Technical Data 2110
Effective February 2021
Supersedes August 2020
HTC
PCB Fuse accessories for 5 mm fuses
PCB Fuse blocks
HTC-15M
UL 4248 rating: 250 V, 20 A
IEC 60217-6 rating: 250 V, 6.3 A, 1.6 W
Self-certified voltage rating: 500 V, 20 A
Tin plated brass terminals
cURus: Guide IZLT2 & IZLT8, File # 14853
Cover available:
Dimensions- inches (mm)
1.047"
(26.6mm)
.354 "
(9.0mm)
HTC-140M
Cover
.571 "
(14.5mm)
.217 "
(5.5mm)
.531 "
Mounting Holes
(13.5mm)
.890 "
.866 "
(22.60mm)
(22.0mm)
_ .002" Dia. (Typ.)
.059 " +
.177 "
HTC-150M (Transparent)
Flammability rating: UL94-V2
_ . 05mm)
(1.50 +
(4.5mm)
HTC-140M (Beige/Natural)
Flammability rating: UL94-V0
IEC 60127-6 rating: 250 V, 6.3 A, 1.6 W
90
0.5 mm)
(1.5
0.0197 x 0.047
(0.5 x 1.2mm)
0.890
(22.6mm)
0.890
(22.6mm)
Mounting holes
0.039
(1.0mm)
0.138
(3.5mm)
0.453
(11.5mm)
HTC-78M
0.413
(10.5mm)
0.370
(9.4mm)
0.961
(24.4mm)
Cover available:
HTC-100M
.886"
.354"
(22.5mm)
.551"
Tin plated bronze terminals
(15.0mm)
.102" Dia. Hole
(2.6mm)
.051" Dia. Hole
(3.5mm)
HTC-60M
.591"
(9.0mm)
(1.3mm)
.138"
(3.5mm)
38.2±0.5
BK4-HTC-518M
27±0.3
Ø2
250 V, 15 A
Bakelite, UL 94V-0, black
Clip: copper alloy, nickel plated
Terminals: brass, nickel plated
Ø6.56
6.25±0.3
0.0
3.8±0.2
5
34.4±0.5
8.5±0.5
0.5
15±.5
7±0.3
0.3±0.05
22.2±0.3
9±0.2
6.5±0.2
4.3
10±0.3
A
22.2±0.3
27±0.3
8.5±0.5
40°
15.4±0.5
A
5
.0
±0
0.7
7±0.3
6.25±0.2
5
.0
±0
0.5
250 V, 15 A
56
10±0.3
Ø6.
BK4-HTC-528M
SECTION A-A :
HTC
Technical Data 2110
.319"
Tin plated bronze
Tape and fan fold packed
(12.7mm)
BUSS
HTC-200M
.50"
(8.1mm)
BUSS
.177"
(4.5mm)
BUSS
PCB Fuse clips
.157"
(3.99mm)
.929"
(23.6mm)
.61"
(15.5mm)
.031"
(.79mm)
.012"
.217"
(.3mm)
(5.5mm)
.50"
.50"
(12.7mm)
(12.7mm)
4.32mm
HTC-210M
2.54mm
Tin plated brass
2.29mm
8.73mm
2.54mm
6.26mm
3.91mm
6.22mm
1.46mm
2.85mm
2.54mm
PCB Fuse holders
HTC-45M
250 V, 10 A, 2.5 W
Bayonet cap/carrier
Operating temperature range: -30 °C to + 85 °C
1.303"
(33.1mm)
max*
.512 "
Mounting Holes
Not recommended for
new designs.
Recommended repalcement
is H15
(13.0mm)
FU
SE
.461 "
(11.7mm)
cURus: Guide IZLT2 & IZLT8 File # 14853
.394 "
Printed Circuit
Board
(10.0mm)
.051 _
_ .05mm )
( 1.30 +
Dia. (Typ.)
* Maximum dimension with fuse is installed
HTC-50M
250 V, 10 A, 2.5 W
Bayonet cap/carrier
.512 "
(13.0mm)
1.303"
(33.1mm)
max*
SE
FU
Mounting Holes
_ .002" Dia. (Typ.)
.051 " +
_ .05mm )
( 1.30 +
.461 "
(11.7mm)
Common HTC specifications
.394 "
Printed Circuit
Board
(10.0mm)
Solerability: In accordance with IEC 68-2-20
Molded materials: UL94 V-0
Packaging codes
Packaging code prefix
Description
Blank
10 pieces packed into a carton (HTC-15M and HTC-60M only))
BK-
100 pieces packed into a cardboard shelf package (HTC-15M and HTC-60M only)
BK1-
1000 pieces packed into a poly bag
BK4
4000 pieces packed into a carton (HTC-518M and HTC-528M only)
AP
1000 pieces per box in Ammo pack (HTC-200M only)
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2021 Eaton
All Rights Reserved
Printed in USA
Publication No. 2110
February 2021
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BK-HTC-100M”相匹配的价格&库存,您可以联系我们找货
