BK/C515-250-R
BK/C515-250-R
    EATON(伊顿)
    插件,D5.5xL15.2mm
    一次性保险丝(熔断) 250mA 250V
BK/C515-250-R 数据手册
Effective May 2017 Supersedes October 2009 Technical Data 2006 C515 5 mm x 15 mm Axial-leaded, time-delay, glass tube fuses Electrical Characteristics Amp Rating Opening Time 135% 60 minutes max. 125mA - 250mA 3 seconds min. 200% 120 seconds max. 100% 4 hours min. 470mA 30 minutes max. 350mA 600mA 90 seconds max. 2A 2 seconds max. 6A 500 milliseconds max. 135% 60 minutes max. 375mA - 7A 3 seconds min. 200% 120 seconds max. Rated Current Product features Axial-leaded, time-delay 5 x 15mm physical size Nickel-plated brass endcap construction Leads are tin coated Optional sleeve is flexible flouropolymer (UL Flammability rating VW-1). • UL Listed product meets standard UL 248-14 • • • • • Ordering • • Agency information • • UL Listed Card: C515 125mA-250mA and 375mA-3A (Guide JDYX, File E19180) • • UL Recognized Card: C515 350mA, and 3.5A-7A (Guide JDYX2, File E19180) Specify product code Insert packaging code prefix before part number. E.g., BK (or TR2)/C515-2-R With TR2 packaging code, lead wire length is 20.3mm Specify option code, if desired For insulation sleeve, insert “S” after part series. E.g., BK/C515S-2-R • CSA Certification Card: C515 125mA-250mA and 375mA-3A (Class 1422-01, 53787 Product Code C515-125-R C515-250-R C515-350-R C515-375-R C515-500-R C515-600-R C515-750-R C515-800-R C515-1-R C515-1.25-R C515-1.5-R C515-1.6-R C515-2-R C515-2.25-R C515-2.5-R C515-3-R C515-3.5-R C515-4-R C515-5-R C515-6-R C515-7-R Voltage Rating Vac 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 125 125 125 125 125 Specifications 600Vac 25 - Interrupting Rating (amps) 250Vac 35 35 35 35 35 35 35 35 35 100 100 100 100 100 100 100 - 125Vac 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 400 400 400 400 400 *DC Cold Resistance (Measured at
BK/C515-250-R 价格&库存
很抱歉,暂时无法提供与“BK/C515-250-R”相匹配的价格&库存,您可以联系我们找货
BK/C515-250-R
  • 25+22.86409
  • 100+17.24177
  • 1000+6.06969
  • 5000+5.45305
库存:200
BK/C515-250-R
