Technical Data 10985
Effective November 2019
ACE1V3225
Automotive grade common-mode chip inductor
Applications
Product features
AEC-Q200 qualified
1210 (3225 metric) package
Impedance range from 500 ohms to 15000
ohms
Inductance range from 11 uH to 200 uH
Moisture sensitivity level (MSL): 1
Controller area network (CAN)
Ethernet architectures
Automotive signal line filter
Advanced driver assistance systems (ADAS)
Infotainment, safety cameras, sensors,
xEV, Powertrain
Engine control unit (ECU)
Electric power steering system (EPS)
Battery management systems (BMS)
Environmental data
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
ACE1V3225
Product specifications
Common-mode
impedance Z (Ω) at
10 MHz
Part number
Common-mode
inductance (μH) at
100 kHz
DCR (Ω)
@ +25 °
maximum
Idc (mA)
maximum
Rated voltage
(Vdc) typical
Insulation
resistance
(MΩ) minimum
ACE1V3225-110-R
300 minimum
500 typical
11+50%/-30%
0.40
300
80
10
ACE1V3225-220-R
500 minimum
1000 typical
22+50%/-30%
0.50
250
80
10
ACE1V3225-510-R
1000 minimum
2600 typical
51+50%/-30%
0.70
200
80
10
ACE1V3225-101-R
2200 minimum
5100 typical
100+50%/-30%
1.50
150
80
10
ACE1V3225-201-R
NA
200+30%/-20%
4.80
70
80
10
1. Part Number Definition: ACE1V3225-xxn-R
ACE1V3225 = Product code and size
xx= inductance value in uH,
n= multiplication factor: 10^n (i.e. 110 = 11 * 10^0 = 11 uH)
-R suffix = RoHS compliant
Mechanical parameters, schematic, pad layout (mm)
Recommended pad layout
B
A
Epoxy
C
D
Terminations
Wires
E
E
F
F
Equivalent circuit
1
4
2
3
No polarity
Part Number
A
B
C
D
E
F
L
H
G1
G2
ACE1V3225-xxn-R
3.2±0.2
2.5±0.2
2.5 max
0.2±0.1
0.9 typ
08 typ
3.7 typ
2.8 typ
2.4 typ
1.2 typ
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Pad layout dimensions are reference only
Traces or vias underneath the inductor is not recommended
2
www.eaton.com/electronics
ACE1V3225
Packaging information (mm)
Supplied in tape and reel packaging, 1000 parts per 7” diameter reel
Ao
2.80±0.10
Bo
3.60±0.10
Ko
2.20±0.10
W
8.00±0.20
E
1.75±0.10
F
3.50±0.05
Po
4.0±0.05
P1
4.0±0.10
Do
1.0±0.1
3
ACE1V3225
Performance curves
ACE1V3225-220-R
Impedance (Ω)
Impedance (Ω)
ACE1V3225-110-R
Frequency (MHz)
Frequency (MHz)
ACE1V3225-101-R
Impedance (Ω)
Impedance (Ω)
ACE1V3225-510-R
Frequency (MHz)
Frequency (MHz)
Common mode measurement method:
Impedance (Ω)
ACE1V3225-201-R
Differential mode measurement method:
Frequency (MHz)
4
ACE1V3225
Solder reflow profile
Table 1 - Standard SnPb solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“ACE1V3225-101-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.39360
- 10+6.23160
- 30+6.13440
