363.5) 12.38 (314.5) 46.56 (1182.6) 1.91 (48.5) 81 (37) 0.25, 0.50, 0.75, 3, 3.50, 4 SLDN600 Type 3R 48.31 (1227.1) 14.91 (378.7) 15.50 (393.7) 46.56 (1182.6) 1.92 (48.8) 84 (38) 0.25, 0.50, 0.75, 3, 3.50, 4 RLDN600 Type 12 48.31 (1227.1) 14.91 (378.7) 15.50 (393.7) 46.56 (1182.6) 1.92 (48.8) 81 (37) — JLDN600 Type 1 61.22 (1555.0) 21.44 (544.6) 15.41 (391.4) 61.84 (1570.7) 1.97 (50.0) 178 (81) — SNDN1200 Type 3R 63.59 (1615.2) 22.00 (558.8) 17.63 (447.8) 61.84 (1570.7) 1.97 (50.0) 175 (79) — RNDN1200 Type 12 63.59 (1615.2) 22.00 (558.8) 17.63 (447.8) 61.84 (1570.7) 1.97 (50.0) 170 (77) — JNDN1200 Engine Generator Circuit Breakers CA01214001E—June 2011 www.eaton.com CA0_.fm Page 7 Thursday, June 2, 2011 11:28 AM Engine Generator Circuit Breakers Molded Case Circuit Breakers Type 1 Surface Mounted Type 3R Rainproof E B E C Type 12, 12K Dustproof E C C ON A D A D D ON OFF OFF A B B Enclosures, continued Neutral Kits, Insulated and Groundable Max. Enclosure Rating (Amperes) Main Lug Number Size Cu/Al Ground Lug Size Cu/Al Catalog Number 100 (1) 14–1/0 (1) 14–1/0 INK100 250 (1) 6–350 kcmil (1) 4–300 kcmil INK250 400 (1) 4–750 kcmil or (2) 1/0–250 kcmil (1) 4–300 kcmil INK400 600 (2) 250–500 kcmil (1) 4–300 kcmil INK600 1200 (3) 1/0 to 750 kcmil or (4) 1/0 to 750 kcmil (1) 6–250 kcmil INK1200 Engine Generator Circuit Breakers CA01214001E—June 2011 www.eaton.com 7 CA0_.fm Page 8 Thursday, June 2, 2011 11:28 AM Engine Generator Circuit Breakers Molded Case Circuit Breakers Options and Accessories Internal Accessories Standard Terminals Auxiliary Switch  Breaker Frame Max. Amp Rating AWG Wire Range Metric Wire Range mm2 Catalog Number FG 100 14–1/0 2.5–50 FG 150 4–4/0 25–95 JG KG 250 4–350 kcmil 350 250–500 kcmil 25–185 120–240 3T100FB  Breaker Frame Factory Mounted 1A-1B Field Kit Catalog Number Factory Mounted 2A-2B Field Kit Catalog Number 3TA225FD  FG  A06 A1X1PK A13 A2X1RPK TA250KB JG A06 A1X2PK A13 A2X2PK TA350K KG A06 A1X3PK A13 A2X3PK LG A06 A1X4PK A13 A2X4PK NG A06 A1X5PK A13 A2X5PK  KG 400 3/0–250 kcmil (2) 95–120 3TA400K LG 600 250–500 kcmil (2) 120–240 3TA603LDK NG 700 1–500 kcmil (2) 50–300 TA700NB1 NG 1000 3/0–400 kcmil (3) 95–185 TA1000NB1 NG 1200 4/0–500 kcmil (4) 120–300 TA1200NB1 Breaker Frame Rating Factory Mounted Field Kit Catalog Number FG  12–24 Vdc S02 SNT1LP03K JG 12–24 Vdc S42 SNT2P04K KG 12–24 Vdc S42 SNT3P04K 3T100FB LG 12–24 Vdc S02 SNT4LP03K 12–24 Vdc S02 SNT5LP03K Optional Terminals Breaker Frame Max. Amp Rating AWG Wire Range Z Suffix (Line and Catalog Load Terminals) Number FD, FG 100 14–1/0 LZ04 225 4–4/0 LZ05 3TA225FD NG Notes  Package of three terminals.  Other accessories are available. Same as standard frame breakers.  Field installation on the FG Frame is not UL listed. JD, JG 250 4–350 kcmil N/A TA250KB KD, KG 225 (1) 3–350 kcmil Z01 TA300K 350 (1) 250–500 kcmil Z02 TA350K 400 (2) 3/0–250 kcmil Z04 3TA400K 400 (1) 4/0–600 kcmil Z12 3TA401LDK 450 (2) 4–4/0 Z22 TA450LD 500 (2) 3/0–350 Z01 TA602LD 600 (2) 400–500 kcmil Z04 3TA603LDK 700 (2) 1–500 kcmil Z01 TA700NB1 1000 (3) 3/0–400 kcmil Z02 TA1000NB1 1200 (4) 4/0–500 kcmil Z04 TA1200NB1 1200 (3) 500–750 kcmil Z03 TA1201NB1 LD, LG ND, NG 8 Shunt Trip  Engine Generator Circuit Breakers CA01214001E—June 2011 www.eaton.com CA0_.fm Page 9 Thursday, June 2, 2011 11:28 AM Engine Generator Circuit Breakers Molded Case Circuit Breakers Breaker Dimensions FG-Frame, Three-Pole Side View Front View On Off 6.00 (152.4) 3.38 (85.7) 4.13 (104.9) JG-Frame, Three-Pole Front View Front View Cutout 0.34 R (8.7 R) CL Handle 1.56 (39.7) 3.94 (100.0) 0.72 (18.2) 0.50 (12.7) Diameter 3 Megger Holes if Required Side View 0.78 (19.8) 2.92 (74.2) CL Breaker 0.19 R (4.8) R 4.13 (104.8) 0.88 (22.2) 3.33 (84.5) 10.00 (254.0) ON OFF 2.75 (69.9) 3.50 (88.9) 1.38 (34.9) 1.75 (44.5) 4.06 (103.2) Engine Generator Circuit Breakers CA01214001E—June 2011 www.eaton.com 9 CA0_.fm Page 10 Thursday, June 2, 2011 11:28 AM Engine Generator Circuit Breakers Molded Case Circuit Breakers KG-Frame, Two- and Three-Pole Front View Front Cover Cutout 0.34 R (8.7 R) C L Handle Side View 4.31 (109.6) 5.49 (139.4) 0.83 3.75 1.64 (21.0) (95.3) (41.7) 0.19 R (4.8 R) ON 1.31 (33.3) 2.63 (66.7) 2.39 (60.7) 4.78 (121.5) 1.25 (31.8) 10.13 (257.2) OFF LG-Frame, Two- and Three-Pole Front Cover Cutout Side View Front View 3.81 (96.8) 3.44 (87.3) 1.33 2.29 (33.7) (58.2) 3.28 (83.3) CL Breaker 1.72 (43.7) CL Handle 0.25 (6.4) R 10.75 (273.1) 3.64 (92.5) 8.21 (208.6) 0.19 R 1.50 (4.8) R (38.1) 7.28 (184.9) 8.25 (209.6) NG-Frame, Two- and Three-Pole Front View Front Cover Cutout Side View 3.44 (87.3) 1.72 (43.6) 0.25 R (6.4 R) CL Handle 1.91 (48.4) 3.68 (93.2) 1.50 (38.1) 10 CLHandle 0.19 R (4.8 R) 3.19 (80.9) 6.38 (161.9) 16.00 (406.4) ON/I OFF/O 5.50 (139.7) 8.25 (209.6) Engine Generator Circuit Breakers CA01214001E—June 2011 www.eaton.com CA0_.fm Page 11 Thursday, June 2, 2011 11:28 AM Engine Generator Circuit Breakers Molded Case Circuit Breakers Engine Generator Circuit Breakers CA01214001E—June 2011 www.eaton.com 11 CA_SupplementBack.fm Page 24 Thursday, June 2, 2011 11:27 AM Eaton’s Electrical Sector is a global leader in power distribution, power quality, control and automation, and monitoring products. When combined with Eaton’s full-scale engineering services, these products provide customerdriven PowerChain™ solutions to serve the power system needs of the data center, industrial, institutional, public sector, utility, commercial, residential, IT, mission critical, alternative energy and OEM markets worldwide. PowerChain solutions help enterprises achieve sustainable and competitive advantages through proactive management of the power system as a strategic, integrated asset throughout its life cycle, resulting in enhanced safety, greater reliability and energy efficiency. For more information, visit www.eaton.com/electrical. Eaton Corporation Electrical Sector 1111 Superior Ave. Cleveland, OH 44114 United States 877-ETN-CARE (877-386-2273) Eaton.com ©2011 Eaton Corporation All Rights Reserved Printed in USA Publication No. CA01214001E / Z10660 June 2011 Eaton is a registered trademark of Eaton Corporation. All other trademarks are property of their respective owners.
A1X1PK 价格&库存
很抱歉,暂时无法提供与“A1X1PK”相匹配的价格&库存,您可以联系我们找货
