Technical Data ELX1121
Effective February 2023
Supersedes December 2021
AHC
High voltage 1/4” x 1-1/4” fast-acting ceramic tube fuse
Applications
High voltage ceramic tube fuse
Compact 3AB footprint:
¼” x 1 ¼” (6.3 x 32 mm)
Fast-acting performance
600 V rating
Cartridge and axial lead versions available
Very high interrupting ratings to help safely
protect against dangerous high fault currents
Fuse accessories (cartridge version):
HVP Panel mount fuse holder (480V)
HVI In-line fuse holder (600V)
S-8000 Panel mount fuse block (600V)
1Axxxx (up to 600V) fuse clips
Agency information
cURus recognition file number:
E19180 Guide JDYX2 and JDYX8
Industrial control panels
Motor control - UL 508A panels
Uninterruptible power supplies (UPS)
Variable frequency drives
Energy storage and battery systems
High voltage power conversion
Environmental compliance
Product features
HALOGEN
Pb HF
FREE
Ordering part number
BK-AHC-V-5-R
Packaging prefix
Family name
Option code (V = leaded)
Ampere rating
RoHS compliance
Packaging prefix
Blank
5 pieces in tin case for AHC-XXX-R, 4 pieces in
tin case for AHC-V-XXX-R
BK11000 pieces in polybag for AHC-XXX-R
BK-
100 pieces in carton for AHC-XXX-R,
AHC-V-XXX-R or AHC-V2-XXX-R
TR500 pieces on reel for AHC-V-XXX-R
Option code
-V
Axial leads with 38.1 mm length – copper
tinned wire with nickel plated brass over caps
-V2
Axial leads with 50.8 mm length – copper
AHC
Electrical characteristics
Amp Rating
1.0 In
minimum
2.5 In
maximum
0.2 A - 10 A
4 hours
120 seconds
Product specifications
Part number
Current
rating
(A)
Voltage
rating
(Vac)
Voltage
rating
(Vdc)
Interrupting rating
@ rated voltage
(A) Vac
Interrupting rating
@ rated voltage
(A) Vdc
Typical resistance1
(mΩ)
Typical voltage
drop3
(mV)
AHC-200(-V)-R
0.2
600
600
10,000
10,000
4310
1060
AHC-250(-V)-R
0.25
600
600
10,000
10,000
2703
895
AHC-400(-V)-R
0.4
600
600
10,000
10,000
1436
730
AHC-500(-V)-R
0.5
600
600
10,000
10,000
1047.5
680
AHC-600(-V)-R
0.6
600
600
10,000
10,000
784.5
585
AHC-1(-V)-R
1
600
600
10,000
10,000
360
425
AHC-1-5(-V)-R
1.5
600
600
10,000
10,000
250
550
AHC-1-6(-V)-R
1.6
600
600
10,000
10,000
196
425
AHC-2(-V)-R
2.0
600
600
10,000
10,000
162
500
AHC-2-5(-V)-R
2.5
600
600
10,000
10,000
119
475
AHC-3(-V)-R
3.0
600
600
10,000
10,000
95
450
AHC-3-15(-V)-R
3.15
600
600
10,000
10,000
83
400
AHC-4(-V)-R
4.0
600
600
10,000
10,000
53.8
350
AHC-5(-V)-R
5.0
600
600
10,000
10,000
42.5
350
AHC-6(-V)-R
6.0
600
600
10,000
10,000
30.3
250
AHC-8(-V)-R
8.0
600
600
10,000
10,000
23
300
AHC-10(-V)-R
10
600
10,000
10,000
16.5
300
1. Typical resistance measured at
很抱歉,暂时无法提供与“AHC-1-6-R”相匹配的价格&库存,您可以联系我们找货
